95 dakota wont start - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 02-04-2013, 02:18 AM Thread Starter
roysduster
Question 95 dakota wont start
I have a 2.5 manual that was running good. Then while driving the speedo started to jump around and then lost power. Started back up and ran good, then died again.
Have checked codes have none, but now when the engine is cranked over the injector pours fuel in, and i have no spark. Have checked coil and it checks out to be good, have check wires and seem to be good, voltages are good, have installed new speed sensor, still the same problem. Have checked for the red wires in loom coming from fuse box under hood, cut loom open from box up to fire wall and did not have any red splice, had a green and couple of black wires splices that looked good.
Got any ideas on this ?
roysduster is offline
post #2 of 5 Old 02-04-2013, 10:45 AM
dodgef25
Crazy4x4RT
dodgef25's Avatar
I don't know if the 4cly used crank or cam shaft sensors but that is 1 possibilty. I would start at the PCM and see if it is reciving proper power and ground inputs.
"No truck should ever be lowerd! NEVER"
dodgef25 is offline
post #3 of 5 Old 02-04-2013, 02:42 PM
Preacher
Have you checked your timing belt?
Mine displayed the same symptoms, pulled the top cover at the timing belt off and everything looked good, but the belt had lost the teeth around the crank shaft.
You can see if the belt is turning through the peek hole in the cover, if it is not moving when you are turning over the engine your belt is toast.
Good news is the 2.4 is not an inference motor so you did not do any damage to the valves.
Preacher is offline
post #4 of 5 Old 03-10-2013, 12:03 AM Thread Starter
roysduster
engine will not start
thanks for the suggestions found the problem it had lost the ground on back of block from the pcm, the wire had pulled out of the harness.
post #5 of 5 Old 05-14-2013, 08:32 AM
Zyerx
Is the 3.9L an interference motor?
1990 Dodge Dakota SE 3.9L Magnum
1981 Chevy C30 5.7L
2002 Audi TT Quattro 1.8T < For Sale >
Zyerx is offline
    98 dakota wont start dakota_mike 2G Dodge Dakota General Talk 0 04-14-2012 04:21 PM
    *Please help*truck wont start -91 dakota TBI v6 Mopar Guy Dodge Dakota 1st Gen (87 -96) Forum 4 01-27-2008 01:30 AM
    HElP! My husband borrowed my friends dakota and now it wont start!!!!! DMcCurley0006 Dodge Dakota 1st Gen (87 -96) Forum 11 04-13-2007 01:45 AM
    91 dakota wont start rumjy Dodge Dakota 1st Gen (87 -96) Forum 2 01-28-2007 06:43 PM
    88 dakota stalls wont start hot billy b Dodge Dakota 1st Gen (87 -96) Forum 2 01-05-2005 11:58 AM
