Compressor mounting spots?? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 3rd Gen (02 – 08) Forums > 3G Dodge RAM - General Talk
badblackram
  Compressor mounting spots?? - Posted: 12-10-2012, 10:07 PM
badblackram's Avatar
City: brookhaven
State: MS
Post #1
Where are you guys mounting your compressors?
My setup is a 200psi viair compressor, 5 gallon tank.
I've had mine mounted sideways on the inside of the frame where the spare tire is supposed to be. After about a year and a half it just died on me last week. I have the filter ran over the fuel tank, rarely even ran it(maybe twice a month sometimes more if I have to air up tires), never ran it in the rain or when it's wet out. So my guess is because of how it was mounted it didn't last long. It was a viair compressor but unsure of the model but did have a 200psi rating. I have another but plan to get mounting location opinions and ideas to make this one last longer.
One idea I had throwing around my head was building a small steel box and spraying it with bedliner and mounting it in the bed. Hoping to make it as weather resistant as I can. Is that over doing it? I just don't want to keep buying $200 compressors ever year and a half. Any input would help.
Thanks
2006 Ram 1500
4.7L- Gibson S/S ceramic shorties
Catless w/ 12279 magnaflow
Apm ram air hood w/ ram air intake
Painted grille, bumper, & handles
Painted headlights w/ Retrofitted morimoto projectors
Power slot rotors
Superchips vivid Paq w/ ATT
2/5 McGaughy's drop kit
Stk. 3.92 gears
Nitto 420s 285/50r20
VINCH
 Posted: 12-11-2012, 12:09 PM
VINCH's Avatar
City: Lancaster
State: CA
Post #2
tool box
Red Neck White Hair Blue Collar
2012 Ram Crew Cab 3500 6.7 H.O. CTD 4x4 SRW
295/70/17 Nitto trail grappler tires
Pin striping by Bob Spina
86bcook
 Posted: 12-11-2012, 12:16 PM
86bcook's Avatar
Skid's Customz
City: Borger, Tx
Post #3
There is one guy on here that mounted his behind his front bumper ontop of a aluminum plate (like between the frame rails)
2005 RCSB Hemi
THE SHOW
Completely Repainted
ABC Exclusive Cowl Hood
PURE Custom Tailgate Spoiler
Debadged!!
Honeycomb Grille with R/T elblem
OEM SRT-10 Pillar w/ Autometer Tranny Temp
MRK Group silver interior package
5% tint all the way around
8000k hid's headlights and fogs
All led bulbs (int/ext)
2/4.5 McGaughys drop w/ Chrome SRT-10 22's
Power Show-N-Go Retractable License Plate
DEE ZEE Tailgate EZ Down Strut Kit
THE GO
Bills custom intake w/ 1in throttle body spacer
Airram Scoop
NGK 5306's
Taylor Red 8.2 Thunder Volt Shorty Wires
Jet 180 Thermostat
SCT 9550 Hemifever Tune
Prothane Sway Bar Bushings
Prothane Rack and Pinion Mount Bushings
Motive 4.56 gears
Powerstop drilled/slotted rotors with hawk pads
Pacesetter Headers and off-road x-pipe
Dual 14 inch magnaflows and exit out like the 2010's. With notched rear bump!!
Www.dodgetalk.com/forums/showthread.php?t=363131
TexasAxMan
 Posted: 12-11-2012, 12:37 PM
TexasAxMan's Avatar
City: Houston, Texas
Post #4
I'd go with the toolbox idea.
2006 Silver QC Hemi 2WD
SnugLig Tonneau w/ Bed Rug
SuperChips 3815
eBay CAI
Motive 4.56's
2006 Black SC Hemi 2WD
SuperChips 3865
Bed Rug
eBay CAI
badblackram
 Posted: 12-11-2012, 12:57 PM
City: brookhaven
State: MS
Post #5
Yeah I thought about a chest type toolbox but didn't want to spend too much on it. Ill have too keep my eye out on a used one.
2006 Ram 1500
Power slot rotors
Stk. 3.92 gears
badblackram
 Posted: 12-11-2012, 01:02 PM
City: brookhaven
State: MS
Post #6
I also looked into doing this but my train horns are in the way and if I moved it back any further I would not be able to get to my oil filter.
2006 Ram 1500
Power slot rotors
Stk. 3.92 gears
trickedinferno
 Posted: 12-11-2012, 01:13 PM
City: Fort Smith
State: OTHER
Post #7
Did you try spraying some lube down the vent hose? The Viairs are good compressors, but if you don't use them enough (sounds like your case) they tend to lock up after a little while. Just like a car motor, it's better for them to be used and not sit. Those compressors won't get hurt being mounted where you had yours mounted, putting them in a box would probably make the situation worse because there won't be any chance of the motor getting cooler air to it.
