Aftermarket Fuel Pump???? HELP NEEDED - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 14 Old 11-26-2012, 08:05 AM Thread Starter
SinnerRam6
Ram 4.7L Yellow Jacket
SinnerRam6's Avatar
I've ben looking for an aftermarket fuel pump but cant seem to find much, or any for my truck.
I need on for a 2002 Dodge Ram 1500 4.7, if anyone has any info or knows of any compant who makes the, please let me know.
I'm looking for a larger more powerful fuel pump to run my Eaton M112 that i am putting on my truck,
http://www.dodgetalk.com/forums/showthread.php?t=363824
SiNNeRRaM6
Black Truck Club # 606
SUPERCHARGED 02 Dodge Ram 4.7L Build Thread (Yellow Jacket) Link:
If You Can't Dodge it . . . RAM it!
Engine MoDs: E-Fan, Custom CAI W/ Spectra filters, Jet Stream Scoop, Breather filter, 72mm F/B Throttle Body, HO Cams, Knolton Thunder Race Ported Heads, Comp Cams high load Springs and Valves, ARP Studs, Custom LongTube Pacesetter Headers, 180* T-Stat, True Dual 3" pipes into Magnaflow X-Pipe into dual AT3030 Aero Turbines dumped before rear axle, Custom Mount with Oil & Transmission Coolers, Superchip, 4.56 Gears Detroit true trac, Optima Battery, (Red Top), SS Braided Insulated Fuel Rails, Walbro 255 Fuel Pump, Color matched valve covers, Sonnox Line Pressure Booster, ATI Harmonic Balancer, Eaton M112 with "Steg" Venom Cooler, 2.8" Upper pulley w/ quick change hub, Custom built plenum, Custom built intercooler adapter plate, AutoMeter Boost Guage, Air/Fuel Guage, Trans Temp Guage, Innovate LM-2 Wideband data logger, SCT Tuner and Boost Tuned, Custom intercooler water tank, Dual Heat Exchangers with custom mount, Devils Own Water/Meth Injected, PowerMax 250 Amp High output Alternator, 06 Hemi Fuel Pressure Regulator, NGK2668 Plugs.
Exterior MoDs: Blacked Out Tail lights & 3rd Braske Light, Halo Projector Headlights, 5% Timts, (ALL around), 20' XTD Rims, (Blacked out), Diamond Plated Toolbox, (Nitrous case), Custom Limited Ed. Ram Air Hood, Aluminum Black Lower Bumper Grillie and custom painted upper billet grille, Blacked out hood Ram badge, "RAM" blacked out letters on grillie.
Inside Mods: JCV Amp w/ dual 10' Kickers, Custom Door Speakers and Alpine Radio, Remote Start w/ Alarm, 3 Pod Guage Pillar.
SinnerRam6 is offline
post #2 of 14 Old 11-26-2012, 09:16 AM
DannyMK2
DannyMK2's Avatar
Quoted: 12 Post(s)
you could ditch the in tank pump and go frame mounted. then pick the fuel pump of your choice.
2012 Express QC 4x4
2004.5 QC DRW 3500 Cummins 4x4
1998.5 QC DRW 3500 Cummins 4x4 - SOLD
2002 Ram 1500 QCSB 4.7L 4x4 - SOLD
Dodgetalk.com 287 Enthusiast Member #108
DannyMK2 is offline
post #3 of 14 Old 11-26-2012, 12:21 PM
HemiLonestar
Red Trucker
HemiLonestar's Avatar
Quoted: 43 Post(s)
What is your stock fuel pressure? One of the 2003 hemi upgrades is to use either an 04/05 pump or scavenge the regulator out of one. The 04+ run 10psi higher than the 03's (48 vs 58 IIRC). Might help unless you need pressure beyond that, then the above suggestion may be the way to go.
2003 Ram 1500 QC Hemi Lonestar "Big Red" & 2006 Charger R/T "Little Red"
SRT-10 suspension, brakes and interior parts, Circle D, Bilsteins, Superchips, AiRaid, Taylor shorties, McGaughy's shackles, Borla cat-back, Extang Tonneau, Sonnax, Power wire, Daytona lip, tow mirrors, SRT hood.
