Fan belt squeal - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 11-25-2004, 09:17 AM Thread Starter
coachholland
Backwoods Hillbilly
coachholland's Avatar
Fan belt squeal
I recently replaced the fan belt after it started squealing and noticed some cracks in it, so it was time to change out. It's been fine, but recently we've been getting a bit wet around here and the squeel is back. The D has that automatic belt tensioner, however I'm wondering if this can be adjusted or what can be done to get rid of the squeal. It's embarrassing going up to a ride that nice and starting her up. I want to turn heads based on looks, not on some squawking noise!
2005 Durango Limited Hemi Bone Stock for Now.
Previously:
*DodgeTalk.com 318 Enthusiast Member #(5)*
1999 Durango SLT 4x4 5.2 V8 Light Driftwood Satin
Engine and Exhaust Mods
Mopar Performance PCM. 360 Air Intakez Power Shot w/ heat shield. DynoMax Super Turbo exhaust. Autolite Platinum 3923 Plugs. 180 T-Stat.
Interior Mods
EVS II Plus Security. Upgrade interior seating and door skins to leather. Replaced cassette w/ factory CD/Cassette then replaced w/ Pioneer DEH-45DH. Pioneer speakers. Powered MTX Thunderform. Dynamat Xtreme on all doors. APC White Face Gauge.
Exterior Mods
Front windows 20% tint. Ventshade window air deflectors. Blue Xenon headlights. Street Scene Grill Inserts. Diamond Cut Headlights and Corners. Altezza tails. Chrome grill. Chrome Bumper w/ stock valance. Polished Billet Locking Fuel Door. Mirrored Ram's head front license plate. Ram's head rear window sticker. Installed OEM fog lights. Polished stainless steel nerf bars. Chrome rear differential cover. Fender flares upgrade.
Wheels and Suspension
Monroe Sensa-Trac shocks. Drilled and slotted performance brake rotors. Aluminum to alloy wheels upgrade.
To Do List:
Custom Striping (To be installed). Fastman TB. Mopar Performance M1 Intake. Anodized Engine Accents. Performance Headers. Chrome Wheels.
Replacement Maintenance and Repairs:
Rear speed sensor. Window motor. Greasable upper ball joints. Water pump. Goodyear Wranglers. Mopar plug wires.
coachholland is offline
post #2 of 13 Old 11-25-2004, 10:55 AM
Almond Pale Ale
Patriot....
Almond Pale Ale's Avatar
could be the bearings on one of the pulleys?
I use the Goodyear Gatorback belt - it has grooves to allow flex and eliminate noise
2004 Ram 2500 4x4 SLT, 305/555 CTD, 48RE, QC, LB
Intake: aFe Stage I intake, aFe Torque Tube Exhuast: IMCO HD performance muffler Drivetrain: PML rear diff cover, PML Tranny cover, Bilstein shocks Power: Diablosport Power Puck set on 60hp/100tq Fluids: AMSOIL front to back
Almond Pale Ale is offline
post #3 of 13 Old 11-25-2004, 11:35 AM Thread Starter
coachholland
Backwoods Hillbilly
It's definitely the belt, not the bearings. Mind if I ask where you picked up the gatorback belt?
Previously:
Interior Mods
Exterior Mods
To Do List:
post #4 of 13 Old 11-25-2004, 11:46 AM
B1G BLEU
WORLD'S GREATEST TRUCK
B1G BLEU's Avatar
It's probably your belt tensioner. Try a little wd-40 for a temp. fix.
Paul
02 Durango (build 11/01) SLT┼ AB/BLACK INT 4.7L NGC 45RFE PT3.55 LSD 4X4 - Superchips 3715 Performance - Sensatracs - Chrome Nose - Carriage Works Billet Grilles - APC Clear Corners - Infinity 6022i's w/stock tweeters - - Hidden Hitch - Silverstar 9007ST's - K&N high-flow 33-2175 air filter- TFP Chrome Handles - 33K Miles - (MB Gunner Chrome Wheels + General Grabbers wintering in basement) Hammered blue factory rims
Wife's Ride : 2006 Grand Caravan SXT INFERNO RED
Work Ride : 2009 Ford Edge SEL
Daughter's Ride : 2011 Jeep Compass Latitude
Son 1's Ride : 2012 Nissan Altima S Coupe
Son 2's Ride : 2006 STi Stage 2 Grandma Gray (kinda mine, too
B1G BLEU is offline
post #5 of 13 Old 11-25-2004, 02:40 PM
rockadaous
Keystoner
rockadaous's Avatar
I have a gotorback too. picked it up from autozone. I think they run arond $30. like bleu said hit the pulley's with WD-40
rock
99 SLT+ 4X4 (5.2/318 & 44RE trans)
Patriot Blue (3.55 axle ratio)
Interior mods
APC rev glow gauges*Lotek Gauge Pod w/APC gauges*Nu-Image A/C & light panel*Redline shifter*Pilot titanium mesh pedals*Nu-Image gauge bezel*dodge logo door sills*blue jel light covers*Phoenix imaging interior
Exterior mods
Keystone kit*Cervinis SS Hood*Keystone Spoiler*Billet gas door*Altezza tail lights*Diamond cut euro headlights & parks*SS speed grille*3A Racing fog lights*APC M3 mirrors* MB Motoring Smoothies 20X10*Goodyear Eagle GT II 275/45/20*Pilot billet antenna*chrome differential cover*shaved roof rack*vent visors*APC bulbs*smiley grill*reflex shocks*drilled & slotted rotors*hawk HPS pads*TFP handle covers*2" drop"debadged
Engine mods
Intense performance stage II CAI w/9" big mouth filter*mopar valve covers*TD billet engine caps*180 T-stat*IAT Sensor Mod*GSport radiator hose*Goodyear gatorback S-belt*Flowmaster 40 series muffler*Dual exhaust*synthetic fluids*yellow loomz*brass cap & rotor* BP billet fuse cover*AL 3923 plugs*
rockadaous is offline
post #6 of 13 Old 11-25-2004, 03:40 PM
Neil F.
