Thread Tools |
RPM Limiter
- Posted: 01-20-2013, 08:57 PM
Post #1
Ok tuning guru's, can someone please tell me exactly what happens when the engine smacks into it's rpm limiter? Fuel cut? Ignition cut? TB closed? Also any supporting information is greatly appreciated. Thanks,
PI_greg2003 RCSB SXT-Hemi - OEM SS/T rims/275/55-17 tires, AeroForce-w/wideband, Trans LP gage, SC3865/PSC1, High Idle mod, 6.1 dual coil ignition, 05 fuel pmp, pwr wire, K&N -77 CAI, Fastman TB, Snow Wtr/Meth, 20% U/D, eFan, TCI FastGate shifter, AutoMeter Shiftlite, Autometer Tach adapter, 180 thermostat, TMR, Sonnax, 2500HD OEM Trans Cooler, Crazy Spartan/112 lsa, 2800 stall Edge Converter, DTT 4:10, LT's, Magnaflow SI/DO, duals cats, Mcgaughys 3/4.5 spindle kit, Monroe gasomatics shocks, Caster/camber adjusters, Caltracs traction bars, Aeon springs for bump stops Frt/Rear, 04 Laramie leather SLT 10 way seat and SLT leather steering wheel, CD/radio, stand alone OEM foglights, billet grille inserts, painted cowl (shaved) and upper bumper cover, Shaved tailgate w/EZdown, Shaved Antenna, Amplified hidden antenna, sliding rear window, welded steel Roll Pan, Hidden hitch, Sport mirrors, Painted Front bumper, Fiberglass tonneau cover, OEM bed liner, OEM SRT-10 gage pillar, billet gas door, de-badged, tint strip. |
| Sponsored Links | |
Advertisement |
Posted: 01-20-2013, 11:50 PM
Post #2
Bump, Ive always wanted to know this also.
03 QC Hemi 4x4, Motive 4.56's, APS 2800, Dynatech Lt's/Y,Comp 260, 125 shot, AT3030/AR30 Res, SC 3715, AEM CAI, AEM Wideband, Trac lok LSD, MSD 9mm's, Rancho RS9000, Undercover bed cover, LMC Rollpan, PML Diff cover |
Posted: 01-22-2013, 06:44 AM
Post #3
Pretty sure it's just a power cut like when you hit the governor. You can still rev and keep the speed but you won't go any faster. Not sure what exactly causes it though. Hmmmm now I'm curious as well lol
2008 2WD HEMI, 6" FabTech Lift, DIY CAI, BFG T/A KO's 275/65R20, Debadged Military Truck Club #152 |
Posted: 01-22-2013, 07:26 PM
Post #4
Most ECU's cut fuel (The LS1's do). If you think about it if they cut ignition you would have unburned fuel passing thru the motor not good for most emissions eqpt in the exhuast system.
04 Hemi powered Ram QC 1500 Sport Gone 09 Hemi powered Ram QC 2500 Sport Fuel Boost rims 17x9 +20MM Nitto Terra Grapplers 305/70/17 OEM 4.56 gears SuperChips Cortex 3950 (1449666)
Posted: 01-22-2013, 07:40 PM
Post #5
Thanks, I agree the fuel would be cut as there is no backfire or indication anything is rich. I'm hoping the TB continues to operate without closing. I feel it is independent, but was looking for confirmation, Thanks.
Posted: 01-22-2013, 09:40 PM
Post #6
The 2 time's i hit the limiter when i first got a tuner and playing with it, the truck just died for a sec. or 2 then came back to life. (1st gear burnout) There was no doubt it had cut fuel. The only way to know for sure if the TB is closing would be to log the correct pid's and run it up and hit the limiter. The log should show what is being effected.
2005 QC S/B Hemi Sport Performance:Vararam Intake/Dyanatech's w/Hi-Flow Cat's&Stage 8's/Borla/Daytona Exhaust/Black Magic E-Fan/Ported&Polished TB/Jet 180* Tsat/Predetor Tuner/BellTech swaybar/TA Performance Cover/Amsol Fluid's Apperance:SRT-10 Rear Spoiler/Hemi badges on scoop/Scoop Insert/Line of Fire/Easy-Down/Painted Caliber's/Billet strut cover's Interior:Triple Pillar Pod w/Phantom Gauges-Wideband Afr-Oil-Water/Custom led's/Billet-Ram head knob's-Door pin's-Power window panel's-Glove box dash plate& more/Daytona mat's |
Posted: 01-23-2013, 04:00 AM
Post #7
I hit the speed limiter (105) the firts time I raced it on the interstate against a Silverado SS. It just wouldn't go any faster; no bogging, no bucking, nothing. It stayed at that speed and would not go any higher. I attributed this to it being a fly-by-wire all the computer has to do is stop the TB from opeing any more.
![]() 2003 Ram 1500 QC Hemi Lonestar Edition "Big Red" SRT-10 suspension, brakes and interior parts, Circle D, Bilsteins, Superchips, AiRaid, Taylor shorties, McGaughy's shackles, Borla cat-back, Goodyear 305/50R20 GTII's, Extang Tonneau, Sonnax, Power wire, Daytona lip, tow mirrors, SRT hood. Mods to come: 06+ coil conversion, Comp 260 install, 05 PCM conversion. Sarcasm - it beats killing people. |
Posted: 01-23-2013, 04:26 AM
Post #8
Posted: 01-23-2013, 07:23 AM
Post #9
Greg, got to think'in after my post, i do know a tuner/friend. It's about time i gave him a call. He may have seen this in a customer's log and may be able to answer that question. He can be a little hard to get ahold of, but i'll see if i get an answer to that question for you. I'll post up if i have any luck.
Posted: 01-23-2013, 07:35 AM
Post #10
Posted: 01-23-2013, 02:02 PM
Post #11
Greg i got ahold of him and he believe's that all 3 are cut, but he's not 100% sure. I asked if he had any customer log's of the rev limiter being hit. He did so i got him to take a look at it. In the log he could see fuel and spark being reduced. The spark was not a lot and might have been from the rpm drop but it was reduced. As far as the TB % it was not a pid he used or use's so there was no data on that. Sorry Bro!!!, Guess were back to the experiment stage. lol
Posted: 01-23-2013, 05:26 PM
Post #12
Posted: 01-23-2013, 05:55 PM
Post #13
I'm hoping the FBW operates independent of the rpm/speed limiters so that cruise control can be retained and more of the original configuration is maintained. I want to maintain the basic functions of the OEM PCM only removing fuel, ignition and knock sensors. I'm planning to work first moving ignition to the MS unit. When that's up and running then move fuel control over. That will be when the FBW will let me know if it's going to play nice or not. The knock sensor I don't believe will be a problem. Very much appreciate everyone's input, this is doable, just need to figure out the simplest approach. Thanks,
Posted: 01-24-2013, 11:26 AM
Post #14
Keep us updated.
| Thread Tools | |
| rev limiter??? | 3184x4dakota | Dodge Dakota 1st Gen (87 -96) Forum | 6 | 03-24-2007 10:39 AM |
| rev limiter +500 rpm? | dline | 3G Dodge RAM - General Talk | 10 | 06-24-2005 08:41 AM |
| Rev-limiter? | jmfrealty | 3G Dodge Ram Performance Talk | 6 | 06-06-2005 09:33 PM |
| Rev Limiter | Joshs Hemi | 3G Dodge RAM - General Talk | 13 | 05-04-2005 06:52 AM |
| Rev limiter | Superman750 | 2G Dodge Ram Performance Talk | 32 | 03-10-2005 09:19 PM |
Privacy Statement | |