Mods to come: 06+ coil conversion, Comp 260 install, 05 PCM conversion.
Sarcasm - it beats killing people.
HemiLonestar is offline
post #4 of 14 Old 11-26-2012, 05:02 PM Thread Starter
SinnerRam6
SinnerRam6's Avatar
Thx! i'll look into the hemi pump, if not i'll have to mount it on the frame.
SiNNeRRaM6
post #5 of 14 Old 01-25-2013, 10:43 PM
AIR_RAM
AIR_RAM's Avatar
Quoted: 19 Post(s)
I have a HEMI pump in storage... Ill grab that in the morning... But we are not even sure it would be enough...
Your Should be making around 400RWHP at 10psi... Not sure if the HEMI pump is up to that.
SPEED SAFE, AIR RAM
4.7L PERFORMANCE ENTHUSIAST - DODGE RAM's, DAKOTA's, DURANGO's & JEEP's.
AIR_RAM is offline
post #6 of 14 Old 01-25-2013, 11:16 PM
Redtruck-VA
Redtruck-VA
Redtruck-VA's Avatar
Quoted: 4 Post(s)
I read where a SRT10 pump might work. Uses a 255 Walbro.
Greg
2003 RCSB SXT-Hemi - OEM Durango rims/275/60-18 tires, AeroForce-w/wideband, Trans 46RH, PPP Track Warrior, 6.1 dual coil ignition, 05 fuel pump, w/external reg, K&N -77 CAI, 90 BBK TB, 20% U/D, eFan, TCI FastGate shifter, AutoMeter Shiftlite, 180 thermostat, 2500HD OEM Trans Cooler, 3000 stall Edge Converter, 2500 manual PCM, DTT 4:10, LT's, Magnaflow SI/DO, duals cats, Mcgaughys 3/6 spindle kit, Caltracs traction bars, Aeon springs for bump stops Frt/Rear, 04 Laramie leather SLT 10 way seat and SLT leather steering wheel, CD/radio, stand alone OEM foglights, billet grille inserts, painted cowl (shaved) and upper bumper cover, Shaved tailgate w/EZdown, Shaved Antenna, Amplified hidden antenna, sliding rear window, welded steel Roll Pan, Hidden hitch, Sport mirrors, Painted Front bumper, Fiberglass tonneau cover, OEM bed liner, Triple gage pillar, billet gas door, de-badged, tint strip. With 89' D250 Diesel support vehicle.
Redtruck-VA is offline
post #7 of 14 Old 01-26-2013, 12:38 PM
darell_n
Boost, you say!?
darell_n's Avatar
SPEED SAFE, AIR RAM
I was running 9psi on my stock 5.7 with a stock '04 Hemi pump and it wasn't leaning out. After a built engine I upgraded my fuel system.
Cheap. Fast. Reliable. (Pick 2)
darell_n is offline
post #8 of 14 Old 01-26-2013, 05:07 PM Thread Starter
SinnerRam6
SinnerRam6's Avatar
My tunner said I'm leaning out around 4000k with my stock pump now. I bought a walbro 255 however upon removing the pump pump housing from my 2002 tank I realized I can't get the pump out of the module and it seems like a plastic ring was machined pressed into it to secure the pump. Does the 04/05 fuel pump come with the whole housing that I can just drop back into the tank or do I need to modify it?
Also ill be running 10PSI with a 4.7L. I still have stock internals in the block but everything else is aftermarket, do you think that it will be enough pump or a large enough upgrade from what the stock pump capabilities were to get the fuel I need?
And last do you have a link or part number for the pump you used!?
SiNNeRRaM6
post #9 of 14 Old 01-26-2013, 05:57 PM
darell_n
Boost, you say!?
darell_n's Avatar
I'm not sure if the 4.7 and 5.7 pumps are the same, and I don't have any part numbers. That's the dealership's job, sorry.
darell_n is offline
post #10 of 14 Old 01-26-2013, 09:46 PM
mirada80
2005 Hemi Ram
mirada80's Avatar
Quoted: 2 Post(s)
As long as the tanks are the same which i think they are, you probably could use an srt 10 pump. It would be direct swap, sending unit and all, and should support over a good bit over 500 horsepower. They only thing that may need changed would be the pigtail to the pump. Heres the flow from the 4.7 pump to the srt pump. Ill add the 5.7 aswell. All are for 26 gallon tank which u should have being rcsb.
