rear main oil seal - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 3rd Gen (02 – 08) Forums > 3G Dodge RAM - Drivetrain Talk
vietnam67
  rear main oil seal - Posted: 01-07-2013, 11:56 PM
State: CA
Post #1
2008 dodge ram 1500 rear main oil seal leaking, do you remove the trans or drop the oil pan and go from there can anyone help me thank you.
blk05hemi
 Posted: 01-08-2013, 08:06 AM
blk05hemi's Avatar
State: FL
Post #2
You have to drop the tranny. Haven't heard of anyone having problem's with the rear main seal. Where are you seeing the oil?
2005 QC S/B Hemi Sport
Performance:Vararam Intake/Dyanatech's w/Hi-Flow Cat's&Stage 8's/Borla/Daytona Exhaust/Black Magic E-Fan/Ported&Polished TB/Jet 180* Tsat/Predetor Tuner/BellTech swaybar/TA Performance Cover/Amsol Fluid's
Apperance:SRT-10 Rear Spoiler/Hemi badges on scoop/Scoop Insert/Line of Fire/Easy-Down/Painted Caliber's/Billet strut cover's
Interior:Triple Pillar Pod w/Phantom Gauges-Wideband Afr-Oil-Water/Custom led's/Billet-Ram head knob's-Door pin's-Power window panel's-Glove box dash plate& more/Daytona mat's
vietnam67
 Posted: 01-08-2013, 12:20 PM
State: CA
Post #3
I'm seeing the oil just in front of the trans bell housing where it connects to the engine, it is leaking at the bottom of the housing where the two connect. i check the oil pan no problems there, i had to add 2 1/2 qts of oil, so far the other day, i read that i could go through the oil pan area after i remove the pan and oil pump to gain access to the rear seals,is this true or like you said i have to remove the tranny.
blk05hemi
 Posted: 01-08-2013, 05:47 PM
blk05hemi's Avatar
State: FL
Post #4
To be honest with you, i have never had to replace one. Just to make sure i looked in the manual to check. Yes you can do it through the oil pan area, but you will have to remove a main cap and mabe loosen another. (seal is 2 pcs.) Before you go through all this trouble there is one other place to check that may be a possible cause. I also found oil leaking at the trans. support brace,(were the bellhousing meet's the block) also on the trans. pan and thought my rear main was leaking. After a couple time's checking it what i found was, the front crank seal was the problem. The oil was running along the top of the oil pan lip and coming out of the small hole in the trans. support brace. Take a look at the front crank seal and see if it's wet. If so this could be your problem. If your lucky and the front seal is your problem, it will be a whole lot easier to replace.
vietnam67
 Posted: 01-08-2013, 07:23 PM
State: CA
Post #5
hey thanks for the info i never thought of that, just as you said i hope it's the front crank seal. will get back to you on this for a heads up. i also check with another auto shop on replacing the rear main seal, labor $ 375.00 plus parts. thats not to bad of a cost compare to the others.
vietnam67
 Posted: 01-09-2013, 12:26 AM
State: CA
Post #6
ok i removed the drive shaft disconnect the trans,i used a trans jack to whole it up, i made sure when i removed the trans and the torque converter as one unit, on the drive shaft i mark the yokes and also i remove the crank shaft position sensor which is located at the rear of the engine block near the drive shaft , i mark the converter and drive plate to make sure the balance is the same when i put it back on, and i disconnect everything else the was connected to the trans. man there is a lot of stuff connected to the trans anyway i removed the flywheel along with the drive plate i mark those to to make sure i put it back in the same position. i pryed out the oil seal clean the seal bore then i lubricate the new seal with clean engine oil and put it in,and then i put everything back this took me over 5 hrs while doing this on my back, i know i save a few hundred bucks but if this ever happens again i'll take it into a shop lol. i want to thank y'all for your in put on this THANKS.
chefred112
 Posted: 01-11-2013, 02:11 PM
chefred112's Avatar
Valdez Racing Team
City: Tracy, CA
State: CA
View This User's Timeslip View This User's Dyno Entries
Post #7
was that the problem? could you tell it was leakin from there? yea, i've done that many of times taking my tranny out on my back..
--- Fast Freddie ---05 Hemi QC 1500 2wd (230,000+ on odo)
2005 Dodge Ram 1500 SLT: 12.100 @ 113.960 MPH
12.93 @ 101 na
12.10 @ 113 sprayin
If you don't stand behind our troops, feel free to stand in front of them.
Proud Member of the White Truck Club (#30)
Part number for the 1 ton tranny cooler is 52029089AB
Performance mods: Yes...
vietnam67
 Posted: 01-11-2013, 02:30 PM
State: CA
Post #8
i first i did not know where it was leaking. i really thought it was the trans because of where the oil was coming out from the bottom of the trans bell housing where it was connected to the engine, but then i check the engine oil dip stick and saw i was low on oil so i put two and two together and knew that it was the rear main seal was leaking out through the bottom of the trans bell housing gasket. i bought a manual for the truck and from the info on here i got some great info to do it myself. and the rest is history lol.
chefred112
 Posted: 01-11-2013, 06:47 PM
chefred112's Avatar
Valdez Racing Team
City: Tracy, CA
State: CA
Post #9
hmmm..nice to know..I'll have to smell the fluid at bottom of bellhousing and see whether thats tranny or motor oil...where in Cali are you?
12.93 @ 101 na
12.10 @ 113 sprayin
rear main seal spun360 2G Dodge RAM - Drivetrain Talk 0 10-22-2009 05:12 PM
Rear Main Seal zogg Dodge Ram Truck 1st Gen (88 - 93) Forum 0 09-20-2009 08:19 AM
Rear main seal Ripjaw 1G Dodge Durango General Talk 0 08-18-2009 05:35 PM
Rear main seal ?'s dodgeneonACR98 Dodge Neon - Performance Talk 11 07-17-2005 05:15 AM
Rear Main Seal Scoeri 2G Dodge RAM - General Talk 1 01-04-2005 09:33 AM
