bbk header noise???? need help - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 21 Old 02-16-2013, 10:56 AM Thread Starter
Jrod101
ram r/t
I just installed my bbk headers and I hear a little ticking noise when I get on it??? What could it be??
Jrod101 is offline
post #2 of 21 Old 02-16-2013, 11:59 AM
1500ram12
1500ram12's Avatar
Quoted: 18 Post(s)
From what I've read the headers magnify the pinging noise from the engine
Sent from my DROID RAZR MAXX using Tapatalk
2015 Ram 2500 6.4L Hemi Tradesman, 275/70/18 Fierce Attitude MT, 18x9 ?, LED Interior Lights, 7" Premiun Instrument Cluster Upgrade, 2013 OEM Projectors, OEM Bumper w/fogs. Plastidip'd bumpers, Western In channel Vent Visors.
1500ram12 is offline
post #3 of 21 Old 02-16-2013, 12:25 PM Thread Starter
Jrod101
ram r/t
Thanks because I just checked all of the bolts and they are all tight so I didn't know what it was
Jrod101 is offline
post #4 of 21 Old 02-16-2013, 06:36 PM
05Ramhendrix
Ramistered User
05Ramhendrix's Avatar
Quoted: 15 Post(s)
What gaskets did you use with the install?
Scott
2005 QC HEMI * 2wd * PSB Bright Silver * AEM Brute Force Intake * Powerwire * Jetstream Scoop * Stant 14168 180* T-stat * Superchip Flashpaq 3865 w/ Trans Tuning * BBK Ceramic Shorty Headers * Magnaflow Y Pipe * Magnaflow Catback * Motive 4.56 Gears LSD * Rough Country 6" Lift *Moto Metal 951 20x10 *Nitto Terra Grapplers 305/55/20 * Alpine Audio
05Ramhendrix is offline
post #5 of 21 Old 02-16-2013, 07:10 PM Thread Starter
Jrod101
ram r/t
I was goin to us the OEM gaskets but I couldn't get them to work with the headers so I used the gaskets that came with them
Jrod101 is offline
post #6 of 21 Old 02-16-2013, 07:55 PM
05Ramhendrix
Ramistered User
Quoted: 15 Post(s)
I'm speaking from experience, I had nothing but trouble when I installed the gaskets that came with the headers. That single layer of composite material doesn't seal correctly IMO, (that's the ticking you hear now). Within 6-8 months my gaskets started to blow chunks, leaked and hardened to the point they fused themselves to the aluminum block. I since had to start over with OEM and things have been quiet and leak free ever since. Not sure why OEM's didn't work for you but IMO they are the answer to the fix. Just sharing my experience, hope yours works out better.
Scott
post #7 of 21 Old 02-16-2013, 08:04 PM Thread Starter
Jrod101
ram r/t
Ok I'll have to look into it....my OEM gaskets have a 45 degree heat shield riveted together with the gasket material...when I was goin to install them the metal shield was hitting the header..so maybe I'll try to take the shield off
Jrod101 is offline
post #8 of 21 Old 02-17-2013, 09:27 AM
BMRbrnSNRbrd
Try harder
BMRbrnSNRbrd's Avatar
I agree with 05RamHendrix, OEM header gaskets are the only way to go.
Mineral Gray 2010 Dodge Ram CC Hemi Sport
Exterior: Limo tint | Painted tips | Painted calipers | De-badged | Painted grill inserts | Gloss black b-pillars | Color matched antenna base |
VHT tinted puddle lights | Color matched tailgate handle | Shaved and two-toned grill | Painted Vararam lid w/ two-toned Ram badge |
Color matched Laramie 2500 flares | Shaved tailgate badge | Shortened and painted antenna
Lighting: Color matched headlights retrofitted with 5000k Morimoto projectors |
5000k HID fog lights tinted with Lamin-x | 6000k HID retrofitted reverse lights
Interior: Color matched interior plastics | 2 MTX 12" subs in a cheap box | REN MyGig 30gb headunit | Black microsuede wrapped headliner and sun visors | Black microsuede wrapped and shaved pillars | Black microsuede wrapped custom made door inserts | SEM black painted interior plastics
Suspension: McGaughy's 2/5 Economy drop | BrakeMotive cross-drilled and slotted rotors | All black Milano M724 22s | 305/40R22 Nitto 420s | AirLift Helper Bags
Performance: Superchips Vivid Paq w/ trans tuning | Vararam Air Grabber | Magnaflow 18" Muffler | Raceland USA E-Cutout |
Billet Technology Oil Catch Can | Clutch fan delete | 180 T-stat | Magnaflow Y-Pipe with relocated crossover pipe
BMRbrnSNRbrd is offline
post #9 of 21 Old 02-17-2013, 09:34 AM Thread Starter
Jrod101
ram r/t
Yea I should have just put the OEM one in but I figured out the problem it wasn't the headers...before I took my bullydog off I programmed it back to stock...and it most have had something to do with the motor because when I flashed my computer today to make sure everything was set back the noise went away
Jrod101 is offline
post #10 of 21 Old 02-17-2013, 02:04 PM
compressor man
compressor man's Avatar
It will be back with a vengence, if I were you I would get those shit gaskets out and OEM's in before you end up with more work scraping the head clean. I used the paper gaskets once too, no bueno.
