Thread Tools |
How to make my truck more "drift-able"?
- Posted: 12-07-2012, 04:07 AM
Post #1
There are no curvy roads around here (central valley) and I would have to drive too far to get to one, so the only way to really enjoy driving is to slide around on the lonely country roads between home & work.
So on to my unorthodox question: what can I do to my truck (08 4.7 6spd with 3.92's, Bilstein HD's, & rear drop shackles) to make it more prone to losing rear traction on demand other than adding power or changing gear ratios? Some ideas & Q's... 1. Add a DTT or Auburn (leaning towards the DTT) - nothing annoys me more than turning one-wheel burnouts, so planning on adding a limited slip in the next few months, once the 5yr LPT warranty inspection is complete 2. Add a rear sway bar - How much does this actually affect ride quality? I do drive 40k+ per year on beat up country roads, so can't absolutely destroy what ride quality I have now. Which sway bar would you guys recommend? 3. Increase rear brake bias - how can this be done? I realize that I would have to be careful as too much rear bias can make the truck too spin-happy. How does one adjust f/r brake bias on our trucks? 4. Install a handbrake - anyone actually done this? Would love to convert the truck over to a hand lever actuated e-brake. Then I might use it for more than just parking...
'08 Ram 1500 QC 4wd 4.7L 6spd (205k) Bedryder seats; Bilstein HD's; McG drop shackles; Hellwig rear swaybar; Bosch euro beam lights BTG; Hella CELIS/LED taillights; Duplicolor'd yellow fog lights; Mopar wheel-to-wheel DP aluminum steps; Magnaflow muffler & y-pipe; Mopar wheel-well liners; 33" Hankook ATM on 20" forged Centerlines; REC receiver with Nakamichi(f) & Memphis(r) speakers, 10" old-school round Kicker Solobaric in a SC/Boyd sealed center-seat box, Infinity 6ch amp; Aspen steering wheel w/SWAC; SRT brake & clutch pedals; heated/cooled Infiniti leather driver seat; Bedrug mat To be installed: Cibie pencil beams BTG; SSBC f&r big brakes '97 Ram 2500 CTD 4wd 5spd flatbed (247k) - plenty of fuel with a stock turbo |
| Sponsored Links | |
Advertisement |
Posted: 12-07-2012, 08:30 AM
Post #2
More power. Thin tires
Posted: 12-07-2012, 08:40 AM
Post #3
The LSD in the rear I would think would be a big help to. My Dakota (5.2L, 5-speed, 3.92s with LSD) was awesome for drifting around on the snowy roads here. Now that winter is back I'm starting to really miss that truck.
![]() 98 Ram 1500 RCSB 2wd (5.7 Hemi swap has begun!!) 5.9 magnum, 3.55 gears, K&N CAI, 3rd gen 20's, aftermarket 1pc headlights, LED tails/3rd brake lights, blue LED dash, tinted windows, 2in drop shackles, hard tonneau, true duals with flowmaster super 44's and 70's challenger style tips Link to my HEMI swap build thread http://www.dodgetalk.com/forums/showthread.php?t=367796 06 Ram 1500 QCSB 4x4 5.7 Hemi, K&N CAI, diablo Intune, flowmaster super 40, KC high lites behind the grill, hard tonneau |
Posted: 12-07-2012, 08:47 AM
Post #4
Drive faster, turn sharper
06'-Ram-Hemi-Pearl Black-113 Spartan Cam-Performance Valve Job-.020 Mill-Long Tubes-Magnaflow-AEM CAI-Wideband-Diablo PCM Dyno Tuned By xhpsolutions-TCM tunes and PCM tweaks made WILD by Whitelighting 06'-Magnum R/T-Hemi-Pearl Black-Magnaflow-Diablo Tuned |
Posted: 12-07-2012, 09:12 AM
Post #5
The most effective addition would be a posi. A rear sway bar would really do nothing to increase driftability, and generally stunt brakes are only on one rear wheel, not both like the factory parking brake. Also, I wouldn't mess with the brake bias, as drifting is based on throttle control, not cranking in more rear brake.
In all honesty though, you should be able to drift your truck pretty good as is, especially with a 6spd. Even with an open rear end I can throw my truck around pretty good on dirt roads. But if you really want it to perform better, a posi is where it's at.
2004 Ram 1500 SLT QC SB 4x4 |
Posted: 12-07-2012, 10:24 AM
Post #6
LSD for sure. Agree on brakes, drifting is all about power.
2006 Silver QC Hemi 2WD SnugLig Tonneau w/ Bed Rug SuperChips 3815 eBay CAI Motive 4.56's 2006 Black SC Hemi 2WD SuperChips 3865 Bed Rug eBay CAI |
Posted: 12-07-2012, 10:29 AM
Post #7
What kind of road surfaces are you referring to?
Pickup trucks aren't designed or intended for Tokyo-Drift stuff... ![]()
2007 1500 SLT 4x4. 2-dr, short bed; 4.7l; 3.55 w/LSD. -- More to come...
Posted: 12-07-2012, 10:32 AM
Post #8
2004-ST RCSB 5.7L-Superchips 3865, Yukon 4.56s oem LSD, black magic 183, comp 260, 6.1 springs an pushrods, 2/4 Mc.G's w/ belltech streets, 4g oem 20s w/ Goodyears, C392 long bars
Posted: 12-07-2012, 12:34 PM
Post #9
Increased rear brake bias not only keeps the vehicle flatter under braking (less nosedive), but it will also pivot more easily. However, after thinking about it, I'm going to leave the brake bias alone. The bias on our trucks is pretty good, and I seem to be able to overheat the rear brakes just as easily as the fronts when carving through the hills. It is very easy to drift around on dirt/mud/snow and even in the wet sometimes and yes the 6spd definitely helps. But with sticky 275mm all terrains on dry asphalt, there's no forgetting it's got a peg leg. Quote:
Just to clarify, I have no intention of "professionally" drifting or participating in any events. It is purely to add some driving fun to these boring, straight, & flat country roads that I'm forced to spend so much time on.
