New wheels, and 4.56's installed - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 31 Old 12-29-2012, 01:00 PM Thread Starter
JFM-jr
JFM-jr's Avatar
I picked my truck up this morning i had a set of Fuel Boosts 17X9 +20MM offset and Nitto Terra Grapplers 305/70/17 installed. They look really good and only poke out a tiny bit further than the stock wheels did. No rubbing or fitment issues it's a 34 inch tire and still retained the E load rating (10 ply sidewall) as I tow a camper with it. I also had a set of Chrysler OEM 4.56 gears installed along with PML front and rear differential covers (great company great products I have their trans pan as well). Everything went well gears are quiet I just gotta reflash the ecm with my Superchips for the gear and tire change so the speedo reads correctly. I also scored a Magnaflow catback off Craigslist it was brand new in the box for 250 bucks. Heres before/after of the wheels. Contemplating a leveling kit next.
09 Hemi powered Ram QC 2500 Sport
Fuel Boost rims 17x9 +20MM
OEM 4.56 gears
SuperChips Cortex 3950 (1449666)
JFM-jr is offline
post #2 of 31 Old 12-29-2012, 03:45 PM
mirada80
2005 Hemi Ram
mirada80's Avatar
Quoted: 2 Post(s)
Good choice in wheels, truck looks great. I say do the level. The rakes more noticable now after the news rims and tires.
2004.5 2500 QC SB 4x4 5.9 H.O.
MODS | Studded | Cold Air | 5" Turbo Back | Fass Fuel | Tinted Windows | HIDS
03 Silver Dodge Ram 1500 4x2 5.7 Hemi
MODS | Home Brew Ram Air CAI | Superchips 3815 | Comp Custom Grind Cam | 6.1 Springs And Pushrods | 06+ Coil Conversion | High Idle Mod | Summit Racing 25% Underdrive | Circle D 3200 245mm converter l TMR Mod | Sonnax Line Pressure Booster | Pacesetter Longtubes l Matching Off Road Y-Pipe l Magnaflow 14" SI/SO muffler | Electric Fan | 180 Stat | Walbro 255 With 05 Sending Unit | Auburn Limited Slip| B&M ProStick Ratchet Shifter | Custom Gauges | Custom Shifter Surrond | Ventvisors | Debadged | Tinted Tails | Tinted Third Brake Light | Smoked Headlights | 5000k HIDS in heads | 3000k HIDS in fogs | Roll Pan | Shorty Antenna | Custom Painted Grill | Street Scene Bumper | Poor mans 2/4 Drop | Dipped 17" Ram SS/T Wheels With Radials | 2009+ Chrome 20's | And A Little Bit of ZEX
BEST 1/8-Motor-8.43@80.52__Spray-7.85@89.12
BEST 1/4-Motor-13.38@98.9_Spray-12.27@110.42
BEST 60'-1.75
SOLD05 Patriot Blue Pearl Dodge Ram 1500 4x4 5.7 Hemi
mirada80 is offline
post #3 of 31 Old 12-29-2012, 06:43 PM
JonRoc
Creature Of The Wheel
JonRoc's Avatar
Wheels look great on the truck, Fuel makes some nice black wheels.
"Code Red" 07 Ram RC 2/4.5 2WD 4.7
McGaughys Deluxe 2/4.5-Two Toned OEM SRT10 Hood & Wing-TMD Bumper Cover
20" Black SRT10s-EFX Rollpan-GrillCraft MX Grille-Flame Red Heads-DMH ECutout
SC3865 w/ Trans Upgrade-Airaid CAI-70mm TB-MF YPipe-08 Intake Manifold
Radio Bez & Fuse Box Hydrodipped In Red Skulls-Misc Pieces In Carbon Fiber
NS'ed Sonar Smoked LED Tails & Recon 3rd-Red Grille LEDs-15% Tint-Nuvi 50LM
SiriusXM Radio-Sonnax Booster-Powerwire-Tailgate Bar-6" Stubbie-BT Emblem
Jet Stream Scoop-Cree 9W Rev LEDs-3W Int LEDs-Mopar Batt Shield
Bosch Icon Blades-Hawk HPS Pads-Belltech Street Shocks
JonRoc is offline
post #4 of 31 Old 12-29-2012, 07:47 PM
MonsoonMike
Site Administrator
MonsoonMike's Avatar
Quoted: 231 Post(s)
Looks good. Love the tire choice. I'll be getting some as well very soon.
If you do alot of towing, maybe not level it...
