Getting out of Park - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Dakota 2nd Gen (97 - 04) Forums > 2G Dodge Dakota General Talk
mydodge04
  Getting out of Park - Posted: 01-23-2013, 05:26 PM
State: NV
Post #1
Hard to get out of park
must wiggle shifter arm several times before it comes out of park.
hear light noise as it comes out of park.
dakota2004 SLT,
4.7L
55,000
Thank you for your help.
MikeHTally
 Posted: 01-23-2013, 06:25 PM
MikeHTally's Avatar
Got 2 Hemis
City: Tallahassee, FL
Post #2
On a hill?
'03 1500 QCSB Hemi
Vent shades/15% tint
A.R.E. Tonneau/Bed Rug
Nerf step bars
Rear LED light bar/LED frt. turn signals
LED tails & 3d brake light/White Night backup lamps & LED interior lights
Halos/projector headlights KC HiLites Titanium Driving lights
Tailgate Easy Lift & EZ Down
E&G Classics mesh grill
WeatherTech Floor Liners
Overhead console with HomeLink
JVC KD-AR780 Receiver & CH-X1500 Changer
Jensen 6x9 3-way up frt., 5 1/4" 2-way rear
GenTex auto-dimming mirror & Towing mirrors
Fender liners & Ram splash guards
Silver Truck Club Member #140
S.N.A.T.C.H. Club Member 666-666
2 1/2" level kit
Jetstream Scoop/Power Wire
MagnaFlow Stainless Cat-back SI/DO
TrueFlow intake kit
Hellwig 7651 sway bar
Flex-a-lite Black Magic Extr. 180 Elect. Fan
Dick Cepek Chrome DC-1s/Bridgestone Revo2 285/70
mydodge04
 Posted: 01-23-2013, 06:55 PM
State: NV
Post #3
No hills not even a bump, parked on, flat as a pancake.
07MegaCabRam
 Posted: 01-23-2013, 07:33 PM
07MegaCabRam's Avatar
:: Mike ::
City: Chandler
State: AZ
Status: Online
Post #4
It's your brake switch at the pedal. Check the connections, if ok, you'll need a new switch. It will not allow the truck to be removed from brake unless it's activated.
IF it's cause you're on a hill. Before placing your truck in park, apply the parking brake. Then when you start the truck, put it in drive then remove the brake..
::2007 Dodge Ram Mega Cab 4x4 5.7L Hemi::
Vision V-Tec Raptor 17x9 Wheels, 35" Nitto Trail Grappler MTs, KC 5" Apollo Lights in Factory Fog Light Location. Flowmaster Original 40 Series Muffler,
Painted B Pillars, Kenwood Sound System. Defender-PRO Spray in Bedliner I sprayed myself, 15% Window Tint applied by myself,
Carli Progressive 3" coils and Bilstein 5100s on all 4 corners. Updated 08+ Steering and Carli Steering Stabilizer 7100. 1.5" blocks in the rear. Carli Adjustable Trackbar.
Jimmi Jammer Door locks installed in all 4 doors. Kenwood DNX5120 head unit with 2 Kenwood 10"s, Kenwood 5 channel amp and Kenwood Components in all 4 doors.
mydodge04
 Posted: 01-24-2013, 10:30 AM
State: NV
Post #5
I've disconnected the wires on the switch a few weeks ago, that allowed be to use the truck, but I've not had time to go into the city dealer for that switch.
To me, this soft noise (as it comes out of park) into R, N, D seems to be inside the column. ( I always use parking brake)
Thank you.
Josh_101
 Posted: 01-30-2013, 05:41 PM
City: Elizabeth City, NC
Post #6
Pull the gear selector boot out of the column and check the locking mechanism. There's a tab that is suppose to slide in out of the way when you turn the key. When it gets sticky from lack of lubrication, it won't let you take it out of park. Had this problem last year, put a tiny shot of silicone grease on it and never again had an issue yet.
2004 Dakota SLT Quad Cab 4x4 4.7 v8 Metallic Grey
Pioneer DEH-P4100UB / eD Nine.2 2ch amp / eD Nine.4 4ch amp / eD e9.65i 2-way components in front doors / Two eD e3.8 8" subs
Clutch fan delete
14" Magnaflow muffler
Bridgstone Dueler A/T Revo, stock 265/70/16 size
Soon to get: Westin Signature Series Chrome Nerf Bars
mydodge04
 Posted: 01-30-2013, 06:30 PM
State: NV
Post #7
Funny I was trying to get the plastic shroud off, so I could see the inside better.
( Shroud hanging up on left front steering wheel end, side of column, don't want to break it).
Shifter boot popped out, noticed that if I put light pressure on that small rectangular tab I could get it out of park.
Did you just lube that tab area? or do I still have to get the shroud off, so I can lube the top of the tab mechanism that I can't get to, without getting that shroud off.
Thank You Josh!!
Josh_101
 Posted: 01-30-2013, 07:02 PM
Post #8
If I remember right, that tab connects to a slider mechanism that moves it, it's right there in plain view when you look through the shifter hole. Put a shot of lube on the slider then it'll move freely.
Clutch fan delete
mydodge04
 Posted: 02-04-2013, 03:37 PM
State: NV
Post #9
Great!
I'm out of town till Wednesday.
I've got a can of Silicone Spray ( Sprayway # 945 if I recall ), I can put that on slide on Wed or Thur.
Will let you know.
Thanks
Park to D Park to R Delay + Thud Quadder 2G Dodge Dakota - Drivetrain Talk 5 03-23-2009 11:38 AM
Park to Drive Thud Park to Revere Thud Quadder 3G Dodge RAM - Drivetrain Talk 14 01-02-2009 02:18 AM
out-of-park alarm or wont go into park?? dbwalters 3G Dodge RAM - General Talk 0 08-27-2007 08:59 AM
engine cutting off when changing gears from drive to park or reverse to park songho79 3G Dodge RAM - Drivetrain Talk 7 11-01-2006 08:26 PM
Mopar's on the Park, Raceway Park in Shakopee, MN Snake Bitten West North Central 1 05-29-2003 04:36 PM