Neil F.'s Avatar
I hit everything with WD (pulleys, belt) I've had off and on cold start squeel.
99 Durango 5.9, FT 4x4, IP stage III w/ K&N air hat, M1, MOPAR PCM, Fastman TB, 1.7 RR, JBA headers, Borla cat back, Martin Saine valve body, Hotchkis swaybars, Blistein shocks, lowered 2" Black Rhino Kenya wheels, 246. 7 RWHP, 319 TQ
Neil F. is offline
post #7 of 13 Old 11-25-2004, 04:31 PM
Ugg
The A#1 Original!
Ugg's Avatar
Coach:
It's more than likely your belt, but did ya get it on thight enough in the 1st place? You should have less than 1/8" play in it. Old trick, use sandpaper to rough up belt & pulleys. Also try some belt dressing.
Later
Ugg
The One, The Only, The A#1 Original
The Original DOC Black Sheep #1.
Signature Police Officer # 013
2001 Durango R/T, Patriot Blue with All factory options but block heater.
*Fastman TB. *JBA Headers. *DynoMax Flo Thru Muffler. *Hitch Mounted 55 Watt Back-Up Lights. *Yellow Krypton Fog Lights. *Nu-Image Flame Glo Gauges. *Orange Flame Seat Covers. *Autolite 3923 Plugs. *Remote Start-Up & Alarm. *Country Craft Brushed Aluminium Grille & Billet. *Blue Indiglo Glo Gas And Brake Pedals. *Lund Sun Visor. *LUND Rear Window Deflector. *Removed Factory Running Boards. *Rancho RS 9000 Shocks. *Ken Thompson Wheel Well Covers. *All Steel Skid Plates Installed To Replace Plastic Skids. *IP Stage II Cold Air Intake. *Rosewood Dash Kit by Trim King. *Cargo Liner by CargoLiner. *WeatherTech Vent Visors. *T-Bars cranked Up 3 Turns. *Extra Leaf Added Per Side On Rear Springs, *Rams Head Tail Light Covers. *55 Watt Back-Up Light Bulbs (installed in normal location for MORE light). *Go Rhino Hitch Step. *Ash Tray & Cup Holders Mounted by 2nd Row Seats. *American Flag
& Black Ribbon Mounted on Antenna. *Lest We Forget, Fuzzy Dice. *Oh, & A Little White German Shepherd On The Dash, Howling.
PENDING REPLACEMENT
*Kumho Venture AT 275/60x17 Tires (WARNING, these tires are GARBAGE!
*Replaced with 15" Yoko Geolander's.
To Be Installed One Day Soon, I Hope
*Blue Engine Dress-up Kit, Made By Toucan Industies. *Jimmi Jammers. *Strobe Lights fore & aft.
The Beast
*1942 WC 53, 3/4 ton Dodge Carryall. *#152 of 8400 Made. *318 V8. *5 spd Trans. *4:86 gears. *Full Time 4WD.
Ugg is offline
post #8 of 13 Old 11-26-2004, 01:27 AM
B1G BLEU
B1G BLEU's Avatar
Sounds like you guys need a helper to start the D whenever cold while you listen underhood. Good luck.
Paul
B1G BLEU is offline
post #9 of 13 Old 11-26-2004, 09:57 AM
calcnerd
i had the same problem. ended up replacing the tensioner. lubing it worked for a day or two. what happened was mine got seized & didn't hold much tension. cost me about $70 for a new one.
2000 Durango 5.9
chili pepper red
Current mods:
- pro-zen intake
- throttle body spacer
Future mods:
- diamond clear corners
- LED turn signal/markers/etc
- headers & dual pipes
- hood
- grille
- 3" suspension lift
calcnerd is offline
post #10 of 13 Old 11-26-2004, 12:26 PM Thread Starter
coachholland
Backwoods Hillbilly
Of course today it dries out and starts up fine with no squeal at all, so it looks like it's only going to do it when it is damp out. Next time that happens, I'm going to do all three... WD-40, rough it up and apply some belt dressing.
If that doesn't work, I'll move on to the tensioner. Thanks for that info and the pricing calcnerd and thanks to everyone for their suggestions.
Previously:
Interior Mods
Exterior Mods
To Do List:
post #11 of 13 Old 11-26-2004, 12:30 PM
Almond Pale Ale
Patriot....
NO Belt Dressing...it's a tacky, gooy mess. I did it to my 95 Dak...big mistake. Try your first two options. I got my Gatorback belt at Autozone in Spring Lake, NC, about 3 miles from Rocks house.
post #12 of 13 Old 11-26-2004, 12:35 PM Thread Starter
coachholland
Backwoods Hillbilly
*scratches that option*
No goo underneath the hood. Don't need crud flying everywhere.
Previously:
Interior Mods
Exterior Mods
To Do List:
post #13 of 13 Old 11-26-2004, 01:40 PM
Almond Pale Ale
Patriot....
My sway bar bushings don't squeak when it's wet, almost the reverse of your belt squeal!
