idle issue, need help. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 3rd Gen (02 – 08) Forums > 3G Dodge RAM - Drivetrain Talk
J.trevor123
  idle issue, need help. - Posted: 12-05-2012, 04:36 PM
Post #1
Okay I have a 2007 ram 5.7. About a month ago I changed my spark plugs, cleaned my throttle body , and had fluids changed. Anyways I noticed (dont believe it was right after these changes or have any corrilation with the changes) when i stop at a stop light for example my truck idling at its normal 600 rpm slowly drops to about 400 rpm then bumps back up to 600. Almost like my truck falls asleep and then realizes it needs to go back to 600 rpm. I notice at night it even effects my lights, for a split second when reving back up to 600rpm the lights dim.... Any clue what would cause this idling issue? by the way it does not do it everytime i am idling but often.
gtrwun
 Posted: 12-05-2012, 04:57 PM
gtrwun's Avatar
City: Modesto
State: CA
Post #2
What kind of plugs did you put in? Champion?
J.trevor123
 Posted: 12-05-2012, 06:23 PM
Post #3
yes sir champion plugs. Gapped to correct dimension
orvtenn
 Posted: 12-05-2012, 08:05 PM
orvtenn's Avatar
+ Hemi Addict +
State: TN
Post #4
An EGR valve that's on its way out can do that
2004 1500 SLT RC/SB 4x4 Hemi 5.7
2006 Grand Caravan 3.3L
J.trevor123
 Posted: 12-05-2012, 08:24 PM
Post #5
an egr valve huh. I put a brand new one in it a little over a year ago. I guess there is no way on knowing until it goes?
MoparAndy04
 Posted: 12-05-2012, 08:25 PM
MoparAndy04's Avatar
City: Twin Cities
State: MN
Post #6
I can attest to that. It happened to me three or so times. Once while idling in stop and go traffic. And twice while coming to a stop at a stop sign. I just pulled the EGR, cleaned it out with some brake cleaner, and its been good ever since.
2004 Ram 1500 SLT QC SB 4x4
5.7L Hemi w/Power Wire, Resonator Delete, 3.55's, Brembo Brake Pads
BFG Rugged Terrain T/A's - 265/70/17's, Monroe Sensa-Trac Shocks
Factory Off Road Wheels, Pioneer Head Unit, Boston Acoustics & Infinity Speakers
Bully Tailgate Lock, Access Rollup Tonneau Cover, Mopar Tail Lamp Guards
Molded Mopar Splash Guards, Sylvania Silverstar Ultras In Headlights & Fogs
J.trevor123
 Posted: 12-05-2012, 08:33 PM
Post #7
huh i guess i need to check it out. It does it almost everytime it idles
crasher76
 Posted: 12-05-2012, 10:27 PM
crasher76's Avatar
Im wired!!!
City: K-TOWN
State: WI
Post #8
does your throttle blade have a little wiggle play in it??
Black 2003 QC SB SLT 4x4 Offroad 5.7L HEMI, Original Owner 3.92 LSD, SRT CAM, 6.1 Rods/Springs, Home Ported/Polished Heads, Psc1, 04 Map sensor and Fuel pump assembly, Oil pressure guage, Amsoil, Champs, MSD 8.5MM Full length Wires, Transgo HD w/out resistor, Superchip, 180 T-Stat, K/N 77 Series, Ceramic Flowtech headers with Y-Pipe, Stage 8 locks, Ditched the cat, O2 sensor mod, Jack Rabbit bed cover, Sprayed bed liner, Big Mouth Grill-Black, Blackend Headlights/Tails, Silverstars, Ditched all chrome, Custom 10's sub enclosure, Upgraded 160 amp alt, Window tint, Relocated purge valve, Energy suspension bushings, Rear spring clamps, Passport 8500 Radar Detector, Ditched the baby seat- kid wasnt mine, Cigarette burn in the seat mod, Debadged, Custom Rewired/Properly Grounded.
J.trevor123
 Posted: 12-06-2012, 06:01 AM
Post #9
on my throttle body? not that i know of. But i havent checked since i cleaned it. When i cleaned it, it did not.
orvtenn
 Posted: 12-06-2012, 05:24 PM
orvtenn's Avatar
+ Hemi Addict +
State: TN
Post #10
Correct. The plunger on the valve usually sticks but I have seen the hole on the block plugged full of carbon, if that's the case shoot some brake cleaner up in there, just wear eye protection - the splash back burns. On these trucks, they usually won't set a code right away. I ran mine for 3-4 months with it occasionally stalling or trying to stall at lights before it finally set a code for the EGR.
J.trevor123
 Posted: 12-06-2012, 08:15 PM
Post #11
okay thanks alot, i took the egr out today and cleaned it. seemed to work. We will see with more driving.
J.trevor123
 Posted: 12-07-2012, 06:30 PM
Post #12
okay i cleaned the egr valve and idle issue was not fixed. I replacved the egr valve and still not fixed. Dont know why it wont idle consistantly... Also i romoved my PCV Valve on my throttle body and it had a oil like substance on it... thats normal?
J.trevor123
 Posted: 12-07-2012, 07:17 PM
Post #13
also notices it idles fine in park, but stopped in drive is not consistant
orvtenn
 Posted: 12-08-2012, 02:42 AM
orvtenn's Avatar
+ Hemi Addict +
State: TN
Post #14
I think they're some PCM software updates available for low idle speed if the EGR doesn't fix the problem.
J.trevor123
 Posted: 12-08-2012, 11:42 AM
Post #15
I guess I would need to take it to the dealership for updates?
help with idle issue hpauto 3G Dodge Ram Performance Talk 7 06-26-2012 06:31 PM
idle issue Challopy 3G Dodge RAM - Drivetrain Talk 0 04-09-2012 02:38 PM
Idle issue gt40girl Dodge Magnum - Performance Talk 0 04-16-2011 06:59 PM
Idle issue Machzzzz1 3G Dodge RAM - General Talk 32 03-16-2011 08:23 AM
idle issue syfir Dodge Neon - General Talk 5 10-04-2010 03:05 PM
