Thread Tools |
4X4 Trouble
- Posted: 01-11-2013, 01:37 PM
Post #1
I have a 2001 4X4 and when I try to engage the 4H on a roll it grinds. If I try to engage N on the roll it grinds. If I engage 4H while stopped it goes in fine but when I start moving it starts sounding at if it is binding and maybe skipping in the Tcase. If I put it in N while stopped I still move as if I am in 2H still. I tested this now on snow and I know it is 2H while the Tcase is shifted to N. If I shift to 4L while stopped and drive I am in 4H with the binding up sound. All tires are the same in case you wonder. I would like to know if anyone has seen this before and what would cause this so I can fix the correct problem.
Thank you in advance. |
| Sponsored Links | |
Advertisement |
Posted: 01-15-2013, 12:52 PM
Post #2
whats on a roll? 30-40mph? or like 10-15 now I know you can shift these trucks in while moving but I slow down or just come to a complete stop to around 15
but the winding might need a rebuild...you have my scratching my head.
96 Ram 5in BDS Suspension lift 35x12.50 Nitto Mud Grapplers 18x9 Pro comp flat black rims 4.56 gears Detroit trutrack posi 360 bored .030 20-604-9 comp cam 512 lift, 210/220 duration Hughes FI Air Gap intake Iron Ram EQ heads with 2.02 intake valves Hughes magnum Roller rockers Trick flow push rods SCT Tune by Hemifever Long Tube 3in Pacesetter headers Glow shift A-piller, Fuel rail pressure, Trans Temp, Water Temp Derale Doubel deep trans pan She thumps and she thumps hard, I love it! Next to come Long are BDS Swap Built tranny, Body work....I love my life lol! |
Posted: 01-16-2013, 04:32 PM
Post #3
I can shift mine in and out of 4H at highway speeds. As long as the wheels aren't spinning in 2wd (like being stuck) you should be able to shift from 4H to 2H without any problems or noise.
2000 1500 Sport 5.9 4X4 QC 46re w/TFODjr ![]() SCT by hemifever, 4.10 Gears, Stainless Steel Headers HellBent Steel leveling kit, 33X12.50X16 Super Swamper TSL Radials |
| Thread Tools | |
| Trouble shifting....real trouble or sensor?? | 99bluedakotar/t | 2G Dodge Dakota - Drivetrain Talk | 0 | 02-24-2010 03:33 PM |
| 6.7 trouble | krazzykustoms | 3G Dodge Ram Diesel Talk - 6.7L | 10 | 02-01-2009 02:15 PM |
| 3.9 trouble | ocjoe | 2.5L, 3.9L, 5.2L, 5.9L, V10 Tech | 0 | 10-05-2007 09:25 PM |
| ABS trouble | austin8214 | 3G Dodge RAM Diesel Talk | 3 | 04-26-2007 05:24 AM |
| EGR trouble | mjamgb | Diesel Tech | 1 | 06-02-2004 06:08 PM |
Privacy Statement | |
