1987 Dakota 4x4 Starter and steering shaft removal - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Dakota 1st Gen (87 -96) Forum
avianblue
  1987 Dakota 4x4 Starter and steering shaft removal - Posted: 12-11-2012, 03:57 PM
avianblue's Avatar
Avianblue
City: Pacific
State: WA
Post #1
Howdy all, I've been looking over the forum posts for a couple of days now, trying to find an answer to my specific problem of removing/replacing the starter on this Dodge Dakota SE / SS 3.9L 4x4. Some posts come pretty close to what I have but not exactly. person I bought the truck from said he changed out the transmission from one without an over drive to one with an over drive gear
I'm not a mechanic, lets get that up front.
The issue is getting the starter out of the engine compartment without pulling off the exhaust system.
Several posts state that there is enough room to wiggle it out through the underneath of the truck without removing the exhaust (with a lot of effort and two people, must be a different dakota from what I have)
I've looked at this option real close and there is no way it can get past the exhaust system and front frame work under the chassie (not sure what thats called *cross member maybe*). Even if I did unbolt the exhaust from the manifold I dont think there is enough room to slide the starter out.
The best option I've found to get the starter out is getting the steering shaft out of the way. But I haven't figured out to to disassemble it. Which is what I need help with
A couple of posts have been pretty helpful and the picturs were informative, but, (always a but) they all seem to be a bit different than what I have.
I've included picutres of my problem (the 1st pic is the truck itself)
Pic #2 is the starter laying in the engine compartment after removing the mounting hardware
Pic #3 is the starter and the steering shaft and the steering gear box (I think thats what it is called) at the front of the truck. At the green twisty wire is a bolt thru the middle of the steering shaft
Pic #4 is a close up of the blot in the middle of the steering shaft
Pic #5 is the end of the steering shaft as it connects to the steering column at the firewall
Pic #6 is the end of the steering shaft as it connects to the steering gear box at the front of the truck (I'm not sure what the large hole is on the side of the part is)
Pic #7 is the SE /SS emblem on the fender
From my reading I'm guessing that there might be something called roll pins that connect all the pieces (not sure). I managed to remove the bolt in the center of the shaft (Pic #4) and it wiggled a bit but didn't slide or come apart.
Any suggestions on where I go from here?
P.S. I get an "error on page" when I try to spell check, so my appologies if I didn't get everything perfect
Last edited by avianblue : 12-11-2012 at 05:41 PM. Reason: where are the pictures? okay, had to resize them
dmcelhannon
 Posted: 12-11-2012, 10:49 PM
dmcelhannon's Avatar
Moderator – David Mack
City: McAllen
View Member's FaceBook Profile
Post #2
Welcome to DT!
I know he has 1Gen but let's see if we can help the new DT member with this problem.
Sent via a Texas RoadRunner Varmint ...
God Squad July 1972-To Infinity and Beyond-#40 Little Rammie Ridin' Shotgun Club
287 Club Member #81 ~ Broken C Clip Club Member ~ Two-Tone Truck Club Member #13 ~ 4.56 R&P Club Member #8
Mighty Cracked Dash Enthusiast Club #11~Mother Earth Raping Big Truck Club Member #25~Truck and Gun Club Member #97
2002 Ram 1500 SLT 4x4 QC - (Nov.01) 4.7L with 89K/3***hrs, 2002 Ram 45RFE Jeep GC TCM Upgrade to 5-45RFE, Knolton Thunder Cylinder Heads & HO Cams by Sawcut, 4.56 R&P/DTT, SRT-10 Pod w/Dynojet Wideband Commander, 2-speed manual transfer case, Clifford Security System w/Auto Start/Auto Windows, RB1 CD/DVD/NAV Infinity Sound System w/30GB iPod, Offroad Package, 33" BFG T/A KO E's, Mopar Rear Wheel Liners, EBC Greenstuff Roadsport Brake Pads, K&N w/Airaid Jr Modular Intake Tube, BBK 70mm Throttle Body, Sonnax Line Pressure Booster, AIR_RAM Jet Stream Scoop, PML Diff Cover, ASP Underdrive Crank Pulley, MSD 1.65 Alt Pulley, Lincoln E-Fan, DCC 2-Speed E-Fan Controller, 180 Jet T-Stat, Denso 160-amp Alternator, Flowmaster SI/DO Exhaust, Accele 3.5" LCD Backup System, Line of Fire LED Light Bar, Sylvania Ultra Silverstars, Hella 500 Black Magic-100W, Nokya Hyper Yellow Fog Lights, $1600 Oil Pick-up Tube thanks Dodge
Texas 1845: We the People of the Republic of Texas, acknowledging, with gratitude, the grace and beneficence of God.
