Did the first plug change today.... - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 4th Gen (09 – Up) Forums > 4G Dodge RAM - General Talk
gutty96
  Did the first plug change today.... - Posted: 01-19-2013, 11:55 AM
gutty96's Avatar
State: ON
Post #1
Well, I did the dreaded 30k mile (50k kms) plug change this morning. It was too darn cold out for my father in law and I to do it, so I sent it to the Goodyear shop I have been using lately. They did it in around 2.5 hours, and that is including changing the oil and rotating the tires. I am fine with that.
After researching, I decided the give the Autolite XP5325 a try. Ordered from rockauto.com on Tuesday, was delivered to CANADA on thursday! I was very impressed with that for $12 shipping.
First impression, idle is smooth, throttle is smooth, shifting even seems smoother. I am happy with these plugs, and shouldn't have to bother changing them again for a lot longer then the stock plugs.
If you are on the fence to try these plugs like I was. Go for it!
Dawizman
 Posted: 01-19-2013, 12:43 PM
City: Cold Lake, Alberta
State: AB
Status: Online
Post #2
The reason we have to change our plugs every 50,000Km is because of the exposed threads in the combustion chamber. The longer you let them go, the more carbon builds up on the exposed threads, and the more likely you are to break a plug off during removal. This is why most guys stick with the copper NGK or champion plugs. They are cheap, and it's what Chrysler designed the engine to work with.
2012 Ram 2500 Powerwagon, Bright White Clearcoat w/ Rambox CMS, Stock (For Now)
2010 Ram 2500 SLT CCSB 4x4 5.7, Deep Water Blue, Toyo Open Country A/T, SpaceKap + Ladder Racks + Conduit Box(Work Truck)
Gone:
2010 Ram 2500 TRX4 CCSB 4x4 5.7, Brilliant Black, Truxedo Edge, Go Rhino Dominator III Nerf Steps, Superchips 3865.
2004 Ram 1500 SLT RCSB 4x4 5.7, Atlantic Blue, 33" Toyo Open Country M/T
gutty96
 Posted: 01-19-2013, 12:48 PM
gutty96's Avatar
State: ON
Post #3
LOL, now you tell me.
RedRam2010
 Posted: 01-20-2013, 06:41 PM
RedRam2010's Avatar
Countryman
City: Port Orchard
State: WA
Post #4
Good to know... I'll be changing mine when I get home from deployment.
2010 Dodge Ram 1500 Big Horn Crew Cab 4x4 Hemi - "Green" air filter, HBS 2.5" Leveling, Line-X Bedliner, 4 X KC Apollo 5" Lights, Cobra 29LX CB, Iron Bull front bumper!
FT1(SS) Countryman USN
mineralram
 Posted: 01-21-2013, 08:06 AM
mineralram's Avatar
City: Mississauga
State: ON
Post #5
I certainly hope they used Anti Seize on the threads otherwise those plugs may be breaking off faster than you think at the next 50,000. Also hope the heat the range is the same as the OEM's if not it may void your warranty on coil packs when they start to melt this has happened to other people who have used plugs other than OEM.
2011 Dodge Ram Sport Quad Cab
BMRbrnSNRbrd
 Posted: 01-21-2013, 08:15 AM
BMRbrnSNRbrd's Avatar
Lovin' this life
City: Norman
State: OK
View Member's FaceBook Profile
Post #6
This is why I do my own every 30k miles with the factory replacement plugs.
Unless you are running boost, there is no real reason to change to a different heat range.
