Thread Tools |
Hellwig rear sway bar installed...shoulda done this a long time ago!
- Posted: 01-14-2013, 02:02 AM
Post #1
Purchased a Hellwig 7561 rear sway bar for my '08 1500 a few weeks ago, and finally got around to installing it. Install took almost 3 hrs, but that's because I kept running inside to check on football. If I were to do it again, pretty sure I could get it done in an hour. As mentioned in the following link (which was a great help for the install), the hardest part was lowering & raising the spare. Everything bolted right up and only the right rear brake line had to be slightly moved.
http://www.dodgetalk.com/forums/showthread.php?t=340369 Results are fantastic! I notice absolutely zero degradation in ride (even on bumpy paved country roads) and the only time I've noticed it's there (other than in turns) is when going over railroad tracks or speed bumps diagonally. I really expected the ride to get worse, which is why it took so long to try ![]() Handling is GREATLY improved, not so much in ultimate grip but in balance. Though the front suspension rolls as much as ever, the nose tucks a lot better and the greater rear roll stiffness causes the truck to actually pivot without having to use throttle lift or trail braking. I took the truck for a run up Hwy 132 and was pleasantly surprised how much faster I was able to comfortably take turns, even under full throttle. As long as your truck is not a rock crawler / trail rig and you understand vehicle dynamics & basic car control, I highly recommend getting a rear sway bar!
'08 Ram 1500 QC 4wd 4.7L 6spd (205k) Bedryder seats; Bilstein HD's; McG drop shackles; Hellwig rear swaybar; Bosch euro beam lights BTG; Hella CELIS/LED taillights; Duplicolor'd yellow fog lights; Mopar wheel-to-wheel DP aluminum steps; Magnaflow muffler & y-pipe; Mopar wheel-well liners; 33" Hankook ATM on 20" forged Centerlines; REC receiver with Nakamichi(f) & Memphis(r) speakers, 10" old-school round Kicker Solobaric in a SC/Boyd sealed center-seat box, Infinity 6ch amp; Aspen steering wheel w/SWAC; SRT brake & clutch pedals; heated/cooled Infiniti leather driver seat; Bedrug mat To be installed: Cibie pencil beams BTG; SSBC f&r big brakes '97 Ram 2500 CTD 4wd 5spd flatbed (247k) - plenty of fuel with a stock turbo |
| Sponsored Links | |
Advertisement |
Posted: 01-14-2013, 10:50 AM
Post #2
Let us know, how that works out in the long term.
I was thinking of doing this as my truck acts a lil goofy when i'm towing my four wheelers, i always blamed it on the longer soft ride leaf springs. |
Posted: 01-14-2013, 11:25 AM
Post #3
Nice mod for sure, made a big difference on my 05QC 4x4.
2004 RC SRT10 6spd Black, 500+ HP and 525+TQ already![]() #50 of 3057, B&G Stage2 PCM BT underhood items, JTSVP Gen1 shifter#49 and Snakeskin radiator cover, 06 rebadged, hard tonneau with BedRug, tinted windows, WeatherTech mats, more to come On the way, JMB catless mids, ROE Racing TB, Screamin' demon coils and JTSVP Wires, Venomous1 Racing Billet UD pulley, Volant CAI, 170* thermostat, JTSVP lowering blocks and more SnakeSkin stuff!!!!!!!!
Posted: 01-14-2013, 01:49 PM
Post #4
Makes a truck drive like a car pretty much. Like he says, if you use 4x4, don't get it. It's then you have taken your car off road!
![]() I've heard it's about the same as putting 100lbs in your bed. If you've ever driven with weight in your bed and noticed how much better the ride is. It's almost that feeling.
Posted: 01-14-2013, 04:09 PM
Post #5
Not at all what I said. The only time the sway bar will get in the way is when you need more wheel articulation, like on slow trails or for rock crawling. It actually makes for better traction off road with my peg leg diff...less weight transfer causes less inside wheelspin. Even with my work around the orchards (often in 4x4), I have yet to find a downside of the rear sway bar. And no, it does not make your truck feel like there's weight in the bed. The ride did not improve at all, but it also didn't get any worse.
