Misfire, losing coolant, and smoking - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 2nd Gen (94 – 01) Forums > 2G Dodge RAM - General Talk
thechief
  Misfire, losing coolant, and smoking - Posted: 12-30-2012, 05:40 PM
Post #1
Hello and happy holidays. I am second owner of '99 1500 5.9l with 113,000, i bought it with 65,000 in '06. A year ago a code for a misfire on 8 came with no notice of performance problems, has maybe came up 4 times in that year. I did a tune up plugs, wires, cap and rotor as well as reroute the wires a few months before the code and replaced plugs after the code. A few months ago i replaced the water pump, due to a coolant leak and last week i replaced the coils and shocks.
Christmas at 4 am my cel starts flashing, a first. I stoped and checked oil and added a quart. The light remained on but stoped flashing. Symptoms were a rough idle, loss of heater. My temperature gauge is always at 1/4, in between the lowest temp and the 210 middle mark. That night and since it will fluctuate between that 1/4 and 210, never over. I have never seen my truck run at 210 though, ever.
I got home and had 3 codes p0300, 304, 308. Random/multiple misifre, misfire 3 and 8 cylinders. I replaced cap, rotor, plugs, and thermostat. Nothing was fixed including temperature and heater, which i was thinking was a seprate issue. She has started smoking at startup, blowing excesive amounts of white smoke. It looks just like a typical cold winter white smoke but too much for too long, but it does stop. Im losing coolant with no visible leak and my oil is brown.
Head gasket leaking coolant into cylinder causing misfire and white smoke? I am very amateur, and this is assumption on research. I dont even know what the head is. Sorry for long post id appreciate some thoughts.
Cliffs: Misfire, white smoke, brown oil, losing coolant, heater doesnt work
dodgensince74
 Posted: 12-30-2012, 07:57 PM
Post #2
sounds like you have a bad head gasket, white smoke=burning coolant, you are leaking coolant into your cylinders and also into the engine where it is mixing with your oil, not good for the bearings. Looks like you will need to remove your head(s) to replace the gaskets and have your heads checked for cracks.
01 1500 5.9, Q/C, L/B, 4X4
Tanue cover
Super chips
Magnaflow S/i-D/o
K&N cai
Eagle alloy 102's
BFG LT285/75r16 A/T's
michigan roman
 Posted: 12-30-2012, 09:03 PM
michigan roman's Avatar
State: MI
Post #3
im no mechanic but work on my own vehichles because im not a millionaire whom can pay dealerships to but seeing you might have to get into some engine disassembly i figured ide throw this idea out : ive got same truck and every time i get into engine im wishing it didnt have the ac system as it just gets in the way a bunch of times and here in michigan i never use it . well seeing you say your not a mechanic neither figured you might not know but you can buy a pulley for less than 50 to replace ac pulley and remove entire ac system if you dont need it . im doing it next summer , priced the pulley at auto zone but cant recall part name right now . no doubt most guys here no it though . and also if your not up on it many say the intake manifold gasket or whatever exact term is should be replaced as they tend to go bad on these
Moparite
 Posted: 12-31-2012, 10:53 AM
Post #4
Sounds like you have multiple issues. The first is the plenum gasket. It causes a leak between the crank case and the intake causing the misfire and oil loss/burning. I would suggest getting the Hughes kit.
http://www.hughesengines.com/Index/p...d&partid=27091
When you replaced the water pump did you put silicon on the bolts that run into the crankcase/timing chain cover? This could be where you are getting coolant in the oil. Is the issue with the temp gauge the sender or the gauge? Since you have all this other work to do get a new sender and put it in. I think the no heat issue could be the blend door but i'd get the all the other stuff done first and then figure out the heat issue.
thechief
 Posted: 12-31-2012, 01:11 PM
Post #5
How do I get all the water and moisture out of my motor? And does the engine have to come out to get to the head and gasket? Is the head and gasket the only way for coolant to enter the motor? And would this cause my temperature to fluctuate and heater not work. Does there need to be diagnosing or is it clear its the head
Thnx for the replies, no I didn't silicone the bolts. Would this cause the white smoke. It appeared the leak was coming from the timing gasket but I just changed water pump and the leaked stopped.
dodgensince74
 Posted: 12-31-2012, 04:49 PM
Post #6
you should do a compression test and a radiator leak test, you can rent both tools at the parts store on thier loaner tool program. You will have to change the oil to get the water out of it, do not run it until you do. When you do both test remove your plugs and then do both test.
Tanue cover
Super chips
Magnaflow S/i-D/o
K&N cai
Eagle alloy 102's
thechief
 Posted: 01-02-2013, 07:31 PM
Post #7
I rented both tools and changed the oil. First i did a pressure test on coolant system with the plugs in and didnt lose pressure, the i started the truck and let it warm up for the compression test. I took out all the plugs and connected to the #2 turned it over and got sprayed by coolant out of the #4 plug hole. I stopped compression test and redid coolant pressure test with the plugs out and water/coolant came out of the #4 plug. Presure was pretty steady though. I didnt finish the compression test.
