Performance Upgrade Questions - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 4th Gen (09 – Up) Forums > 4G Dodge RAM Diesel Talk
SoCal Hemi
  Performance Upgrade Questions - Posted: 12-28-2012, 05:48 PM
SoCal Hemi's Avatar
City: Riverside, California
State: CA
Post #1
I have just recently purchased a new 2012 CTD Mega Cab 2500.
I have been trying to research and review what components are available for this vehicle since I have always upgraded my vehicles I don't see this one remaining stock for long either.
My questions are which manufacturer's would you recommend for the EGR/DPF Delete kits, Air Intake Systems, Programmer and an Exhaust ? I have noticed that not many components are available for the 2012's for whatever reason.
I am really trying to avoid an exhaust system or upgrades that create an annoying drone noise. I would like for it to remain rather quiet if that's possible with the upgrades I have mentioned.
Thank you,
Michael
2012 Dodge Ram 2500 Mega Cab 4x4 - Laramie Equipment Package, 6.7L Cummins Turbo Diesel
Stock For Now ! ! !
2007 Dodge Ram 1500 Quad Cab 4x4 5.7L Hemi Sold !
ATI ProCharger 7 PSI, Diablo Sport Trinity, Magnaflow Catback Exhaust, Rancho Quick Lift Leveling Kit, Rancho RS9000XL Shocks In The Rear, Rancho My Ride Wireless Ride Controller, Eagle Alloy Wheels 17x9, BFG Mud Terrain KM2 35x12.50x17, Bushwacker Fender Flares, Black Powder Coated Billet Grille Inserts(Upper & Lower), Billet Tailgate Latch, Billet Flame Door Handles, Fox Acoustics Box, W/ 2 10" Kicker Comp VR's, MB Quart 1000w Amp, Pioneer 6x9 and 6.5" Door Speakers, Kenwood DNX 8120 Navigation, Hella's Behind The Grille & HID Kit For The Headlights and Fog Lights.
VINCH
 Posted: 12-29-2012, 12:24 PM
VINCH's Avatar
City: Lancaster
State: CA
Post #2
Thank you,
Michael
I would leave the engine/exhaust alone
#1 California's smog laws you get caught it is $10,000 fine
#2 Chrysler LLC will void your warranty if you do any of the listed performance modifications you listed
I am close friends with my service writer and he made it clear that I cant modify my 2012 3500 CTD like I did my Hemi and if I did my warrant would be toast. He said that Chrysler LLC is looking real hard at Mods done to CTD cause it has cost them $$ in years past.
Also why do you need more that 350 hp and 85#torque my beast has eaten everything I could throw at it no problems only thing you might gain is some MPG but is did not think it was worth the loss of 5yr 100,000 mile warranty
My .02
Red Neck White Hair Blue Collar
2012 Ram Crew Cab 3500 6.7 H.O. CTD 4x4 SRW
295/70/17 Nitto trail grappler tires
Pin striping by Bob Spina
SoCal Hemi
 Posted: 12-30-2012, 04:36 PM
SoCal Hemi's Avatar
State: CA
Post #3
I am well aware of the smog and warranty implications, I am more so interested in further increasing the fuel economy than the additional power and torque.
Stock For Now ! ! !
SikHemi
 Posted: 12-30-2012, 04:50 PM
SikHemi's Avatar
Mopar Or No Car
City: 08360
State: NJ
Post #4
Look into h&s. also 2nd gen manifold swap for sound
Sent from my iPhone using AutoGuide.com Free App
2012 Mineral Grey RCSB
33x12.50x20 Toyo Open Country Mt's
20 X 9 Fuel Hostage Rims
ReadyLift SST 2.5 & 1.5
K&N CAI
3" catback true duals w/ x-pipe
Tinted tails & 3rd
debadged
plastidiped grill & tailgate ram
stubby antenna
Line-X
Morimoto 5Five 6K heads & fogs
DieselWorkin
 Posted: 12-30-2012, 11:33 PM
DieselWorkin's Avatar
6 Big Cylinders
State: CA
View This User's Garage
Post #5
Since you want it quiet just do a "DPF delete pipe". It's called a dpf delete pipe but will replace the nox and dpf with a straight piece of pipe. You will want one that has the 3 bolt flange on one end that will bolt to the stock downpipe, and the other end will slip fit into the stock muffler. The stock downpipe has a cat which will keep the exterior and interior sound from getting very loud and prevent drone. (I have had this setup on my truck) If that proved to be too loud you could splice in another muffler into the delete pipe if you needed to. I can't imagine needing to do that, but it would be an option.