I had my battery, compressor, 5 gallon tank, and 4 valves mounted behind my front bumper.
Check Us Out, and LIKE us!
http://www.facebook.com/Precision.Installs.AR
badblackram
 Posted: 12-11-2012, 06:27 PM
City: brookhaven
State: MS
Post #8
I shot some lube in the compressors head and let it set for a hour but no luck. I used a test light and the hot wire has power going into the motor. Made sure I had a good ground but no luck there either.
I checked behind my bumper while I was under there and there is no way ill have room for my tank, compressor, and train horns and still be able to get my oil filter off and let it drain. It was a good idea but just won't work for me.
2006 Ram 1500
Power slot rotors
Stk. 3.92 gears
nickm5
 Posted: 12-12-2012, 09:58 PM
nickm5's Avatar
Post #9
I had the same thing happened to mine,I have mine mounted up front behind the bumper and water got into the unit and it just stopped working.I pulled it a part and open it and cleaned it out with some WD-40 and put it back together with some silicone around the joints,then i sprayed plastic dip over the whole casing but not the cooling fins and it's never fail me again,4 years and counting.....
2006,2500 Hemi Volant Cold Air Kit, Volant Stainless Steel Cat Back Bushwhack Painted Fenders, Painted Back Rack, Diamond Plated Tool Box
Behind The grill Driving & Fog Lights, Superchip Tuner
Rear View Back up Camera, De-badged
On Board Air Compressor, Triple Train Air Horn
Stainless Steel Side Step
Painted grill,black mess,LED step lights,LED strip lights under amber light,315/70/17 mounted on 2010/11 polished alloy dodge wheels.
MY LITTLE FLEET
nickm5
 Posted: 12-12-2012, 10:03 PM
nickm5's Avatar
Post #10
I have mine up front behind my bumper,3 train horns,compressor,and air tank..you can fit it for sure,I'll post some photos when I get a chance.... I have plenty of room to change the oil filter and so on.....
MY LITTLE FLEET
bnii
 Posted: 12-13-2012, 01:12 AM
bnii's Avatar
Bill Newell
City: Medford
State: OR
Post #11
I use a york engine driven comoressor as my primary compressor, but I have an air zenith mounted inside the fram rail in the rear near the notch where the gas tank used to be as a back up. It only fires up once every couple months. These compressors are designed to be sealed but if moisture sits it can cause them to bind up. Easy to take apart and clean up. I've been lucky and had no problems but I've had to fix a few other people's.
TrueCowboy426
 Posted: 12-13-2012, 08:45 AM
TrueCowboy426's Avatar
Double Rammin'
City: Woodstock/Chatsworth
State: ON
Post #12
I mounted my compressor behind the drivers side headlight. This was the best place for me to put it as it was up out of the way so it wouldn't get damaged and stay mostly out of water and mud when I offroad, and the air inlet if mounted high up in the fender by the battery.
2007 Dodge Power Wagon - Inferno Red Quad Cab, G56 6-speed, 35x12.50 Toyo MT's, Offroad lights behind the grill, Warn wireless winch remote, Carli front Diff Guard, Carli Long Travel Air Bags, On board air complete w/ train horns, homemade hidden gooseneck hitch, Homemade locker bypass
Awaiting install: KRC 210X cam, 6.1 springs and pushrods
Old Faithful: used and abused, but keeps firing up.
2002 Dodge Ram 1500 ST 4x4 Quad Cab 4.7L Bright Silver (Totalled Dec 2/08, back on the road Feb 4/09. She ain't pretty but still a beast)
HO Cams, 12,000 lbs Winch mounted behind bumper, 4.56's, 2500 factory tow hooks, DMH E-cutout, 35x12.50 Toyo MT's, Air-Lift Ride Control bags, homemade hidden ball gooseneck hitch.
1987 Dakota RCSB (scary ride) :
413 BB truck motor, long tube headers, 727, Holley 4bbl, and a bit more to come.....
My other Vehicles:
1987 Ram W100 4x4 - mild 360
1997 Jeep GC Limited - 4L
1999 Jeep TJ, 4cyl(boo), 5spd
weedahoe
 Posted: 12-15-2012, 09:06 PM
weedahoe's Avatar
Tricked out Ram
City: Albany
State: GA
Post #13
My tank and compressor USED to be in my toolbox but after needing more room in the toolbox several times, I deiced to move it.
