rough idle - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Dakota 2nd Gen (97 - 04) Forums > 2G Dodge Dakota Performance Talk
mmkkpro
  rough idle - Posted: 12-03-2012, 11:42 PM
State: WV
Post #1
Got a 97 dak 3.9,have checked for vac leaks,no check engine lights are on,is it possible to put a carb on this engine,i know carbs,fuel injection is alien to me im old xschool seems like to much crap to go wrong with FI,give me a 1970 440 in happy
IronHorse98
  idle - Posted: 12-14-2012, 05:08 PM
IronHorse98's Avatar
State: GA
Post #2
For the idle, i would get new gas and use gas treatment with it (seafoam). I would then check for a blown intake gasket, the belly pan gaskets on the 5.2 and 5.9's are known for blowing out. Not sure on the mechanics of the 3.9, but something to look at. Also, change the plugs, wires, cap rotor-button, and coil. Cant hurt. Anything else would be guessing by me, im not familiar with the 3.9, these suggestions are just basic knowledge. Hope this helps.
1998 2wd R/T CC, 3inch lift, 32/11.50/15 Nitto's, 4:56 gears, 5 speed conversion, full exhuast header to dumped flowmaster, in bed tire carrier, all badges removed, pre-runner front tube bumper, lights everywhere, BIG ASS GREDDY RADIATOR with 21 inch fan, 5.9 + 5 speed= alot of offroad fun.
Future mods: Carb conversion, 408 stroker, 4 link rear suspension.
"If your too scared to carry your truck offroad, take your pansy ass and go buy a honda" - Robby Gordon..
mmkkpro
  rough idle,no power - Posted: 01-03-2013, 02:51 PM
State: WV
Post #3
thanks,today i pulled all plugs found 2nd plug on passenger side wet,did compression test and all cylinders tested at 125 psi,so i am in process of changing cap rotor and putting accel super stock 7mm wires on too.I have ran seafoam through it,no change,cleaned iac valve and port.So soon as i get these wires made got to custom make them will give another report,ive got a 1993 full size gmc with a 4.3 and it will run circles around this dakota,im not knocking my dakota i really like it but its a dog right now.
mmkkpro
 Posted: 01-16-2013, 04:25 PM
State: WV
Post #4
ok report time today i put an accel super coil on the truck pulled the number 4 plug wet with gas no surprise,cleaned plug put it back in ran some carb cleaner through my pcv valve cant get it out checked over the engine for loose conections found none put air intake system back on started engine still had a skip,so took it for a test drive by the time i got around the block idle had risen to 1400 from 900 skip is gone,idled it back down running on all cylinders now but im still suspect something is still wrong,seems it runs much better when its hot than cold,i suspect possible small head gasket leak and belly pan gasket,but the skip is gone for now so im happy,ive used sodium silicate to seal head gaskets in the past works great,im learning my dodge i really like the truck want to fix her up mabey v8,anybody got a 1970 440 laying around?id settle for 360,im definately going back old school on it asap,i like carburators and msd ignitions simple and run great,thanks to all that helped me im sure ill be back soon
mmkkpro
 Posted: 01-17-2013, 10:29 AM
State: WV
Post #5
drove truck to pittsburgh from morgantown wv 160 total miles used whole tank of gas ran like crap,pulled #4 plug its dry now but something else is wrong zero power,ive had it going old school goin to save some money find a 1970s 318 carb reg ignition and puttin it in,they can take all these sensors,computers and trash them,it takes an aerospace enenginer to find the problems on these things simple is best,compression ,gas ,spark it runs period
Rough Idle wagntwister 3G Dodge RAM - General Talk 0 01-27-2010 08:04 AM
rough and low idle 02patriotcrew Dodge Dakota 1st Gen (87 -96) Forum 1 10-28-2006 02:13 AM
4.7 rough idle blackice85 1G Dodge Durango Performance Talk 9 08-26-2005 09:32 PM
Rough Idle ? BDickinson 1G Dodge Durango General Talk 26 06-09-2004 11:24 PM
Target idle/rough idle ss62 3G Dodge RAM - General Talk 13 06-30-2003 09:29 PM