For EGR, since you'll need smog check every 2 years don't remove the EGR. The tuner will disable it automatically.
For the tuner, you may or may not have heard both Smarty and H&S recently stopped selling dpf delete tuners. As far as I have seen you can still find tuners for sale though. I don't really have a recommendation between the two. I've run both and both worked. 2012 results may be different than mine. I like H&S for the gauges.
YouTube.com/DieselWorkin
2010 Ram 3500 SLT RC/LB/DRW 6.7L 4x4 G56/Manual 3.42
Straight Pipe 4" DP To 5" To 6" Tip Side Exit / Airaid Intake / H&S MM
NoPlugsRequired
 Posted: 12-31-2012, 12:27 AM
State: AZ
Post #6
The delete pipe... that does require a tuner or EGR delete kit to prevent throwing codes, correct?
2012 Ram 3500 Limited
4x4 CrewCab Longbed
*shrugs* It's stock...
DieselWorkin
 Posted: 12-31-2012, 02:03 AM
6 Big Cylinders
State: CA
Post #7
Basically yes if you remove the DPF you need a tuner with dpf delete tuning. Otherwise it would throw codes and probably end up in some kind of limp mode. There is also another method that much fewer people seem to use... With the use of resisters connected to a few of the sensors that plug into the DPF you can trick the computer into thinking it never needs to regen... I don't know much about it. Considering the heat the tuning companies have taken recently it may start to become a more common method. Just google "6.7 cummins resistors delete" or something along those lines and I'm sure you'll find the info you need if interested.
For EGR delete on 4th gens (2010+) if you install a dpf delete tuner then you don't have to touch the EGR at all. EGR will be disabled automatically in the tuning. If you use the fooler method to delete the DPF I'm not sure that there is any way to avoid throwing a code if you unplug or remove the EGR, but it's not something I am very familiar with so I don't know for sure.
jasonsdakota
 Posted: 12-31-2012, 06:20 PM
Post #8
hmmm... what kind of gas mileage can the 6.7 get when you delete the dpf. its pretty horrific stock as i understand.
2004 slt blue quad cab 2wd hemi
4.10 gears on 17s
magnaflow si/so exhaust
superchips w/custom trans tune
retro solutions 55watt 4300k hids, stock reflectors, BEST MOD YET!!
trifecta tannoe cover covering 500lbs of pdr tools
4 dually spots
retro 5 watt led reverse lights
mods coming
180 t-stat
dream mods
more efficent, slightly higher stall convertor
6.4 stroker engine with 260, advanced timing cam or small 4psi turbo setup
SoCal Hemi
 Posted: 12-31-2012, 06:38 PM
SoCal Hemi's Avatar
State: CA
Post #9
I am currently getting 14-15 around town and 18 on short freeway runs completely stock, then again it barely has 1k miles on the truck at the moment either. Would kind of like to know the same information myself.
Just basically trying to gauge what to begin planning towards/around so I don't have to do the upgrades multiple times.
Stock For Now ! ! !
NoPlugsRequired
 Posted: 01-01-2013, 01:40 AM
State: AZ
Post #10
A big thing is gonna depend on the gears... I've got 4.10s so I'm hitting 2k RPMs at 70. But on my daily drive where I'm running 55 or so, I've been able to get my EVIC as high as 16.5... but it's usually in the 15-15.5 range.
4x4 CrewCab Longbed
SoCal Hemi
 Posted: 01-01-2013, 01:42 AM
SoCal Hemi's Avatar
State: CA
Post #11
Yeah I know what you mean, that was why I went with the 3:73's personally.
Stock For Now ! ! !
NoPlugsRequired
 Posted: 01-01-2013, 01:58 AM
State: AZ
Post #12
For that reason... yes, the 3.73s would be good. But the 4.10s come with a lot higher towing capacity which works great for me.
4x4 CrewCab Longbed
neebs22
 Posted: 01-02-2013, 12:37 PM
State: KS
Post #13
The DPF isn't causing the biggest hit to MPG... it's the EGR.
