Thread Tools |
Dealer trying to tell me 10.5" axle whine on decel is normal
- Posted: 01-15-2013, 04:23 PM
Post #1
Can anybody tell me if they have run into this before? I took the truck in for a second time for rear axle noises.
It's a 2008 4x2 Mega Cab 1500 with the AAM 10.5" rear axle. It's whining under deceleration and very noticeable around 50mph. I had it rebuilt by them under warranty due to noise on acceleration and then the noise changed to deceleration. Now, they're trying to tell me the noise is ok and that all the specs are in spec from what they can tell and the pattern looks ok. It can be heard easily with all the windows closed so it's not a real minor whine.
2008 Ram 1500 Mega Cab 2WD Magnaflow muffler with no resonator 2" drop shackles out back |
| Sponsored Links | |
Advertisement |
Posted: 01-15-2013, 04:33 PM
Post #2
It's not normal, try a different dealer. If the gears were whining on acceleration and havent been replaced, that might be the problem.
How many miles were put on, with the acceleration whine? And what's the name of the dealer? 3.73s are stock amd as you know, shouldnt whine |
Posted: 01-15-2013, 06:09 PM
Post #3
R&P were replaced during the initial rebuild. I bought the truck with about 45k miles on it and it was doing it when I bought it. So no clue how long it was doing it before, the previous owner probably traded it in because of it.
It does have 3.73's and it was my opinion they should not whine also, regardless of it being a 10.5" axle. The dealer is AutoPark Chrysler Jeep, it's not a Dodge/Ram dealer but the same place does have a dodge dealer also (Leith). Only reason I took it here was because thats where I bought it from and they've been good so far. The sales guy has offered to make it right for me if they can't fix it but i've grown to love my mega cab and don't really want something else. I'm going down tomorrow to check it out with the cover off and talk to the service manager. So we'll see what comes of it.
Posted: 01-16-2013, 10:37 AM
Post #4
I went an found a factory service manual for 08 1500, 2500, and 3500 trucks and it mentions nothing about noise being normal. In Fact in the diagnosis section it describes my exact issue and says it's coming from the pinion bearing.
No where does it mention any whining is ok under normal operation. This is straight from the service manual: Pinion bearings have a constant-pitch noise. This noise changes only with vehicle speed. Pinion bearing noise will be higher pitched because it rotates at a faster rate. Drive the vehicle and load the differential. If bearing noise occurs, the rear pinion bearing is the source of the noise. If the bearing noise is heard during a coast, the front pinion bearing is the source.
Posted: 01-16-2013, 12:06 PM
Post #5
Sounds like to me that the backlash isn't within specs.
Posted: 01-16-2013, 12:49 PM
Post #6
They told me over the phone the backlash is in spec and the pattern looks good. However I think the issue is actually pinion bearing pre-load. I believe this could still produce a valid pattern but still cause noise. The noise is the bearing itself and opposed to the ring and pinion making noise.
Posted: 01-16-2013, 07:25 PM
Post #7
Well, they are going to tear it down and try shimming it a bit one way or the other like the "Chrysler engineer" told them to try. I still think it's the pinion bearing pre load.
I could tell by the tech demeanor he doesn't give a shit about my problem, and because the gear pattern looks normal that the noise must be ok. They keep saying it's gear whine and no way it can be the bearing, I called BS on that but they don't seem to care much. If they don't fix it, i'm making the dealer take this hunk of junk back and i'm gonna go find a chevy. I never trusted Dodge trucks and it seems like Chrysler has confirmed my concern. Hopefully they fix it and it doesn't come to that, but I have zero confidence in them right now.
Posted: 01-17-2013, 10:25 AM
Post #8
I didn't think about the pinion preload, that's a very good possibility. I'm just wondering if he said screw and not replace the pinion bearings at all. So that would account for the noise because the pinion shaft was never removed to begin with.
Posted: 01-17-2013, 12:47 PM
Post #9
I was told all the bearings were replaced. I'm wondering if they didn't check pre-load using proper methods and got a artificially high number or something so it's not set right.
Or, heck, maybe the housing is screwed up somehow and no matter what they do it won't be right. Only option then is to replace the whole thing.
Posted: 01-17-2013, 01:25 PM
Post #10
![]() Red Neck White Hair Blue Collar 2012 Ram Crew Cab 3500 6.7 H.O. CTD 4x4 SRW 295/70/17 Nitto trail grappler tires Pin striping by Bob Spina |
Posted: 01-21-2013, 01:38 PM
Post #11
Apparently when they tore it down to "try" something to fix the problem they discovered a bad bearing. It was replace before but apparently once they got the carrier out they noticed a hard spot when rotating the pinion by hand.
