Thread Tools |
fog light options
- Posted: 12-19-2012, 08:17 PM
Post #1
ok, so my truck didn't come with fog lights, but i wanna know what all my options are for fogs. obviosly factory fogs is one option, but are there aftermarkets made to bolt up and are brighter? or better in some way? what have you guys replaced your factory fogs with, or in general what have you done with them. right now im thinking find some factorys and put in 55watt 4300k hid kit. what else could i do or need to know?
2004 slt blue quad cab 2wd hemi 4.10 gears on 17s magnaflow si/so exhaust superchips w/custom trans tune retro solutions 55watt 4300k hids, stock reflectors, BEST MOD YET!! trifecta tannoe cover covering 500lbs of pdr tools 4 dually spots retro 5 watt led reverse lights mods coming 180 t-stat dream mods more efficent, slightly higher stall convertor 6.4 stroker engine with 260, advanced timing cam or small 4psi turbo setup |
| Sponsored Links | |
Advertisement |
Posted: 12-19-2012, 09:55 PM
Post #2
Some of the trucks may not have the fog lights but they have the wiring. The best way to find out is to look under the bumper and you'll may find the end of the wiring harness. The connectors are red if I remember right. If that much is there, you only need the lights and a new headlight switch. From there the options open up.
Sent via a Texas RoadRunner Varmint ... God Squad July 1972-To Infinity and Beyond-#40 Little Rammie Ridin' Shotgun Club287 Club Member #81 ~ Broken C Clip Club Member ~ Two-Tone Truck Club Member #13 ~ 4.56 R&P Club Member #8 Mighty Cracked Dash Enthusiast Club #11~Mother Earth Raping Big Truck Club Member #25~Truck and Gun Club Member #97 2002 Ram 1500 SLT 4x4 QC - (Nov.01) 4.7L with 89K/3***hrs, 2002 Ram 45RFE Jeep GC TCM Upgrade to 5-45RFE, Knolton Thunder Cylinder Heads & HO Cams by Sawcut, 4.56 R&P/DTT, SRT-10 Pod w/Dynojet Wideband Commander, 2-speed manual transfer case, Clifford Security System w/Auto Start/Auto Windows, RB1 CD/DVD/NAV Infinity Sound System w/30GB iPod, Offroad Package, 33" BFG T/A KO E's, Mopar Rear Wheel Liners, EBC Greenstuff Roadsport Brake Pads, K&N w/Airaid Jr Modular Intake Tube, BBK 70mm Throttle Body, Sonnax Line Pressure Booster, AIR_RAM Jet Stream Scoop, PML Diff Cover, ASP Underdrive Crank Pulley, MSD 1.65 Alt Pulley, Lincoln E-Fan, DCC 2-Speed E-Fan Controller, 180 Jet T-Stat, Denso 160-amp Alternator, Flowmaster SI/DO Exhaust, Accele 3.5" LCD Backup System, Line of Fire LED Light Bar, Sylvania Ultra Silverstars, Hella 500 Black Magic-100W, Nokya Hyper Yellow Fog Lights, $1600 Oil Pick-up Tube thanks Dodge Texas 1845: We the People of the Republic of Texas, acknowledging, with gratitude, the grace and beneficence of God. “Firearms stand next in importance to the constitution itself. They are the American people’s liberty teeth and keystone under independence … from the hour the Pilgrims landed to the present day, events, occurrences and tendencies prove that to ensure peace security and happiness, the rifle and pistol are equally indispensable … the very atmosphere of firearms anywhere restrains evil interference — they deserve a place of honor with all that’s good.” - George Washington
Official DodgeTalk Facebook Page |
Posted: 12-20-2012, 07:54 AM
Post #3
EBAY. I got a mopar set off of ebay. With wireing and switch. it was like $120, but that was about 7 years ago. I am just running stock bulbs n them. I love them. They do help out alot!!!!
2005 Reg cab 3.7 auto ![]() AEM intake flowmaster super 40 muff Stage 1 jetchip E-Fan ![]() Member "The Red Truck Club" #114 |
Posted: 12-20-2012, 08:32 AM
Post #4
yea, a mopar set with stocks bulbs would be a good start. i already have retros hids now, so i would probably barely notice a difference. i need to just install these dually d2 wides behind my grill and call that a day. can that be wired to a stock mopar switch. for instance, i pull the switch out as if factory fogs were gonna come on, but the dually d2s come on instead? can that be done?
Posted: 12-20-2012, 09:22 AM
Post #5
The problem there is that the factory switch turns off the fogs when you hit the high beams. There is a work around for 2005 and earlier.
