09 Journey SXT AWD Ball Joint Replacement - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Vehicle Forums > Dodge Journey Talk
GreaseMonkey80
  09 Journey SXT AWD Ball Joint Replacement - Posted: 01-01-2013, 09:27 PM
GreaseMonkey80's Avatar
City: Germany
State: OTHER
Post #1
My front lower ball joints are worn and need to be replaced to pass my vehicle inspection. Does anyone know how to do this or ever done it them selves? I've done ball joint replacements before but on a much larger scale. I just want to know what Im getting my self into on this job because damaging a part CANNOT happen. I am a US Soldier stationed overseas and parts are not readily available. Ordering parts online is the most affordable for those of us overseas.
dodgefan360
 Posted: 02-04-2013, 09:26 PM
dodgefan360's Avatar
Platinum 2K R/T
City: Kitchener
State: ON
Post #2
If you haven't managed to change them yet, Dodge is notorious for riveting ball joints in place. You'll have to drill them out, replace with bolts and of course the new joint. I've never done ball joints myself but have assisted and they can be troublesome. I doubt you'll break anything, as I didn't when a friend helped me out with one of my old cars.
2000 5.9 R/T - Platinum
140,000m (225,000kms)
Amsoil in the diffs, transfer case and engine - Hughes Plenum - Fastman 52mm TB - K&N FIPK - SCT tuner currently set at 87 octane - Magnaflow 15659 exhaust
My 2000 R/T
2000 R/T Factory service Manual
GreaseMonkey80
 Posted: 02-05-2013, 04:44 PM
City: Germany
State: OTHER
Post #3
I got them replaced finally! They were pressed in but I was able to remove them using a large c clamp a 3inch deep well impact socket and a cheater pipe. I used the same tools to repress the joints back into place! You do have to remove the rotor and heat shield to gain access and you can just hang the caliper from the over springs thanks to 3-4in flex tubes at the end of the brake lines. The suspension system on the Journey is very similar to the Jeep Wrangler!!! Be sure to put lock tight on the caliper mounting bolts before reinstalling. This can be fairly simple to do especially if you have a friend lending you hand. My friend and I completed this job in just under 2hrs. Could have gotten it done in half the time if we had figured out the c clamp and socket trick before hand. After the job is completed, pump the brake pedal until pressure returns before moving the vehicle...thanks to self bleeding system. If you are as lucky as I was, an alignment was not needed after doing a road test at city speeds...not to exceed 50mph. Thank you everyone for your suggestions. Without them I would not have had the courage to attempt this on my own.
ball joint replacement help sony224422 2G Dodge RAM - 4X4 Talk 5 09-03-2009 06:25 PM
Ball Joint Replacement eurocars Dodge Caravan/Grand Caravan Talk 2 04-19-2009 12:53 PM
Ball joint replacement tx04hemi 3G Dodge RAM - Sport Truck Talk 15 10-09-2008 11:02 AM
Ball Joint replacement jgregory 3G Dodge RAM - 4X4 Talk 7 01-26-2007 06:08 PM
Ball joint replacement rammyfan Diesel Tech 12 09-13-2004 07:02 PM
