Steering pump off set - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 12 Old 11-24-2012, 03:09 PM Thread Starter
Warlock's Dad
Quoted: 17 Post(s)
Wanda has always had the pump mounted a belt's width ahead of the flywheel pulley (5/16"?). Not a problem until last night when the belt came off on the highway.
I've looked at it before and it's not a matter of washers or spacers. The bracket for the bump has a factory offset that moves the pump forward. I'm thinking I have the wrong bracket. If the bracket was flat the pulley would appear to line up. Any thoughts or pictures would help.
Question, at the top bolt there is a bracket between the bracket and the block. Should it be in that order?
Or are their likely to be spacers between the pump and the pulley?
Also in the picture it looks like the bracket bends forward a bit at the the bottom. In real life I think it is straight (vertical) (other than the offset).
Thanks Grady
Wanda - 1978 Shortbed Warlock clone
1972 318 w/ lock-up 727 (not the 360 advertised)
In her 2-3 life - too many new parts to list
Poly steering "rag joint" and steering box braced
Poly mounts/bushings, springs & suspension parts
Upgraded cooling & fans
Front Sway Bar added
Warlock's Dad is offline
post #2 of 12 Old 11-24-2012, 07:00 PM
Roanoker494
I just went and took a picture of the setup on my 1978 D200 and I will post it as soon as I get to my computer.
Johnnie Watkins
1978 Dodge D200, 318, 2bbl, 2wd, 4spd
Roanoker494 is offline
post #3 of 12 Old 11-24-2012, 07:04 PM
dodgensince74
Quoted: 11 Post(s)
maybe the crank should have two pulleys or it could be the wrong pump??? I check orielly's site and they show two different pumps for your truck
01 1500 5.9, Q/C, L/B, 4X4
Tanue cover
Super chips
Magnaflow S/i-D/o
K&N cai
Eagle alloy 102's
BFG LT285/75r16 A/T's
dodgensince74 is offline
post #4 of 12 Old 11-24-2012, 07:44 PM
Roanoker494
Here is that picture, though mine is a 318.
Uploaded with ImageShack.us
Johnnie Watkins
post #5 of 12 Old 11-24-2012, 08:24 PM
maachine
maachine's Avatar
Quoted: 45 Post(s)
My old 318 had a quad crank pulley setup on it. 2 for main belts and one is for power steering, one is empty, if I recall correctly.
1987 Dodge W-150 "The Beast"
some sort of lift
33" AT's
LA 360 bored .030 over, EQ Magnum heads, Hooker Headers, true dual exhaust, Holley 4160 w/Truck Avenger parts, Edelbrock Performer dual plane intake, StreetFire ignition box & MSD coil
208 t-case/727A trans w/3.23 gears
maachine is offline
post #6 of 12 Old 11-25-2012, 11:54 AM Thread Starter
Warlock's Dad
Quoted: 17 Post(s)
The 2 pumps they list are the same for a 225, 318 & 360. I'll check and see if they have different bracket to pulley lengths.
Roanoker - Thanks for the picture. I tried to compare the nose lengths and they appears to be the same.
Grady.
post #7 of 12 Old 11-27-2012, 11:25 AM Thread Starter
Warlock's Dad
Quoted: 17 Post(s)
The belt came off again so I replaced it and took a (quick) closer look.
I think the bracket is a little bit bent so that the pulley angels towards the radiator. The outside (fender side) of the pulley is on a plane with the crankshaft pulley groove.
I'm wondering if I could shim it back with an extra couple of washers? I don't think I could twist it back into straight w/o heat or a press. Might look for a used one too. Something to consider this weekend.
post #8 of 12 Old 11-27-2012, 06:23 PM
lunchbox1671
Fabricator Extraordinaire
lunchbox1671's Avatar
I had to "shim" an alternator bracket on my Jeep with washers. It worked well. Not perfect, but it reduced the stress on the belt and the bearings in the alternator.
1975 Dodge D100
-Clubcab "Adventurer Sport"
-1-ton Dually
-440
-Auto
lunchbox1671 is offline
post #9 of 12 Old 11-27-2012, 08:51 PM
roadram360
roadram360's Avatar
i think an extra pulley on the crank will get you going
you like your truck more than you like me. sometimes i do
1978 d-150, 95 360, eddy 750, 4 speed auto, 9.25 rear. her name is sabrina
GOD BLESS AMERICA
*DodgeTalk.com 318 Enthusiast Member #(129)*
roadram360 is offline
post #10 of 12 Old 12-05-2012, 06:34 AM
rafaelsmall94
rafaelsmall94's Avatar
A lever on the other hand can be useful on times.
Life's like this
Old classic
rafaelsmall94 is offline
post #11 of 12 Old 12-05-2012, 05:42 PM Thread Starter
Warlock's Dad
Quoted: 17 Post(s)
It's holding so far with a new belt and a bit tighter. Not much to lever against except the headers, the pump reservoir and it's bolted into/through the water pump and block.
I think taking it ff and using a persuader might be better. But I'm really hoping one comes up on eBay.
post #12 of 12 Old 12-05-2012, 06:16 PM
lunchbox1671
If you can get it in a vice and use a torch, that would be better than hammering/cold-bending. When you hammer and bend metal when it's cold, it's waaaaayyyyyy more likely to crack/fail...
1975 Dodge D100
-1-ton Dually
-440
-Auto
    Steering pump going? MaceDew 1G Dodge Durango - Tire/Wheel/Susp Talk 4 04-03-2009 11:41 PM
    steering pump jakerboy 1972-1987 Dodge Ram Trucks (D, W-series) 1 05-17-2007 01:28 PM
    Better Than OEM Steering Pump? Ramin N' Jamin 2G Dodge RAM - 4X4 Talk 8 12-30-2006 11:36 PM
    Power Steering pump travistlo 2G Dodge Dakota - Tire/Wheel/Susp Talk 0 07-09-2005 04:32 AM
    steering pump light 2G Dodge Stratus - General Talk 1 04-27-2005 06:26 PM
