Thread Tools |
New Tires and Trackbar
- Posted: 01-09-2013, 11:48 AM
Post #1
I had another case of death wobble. It was bad this time! Come to find out that the BFG Goodrich TO A/Ts that I have are known to cause death wobble on these truck, even stock height. So with my Carli 3" springs, the lack of my axle being centered under the truck with the stock trackbar, I said screw it. I can't have this.
So try to get rid of it, I went to Strapt Performance here in Tempe and got a Carli Adjustable trackbar. Then I drove over to Discount and said get me some MUD TIRES! They made it happen! ![]() New Carli Trackbar next to the stock one. ![]() The bushing were worn out for sure. Battery acid dripped on it from a bad battery. ![]() Bushing worn. Hard to believe that this and tires can cause death wobble! ![]() and now to the good part! ![]() The guys at Discount were thinking OH CRAP! When they started to remove my old tires and were tearing some of the plasti-dip. I said, guys no worries.. haha it's plasti-dip. But gave me a great idea! I removed the Plasti-dip along the edge of the wheel! Looks so much better!! ![]() SO I think I will paint these wheels just like this! Figure paint is easier to keep clean and would look better when all said and done for details. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Now I haven't really drove it since I got the track bar on lastnight. So hopefully this $2K was spent good!
| Sponsored Links | |
Advertisement |
Posted: 01-09-2013, 12:49 PM
Post #2
Hope that cures the DW issue!
Common sense is like deodorant, the people who need it most NEVER use it. |
Posted: 01-09-2013, 01:20 PM
Post #3
You know there is a Tire and Wheel section, right!?
![]() Truck is looking great, I like the chrome edge on the wheels. I hope your death wobble goes away.
Mike AKA: WixTheDog 2007 Dodge Quad Cab 2500 - 4x4 - 6.7 CTD -G56- LWB - White Some new stuff, some old stuff, some stuff fell off. 2013 Ford Focus --> Commuter Car! |
Posted: 01-09-2013, 01:26 PM
Post #4
Yes smarty! In fact, if you look there, You'll notice that I posted some of the pictures from lastnight there lastnight! ![]() This thread also showed the trackbar and tires. So "general" came to mind! ![]() http://www.dodgetalk.com/forums/showthread.php?t=366779 Trying to give me my own medicine hahahaha
Posted: 01-09-2013, 03:25 PM
Post #5
Hopefully that will fix the DW. Looks good with tires and the wheels done that way.
05 Patriot Blue Pearl Dodge Ram 1500 4x4 5.7 Hemi MODS | VaraRam Hemi Under Glass | Superchips 3865 with Trans Tune | SLP Powerflo Catback Exhaust | Shorty Wires | Electric Fan | 180 Stat | Ventvisors | Debadged | Billits in the Grill | Blacked out Led tailights | Blacked out Third Brake Light | Color Matched Headlights | 6000k HIDS in Heads and Fogs | Shorty Antenna | Torsion Bar Level 03 Silver Dodge Ram 1500 4x2 5.7 Hemi MODS | Home Brew Ram Air CAI | Superchips 3815 | TMR Mod | Magnaflow 14" SI/DO muffler | Electric Fan | 180 Stat | B&M ProStick Ratchet Shifter | Custom Gauges | Custom Shifter Surrond | Ventvisors | Debadged | Tinted Tails | Tinted Third Brake Light | Smoked Headlights | 5000k HIDS in heads | 3000k HIDS in fogs | Roll Pan | Shorty Antenna | Custom Painted Grill | Dipped Front Bumper | Poor mans 2/4 Drop | 17" Ram SS/T Wheels | And A Little Bit of ZEX BEST 1/8-Motor-9.23@77__Spray-8.89@78-Spinning BEST 1/4-Ill Know Next Year BLUE TRUCK MEMBER #246 | SILVER TRUCK MEMBER #261 |
Posted: 01-09-2013, 04:46 PM
Post #6
How much did the tires set you back? I need something to make me feel better, I dropped close to $3,000 on my truck last week!
Posted: 01-09-2013, 04:55 PM
Post #7
Looks great with the new tires and the ring on the wheels exposed!!...
I have been debating those same tires for my Wrangler since I drive it daily now.. The super swampers I have on it now are freakin awesome but obviously shit for a daily driver... Have you had any more drive time? are the tires loud? smooth?.. I don't mind humming but my swampers are worse than driving on the highway rumble strip non stop, and with an hour drive to work it gets old... I have the Trail Grapplers ATs on the F-150 and they are pretty good but not aggressive enough for the jeep.. I really like those MTs I think they would be a great compromise for looks and practicality.. As far as the death wobble, I hope the track bar helps and I'm sure with the lift this has been addressed, but is there anyway to increase the caster a bit.. Seems that could be beneficial also..
...............................Bright Silver RC SRT-10
Posted: 01-09-2013, 06:32 PM
Post #8
What have you done to yours? Quote:
I think the tires and trackbar are #1 and #2 reason I've got this wobble. I'll actually go into work tomorrow instead of working from home just to test them. See if that did it....
