'87 W150 auto trans woes - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Vintage Dodge Truck Forums > 1972-1987 Dodge Ram Trucks (D, W-series)
electraglide
  '87 W150 auto trans woes - Posted: 12-04-2012, 02:03 PM
State: VA
Post #1
So, I've had this tranny leak on my Torqueflite 727 since I got the truck. It's not the pan and it's not the stick tube this much I know. It's leaking from above down the right side of the case. I can't see where it's coming from. On top of that, there is this gooey stuff that is running down the case that is like chewing gum. Does anyone know what this is and where the leak could be coming from. The trans works fine.
Moparite
 Posted: 12-05-2012, 07:01 AM
Post #2
It may be a crack. There's nothing that can leak on top it's one complete housing.
electraglide
 Posted: 12-05-2012, 10:51 AM
State: VA
Post #3
Thanks! I don't think it's a crack though. I'm thinking it's the dipstick tube seal afterall and what I'm seeing down the case is that gooey stuff melting from above. It's grey in color and sticky like chewing gum. Any idea what is melting from above?
maachine
 Posted: 12-05-2012, 01:23 PM
maachine's Avatar
City: Hammond
State: LA
Post #4
there is a plug of some sort at the tope of the trans. i have a 727a sitting in my garage that came out of my 87. i could take a picture and you can see what it looks like
1987 Dodge W-150 "The Beast"
2" Lift
33" AT's
318 build currently in the works
208/727A w/3.21 gears
electraglide
 Posted: 12-05-2012, 01:39 PM
State: VA
Post #5
that would be great! Thanks!
acton mike
 Posted: 12-05-2012, 04:30 PM
City: acton ontario
Post #6
check to be sure that you do not have a leaky rocker cover gasket
the oil can run down the engine and onto the bell housing and then onto the transmission and trick you into thinking there is a transmission leak
maachine
 Posted: 12-05-2012, 07:24 PM
maachine's Avatar
City: Hammond
State: LA
Post #7
sorry electraglide. i was thinking about the transfer case and not the transmission. transmission is just bare case on the top. nothing fancy. if you sitll want that pic i'll get one for you.
as someone mentioned, could be oil. valve cover gaskets or the oil sending unit could be leaking.
2" Lift
33" AT's
electraglide
 Posted: 12-05-2012, 09:33 PM
State: VA
Post #8
that's cool then i don't need the pic. definitely tranny fluid. yep, red! took the filler tube out today and got a new o-ring. And it looks like the new ring is the same diameter as the tube as it is fitted in the groove. i wonder if i should get the next size bigger?
electraglide
 Posted: 12-07-2012, 08:29 AM
State: VA
Post #9
as a followup I finally got the tube and new seal replaced and eureka! No more tranny leak. I had to straighten the tube some since it had been crimped in 2 places, but a small price to pay for nearly 5 years of leaky mess. Thanks to all that took an interest.
roadram360
 Posted: 12-08-2012, 07:35 PM
roadram360's Avatar
City: mostly on the road
State: LA
Post #10
that thick goo could be from the voltage regulator sealer leaking
you like your truck more than you like me. sometimes i do
1978 d-150, 95 360, eddy 750, 4 speed auto, 9.25 rear. her name is sabrina
GOD BLESS AMERICA
http://s745.photobucket.com/albums/x...am360/sabrina/
www.waltonandjohnson.com
www.marklevinshow.com
www.michaelberry.com
*DodgeTalk.com 318 Enthusiast Member #(129)*
electraglide
 Posted: 12-09-2012, 04:22 PM
State: VA
Post #11
Thanks, Roadram! I'll check it.
stosh562
 Posted: 12-16-2012, 01:04 PM
City: Solon
State: OH
Post #12
those dipstick tubes do have a tendency to leak alot. i have replaced a few over the years. mostly just annoying
electraglide
 Posted: 12-17-2012, 05:55 AM
State: VA
Post #13
You got that right! thankfully, mine is still holding. Thanks.
Auto to manual swap 1990 w150 codyglock Dodge Ram Truck 1st Gen (88 - 93) Forum 3 12-05-2012 01:06 PM
1987 Power Ram auto tranny woes electraglide 1972-1987 Dodge Ram Trucks (D, W-series) 4 01-08-2012 07:19 AM
Industry woes cast pall over Detroit auto show Ram3500Dually Rumor Mill & Gossip Talk 0 11-27-2008 08:30 AM
Auto woes will endure through all of 2008 RAM MAN Rumor Mill & Gossip Talk 1 02-29-2008 05:17 PM
1984 W150 trans. problems 10cylinderRAM 1972-1987 Dodge Ram Trucks (D, W-series) 8 11-13-2006 02:55 AM