FRI'D 2007 Bright Silver QC 4X4 HEMI SLT SPORT. In the 13's
compressor man is offline
post #11 of 21 Old 02-17-2013, 02:14 PM Thread Starter
Jrod101
ram r/t
I'll probably change them sometime this week when the weather gets a little warmer....
Jrod101 is offline
post #12 of 21 Old 02-17-2013, 07:28 PM Thread Starter
Jrod101
ram r/t
Ok so I just installed the OEM gaskets and it still does but only when I'm driving and my foot on 1/4 pedal
Jrod101 is offline
post #13 of 21 Old 02-17-2013, 07:57 PM
TNhemi12
Quoted: 1 Post(s)
I thought you were getting rid of your truck?
TNhemi12 is offline
post #14 of 21 Old 02-17-2013, 07:59 PM Thread Starter
Jrod101
ram r/t
I'm not really sure yet but I wanted to get my.exhaust leak stopped first
Jrod101 is offline
post #15 of 21 Old 02-17-2013, 08:02 PM
HEMI450HP
Moe's Performance
Quoted: 4 Post(s)
If all bolts are tight, it is more than likely just the standard hemi tick that is magnified with aftermarket headers. Many guys with aftermarket headers have reported the same results with both the JBA shorties and ARH longtubes as well.
2011 Ram 1500 RC/SB 5.7
11.99 @ 110.66 MPH N/A
11.09 @ 120.13 MPH Nitrous
Full Bolt-Ons, Modern Muscle Ported Heads, Moe's Performance XTP Cam, Hemifever Tuned, 4.10 Gears, Edge 3400 Stall Converter, Nitrous Outlet 85MM Plate Kit
HEMI450HP is offline
post #16 of 21 Old 02-17-2013, 08:22 PM Thread Starter
Jrod101
ram r/t
Ok that's nice to know I thought maybe the collector flange was leaking
Jrod101 is offline
post #17 of 21 Old 02-18-2013, 02:19 AM
O-town sport
09 Ram owner
O-town sport's Avatar
may be off topic but when did BBK release for the 4th gen hemi? i thought their ports had the "circle" shape compared to the eagles "D" shape? did i miss that release along time ago lol? If i recall a member on here bought them, and then sent em back because the port was wrong still.
[/SIGPIC]NAME: Chris
RIDE: 2009 Ram 1500 SLT Big Horn Crew Cab
Brilliant Black
5.7L HEMI
20% tint, 18"magnaflow muffler, Liquid Metal 20's, 8k HID's (heads & Fogs), Paint matched headlights, blacked out tails & 3rd brake light, "Dodge" door sill guards,DE-Badged, Pioneer door 6x9's, McGauphy's 2/4 deluxe drop kit. Painted rear "dodge" badge, painted antenna base. K&N Cold air Intake, superchips 3865 (91 performance tune) Silver mesh grille w/color matched surround, plasti-dip'd front lip, lamin-x on fogs, stubby antenna, Painted interior trim, magnaflow y-pipe, painted calipers, billet-tech catch can, 4.10's & DTT.
(coming soon:headers, hard tenneau)
Previous truck:
2002 Ram 1500 4wd
Atlantic blue sport
5.9L (136k miles)
O-town sport is offline
post #18 of 21 Old 02-18-2013, 03:18 AM Thread Starter
Jrod101
ram r/t
My ports are not circle they match my OEM gaskets
Jrod101 is offline
post #19 of 21 Old 02-18-2013, 10:04 AM
HEMI450HP
Moe's Performance
Quoted: 4 Post(s)
Check out the link below...they released the new correct headers on Jan. 31st.
http://www.dodgetalk.com/forums/showthread.php?t=367735
post #20 of 21 Old 02-18-2013, 11:47 AM
O-town sport
09 Ram owner
sweet thanks for the info i missed that thread. . . . well now there is two things on my next order. thanks again guys!
Brilliant Black
5.7L HEMI
Previous truck:
2002 Ram 1500 4wd
Atlantic blue sport
5.9L (136k miles)
    Engine noise Clacking Noise when cold Active 3G Dodge RAM - General Talk 5 02-01-2009 11:01 PM
    Weird noise when I hit bumps...sounds like brake rotor noise. -Ross- 3G Dodge RAM - General Talk 9 07-13-2007 09:09 AM
    weird noise after header install DAYTONA81 3G Dodge Ram Performance Talk 4 10-22-2006 09:16 PM
    Weird noise at WOT after header install phantom345 3G Dodge Ram Performance Talk 17 09-19-2006 07:58 AM
    What Is The Best Header under $700.00 rumbleT 3G Dodge Ram Performance Talk 1 06-09-2005 04:52 PM