Posted: 01-14-2013, 04:41 PM
Post #6
I would have bet the ride would have stiffened up a bit at least. Maybe the lowering shackles put less of a preload on the bar. Sounds like you outta know your ride though.
What was your cost? Install sounds easy enough. And why did you decide to install it at all? Just curious.
05 RC SB 4.7 4x4 |
Posted: 01-14-2013, 05:18 PM
Post #7
Sway-bars don't affect ride quality. They sure improve handling though. I did this mod over four years ago - I love the way the truck feels like its up on its toes.
'03 1500 QCSB Hemi |
Posted: 01-14-2013, 06:09 PM
Post #8
Sway bars only hurt ride in side-to-side bumps, like driving diagonally over a speed bump or when only one rear wheel hits a larger bump. I also expected some ride degradation because of this, but haven't noticed any negative effect. Not sure if the lowering shackles affect it, but I was worried about spare tire clearance with the small drop. Zero issues there as well.
Cost was just under $200 shipped, but that was a closeout price and they generally go for about $225 shipped. Reason I installed it: http://www.dodgetalk.com/forums/showthread.php?t=365593 Def one of my favorite mods thus far
Posted: 01-14-2013, 07:03 PM
Post #9
LOL I remember that post. Are you able to powerslide the rear easier now?
05 RC SB 4.7 4x4 |
Posted: 01-14-2013, 07:43 PM
Post #10
Pics?
Posted: 01-14-2013, 08:40 PM
Post #11
_- under construction -_ |
Posted: 01-14-2013, 11:23 PM
Post #12
One of the best mods out there......... I'm ridin' with a Hellwig!
Flame Red 2006 Dodge Ram HEMI Sport 2 WD Quad Cab, Royal Purple 5W20 Engine Oil. Royal Purple Max Gear 75W-140, K&N Performance Gold Oil Filter, Fumoto Oil Valve, SharaDon Third Stage Transmission with Amsoil ATF, Edge 2600 Torque Converter, AutoMeter Trans Gauge, Custom Powdercoated RamHammer Intake, Jet 180 Thermostat, Zerex G-05 Coolant, Flex a lite Black Magic 180 X-treme Electric Fan With Flex a lite Variable Speed Control Module Kit, Moe's Performance Ported Throttle Body, Jet-Hot Coated Doug Thorley Headers, Stage 8 Locking Header Bolts, Custom Powdercoated Moe's Performance Shroud Delete Kit, Cherry Bomb VORTEX Muffler Single In/Dual Out, Magnaflow Y Pipe, DiabloSport Predator U7137, SRT-10 Gauge Pillar, Keystone Good Hood, OEM Tonneau with SRT10 Replica Sport Wing, OEM Ground Effects, GroundForce 2/4 Drop, 22 inch Black machined SRT-10 Replicas, 22 Inch 305/45/22 Yokohama Parada Spec-X Tires, Premium Dimple, Drilled & Slotted Brake Rotors by BrakePerformance.Com, EBC Supreme Green Front Brake Pads & Greenstuff Rear Brake Pads, Hellwig Anti-Sway Bar, Shaved Tailgate, Sir Michael's Roll Pan, Street Scene Electric Mirrors, Powdercoated Wipers & antenna, Debadged, Tinted Windows with custom rear window Ram Logo with Flames, Flame Red Cowl & Door Handles, Flame Red Eyelids, Custom Exterior Sunvizor, Anzo Aftermarket Headlights, Custom Leather Interior From LeatherSeats.Com, BedRug, Jimmy Jammers, Powdercoated Upper & Lower Grilles, Duralast Gold Battery, Clarion Double Din/HD Radio/Bluetooth/CD Player Unit, 8 speaker POLKAudio Sound System including 2 Polk amps, Fox Subwoofer Box, Griot's Garage Detailing Products |
Posted: 01-14-2013, 11:38 PM
Post #13
Haven't had a chance to really try and drift it around yet, but it is definitely easier to bring the tail out under deceleration. I imagine the peg leg will still be an issue to keep the tail out, but that will be remedied in a couplet months.
