2004 Grand Caravan No Front Wipers - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Vehicle Forums > Dodge Caravan/Grand Caravan Talk
pabassman
  2004 Grand Caravan No Front Wipers - Posted: 02-17-2013, 11:27 AM
State: PA
Post #1
Hope you guys can help. My '04 Grand Caravan just started acting up. The front wipers just stopped working. They were working intermittently for a short while then stopped completely. I changed the wiper motor, multi function switch on the steering column and the fuse/relay. Still nothing. I thought it might be the ICM or FCM, but the only symptom is the wipers. From what I'm reading, ICB/FCM issues would affect multiple device. Everything else is working fine. It's just the wipers.
Any ideas?
Ratchet75
 Posted: 02-17-2013, 06:31 PM
State: CA
Post #2
" From what I'm reading, ICB/FCM issues would affect multiple device." True if either looses power but individual internal circuits can go bad as well. ICB???? Do you mean BCM or body control module?
One quick thing to try is disconnect the negative battery cable then unbolt the FCM from the front of the IPM (fuse box). Remove it and inspect the contacts for visible corrosion or damage. Clean with electrical contact cleaner. Now reseat the connection several times and install. This will clean the unseen corrosion that can degrade any electrical connection. The FCM/IPM connection has had a well known history for creating any number of electrical faults. In your case it is the conduit that gets PCI mux bus and park switch inputs from the BCM, and grounds switching signals from the FCM to the two wiper relay coils.
KBD627
 Posted: 04-19-2013, 05:36 PM
2004 GC Anniversary Blue
Post #3
How did you make out? I have an 04 GC and was having trouble for awhile with wipers/signals not always working when tilt wheel was down. I thought it was the multi-function switch. I took covers off to see how easy it was to change switch. After I unplugged wire harness I noticed one wire was broken right at plug. It must have been partially broken. Not alot of slack in wires. I went to junk yard and cut out a plug with lots of wire attached. I cut mine off and spliced in junkyard plug. I left more slack so wires aren't stressed. Works fine.
RickMN
 Posted: 04-21-2013, 07:57 AM
RickMN's Avatar
Post #4
Here's a description of how the system works and a wiring diagram
Chrysler Minivan Wiper System
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology. My blog now has over 1000 in-depth repair articles, TSB's, and wiring diagrams: Rick's Blog
1997 Grand Caravan Front and Rear Wipers Dead... need help! BurgessB Dodge Caravan/Grand Caravan Talk 2 03-09-2013 07:35 PM
Help 2004 Grand Caravan 3.8L No Crank tjraul Dodge Caravan/Grand Caravan Talk 3 09-08-2011 02:47 PM
2004 Dodge Grand Caravan 4u2c Dodge Caravan/Grand Caravan Talk 2 08-14-2007 09:13 PM
2004 Grand Caravan pulling left gpp17 Dodge Caravan/Grand Caravan Talk 4 10-31-2004 10:54 PM
Some Questions about a 2004 Grand Caravan Beau31795 Dodge Caravan/Grand Caravan Talk 0 08-31-2004 10:00 PM