“Firearms stand next in importance to the constitution itself. They are the American people’s liberty teeth and keystone under independence … from the hour the Pilgrims landed to the present day, events, occurrences and tendencies prove that to ensure peace security and happiness, the rifle and pistol are equally indispensable … the very atmosphere of firearms anywhere restrains evil interference — they deserve a place of honor with all that’s good.” - George Washington
Official DodgeTalk Facebook Page
http://www.facebook.com/DodgeTalk
FreeLantz
 Posted: 12-13-2012, 05:27 PM
FreeLantz's Avatar
Administrator
City: Meadows Place
Post #3
Bump for the OP.
David Lantz
DodgeTalk Administrator
FreeLantz@DodgeTalk.com
2007 Ram 1500 Regular Cab 4x4 LWB HEMI
2007 JK Wrangler
Previous: '93 Dakota, '96 Ram 1500, '99 Ram 2500 4x4, '02 Ram 1500 4x4, '05 Dakota 4x4, '08 Magnum R/T, '08 Jeep Patriot
Forum RulesSupport Our SponsorsDodgeTalk on YouTubeDodgeTalk Facebook Group
DodgeTalk Decals For SaleVote in our Monthly Chop Challenge!
dodgef25
 Posted: 12-14-2012, 10:56 AM
dodgef25's Avatar
Crazy4x4RT
City: NM
View This User's Timeslip
Post #4
Yes just remove the intermediate steering shaft. The shaft is in 3 pieces, the middle piece is removable by the 2 center bolts. Remove them then slide it up or down to get it separated. WD-40 will help.
The next option is to remove the shaft from the steering column and/or the steering gear box. Some have simple bolts others use crush pins which have to be punched out, an air hammer with a point is best.
My Youtube Videos! ---My Dana 44 SAS
"No truck should ever be lowerd! NEVER"
avianblue
  1987 Dakota 4x4 Starter and steering shaft removal - Posted: 12-28-2012, 04:49 PM
avianblue's Avatar
Avianblue
City: Pacific
State: WA
Post #5
For those of you with this 1987 Dakota 4x4 and are trying to figure out how to replace the starter, you may have realized that there isn't any way to get the starter out of the engine compartment from underneath the vehicle, nor is there any clearance from the top of the engine to remove/replace the starter. The steering shaft is in the way. Picture #4 from my original post and re posted here, shows a bolt and clip in the middle of the steering shaft. Initally, I removed the bolt and tried to wiggle the shaft around but there was little of any movement in any of the components. What I couldn't see was that the clip itself has a small flange that locks the lower shaft part with the upper shaft (see picture 4a&4b&4c).
Also, what I didn't see was a grooved cut out on the upper shaft on the back side of the clip (see picture 4d) which I found by turning the steering wheel a little bit. The grooved cut out had just enough space for me to insert a small flat tipped screwdriver and tap the screwdriver with a hammer to move the lower shaft part out of the coupler to free the two parts. There isn't a lot of room to swing a hammer so it took a lot of small taps to separate the upper and lower shaft parts.
The starter was $50.00 at autozone with limited lifetime warrenty.
Once the shaft parts are separated they swing easily out of the way to access the starter.
File Type: jpg 004a Dakota bolt in middle of steering shaft.jpg (125.9 KB, 0 views)
volaredon
 Posted: 12-28-2012, 05:38 PM
older trucks ARE better!
State: IL
Post #6
that "SS" emblem isn't stock that aint no Shivvy
that truck has the "old style" starter that Dodge used since the 60s; newer trucks had the smaller starter which would directly interchange... easier to get back in
sorry; they will be prying my "old" truck from my cold, dead, fingers!
the new ones make me want to
WTB: 1997 Dakota Intermediate Steering Shaft stebob Wanted - Dodge Truck Parts 0 09-24-2010 07:52 AM
1987 Dakota steering column removal how to robert8688 Dodge Dakota 1st Gen (87 -96) Forum 2 10-27-2009 09:48 AM
Steering Column Removal/ Steering gearbox removal question b300dude Dodge B-Series Vans 1971 - 2003 4 08-08-2009 09:29 PM
Removing Steering Shaft from 1992 B250 Steering Column gman69440 Dodge Ram Truck 1st Gen (88 - 93) Forum 1 03-23-2008 09:37 PM
1990 Dakota starter removal arobinson7 Dodge Dakota 1st Gen (87 -96) Forum 2 08-04-2006 09:50 AM
