Engine noise - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Vehicle Forums > Dodge Caravan/Grand Caravan Talk
js12278
  Engine noise - Posted: 01-21-2013, 02:58 PM
State: IL
Post #1
103,000 on my 2006 3.8 GC. Seems to be a groaning coming from the drive pulley area. I replaced the belt in Oct 2011. Other than this the vehicle runs fine. Do you think it is possible the belt is bad already? Vehicle does not get driven on a daily basis. Maybe 2-3x a week. ANy help, Thanks.
the_Big_dill
 Posted: 02-14-2013, 11:19 PM
City: Aurora
State: ON
Post #2
Does it happen more aggressively under load? A/C or in gear?
2002 Dodge Grand Caravan Sport 3.3L V6 @ 260,000 KM.
GoldDot
 Posted: 02-15-2013, 12:50 AM
State: SC
Post #3
Nearly all new drive belts these days are 150,000 mile/5 year items. So it is doubtful the belt is bad.
I would start by disconnecting the battery and taking the belt off, then spin each pulley by hand. Usually the culprit will stand out and if not I would then take a look at the tensioner.
If your not to confident in repairing cars just take it to a good mechanic.
Good luck!
dillonj
 Posted: 02-15-2013, 03:09 PM
State: OTHER
Post #4
Probably the alternator going bad. Mine did the same thing. I thought it was the power steering pump starving for fluid. Changed the reservoir and the hose for nothing.
dorian
 Posted: 02-25-2013, 05:00 PM
Post #5
Good day, might want to check the belt tensioner pully, can cause that type of noise when bad.
Engine noise Caravan05850 Dodge Caravan/Grand Caravan Talk 4 07-27-2009 11:33 AM
Engine noise Clacking Noise when cold Active 3G Dodge RAM - General Talk 5 02-01-2009 10:01 PM
Help with engine noise on 2.7 flying dutchman 2G Dodge Intrepid - General Talk 5 04-03-2006 10:07 AM
Engine noise in speakers while engine on?!?!?! ScottyHawaii Mobile Audio & Electronics Talk 5 12-11-2003 01:08 AM