Search "Jumper Mod" . Basically you run a jumper wire on the relays in the fuse box that powers the fog light relay whenever the marker lights are on. I bought a Mopar kit With stock switch along with some 35w HID's from the bay. Install was way easy (write ups are on this forum). The price of admission was worth it for appearance alone. The hid bulbs kick out too much glare, rough on my eyes for long drives. If I did it again, I would buy color matched silver stars or Ultra's, as I can't afford to do hid's right.
05 RC SB 4.7 4x4 |
Posted: 12-20-2012, 10:56 AM
Post #6
I got some KC lights and put them in the spot of the factory ones. I really like them there. I can't use them on the street. But offroad they are nice.
On the road I am blinding everyone. http://www.dodgetalk.com/forums/showthread.php?t=361232 I have since installed the factory fog light bezel I got from a member on here. ![]() And this is the only shot I have of it. ![]()
Posted: 12-20-2012, 12:21 PM
Post #7
Posted: 12-20-2012, 12:34 PM
Post #8
Posted: 12-20-2012, 12:53 PM
Post #9
I also have a HOW TO in the HOW TO SECTION how to make the 9005 bulbs fit in the fogs.. or is that 9006.. can't remember now.. anyhow.. it's there. Makes them brighter (factory fog lights)
Posted: 12-20-2012, 02:37 PM
Post #10
Posted: 12-20-2012, 10:05 PM
Post #11
must be 9005s. thats the high beam bulb and is almost twice as bright as a 9006. what bulbs do the factory fogs use?
Posted: 12-22-2012, 09:58 AM
Post #12
Factory fogs are the 9006
2007 Dodge Ram 1500 ST 4.7L 20x9 American Racing Hot Rod Circuit Rims, Nitto Terra Grapplers 275/65/20, Bilstein 5100's, Radco Tonneau Cover, Locking Tailgate Handle, AVS Window Visors, Ionic SS Nerf Bars, 21" Stubbie Antenna, OEM Chrome Grille Inserts, SRT-10 A Pillar, Auto Meter Factory Matched Trans Temp Gauge, Pioneer Double Din, Nav Bezel, Backup Camera, Hella 700ff w/ PIAA 100w H3 Night-Tech. Volant CAI, Diablo Intune(Hemifever), AirRam Power Wire, AirRam Jet Scoop, JBA Shorty Headers, Magnaflow Y-Pipe, QTP E-Cutout, Magnaflow 14", Optima Red Top Battery, Flex a lite 183 E-Fan, 2008 Intake Manifold, F&B 72MM TB, Autometer Wideband AFR Gaude. Future Mods: H/O Cams, 4.56, Mag-HyTec covers.
Posted: 12-23-2012, 03:35 PM
Post #13
[b]I am not sure what 3rd gen fog light bulbs are. I have a 2011 that uses 9145 bulbs at 42w. I replaced the bulbs with 9005 65w bulbs they are like night and day differance. And no modification need to make them fit plug and play. 9005 bulbs are a "high beam " bulb. /B]
Hemifever 93 tune, JBA shorties, Volant Powercore cai, Moe's 85 mm cnc ported TB, 3"spindle+2.0 spacer, rear 1.5 lift spring , 1.25 RC body lift.
Posted: 12-23-2012, 03:49 PM
Post #14
9005 is 65 watt i believe. The 9006 is 55 watt. Nonetheless good tip. Thanks. What are some options for me besides factory fogs
Posted: 12-25-2012, 06:19 PM
Post #15
Posted: 12-25-2012, 08:04 PM
Post #16
Ditto, Though I'd like to put in a nice looking switch or 3. I've read some threads with pics of sweet looking switch installations. Give my self motivation to add more lights that way also.
05 RC SB 4.7 4x4 |
Posted: 12-25-2012, 08:12 PM
Post #17
Fog light patterns with 3 different bulbs. Stock capped fog bulb, modified hi beam(9005?) bulb, and 35w hid (yellow).
100_0771.JPG 100_0769.JPG 100_0770.JPG 100_0752.JPG Link to post with more pics http://www.dodgetalk.com/forums/showthread.php?t=357799
05 RC SB 4.7 4x4 Last edited by Audie61 : 12-25-2012 at 08:19 PM. |
| Thread Tools | |
| Rear Bumper Light Options | wingerak92 | 4G Ram Power Wagon Talk | 3 | 08-31-2012 04:59 PM |
| cup holder and ashtray light options | 72 rs | 3G Dodge RAM - Interior/Exterior Talk | 7 | 01-18-2010 11:05 PM |
| Fog Light Options? | crash1369 | 3G Dodge RAM - Interior/Exterior Talk | 14 | 01-02-2010 11:11 PM |
| Light bar options? | maclss | 3G Dodge RAM - General Talk | 8 | 07-10-2009 11:51 AM |
Privacy Statement | |
