Which sensor is bad? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 2nd Gen (94 – 01) Forums > 2G Dodge RAM - General Talk
wfmitch
  Which sensor is bad? - Posted: 01-20-2013, 11:17 AM
wfmitch's Avatar
City: Vanceboro
State: NC
View This User's Garage
View Member's FaceBook Profile
Post #1
Ok 97 ram 4x4 5.2 160k miles. Went out Friday morning to go to class and truck started and shut back off and would not crank back up. If I hold the gas to the floor it will crank and run but it will cut off as soon as I let my foot off the gas. Crank sensor, cam sensor? Or something else?
With God all things are possible!
Moparite
 Posted: 01-21-2013, 07:36 AM
Post #2
Could be a weak battery or dirty IAC or TPS. Any codes?
wfmitch
 Posted: 01-21-2013, 08:45 AM
wfmitch's Avatar
City: Vanceboro
State: NC
Post #3
No, no codes. Ran fine until Friday. Charged the battery up and seems to be fine
jdserna
 Posted: 01-21-2013, 11:46 AM
Diego Serna
City: Albuquerque
State: NM
Post #4
Sounds like the CPS. However, my brother's chero had the same issue, we changed it but it did not fix it. It turned out to be the ignition switch.
wfmitch
 Posted: 01-21-2013, 11:51 AM
wfmitch's Avatar
City: Vanceboro
State: NC
Post #5
Cps? Is that camshaft or crankshaft position sensor? Any way to test it?
jdserna
 Posted: 01-21-2013, 01:02 PM
Diego Serna
City: Albuquerque
State: NM
Post #6
The crankshaft position sensor. Yes there is a way to test it. We used the method shown in his chilton manual. I can not remember of the top of my head. we used an ohm reader, that part I member.
wfmitch
 Posted: 01-21-2013, 01:09 PM
wfmitch's Avatar
City: Vanceboro
State: NC
Post #7
What's the best way to get it off? Looks like I'm gonna have to drop the exhaust to get my hand up there to it and I expect those manifold bolts are gonna sheer off.
anti-lock brakes sensor (front wheel speed sensor) otnielarencibia For Sale - Truck Parts 0 12-13-2010 08:46 PM
anti-lock brakes sensor (front wheel speed sensor) otnielarencibia For Sale - Truck Parts 0 10-27-2010 08:08 AM
P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I) MOPAR78 3G Dodge RAM - General Talk 5 04-14-2009 09:05 AM
P0132 Oxygen Sensor Circuit High Voltage (Bank 1 Sensor 1) truckeedurango 1G Dodge Durango Performance Talk 2 03-08-2009 01:09 PM
Map Sensor, Air intake Sensor, & Engine coolant sensor Txaircraftmech 3G Dodge Ram Performance Talk 6 05-04-2007 09:51 AM