2002 Dodge Ram 2500.... 24 valve Cummins with a P_pump conversion... SOLD!!
2006 Dodge Ram 1500 Mega Cab 4x4... the Family Truckster
SikHemi
 Posted: 01-02-2013, 06:48 PM
SikHemi's Avatar
Mopar Or No Car
City: 08360
State: NJ
Post #14
I just bought a 6.7 stroker. ( Cummins is the mess that Strokin leaves behind). I'm doing a dpf delete on Friday. It will help your mpg's a lot. Egr.. Exhaust gas recirculator. Meaning it recycles gas back into motor. If u take off filter then soot just exits exhaust faster. Instead of staying in filter and then making truck go into regen. Delete it.
K&N CAI
Tinted tails & 3rd
debadged
stubby antenna
Line-X
jasonsdakota
 Posted: 01-02-2013, 07:08 PM
Post #15
how does the 6.7 compare to the old 5.9 for gas mileage once you delete the egr and dpf? 5.9 has neither right?
4.10 gears on 17s
4 dually spots
mods coming
180 t-stat
dream mods
SikHemi
 Posted: 01-02-2013, 09:20 PM
SikHemi's Avatar
Mopar Or No Car
City: 08360
State: NJ
Post #16
Now I'm at 14-15 with 35's. hoping to see 18-20 after I get done playing.
K&N CAI
Tinted tails & 3rd
debadged
stubby antenna
Line-X
SoCal Hemi
 Posted: 01-02-2013, 09:36 PM
SoCal Hemi's Avatar
State: CA
Post #17
Nice, Atleast gives me some kind of ballpark for where I am looking to be myself.
Stock For Now ! ! !
NoPlugsRequired
 Posted: 01-02-2013, 10:09 PM
State: AZ
Post #18
Really? You've had a Ford for two days and you're already turning into a massive fanboy...
Best of luck with your looks-the-same-as-every-other-powerstroke-on-the-road truck and hope you have a good warranty and insurance company.
4x4 CrewCab Longbed
neebs22
 Posted: 01-03-2013, 07:00 AM
State: KS
Post #19
It's obvious why you went with a ford.... your knowledge of diesel emissions is lacking.
First, EGR (Exhaust Gas Recirculation) takes spent emissions from the exhaust manifold, cools it and then reinserts it into the incoming air stream. The purpose being to reduce the amount of free oxygen available for combustion. By doing so, the temperature of combustion is lowered to reduce the amount of NOx produced in the cylinder. This makes the engine inefficient for fuel use and in addition it promotes the creation of soot.
NOx and soot have an inverse relationship in the cylinder. NOx is created during highly efficient, hot burns... this is also when the least amount of soot is created. Soot being created during inefficient and/or cold burns where NOx is created at lower levels.
Second, the DPF while in place to trap soot particles before they can exit the system, doesn't cause near the loss of fuel efficiency that the EGR system does. There are pages and pages of anecdotal evidence on of diesel specific forums. If the truck is used as a truck, which is unlikely in the event of a Ford, then the DPF will passively regenerate more than it actively regenerates. Passive regeneration is done at no cost to you fuel economy.
Third, your Ford is also utilizing SCR. SCR allows higher levels of NOx to be created in the cylinder which in turn promotes a more efficient burn and less soot. Your use of EGR will be lower and the soot load will be lower (than a non-SCR engine).
Deleting the DPF will have some effect but you get more bang by deleting the EGR assuming you have a tuner capable of modifying the programming to eliminate any derate that comes from doing so.
Wandell
 Posted: 01-03-2013, 11:48 AM
Wandell's Avatar
State: GA
Post #20
Without a doubt, go with a H&S tuner. Contact Rollin Smoke Diesel. They will give you a good price on a tuner and a DPF delete pipe.
2012 Ram 2500 ST Cummins Crewcab. 5 inch Rough Country lift, 37 inch Nitto Terra Grapplers on 20x9 KMC XD Spys, H&S XRT Programmer, MBRP exhaust
Not happy with sub performance, upgrade sub or upgrade to joefox box? kmu Mobile Audio & Electronics Talk 14 08-22-2007 11:45 AM
2003 Neon SXT performance upgrade questions mnbvcxx123 Dodge Neon - Performance Talk 2 10-30-2006 04:12 PM
Trans upgrade, Speedo prob, axle upgrade questions CarPARTsearcher 3G Dodge RAM - Drivetrain Talk 1 07-19-2005 02:47 PM
Trans upgrade, Speedo prob, axle upgrade questions CarPARTsearcher 3G Dodge RAM - General Talk 0 07-18-2005 11:46 AM