I took a piece of stainless from work and bent it to fit between the frame rails and mounted it in front of the radiator (I have a body lift). I mounted the compressor and tank to it and my horns mounted where my spare tire used to be (no spare because my current rims and tires are so big)
There are pics in my gallery links
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Link to my gallery
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
ZMBSNPR
 Posted: 12-16-2012, 12:42 PM
ZMBSNPR's Avatar
City: Staten Island, NY
Status: Online
Post #14
Interested in onboard air as well. Does anyone make an engine driven compressor for our trucks?
2008 Dodge Ram 1500 QCSB 4X4 Hemi
-Air-Ram Intake w/ AFE Pro Dry filter
-SC 3815 (91 Performance Tune)
-Jetstream Scoop
-Powerwire
-AT3030 + Magnaflow Y-pipe
-180º Stant T-Stat
-Sonnax Line Pressure Booster
-Bilstein 5100s F+R
-Procomp Series 52 17x9
-285/70-17E BFG AT/KOs
badblackram
 Posted: 12-16-2012, 12:45 PM
City: brookhaven
State: MS
Post #15
York. bnii stated he uses one.
2006 Ram 1500
Power slot rotors
Stk. 3.92 gears
RUMBLE BEE 1546
 Posted: 12-16-2012, 01:51 PM
RUMBLE BEE 1546's Avatar
BEE Ready!
State: CA
Post #16
When I get air I will build a box to hold everything and mount it where the spare tire is.
2004 Rumble Bee #1546 4X4
Ryan
Performance: Super Chips 3865, K&N CAI, Edelbrock Shorty Headers, Dual Exhaust with 18" Magnaflow Muffler and Y-pipe, Power Wire, Sonnax Line Booster, Jet 180* t-stat, Taylor 8.2mm Shortie wires, Flex-A-Lite 183 E-fan, Grounded TB.
Appearance: 22" Black BOSS 334's wrapped in Nexen Tires, LED Tail Lights & Third, Shorty Antenna, Honeycomb Grill, Tint:5% Visor and Rear Window, Deadged, Retro'd 8000k Projected HID Headlights w/ SMD Halos, 3000k HID Fogs, Switchback LED Turns, Full LED Bulb Swap, Snugtop Tonneau w/ Stripe Extensions & 1546 in Stripe
Other: Kenwood KDC-X994, Pioneer 5ch amp wired to 2 10" Diamond Audio Subs in a custom ported box and 2 Kenwood Door Speakers, Clifford Remote Starter/Alarm System w/ Smart Start, Husky Floor Liners, Push Button Start, Jimmy Jammers.
Future Mods: Looks Like A Cam Possibly This year , Alarm Accesories (Motion Sensors, Microphone Sensors, Level Sensor, ect.)...
ZMBSNPR
 Posted: 12-16-2012, 02:12 PM
ZMBSNPR's Avatar
Status: Online
Post #17
Bnii, would you mind posting pics and info on your setup? Very interested.
-Jetstream Scoop
-Powerwire
-180º Stant T-Stat
-Bilstein 5100s F+R
03 Rammer
 Posted: 12-16-2012, 10:09 PM
03 Rammer's Avatar
AROD'S TRUCK
City: Oviedo, FL
State: FL
Status: Online
Post #18
Mines locked up in my tool box.
Sent from my SPH-L710 using AutoGuide.Com Free App
2003 Dodge Ram 2500 4x4 CTD Rollin on some 19.5s. Quadzilla Adrenaline w/Iquad, leveled,KC light bar 4 Rally 8 lights and a lot of smaller add-ons.
bnii
 Posted: 12-17-2012, 12:41 PM
bnii's Avatar
Bill Newell
City: Medford
State: OR
Post #19
I will take a picture when I get home. I thought I had one on my phone but I looked and no luck. Let me check my facebook.
What is the other 3 spots on the key fob for? jmichael99 4G Dodge RAM - General Talk 9 12-25-2010 10:14 PM
4x4 Spots in (IN) DodgeRam5.9 2G Dodge RAM - General Talk 5 07-18-2009 10:58 AM
mounting air compressor kelowna1500 3G Dodge RAM - 4X4 Talk 10 03-24-2009 07:02 PM
A/C compressor as an on board air compressor? ghblaster Dodge Ram Truck 1st Gen (88 - 93) Forum 5 02-08-2006 09:16 PM
mounting an air compressor and tank? john.colorado 3G Dodge RAM - General Talk 4 09-18-2005 05:54 PM