So they should have it replaced and put back together early this week. Quote:
Posted: 03-12-2013, 04:10 AM
Post #12
I have had nothing but problems with my local dealer. The shimming they are talking about will change the tooth pattern. They said that was good, typically the problem lays with getting the pinion nut torque correct while maintaining the pinion rotation torque value. Unfortunately they like to use an impact wrench to set the pinion nut and it basically can't be done without a lot of luck thrown into the mix. Good luck.. IMO find another dealer..
PI_greg2003 RCSB SXT-Hemi - OEM SS/T rims/275/55-17 tires, AeroForce-w/wideband, Trans LP gage, SC3865/PSC1, High Idle mod, 6.1 dual coil ignition, 05 fuel pmp, pwr wire, K&N -77 CAI, Fastman TB, Snow Wtr/Meth, 20% U/D, eFan, TCI FastGate shifter, AutoMeter Shiftlite, Autometer Tach adapter, 180 thermostat, TMR, Sonnax, 2500HD OEM Trans Cooler, Crazy Spartan/112 lsa, 2800 stall Edge Converter, DTT 4:10, LT's, Magnaflow SI/DO, duals cats, Mcgaughys 3/4.5 spindle kit, Monroe gasomatics shocks, Caster/camber adjusters, Caltracs traction bars, Aeon springs for bump stops Frt/Rear, 04 Laramie leather SLT 10 way seat and SLT leather steering wheel, CD/radio, stand alone OEM foglights, billet grille inserts, painted cowl (shaved) and upper bumper cover, Shaved tailgate w/EZdown, Shaved Antenna, Amplified hidden antenna, sliding rear window, welded steel Roll Pan, Hidden hitch, Sport mirrors, Painted Front bumper, Fiberglass tonneau cover, OEM bed liner, OEM SRT-10 gage pillar, billet gas door, de-badged, tint strip. |
Posted: 03-12-2013, 06:48 PM
Post #13
HAHAHAHAHA, buy that Chevy and let us know how that goes!
Been there, and strayed once away from Dodge. Will never do it again. My 2002 Chevy truck was an expensive POS. Everything was either falling apart or making noise, or just plain crap. I've had 3 Dakotas and 3 Rams now. All with ZERO issues. The one Chevy I had, managed to gobble up huge amounts of time with it's issues. These are mechanical devices. They ALL have issues from time to time. Just look at Toyota! LOL. A leader in reliability, and good construction. So, we thought. Now, Toyota leads the industry in recalls. The new Camry scored last place in safety testing. Let us know how you like that Chevy!! ![]() .
"I enjoy my Second Amendment everywhere I go" |
Posted: 03-16-2013, 09:32 AM
Post #14
That's all set up not bearing, bearing is an excuse.
see a reputable driveline shop that specializes in diffs, not a dealer
71 Dart gt, 73 RR 440-6pk clone, 78 Magnum gt, 85 W-350 Power Ram Le CC, 92 Daytona es, 95 Jeep gc, 99 Dakota, 05 Jeep gc, 08 Dodge 2500 Ram |
Posted: 03-26-2013, 02:14 PM
Post #15
It's been fairly quiet but seems to be getting a bit louder over time again. I'll probably give it some time and let it get noisy again and take it somewhere else. These guys gloated how they were axle guys and I just laughed inside. I may just take it to a driveline shop and pay them to write up an evaluation and use that at the dealer.
Posted: 03-26-2013, 02:15 PM
Post #16
| Thread Tools | |
| 2011 hemi 2500 noise. dealer says normal... | 2manytoys2 | 4G Dodge RAM - General Talk | 169 | Yesterday 07:06 AM |
| 01 Stratus "whine" when turning steering wheel? | nonommy | 2G Dodge Stratus - General Talk | 2 | 02-28-2009 12:03 PM |
| TSB - Axle Whine | Big3 | 2G Dodge Durango - Tire/Wheel/Susp Talk | 5 | 10-08-2008 02:54 PM |
| Loose power steering rack normal? And a good dealer in Houston? | texas_hemi | 3G Dodge RAM - General Talk | 6 | 03-27-2008 11:12 AM |
| 01 T&C, New Steering rack makes clunking noise. Dealer says its normal??????? | maher871 | Dodge Caravan/Grand Caravan Talk | 1 | 02-25-2007 10:56 PM |
Privacy Statement | |