Posted: 01-09-2013, 07:29 PM
Post #9
[quote=07MegaCabRam;4468490]Tires were $314 each. Track bar was $345.
What have you done to yours? QUOTE] I did a Valair organic dual disc clutch and rear main seal for $1850 and then the new tires for $1000. I still need to replace my front differential pinion seal.
Posted: 01-09-2013, 07:42 PM
Post #10
Ha! I am doing my rear pinion seal.
Posted: 01-10-2013, 12:25 AM
Post #11
Posted: 01-10-2013, 11:01 AM
Post #12
Posted: 01-10-2013, 07:10 PM
Post #13
looks good!
Posted: 01-10-2013, 08:46 PM
Post #14
Looks great. Congrats on your second set of Trail Grapplers!
2004 DODGE RAM 2500 LARAMIE w/ THE HEMI - BLACK ON BLACK/GRAY LEATHER - 295/70/18 NITTO TRAIL GRAPPLERS - 18x9 FUEL BOOST 5.75" BS/+20 OFFSET - AEM BRUTE FORCE CAI -CUSTOM MAGNAFLOW CAT-BACK EXHAUST 14" SI/SO - MAGNAFLOW Y-PIPE - NGK 5306 SPARKPLUGS - DIEHARD PLATINUM BATTERY - RECON SMOKED CAB AND 3RD BRAKE LIGHTS - RECON FIRE AND ICE TAILGATE BAR - TOTAL LED CONVERSION FRONT TO REAR - BILSTEIN'S ALL AROUND - EXTANG FULLTILT TONNEAU COVER - ALPINE 9886 HEAD UNIT AND ALPINE MRP_M300 AMP - JL AUDIO 12w1v2 SUBWOOFER - AVITAL 4103 REMOTE START AND KEYLESS ENTRY - UNIQUE COATINGS FLASHTECH HIDS - 9007 6000K BI-XENON HEADS AND 9006 6000K FOGS - EZ-DOWN TAILGATE ASSIST - HUSKY FLOORMATS - SUPERCHIPS CORTEX 3950 w/ TRANNY TUNE - MOPAR REAR WHEEL WELL LINERS - BUSHWACKER EXTEND-A-FENDERS - TEKONSHA PRODIGY BRAKE CONTROLLER-AUTO METER FACTORY MATCHED TRANNY TEMP GAUGE |
Posted: 01-11-2013, 07:46 AM
Post #15
Hard to believe that big, knobby mud-tires would cure the DW problem...
![]() Let us know how it works out, now get those mudders muddy! ![]()
2007 1500 SLT 4x4. 2-dr, short bed; 4.7l; 3.55 w/LSD. -- More to come...
Posted: 01-11-2013, 07:50 AM
Post #16
It's all about the stiffness of the tires. The guy at discount threw the old bfg to the side after removing it from the wheel. The tire actually collapsed in half cause it was so soft.
Posted: 01-11-2013, 08:10 PM
Post #17
That's one nice Mega!!
Posted: 01-12-2013, 10:13 AM
Post #18
Posted: 01-12-2013, 05:02 PM
Post #19
Awesome!
2008 Ram 2500 4x4 automatic CTD Armaguard boxliner, Bakflip Roll-X tonneau cover, LT285 70R17 Bridgestone Revo II ATs, Quaker State synthetic throughout Gone but not forgotten: 2001 Ram 1500 Quad Cab 4x4, 5.9 automatic LT285 75/R16 BF Goodrich All Terrains, K&N FIPK, Flowmaster Super 40 SI/DO rear exit, with chrome tips Edelbrock ceramic coated headers, SCT Tuner by Hemifever, Fastman 52mm, Harland Sharp 1.7 roller rockers, Remote starter/keyless entry, Kenwood deck & speakers, Lund tonneau cover, Line-X bedliner, Detroit Truetrac, Oasis rear differential cover, Tinted windows, Mag-Hytec transmission pan, Mag-hytec front differential cover, Mopar tow hooks, Mopar fog lights, Mopar valve covers, Castrol Syntec oil throughout, Bilstein 5100s, Taylor blue 8mm spark plug wires, Motive Gear 4.10s, Trans-Go shift kitBlue Dodge Truck Member #228
Posted: 01-12-2013, 05:25 PM
Post #20
Did it fix the problem?
$miley
$miley |
| Thread Tools | |
| Yes Another Trackbar Question | Hylander | 2G Dodge RAM - 4X4 Talk | 2 | 10-01-2012 09:42 PM |
| ?Bad steering box and trackbar ?'s | sandman3019 | 2G Dodge RAM - General Talk | 54 | 03-12-2010 03:41 AM |
| 94-01 Thuren Trackbar | pctgreg | For Sale - Truck Parts | 0 | 11-12-2008 10:42 PM |
| aftermarket trackbar?? | madmanmechanic | 2G Dodge RAM - 4X4 Talk | 4 | 06-22-2005 10:54 PM |
| Trackbar | njbiggdogg | 2G Dodge RAM - 4X4 Talk | 13 | 01-29-2005 11:32 AM |
Privacy Statement | |