Posted: 12-07-2012, 02:29 PM
Post #10
find dirt roads!
Posted: 12-07-2012, 02:30 PM
Post #11
![]() Get yourself a hemi stroker, you can do very very long burnouts/drifts then :-) you do have to watch out for concrete guardrails though ![]() Wouldn't caltracs help a lot? Whenever I do stupid stuff and the rear wheels starts spinning, the rear starts jumping, caltracs should prevent this?
2003 hemi quadcab Blitz Black ![]() 392 inertia stroker - Edge 3000 stall - TCI outlaw ratchet shifter - AEM brute force CAI - PLX AFR gauge 392 build thread: http://www.dodgetalk.com/forums/showthread.php?t=338656 ![]() Misc stuff build thread: http://www.dodgetalk.com/forums/showthread.php?t=361771 |
Posted: 12-07-2012, 03:06 PM
Post #12
^ At first glance I thought you hit the guy on the ground!
Posted: 12-07-2012, 07:11 PM
Post #13
You got to buy those special drift tires...I've got a set I'll sell you!
Posted: 12-07-2012, 07:53 PM
Post #14
Well, I was having the same problem. With the BF Goodwrench tires I had to replace the stocks, I would give it a tiny bit of extra gas around the corners in the rain and the back end was gone. Not enough to spin out, just to get the back to brake free to where I was running off the front tires.
When I got my 22" Boss 334's I had to get new tires so I got some nice low profile street tires and it is freakin hard to brake free! I have to dup it down a few gears and it draws to much attention (cops) for it to be worth the fun. But given the right conditions, I can drift in the wet weather. I did it yesterday in fact. My solution so I don't lose my insanity is going out to a field that is muddy and throwing a lil mud doing donuts. ![]()
2004 Rumble Bee #1546 4X4 Ryan Performance: Super Chips 3865, K&N CAI, Edelbrock Shorty Headers, Dual Exhaust with 18" Magnaflow Muffler and Y-pipe, Power Wire, Sonnax Line Booster, Jet 180* t-stat, Taylor 8.2mm Shortie wires, Flex-A-Lite 183 E-fan, Grounded TB. Appearance: 22" Black BOSS 334's wrapped in Nexen Tires, LED Tail Lights & Third, Shorty Antenna, Honeycomb Grill, Tint:5% Visor and Rear Window, Deadged, Retro'd 8000k Projected HID Headlights w/ SMD Halos, 3000k HID Fogs, Switchback LED Turns, Full LED Bulb Swap, Snugtop Tonneau w/ Stripe Extensions & 1546 in Stripe Other: Kenwood KDC-X994, Pioneer 5ch amp wired to 2 10" Diamond Audio Subs in a custom ported box and 2 Kenwood Door Speakers, Clifford Remote Starter/Alarm System w/ Smart Start, Husky Floor Liners, Push Button Start, Jimmy Jammers. Future Mods: Looks Like A Cam Possibly This year , Alarm Accesories (Motion Sensors, Microphone Sensors, Level Sensor, ect.)...
Posted: 12-07-2012, 09:35 PM
Post #15
Posted: 12-07-2012, 09:44 PM
Post #16
It would also be a lot easier to keep it sideways if your had a better weight distribution front to rear. The rear end is so light compared to the front there is no energy to keep it kicked. Hence the popular drift cars such as the 240 and FC rx7 which have near 50/50.
Posted: 12-08-2012, 02:26 AM
Post #17
An LSD, locker or welding the spiders would work wonders but you could still throw an open-diff vehicle into a power slide it just takes a bit more speed and practice, torque breaks one wheel free and inertia will do the rest. I don't know about skinny tires..my truck will power slide just by feathering the throttle and that's with wide and heavy A/T tires.
2004 1500 SLT RC/SB 4x4 Hemi 5.7 2006 Grand Caravan 3.3L |
Posted: 12-08-2012, 04:31 AM
Post #18
stiffer suspension, lower gears, good clutch work, weld your rear end haha
2006 Ram 2500 Quad Cab Longbed 4x4 Auto, Cummins Powered 8" BDS, 20x12 MHT MK-19, 37x13.50 Toyo MT. "Certainly there is no hunting like the hunting of man and those who have hunted armed men long enough and liked it, never really care for anything else thereafter.......E. Hemingway " |
Posted: 12-08-2012, 07:46 AM
Post #19
Posted: 12-08-2012, 10:43 AM
Post #20
Don't weld the spiders on anything you drive on the street! You can probably find a complete rearend w/LSD in a junk yard to swap out. Make sure it at least has 3.92 gears, better if it's 4.56.
| Thread Tools | |
| Looking to make my truck look more "racey" | ivegotcows671 | 3G Dodge RAM - General Talk | 69 | 10-22-2010 09:20 AM |
| can i combine these to "make" a 6" lift?? | MYfirstRAM29 | 3G Dodge RAM - Sport Truck Talk | 13 | 01-30-2009 12:54 PM |
| easiest way to make my truck look "lifted" | 04hemigtx5.7 | 3G Dodge RAM - 4X4 Talk | 22 | 04-11-2008 11:34 AM |
| How do I make it look more "Truck" like | qtipextra | 1G Dodge Durango General Talk | 26 | 12-24-2007 02:48 PM |
Privacy Statement | |