::2014 Ram 2500 CTD Crew Cab Granite Crystal Metallic::
My Vehicle Build =
MonsoonMike is offline
post #5 of 31 Old 12-29-2012, 08:23 PM
wixthedog
That guy
wixthedog's Avatar
Quoted: 36 Post(s)
Sweet! If you level it put some airbags on her so your nose up when towing your camper around.
Mike AKA: WixTheDog
2015 Dodge 1500 Crew Cab Laramie - 4x4- Deep Cherry Red
Stock...
2014 Dodge Durango R/T - 2WD - Redline2
Stock soccer mom car
2014 Mega 2500 = 2014 Crew Cab 3500 = 2013 Crew Cab 3500 = 2007 Quad Cab 2500 = 2003 Quad Cab 1500
wixthedog is offline
post #6 of 31 Old 12-29-2012, 09:01 PM
86bcook
Skid's Customz
86bcook's Avatar
Quoted: 3 Post(s)
Looks real good.
2005 RCSB Hemi
THE SHOW
Completely Repainted, ABC Exclusive Cowl Hood, PURE Custom Tailgate Spoiler, Debadged!!, Honeycomb Grille with R/T elblem, 2/4.5 McGaughys drop w/ Chrome SRT-10 22's, OEM SRT-10 Pillar w/Autometer Tranny Temp, MRK Group silver interior package , 5% tint all the way around, 8000k hid's headlights and fogs, All led bulbs (int/ext), Power Show-N-Go Retractable, License Plate, DEE ZEE Tailgate EZ Down Strut Kit
THE GO
Comp 273 Cam, 6.1 valve springs and push rods, SCT 9550 Hemifever Tune, Pacesetter Headers and off-road x-pipe, Dual 14 inch magnaflows and exit out like the 2010's. With notched rear bump!! Bills custom intake w/ 1in throttle body spacer, Airram Scoop, NGK 5306's, Taylor Red 8.2 Thunder Volt Shorty Wires, Jet 180 Thermostat, Motive 4.56 gears, Powerstop drilled/slotted rotors with hawk pads, Prothane Sway Bar Bushings, Prothane Rack and Pinion Mount Bushings,
86bcook is offline
post #7 of 31 Old 12-30-2012, 12:14 AM
05SlvrBuLLet
05SlvrBuLLet's Avatar
Looks sweet! Definetly level it you will love it! I gotta admit I am a bit jealous about the gears....
05SlvrBuLLet is offline
post #8 of 31 Old 12-30-2012, 12:43 AM
ramjet1
Official HEMI SPORT Owner
ramjet1's Avatar
Quoted: 16 Post(s)
good judgement
Flame Red 2006 Dodge Ram HEMI Sport 2 WD Quad Cab, AMSOIL XL 5w20 Synthetic Engine Oil. K&N Performance Gold Oil Filter, Fumoto Oil Valve, NGK 5306 Copper Spark Plugs, OEM 160 Amp-HD Alternator, SharaDon Third Stage Transmission with Amsoil ATF, PML Extra Deep Trans Pan, Edge 2600 Torque Converter, AutoMeter Trans Gauge, OEM HD Trans Cooler, Custom lettered & Powdercoated RamHammer Intake, Jet 180 Thermostat, Zerex G-05 Coolant, Flex a lite Black Magic 180 X-treme Electric Fan With Flex a lite Variable Speed Control Module Kit, Aeroforce Interceptor Scan Gauge, Moe's Performance 87mm Throttle Body, Jet-Hot Coated Doug Thorley Mid-Headers, Stage 8 Locking Header Bolts, Custom Powdercoated Moe's Performance Shroud Delete Kit, Cherry Bomb VORTEX Muffler Single In/Dual Out, Magnaflow Y Pipe, DiabloSport Predator U7137, SRT-10 Gauge Pillar, Keystone Good Hood, OEM Tonneau with SRT10 Replica Sport Wing, OEM Ground Effects, GroundForce 2/4 Drop, 22 inch Black machined SRT-10 Replicas, 22 Inch 305/45/22 Yokohama Parada Spec-X Tires, Premium Dimple, Drilled & Slotted Brake Rotors by BrakePerformance.Com, EBC Supreme Green Front Brake Pads & Greenstuff Rear Brake Pads, Hellwig Anti-Sway Bar, Shaved Tailgate, Sir Michael's Roll Pan, PlasmaGlow Night Raider Tailgate Bar, Street Scene Electric Mirrors, Powdercoated Wipers & antenna, Debadged, Tinted Windows with custom rear window Ram Logo with Flames, Flame Red Cowl & Door Handles, Flame Red Eyelids, Custom Exterior Sunvizor, Anzo Aftermarket Headlights, Ram Daytona Rear Light Covers, Custom Leather