4.7
Maximum Free Flow Rate (gph):
65
Maximum Pressure Range (psi):
100
Minimum Free Flow Rate (gph):
55
Minimum Pressure Range (psi):
90
Srt 10
90
115
80
105
5.7
80
115
70
95
2004.5 2500 QC SB 4x4 5.9 H.O.
MODS | Studded | Cold Air | 5" Turbo Back | Fass Fuel | Tinted Windows | HIDS
03 Silver Dodge Ram 1500 4x2 5.7 Hemi
MODS | Home Brew Ram Air CAI | Superchips 3815 | Comp Custom Grind Cam | 6.1 Springs And Pushrods | 06+ Coil Conversion | High Idle Mod | Summit Racing 25% Underdrive | Circle D 3200 245mm converter l TMR Mod | Sonnax Line Pressure Booster | Pacesetter Longtubes l Matching Off Road Y-Pipe l Magnaflow 14" SI/SO muffler | Electric Fan | 180 Stat | Walbro 255 With 05 Sending Unit | Auburn Limited Slip| B&M ProStick Ratchet Shifter | Custom Gauges | Custom Shifter Surrond | Ventvisors | Debadged | Tinted Tails | Tinted Third Brake Light | Smoked Headlights | 5000k HIDS in heads | 3000k HIDS in fogs | Roll Pan | Shorty Antenna | Custom Painted Grill | Street Scene Bumper | Poor mans 2/4 Drop | Dipped 17" Ram SS/T Wheels With Radials | 2009+ Chrome 20's | And A Little Bit of ZEX
BEST 1/8-Motor-8.43@80.52__Spray-7.85@89.12
BEST 1/4-Motor-13.38@98.9_Spray-12.27@110.42
BEST 60'-1.75
SOLD05 Patriot Blue Pearl Dodge Ram 1500 4x4 5.7 Hemi
mirada80 is offline
post #11 of 14 Old 01-27-2013, 10:15 AM Thread Starter
SinnerRam6
SinnerRam6's Avatar
4.7
65
100
55
90
Srt 10
90
115
80
105
5.7
80
115
70
95
I heard that the srt 10 pump is different from the 4.7 or hemi. I'm going to look further into it though. I actually thought about doing an entire fuel tank swap with the srt 10 tank, fuel pump and all, I just don't know if the connections would be the same.
SiNNeRRaM6
post #12 of 14 Old 01-27-2013, 10:58 AM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 247 Post(s)
Have you thought about a fuel cell?
dmcelhannon is offline
post #13 of 14 Old 01-27-2013, 11:56 AM Thread Starter
SinnerRam6
SinnerRam6's Avatar
I have, but I'm trying to keep this fuel pump thing as low $ as possible without sacrificing quality. I'm hopping the hemi pump will work since I have a 4.7 and add boost a pump if I need to.
SiNNeRRaM6
post #14 of 14 Old 01-27-2013, 09:51 PM
dmcelhannon
Admin - David Mack
Quoted: 247 Post(s)
Yea, it would put a bent in the bank account.
    1983 dodge ram d150 fuel pump/fuel problem-PLEASE HELP! breeze4400 Dodge Ram Truck 1st Gen (88 - 93) Forum 0 02-21-2011 10:54 AM
    converting a 85 dodge from a mechanical fuel pump to electrical fuel pump 85feedtruck Dodge Ram Truck 1st Gen (88 - 93) Forum 2 12-13-2010 10:37 PM
    Low Pressure Electric Fuel Pump & Rubber Fuel Lines Conversion cooktimj 1972-1987 Dodge Ram Trucks (D, W-series) 6 07-24-2010 01:05 AM
    Fuel PUMP recommendations or Change Fuel Pump Module-1990 B250 van -0 Roadtrek Dodge Ram Truck 1st Gen (88 - 93) Forum 1 08-24-2009 10:14 AM
    Fuel Pump replacement-B250 1990 - Fuel Pump Module Roadtrek Dodge B-Series Vans 1971 - 2003 5 07-24-2009 10:18 AM