Didn't post pics because it pretty much looks identical to the pics in the linked post above. Only differences are that my sway bar is flipped 180 degrees (diff hump pointed slightly down) and the sway bar mounts point downward a little more due to the slightly lowered suspension. Plan on taking the truck for a hard run through the hills this weekend...
Posted: 03-07-2013, 02:52 AM
Post #14
It's been a while, but finally took it for a good hard run (Hwy 120 thru Yosemite). Definitely handles a lot better, though I would prefer some more front roll stiffness. Still understeers if pushed too hard or on throttle too early, but that is pretty easily remedied with a hard lift of some brake application. Did scare myself around one decreasing radius turn that I entered a bit too hot...had to press a little harder on the brakes mid corner than I would've liked, and the tail just let go. Was able to catch it and though I lost plenty of momentum, it probably looked pretty cool from the outside.
Definitely a very worthwhile mod if you've got a decent grasp of car control, but would not recommend it for more inexperienced drivers or those that let their wives/kids drive a lot. Truck will handle fine 99.9% of the time, but I could see the tail coming around in one of those "emergency avoidance maneuvers"
Posted: 03-07-2013, 02:56 AM
Post #15
Posted: 03-07-2013, 09:07 PM
Post #16
Dont anticipate any problems, but will post if anything comes up. Already got a few thousand miles with the rear sway bar, and haven't noticed any negative effects
Posted: 03-08-2013, 06:59 AM
Post #17
The sway bar mod is on my top 3 of mods I need/want to do. If I had the extra cash it would have been done by now. My extra cash is now going to the wife's Jeep, it needs new wheel hubs. Besides she always comes first.
Jon2005 Dodge Ram 1500 Daytona #8398 Silver Truck Number 212 Quad Cab Number 40 SuperChips 3865 Spectre CAI E3 Spark Plugs Taylor Wires Blue Full Length 8.2 Thunder Volts 85mm Ported TB Sonnax Transmission Line Pressure Booster AirRam PowerWire AirRam Jet Stream Scoop Jet 180 TStat Borla Exhaust Magnaflow Y Pipe RP in motor/differentials/transmission/radiator/power steering/transfer case Bilstien Shocks Painted calipers Drilled and slotted rotors x 4 Sirius Sat Radio WeatherTech Window Vents and floor mats Access Tonnosport Dupli-color bedliner with kevlar 2003 Jeep Wrangler Sport (wife's vehicle) Spectre drop in filter Jet 180 TStat RP in motor/differentials/transmission/radiator/power steering Drilled and slotted rotors (fronts only) General Grabber AT2 tires Blacked out rims Skyjacker Nitro 8000 shocks/Skyjacker Hydro 7000 steering stabilizer Painted calipers Sirius Sat Radio |
Posted: 03-11-2013, 02:01 AM
Post #18
Money well spent...I'm sure you'll agree when you get one
| Thread Tools | |
| Hellwig 7651 rear sway bar installed! | TR Custom Parts | 3G Dodge RAM - General Talk | 9 | 08-26-2011 10:03 AM |
| Hellwig Anti-Sway bar installed! | hawk02 | 3G Dodge RAM - General Talk | 11 | 03-17-2010 07:06 PM |
| Installed hellwig rear sway bar on 2500 | senglehart | 3G Dodge RAM - 4X4 Talk | 14 | 03-09-2010 10:27 AM |
| Hellwig Sway Bar installed on my 4x4 | 0212353 | 3G Dodge RAM - General Talk | 68 | 05-03-2009 11:29 PM |
| Front Sway Bar (Hellwig) Installed | SilsHemi | 3G Dodge RAM - Sport Truck Talk | 16 | 08-02-2005 05:05 AM |
Privacy Statement | |
