carpet replacement question - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Vintage Dodge Truck Forums > 1972-1987 Dodge Ram Trucks (D, W-series)
DadTruck
  carpet replacement question - Posted: 12-09-2012, 10:26 AM
State: IN
Post #1
checked the web site for stock interiors
they list carpet sets
19446 74-84 D-150 4 speed/manual
19449 85-88 D-150 4 speed/manual
19452 89-93 D-150 4 speed/manual
The kit that I need is for a 1983 D-150,,2 door std cab, manual tranny... but am not aware of any major interior or floorpan changes among the years for 74 to 93. Why 3 different kits?
On my 83 the carpet just about stopped at the front seat edge, there was a continuation of insulation under the seat,, but nothing on the floor from the back of the seat to the rear wall of the cab.
I wonder if the carpet for the later kits, carpets all the back to the rear of the cab?
a second question, Stock Interiors also has a 'kick pannel' set,, item 2020 that fits 72 to 93 D-150's,, wonder if that is the area, front of the doors and under the dash?
I'll give Stock Interiors a call on monday,, or maybe some has experience with these.
thanks
Speed Dragon
 Posted: 12-09-2012, 11:31 AM
Speed Dragon's Avatar
Aka Force Fed Mopar
City: Campobello, SC
Post #2
There are 2 4-spds, the 833 and the 435, shifters come through the floor in different spots.
Rob M.
'93 D150 RC SWB, 5.2 Magnum, NV4500 5-spd, 9.25" diff
'72 D100 RC LWB, PT project
Roanoker494
 Posted: 12-09-2012, 12:11 PM
City: Glade Hill
State: VA
Post #3
Can not help on the carpets but the kick panel is the area you are thing of. When sitting in the drivers seat it is direct beside your left foot.
Johnnie Watkins
1978 Dodge D200, 318, 2bbl, 2wd, 4spd
lunchbox1671
 Posted: 12-09-2012, 11:59 PM
lunchbox1671's Avatar
Fabricator Extraordinaire
City: Ephrata, WA
State: WA
Post #4
Carpet kits usually account for 4wd shifter levers, if vehicle is equipped with 4wd...
1975 Dodge D100
-Clubcab "Adventurer Sport"
-1-ton Dually
-440
-Auto
DadTruck
 Posted: 12-12-2012, 08:08 PM
State: IN
Post #5
called Stock Interiors and they said...
* their kits are full fire wall to rear wall coverage,, the OE carpet in the 83 D-150 did not cover under or behind the seat. Per Stock Interiors their sets are complete floor pan coverage.
** they say the carpet sets for automatic trannys are different from manual tranny carpet sets because the manuals have a bigger floor hump. Also, to them a 4 speed is a 4 speed, no difference in the carpet set for a 833 or 435.
*** to my original question, why are there three different kits for what is basically the same cab,, ( I tried but I could not get them to overlay the patterns...) they say there must be some difference in the floor pan contours.
for now I have ordered a set of color samples,,
GHS
 Posted: 12-13-2012, 05:54 AM
Post #6
It's because of the different size humps, at least for the automatics when they began using the larger overdrive. I used the later (larger hump '91) carpet in my '73 and just added some extra padding to fill it out.
There also might be a difference during the changeover from a floor mounted gas pedal to a suspended pedal. I converted mine to the suspended version, so that wasn't an issue.
76d100318
 Posted: 12-14-2012, 06:30 PM
76d100318's Avatar
Joey Johnson
State: CA
Post #7
How did you convert it to a suspended pedal? I don't like the floor mounted one anymore.
1976 Dodge D100 regular cab short bed, 318 2 barrel New carter BBD, np435 four speed 91/4 3.21 gears. Headers, dual 2.5 exhaust, into 2 Flowmasters super 44's. Custom
GHS
 Posted: 12-15-2012, 06:37 AM
Post #8
I did the mod in '91, and just bought a new pedal and bracket assembly from the dealer for a '91. It wasn't difficult to change...just had to drill a couple holes in the firewall and fill the ones in the floor.
I did a similar swap on my '64 Valiant using a pedal assembly and cable from a '79 Aspen.
roadram360
 Posted: 12-15-2012, 10:11 PM
roadram360's Avatar
City: mostly on the road
State: LA
Post #9
i did the same thing on my 78.
you like your truck more than you like me. sometimes i do
1978 d-150, 95 360, eddy 750, 4 speed auto, 9.25 rear. her name is sabrina
GOD BLESS AMERICA
http://s745.photobucket.com/albums/x...am360/sabrina/
www.waltonandjohnson.com
www.marklevinshow.com
www.michaelberry.com
*DodgeTalk.com 318 Enthusiast Member #(129)*
DadTruck
 Posted: 12-20-2012, 08:47 PM
State: IN
Post #10
went with the Stock Interiors kit
shipping-delivery was quick
I have this 83 D-150 stripped, so not much in the way for the carpet install..
1. had already coated the floor with micro spheres,,I had done my own tests, an amazing product
2. Dyna Mat on the floor, again, had done a lot of comparison shopping, good value considering shipping and delivery..
3. laid a second ( 3rd?) layer of high density foam over the tranny tunnel,, gear noise is huge..you don't know what it is like, till you don't hear it.
4. put a layer of speaker foam on top of the tranny tunnel to make for a great fit.
http://www.flickr.com/photos/1371835...7632300273058/
should be nice.
lunchbox1671
 Posted: 12-20-2012, 08:56 PM
City: Ephrata, WA
State: WA
Post #11
Very nice!
1975 Dodge D100
-1-ton Dually
-440
-Auto
carpet replacement DadTruck 1972-1987 Dodge Ram Trucks (D, W-series) 5 04-13-2012 06:53 AM
Need carpet replacement vinyl, rubber? srtdodge05 2G Dodge Durango - Interior/Exterior 7 05-23-2008 11:03 PM
Replacement carpet help! Diego1984 3G Dodge RAM - Interior/Exterior Talk 1 11-26-2006 08:30 PM
carpet question country71 3G Dodge RAM - Interior/Exterior Talk 13 01-04-2005 04:23 PM
Interior carpet replacement TripleXJ Dodge Neon - Interior/Exterior Talk 4 10-21-2004 08:04 PM