Woodstock
 Posted: 01-06-2013, 01:40 PM
Woodstock's Avatar
Woodstock
City: Piney Flats
State: TN
Post #8
Remove the heads and see if you have a cracked head or heads... or, be one of the very lucky few with only a blown head gasket.
2000 1500 Sport 5.9 4X4 QC 46re w/TFODjr
SCT by hemifever, 4.10 Gears, Stainless Steel Headers
HellBent Steel leveling kit, 33X12.50X16 Super Swamper TSL Radials
nh5
 Posted: 01-06-2013, 04:03 PM
nh5's Avatar
State: NY
Post #9
Probably need heads, just about 99% sure they cracked all the magnums suffered from cracks between the seats. A pair of new heads from odessa on ebay should be fine. Got a pair of felpro Q1008 head gaskets, a new head bolt set and I was back up and running. Also get the hughes plenum kit perfect time to do it will be when you have the manifold off for the heads. Got 3,000 miles since new heads now.
I determined my heads one head was bad since it was leaking coolant down the back of the block sporadically. Then once I got them off they were disgusting inside, rust around the valve seats, some valves were white others covered in rust. Also on cold start up truck would idle erratically and miss till warm.
02 Ram 1500 QC 4X4 Sport 5.9L Magnum, EQ Iron RAM Heads, 52mm Fastman TB, ebay Shorty Headers, Magnaflow 12576, SRT Hood, 180deg Stat, Superchips 3815, Taylor Thundervolt Wires, Cutout, Detroit Tru Trac & 3.92's, rvinyl'd tail lights, led's all over, leds in tow mirrors, Polk audio's in the dash, center removed. Doors have kenwoods. New freeze plugs and more repairs than mods.
Next, Exhaust, 17rr's 2200 stall TC
http://img245.imageshack.us/img245/1943/009sq.jpg
thechief
 Posted: 01-10-2013, 10:33 PM
Post #10
Thanks for the replies. Been busy trying to work as much as possible and havent time to fix any thing. Ive been looking at those eq heads http://www.ebay.com/itm/NEW-EQ-IRON-...item2322bdb54d
Getting one with springs and stuff is the best option? and im curious about the bigger 2.02 intake, does it need supporting mods and why do they ask about cam? I have few hundred more to spend maybe 6 while in there and dont know what to do, the trucks power isnt very impressive.
Is it worth investing in this motor at 113,000 miles?
dodgensince74
 Posted: 01-11-2013, 07:06 AM
Post #11
if you replace the heads on this motor you can use them on your next build, they ask about the cam so they place the correct springs on the heads
Tanue cover
Super chips
Magnaflow S/i-D/o
K&N cai
Eagle alloy 102's
thechief
 Posted: 01-14-2013, 02:01 PM
Post #12
What do you guys think of putting new heads on a old bottom end?
Woodstock
 Posted: 01-15-2013, 11:04 PM
Woodstock's Avatar
Woodstock
City: Piney Flats
State: TN
Post #13
Do it.
dodgensince74
 Posted: 01-16-2013, 11:20 AM
Post #14
new heads will not hurt the short block, it can actually help if the old heads are bad or don't flow right.
Tanue cover
Super chips
Magnaflow S/i-D/o
K&N cai
Eagle alloy 102's
Woodstock
 Posted: 01-16-2013, 04:48 PM
Woodstock's Avatar
Woodstock
City: Piney Flats
State: TN
Post #15
spun360
 Posted: 01-16-2013, 05:14 PM
spun360's Avatar
City: Pottstown
State: PA
Post #16
they are nice heads! i use them. mods or not 2.02 should be ok. dont use cheap head gaskets though. felpro 1008 is a decent set. always retoque again after 1000 miles!
parts for sale
$125: 210lb double and dampener valve springs .550 lift
$20 : new, standard oil pump
$15 : new, super strength moog #377 frt axle hub universal w/ grease fitting
prices include shipping (for residence of the US)
cheep
shoot PMs my way
'05 Caravan 3.8L losing lots of coolant. Pressure Tests Good. Help Anquan7 Dodge Caravan/Grand Caravan Talk 8 12-16-2011 01:57 PM
losing coolant Tsweat73 4G Dodge RAM - General Talk 2 07-13-2009 11:31 PM
losing coolant Tsweat73 3G Dodge RAM - General Talk 1 07-13-2009 06:05 PM
Losing Coolant??? Trailnut 2G Dodge RAM - General Talk 11 11-24-2007 05:43 PM
Losing Coolant Messer 2G Dodge RAM - General Talk 10 07-10-2005 09:16 PM
