Thread Tools |
Subwoofer Suggestions for 03' QC
- Posted: 12-01-2012, 03:18 PM
Post #1
Hey guys...
With Christmas coming up I am interested in adding some subwoofers to my 2003 ram 1500 QC. My price range is around $500... may go a little bit higher, but nothing ridiculous. I have read quite a few threads, but am still not completely clear on exactly what will be best for my needs. Most people seem to suggest the fox box: http://www.foxacoustics.com/ProductD...Code=DQC-210-V It seems that this would be the best choice for me. My concern is then what subwoofers/amp would work the best. Alpine Type R's seem very popular... Will I need anything besides the enclosure, subs, and amp? Power Wire and any other wires? Any suggestion or insight is welcomed! |
| Sponsored Links | |
Advertisement |
Posted: 12-01-2012, 04:56 PM
Post #2
Joe Fox makes the best bang for the buck. I have had two different styles of his boxes and both have been great. I do want to try his newer ported box but Ive got other projects right now
In my FB I have a pair of Kicker CVR 2ohm DVC subs rated at 400/800 each. Each sub is wired in parallel and then in series to get a 2ohm load on my mono channel amp for 800/1600 watts
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires) | Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights | Link to my gallery ![]() Next projects: - Custom center console - B&M Quicksilver Floor shifter - Custom CAI |
Posted: 12-01-2012, 06:58 PM
Post #3
What amp would you recommend with those subs?
Posted: 12-01-2012, 07:05 PM
Post #4
I run an Audiobahn class D mono amp. You can use anything you want though but have to decide what subs you want first, then match the specs with an amp.
Posted: 12-02-2012, 05:36 PM
Post #5
So I am thinking about reducing cost and going with just one sub.
What do you think about the single driver side 12" foxbox with this sub: http://www.bestbuy.com/site/Kicker+-...7#tab=overview Wire it: http://www.the12volt.com/caraudio/wo...s.asp~Q~1~I~42 What amp would be my best bet then? I would still get plenty of bass out of this setup, while saving some cash also. |
Posted: 12-03-2012, 08:26 PM
Post #6
You can buy two NEW Kicker CVRs off ebay and shipped for that price in the link you have.
My setup!
- Posted: 12-03-2012, 08:35 PM
Post #7
I have 2 kicker 12s in my single cab and they sound amzing for the price u get them at. It would be a good idea to run a cap if possible. Itll save your battery and give your system more power. My amp is 500 watt rms kicker and power these subs at their peak.
Posted: 12-04-2012, 09:06 AM
Post #8
The woofer at Best Buy would be the best option, as they are an authorized Kicker dealer, so you walk in and get problems resolved if any arise, versus sending back to ebay seller.
If you get the CVR 12" there, look at the Kicker DX500.1 they have as well...that'll do it nicely!
2011 Ram Express, KMC 22" Slides on Nitto 420s, Kicker sound system, Extang Trifecta, Bedrug, Ground Force 2" leveling, MGP Caliper covers, Retroshop tinted headlights and tails, Code Alarm remote start, AAC interior and licence plate LEDs, |
Posted: 12-04-2012, 09:59 AM
Post #9
The only issue you are going to have from a sub is if you abuse it. I have had those same Kickers off ebay for several years now. No issues. You can buy them with a Square Trade warranty if you want for up to 2 or 3 years. Buying one at 75-80 versus 150+ is a big difference
I'm about supporting local businesses but at the time, I need to protect my wallet also
Posted: 12-04-2012, 10:03 AM
Post #10
Problem is, some ebay sellers are here today, gone tomorrow, so you may not get that 2-3 year warranty. Now what is freight to ship that woofer back to them? $20? Now your out of a sub, maybe a week, maybe two. Where at BB you can walk in, and get replacement that second.
All I'm saying is what sounds good from the get go, may cost you more in the long run. Warranty from Ebay sellers ( most ) are not covered by Kicker.
Posted: 12-04-2012, 08:18 PM
Post #11
The warranty would be through SquareTrade, not ebay or the seller.
Posted: 12-05-2012, 01:13 PM
Post #12
Understand, but that woofer has to be replaced by Kicker, which it warranties an authorized dealer only.Unless Squaretrade has ample inventory of more woofers to replace with.
Posted: 12-05-2012, 01:23 PM
Post #13
If they can't fix it they refund you the purchase price.
Posted: 12-05-2012, 01:26 PM
Post #14
which is more likely the case. Kicker wont authorize coverage if sold outside the warranty policies.
Posted: 12-05-2012, 01:28 PM
Post #15
You should check out Square Trade. They warranty all kinds of electronics such as phones, tablets, iPads and more.
Posted: 12-05-2012, 01:55 PM
Post #16
I'm sure they do, and understand how they do it, it's just a warranty/insurance program. You get paid if you hurt it, etc. I was just stating if you think you'd get a warranty from Kicker, it would be null.
Posted: 02-25-2013, 03:54 PM
Post #17
The only slamming cvr.s do is in a trash can where they belong. Get a good quality sub and stay away from the "name" brands. Get something like american bass, or sundown, ssa, tc. They can be found cheap and one of them will over power and outlast cvrs any day.
2008 Dodge Ram 1500 5.7L 4x4 - 3" Dumped Exhaust, Superchips 91 Performance Tune, Superchips Trans Tuning, No Cats, Y-pipe, Powerwire, 4" CAI, 1- 12" Alpine Type X, Pioneer Head Unit, Pioneer I-Pod hookup, Alpine mrd m1005, Infinty sound system upgrade, Infinity Reference 6by9s in door, Bell Radar Detector, 400 Watts Aux Lighting (Behind Grill), Recon Headlights, Recon Tailights, AVS Color Matched Vent Shades, 2" Drop Shackles, Full leather interior swap, Painted rads, 2/0awg big 3, Dual Agm Batteries |
Posted: 02-25-2013, 04:39 PM
Post #18
Not to mention, unless you are custom building a box, clearance is an issue. Thus, you are limited to what brands will fit. I've had my kickers CVRs for several years. I have two db spl meters and have hit 152 in my truck. There is a video on youtube of it
Posted: 02-26-2013, 09:22 AM
Post #19
![]() And how does a sub 'over power' others?
Posted: 02-26-2013, 10:49 AM
Post #20
Yeah, I wasn't going to say anything but I've always considered to be on the same level as Pyramid. It's the stuff you see at flea markets trying to be sold for $50 for 1000 watts
| Thread Tools | |
| Suggestions for securing a subwoofer box | holek | 2G Dodge Durango - Interior/Exterior | 12 | 02-22-2009 02:09 PM |
| Subwoofer and enclosure suggestions | BoneDryRacer | 3G Dodge RAM - Interior/Exterior Talk | 9 | 09-28-2006 08:48 PM |
| Subwoofer and enclosure suggestions | BoneDryRacer | 3G Dodge RAM - General Talk | 0 | 09-27-2006 08:13 AM |
| Subwoofer Suggestions | bdcustoms | Mobile Audio & Electronics Talk | 9 | 12-28-2003 09:05 AM |
| Subwoofer Box??? | josegarcia124 | Mobile Audio & Electronics Talk | 6 | 06-28-2003 11:25 AM |
Privacy Statement | |
