1976 400 won't start - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Vintage Dodge Truck Forums > 1972-1987 Dodge Ram Trucks (D, W-series)
04hemi2500
  1976 400 won't start - Posted: 12-06-2012, 08:51 PM
04hemi2500's Avatar
WYOhemi
City: Wyoming
State: WY
Post #1
Hey guys-
I recently bought a 1976 dodge w300 adventurer with a 400 in it. It had been sitting for a few years with no air cleaner on it so i took the carb off cleaned it replaced gaskets and cleaned everything out I could out of the motor, replaced spark plugs, wires, starter, battery, got timing set right. It turns over and is getting spark and fuel but still won't start. Possibly not getting enough spark? Any ideas would be very much appeciated. Thanks!
Sold: 2004 Ram 2500 HEMI
New: 2012 Ram 3500 Cummins
Black Truck Club Member #91
crazzywolfie
 Posted: 12-06-2012, 09:27 PM
City: Orangeville
State: ON
Post #2
have you tried pouring fuel right into the engine?
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
91 dodge d150 short box 318 with a 2 barrel carb
93 ramcharger 318 FI 2wd
04hemi2500
 Posted: 12-06-2012, 09:53 PM
04hemi2500's Avatar
WYOhemi
City: Wyoming
State: WY
Post #3
yea i've poured it right into the carb still won't sputter or anything
B-300
 Posted: 12-09-2012, 02:07 PM
4 Wheel Power Disc Brakes
State: OTHER
Post #4
Compression test all 8 cylinders. Check plugs for fouling/flooding while they are out.
Does the distributor rotor turn? Recheck timing and for spark.
Ram Van/Wagon Club Member #4
B-300
FreeLantz
 Posted: 12-09-2012, 09:18 PM
FreeLantz's Avatar
Administrator
City: Meadows Place
View Member's FaceBook Profile
Post #5
Moved to the appropriate forum.
David Lantz
DodgeTalk Administrator
FreeLantz@DodgeTalk.com
2007 Ram 1500 Regular Cab 4x4 LWB HEMI
2007 JK Wrangler
Previous: '93 Dakota, '96 Ram 1500, '99 Ram 2500 4x4, '02 Ram 1500 4x4, '05 Dakota 4x4, '08 Magnum R/T, '08 Jeep Patriot
Forum RulesSupport Our SponsorsDodgeTalk on YouTubeDodgeTalk Facebook Group
DodgeTalk Decals For SaleVote in our Monthly Chop Challenge!
lunchbox1671
 Posted: 12-09-2012, 11:57 PM
lunchbox1671's Avatar
Fabricator Extraordinaire
City: Ephrata, WA
State: WA
Post #6
If you can get a multi-meter on the ignition system, I'd be curious how MUCH spark you are getting...
1975 Dodge D100
-Clubcab "Adventurer Sport"
-1-ton Dually
-440
-Auto
dodgensince74
 Posted: 12-10-2012, 07:13 AM
Post #7
I would put the #1 on top dead center and then check to see where your rotor is pointing in on the distributor cap, if that is good then do a compression check to make sure you have compression. After setting that long the lifters could be collapsed and you may need to prime the system to pump them up.
01 1500 5.9, Q/C, L/B, 4X4
Tanue cover
Super chips
Magnaflow S/i-D/o
K&N cai
Eagle alloy 102's
BFG LT285/75r16 A/T's
electraglide
 Posted: 12-17-2012, 06:15 AM
State: VA
Post #8
If you have spark, it should fire if fuel is getting to the cylinders. Was the hood and air cleaner on the truck for all those years? You need to pull the carb and soak it in "Solder Seal"(comes in a gallon can with a parts basket inside). Then get several different thickness bare wires that will fit into all the tubes and orifices that you can see to make sure they are clear. Be careful you do not damage anything. Make sure float needle seat and valve is not clogged. May need a new carb.
04hemi2500
 Posted: 12-18-2012, 09:51 AM
04hemi2500's Avatar
WYOhemi
City: Wyoming
State: WY
Post #9
Thanks for all the help. Finally got it started the distributor ended up being 90 degrees off
Shredder1212
  I need help on my 87... - Posted: 01-14-2013, 11:07 AM
State: WY
Post #10
My 1987 power ram 250 does almost the same thing. I can get it to turn over and it's fast but it just seems to not be able to start. I was thinking the ignition coil or something? What do you guys think??? Thanks
Just got a 1976 W100 jrodz308 1972-1987 Dodge Ram Trucks (D, W-series) 13 11-05-2012 06:28 PM
1976 RV 1-ton with 318 V-8 dorzak Dodge B-Series Vans 1971 - 2003 3 04-22-2009 04:29 PM
1976 Firebird duranged03 For Sale - Collector Cars 1 01-06-2008 10:33 AM
1976 D300 michelleb 1972-1987 Dodge Ram Trucks (D, W-series) 19 08-05-2007 08:20 AM
1976 copperhead Mopar Muscle Talk 0 07-28-2004 01:37 AM