Interior From LeatherSeats.Com, WHEELSKINS Leather Steering Wheel Cover, BedRug, EATON/Detroit Tru Trac with YUKON 4.56 Gears, Concept Pattern Engineering Differential Cover-CP4062, AMSOIL Severe Gear 75w-140, Jimmy Jammers, Powdercoated Upper & Lower Grilles, HELLA SuperTone 118db 12 Volt Horn Kit, Duralast Platinum Battery, Clarion CX-501 Double Din/HD Radio/Bluetooth/CD Player Unit, 8 speaker POLKAudio Sound System including 2 Polk amps, Fox Subwoofer Box, Weedahoe's Custom Painted & reworked Double-Din Bezel/Painted door panels/Painted AC knobs, Griot's Garage Detailing Products, NEW MODS COMING SOON to a Ram near me........lol
ramjet1 is offline
post #9 of 31 Old 12-30-2012, 02:10 AM
mulinjohe
mulinjohe is offline
post #10 of 31 Old 12-30-2012, 07:56 AM Thread Starter
JFM-jr
JFM-jr's Avatar
Thanks guys the gears were a tough call becuase of the obvious reason of cost. The 1st shop I went to is a well known local truck shop and they wanted almost 3K and were gonna use aftermarketYukon ring and pinion. Not that aftermarket stuff is bad but I am 42 years old have spent my life modding just about everything I have owned and have learned nothing ever fits like factory components. If OEM is available spend a few extra bucks and get it. I wanted the Chrysler Power Wagon ring and pinion so I was looking at over 3K from this guy. I found another shop even closer to me in fact a mile from my job by recomendation and I am sooo glad I did. This place is GREAT he charged me 2K for the work and used OEM AAM gear sets. 1K dollars less is ALOT of scratch I bought front and rear PML diff covers and was still ahead by over 500 bucks. He steered me in the right direction on wheels and tires so I had him do everything. This guy even painted the brake rotor hats and calipers black before he puts the wheels on I know not a huge deal but small attention to something like that says alot. Anybody on Long Island ever needs work done shoot me a PM I will give you the name and number of this place absolutley recomend him. I think i'll give him a call monday for a level kit you guys all suck lol. Hey at least I have a reason to tell the wife for it "But honey look here i'll show you my thread all the guys on DodgeTalk say to do a leveling kit". It was raining yesterday i'll take some better shots today and post them up later.
OEM 4.56 gears
JFM-jr is offline
post #11 of 31 Old 12-30-2012, 10:13 AM
wixthedog
That guy
wixthedog's Avatar
Quoted: 36 Post(s)
You are lucky guy for finding a good shop who puts out quality work! I found a place that specializes in Cummins thats north of Houston, they will be putting my clutch in on Thursday. They are highly recommended and I hope my experience is the same.
Tell your wife you deserve it, you've been a good boy all year.
Mike AKA: WixTheDog
Stock...
post #12 of 31 Old 12-30-2012, 12:07 PM
ramjet1
ramjet1's Avatar
Quoted: 16 Post(s)
Yeah...go ahead and tell her what we all said.......women understand these kind of issues...........they are sooooooooo understanding......................NOT!!!!
ramjet1 is offline
post #13 of 31 Old 12-30-2012, 01:05 PM
JonRoc
JonRoc's Avatar
Just tell her that if you don't get the leveling kit that a wheel could fall off & cause you to wreak.
JonRoc is offline
post #14 of 31 Old 12-30-2012, 02:51 PM Thread Starter
JFM-jr
JFM-jr's Avatar
More pics for you guys the trucks a lil dirty already we got some snow last night and the good 'ol NY salt is on the roads and the truck.