Mineral Gray 2010 Dodge Ram CC Hemi Sport
Exterior: Limo tint | Painted tips | Painted calipers | De-badged | Painted grill inserts | Gloss black b-pillars | Color matched antenna base |
VHT tinted puddle lights | Color matched tailgate handle | Color matched billet fuel door |
Shaved and two-toned grill | Painted Vararam lid w/ two-toned Ram badge | Color matched Laramie 2500 flares |
Shaved tailgate badge | Shortened and painted antenna | BrakeMotive cross-drilled and slotted rotors
Lighting: Color matched headlights retrofitted with 6000k Morimoto projectors | 6000k HID fog lights tinted wiht Lamin-x |
HID retrofitted reverse lights | custom stealth 40" light bar
Interior: Color matched interior plastics | 2 MTX 12" subs in a cheap box | REN MyGig 30gb headunit
Suspension: McGaughy's 2/4 Economy drop | Black U2-55 22s | 305/45R22 Nankang N990s
Performance: Superchips Cortex w/ trans tuning | Vararam Air Grabber | Magnaflow 18" Muffler | Raceland USA E-Cutout |
Billet Technology Oil Catch Can | Clutch fan delete | 180 T-stat | Magnaflow Y-Pipe with relocated crossover pipe
VINCH
 Posted: 01-21-2013, 11:51 AM
VINCH's Avatar
City: Lancaster
State: CA
Post #7
what are plugs
Red Neck White Hair Blue Collar
2012 Ram Crew Cab 3500 6.7 H.O. CTD 4x4 SRW
295/70/17 Nitto trail grappler tires
Pin striping by Bob Spina
Scotrod65
 Posted: 01-21-2013, 01:00 PM
Post #8
Running the same plugs as OP here. 20,000 miles and very happy.
Most plugs come with anti-seize / anti corrosion plating already. (typically silver colored threads, beware of 'black' threads.)
IMHO, not enough threads sticking into the combustion chamber to 'carbon up' and cause one to bust a plug upon removal.
I won't be changing these out until they have 50-60k on 'em, (or if ~30~ months or so has passed),,,BUT, if other folks wanna change plugs more often, that's fine.
Often wonder if folks notice there is a TIME requirement on changing the plugs as well as a MILEAGE requirement? (Galvanic corrosion/Dissimilar metals is responsible for more seized plugs in alum heads than anything else,,,)
30,000 Miles (50,000 km) or
30 Months Maintenance
Service Schedule
❏ Change the engine oil and engine oil
filter.
❏ Rotate tires.
❏ Replace the engine air cleaner filter.
❏ Replace the top row of spark plugs
(4.7L Engine).
❏ Replace the spark plugs (3.7L and
5.7L Engines).
❏ Inspect the transfer case fluid.
gutty96
 Posted: 01-21-2013, 01:07 PM
gutty96's Avatar
State: ON
Post #9
I will pull one in the spring when it gets warmer to take a look and see how they are going.
As for the heat range, I think the XP5325 are the same range as OEM. They come up as on OEM replacement on every auto parts site.
watkins
 Posted: 01-21-2013, 03:04 PM
watkins's Avatar
Post #10
when i go to Dodge.com, type in my VIN (2009 5.7 1500) it says under the recommended service to change the plugs at 48K.
I already changed at 30K and will wait until 78K to do again.
as with most, they looked great coming out the first time.
hounddogg
 Posted: 01-23-2013, 08:03 AM
hounddogg's Avatar
State: GA
Post #11
The ONLY reason these trucks have the spark plugs that they do is cost. The cop 5.7,Hy-bred 5.7 and the 6.1 have NGK 100,000 mile Platinums. I had a Chrysler rep in 2009 comment that if it was him he'd not put the cheap nickle tipped plug back in every 30k. The FINE WIRE Irdiumns are used a lot in the aviation industarty. Better,better fuel burn and said to keep carbon down. Don't forget on the Autolites to go to the Autolite Website and download the $2.00 each rebate coupon. $32 bucks back. These Fine Wire Irdiumns are good for 100,000 PLUS miles. They have a 5 year UNLIMITED mileage warranty.
2009 Quad Cab SLT White,Hemi,2WD,20 inch wheels,3.92 gear.2003 Quad Dually 4x4,6 speed,4.10 gears,diesel.Banks 4 inch exhaust,Afe Pro Guard filter,Rottech crank sensor mod.Amsoil fliuds front to back.08 Corvette Convertible.
Plug Change TRXHemi 4G Dodge RAM - General Talk 12 02-06-2012 06:30 PM
did plug change on 4.7 today ran into prob RamLion 4G Dodge RAM - General Talk 6 01-07-2012 03:19 PM
Plug Change bob1340 4G Dodge RAM - General Talk 5 03-13-2011 10:52 AM
Plug Change Help tone100 3G Dodge RAM - Drivetrain Talk 1 02-14-2011 08:14 PM
2002 2.7L Stratus Sedan Spark Plug Change and Fuel Filter Change Question stardomains 2G Dodge Stratus - General Talk 1 11-05-2008 05:31 PM