Here is a side shot kinda shows how far out the tires stick with a 9 inch rim with a +20mm offset
Heres the width and height side by side a 305/70/17 vs a 265/70/17
PML differential covers
Magnaflow Catback
Lastly another shot of the wheel and truck
Hope you guys all have a Happy New Year
OEM 4.56 gears
JFM-jr is offline
post #15 of 31 Old 12-30-2012, 11:33 PM
-Arana-
-Arana-
-Arana-'s Avatar
Quoted: 2 Post(s)
Really nice setup
2012 Express Hemi Ram
Flowmaster super44/Magnaflow Y pipe/Vararam Ram Air Intake/Belltech SP 2/4 drop/U-2 55 24s/5 inch Pypes black tips/1400 Pioneer DVD/Xtant 5Channel Amp/Kicker CVR 12/Pioneer 6x9s all around/ Viper Alarm 5704/Rear View Camera/Smoked Taillights/Smoked 3rd Brake light/LED Reverse and Cargo Lights/Debadged/Custom Texans Badges/LED bulbs everywhere/Switchbacks/Black housing headlights/Tint/Eyebrow Tint/Mr. Norms roof spoiler/
2010 Jeep Grand Cherokee
Gone But not forgotten 2008 4.7 RAM
-Arana- is offline
post #16 of 31 Old 12-31-2012, 08:29 AM
ramminsilver
ramminsilver's Avatar
Looks great, congrats!
2004 DODGE RAM 2500 LARAMIE w/ THE HEMI - BLACK ON BLACK/GRAY LEATHER - 295/70/18 NITTO TRAIL GRAPPLERS - 18x9 FUEL BOOST 5.75" BS/+20 OFFSET - AEM BRUTE FORCE CAI -CUSTOM MAGNAFLOW CAT-BACK EXHAUST 14" SI/SO - MAGNAFLOW Y-PIPE - NGK 5306 SPARKPLUGS - DIEHARD PLATINUM BATTERY - RECON SMOKED CAB AND 3RD BRAKE LIGHTS - RECON FIRE AND ICE TAILGATE BAR - TOTAL LED CONVERSION FRONT TO REAR - BILSTEIN'S ALL AROUND - EXTANG FULLTILT TONNEAU COVER - ALPINE 9886 HEAD UNIT AND ALPINE MRP_M300 AMP - JL AUDIO 12w1v2 SUBWOOFER - AVITAL 4103 REMOTE START AND KEYLESS ENTRY - UNIQUE COATINGS FLASHTECH HIDS - 9007 6000K BI-XENON HEADS AND 9006 6000K FOGS - EZ-DOWN TAILGATE ASSIST - HUSKY FLOORMATS - SUPERCHIPS CORTEX 3950 w/ TRANNY TUNE - MOPAR REAR WHEEL WELL LINERS - BUSHWACKER EXTEND-A-FENDERS - TEKONSHA PRODIGY BRAKE CONTROLLER-AUTO METER FACTORY MATCHED TRANNY TEMP GAUGE
ramminsilver is offline
post #17 of 31 Old 12-31-2012, 09:06 AM
Ron380
Just a Comedian.
Ron380's Avatar
Great pictures, JFM!
2007 1500 SLT 4x4. 2-dr, short bed; 4.7l; 3.55 w/LSD.
SC 87 tune; 4" pvc intake; Magnaflow Y-pipe and muffler; Scangauge... oh, and new speakers!
-- More to come...
Ron380 is offline
post #18 of 31 Old 12-31-2012, 02:19 PM
ramminsilver
FYI, I put on Bushwacker Extend-a-Fenders on mine after I put my tires and wheels on and they cover up the added offset. Definitely keeps the truck a lot cleaner without all the added sling of road crap and mud on the side of the truck.
post #19 of 31 Old 12-31-2012, 03:22 PM
Shikity
Fueled by 1.21 jiggawatts
Shikity's Avatar
Those look great, (wheels, tires, diff covers and all) good choice!
.....Visual Mods: Yes.....
.Performance Mods: Yes.
Shikity is offline
post #20 of 31 Old 12-31-2012, 03:22 PM Thread Starter
JFM-jr
JFM-jr's Avatar
I like the OEM flares on the newer trucks. Does anyone know if they are available for 3rd gens?
OEM 4.56 gears
JFM-jr is offline
    4.56's getting installed monday bluedodge57 4G Dodge RAM - Drivetrain Talk 20 07-07-2011 05:27 PM
    4.56's installed...Not Really Impessed. prczx6r 3G Dodge RAM - Drivetrain Talk 38 06-24-2010 11:49 PM
    4.56's Installed Sprocket 3G Dodge Ram Performance Talk 25 04-22-2008 09:28 PM
    4.56's installed!!! Davidbee0233 3G Dodge RAM - Drivetrain Talk 40 02-17-2008 06:59 PM
    getting 4:56's installed jdetten 3G Dodge RAM - General Talk 32 02-17-2006 04:04 PM
