315s on a 2500 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 3rd Gen (02 – 08) Forums > 3G Dodge RAM - Tire and Wheel Talk
JFM-jr
  315s on a 2500 - Posted: 11-22-2012, 08:21 PM
JFM-jr's Avatar
City: Long Island Suffolk Cnty
State: NY
Post #1
Does anybody know what I will need to fit a 315 or a 35 on my 09 2500? level kit,a lift? Will going to an aftermarket rim make my life easier? these 265's gotta go man they look silly on this truck.
04 Hemi powered Ram QC 1500 Sport Gone
09 Hemi powered Ram QC 2500 Sport
Fuel Boost rims 17x9 +20MM
Nitto Terra Grapplers 305/70/17
OEM 4.56 gears
SuperChips Cortex 3950 (1449666)
04Ram2500Hemi
 Posted: 11-22-2012, 09:07 PM
04Ram2500Hemi's Avatar
Same Name, Different Game
City: Missoula
State: MT
Post #2
You can run a 33" tire on the 2500's with no lift and they look great. If you do a 35" tire I'd recommend a 2" leveling kit.
2012 Ram Power Wagon
Truxedo Deuce Bed Cover with Bed Lights, Black Line-X Rocker Panel, Custom Built Rock Rails Sprayed with Line-X, Front & Rear Bumper and Grill sprayed with Line-X, Husky Mud Flaps, Husky Floor Mats, Four VisionX Xmitter Low Pro Prime XP LED Light Bars Behind the Grill, Two Vision X LED Lights on Rear Bumper, Heated Seats
Gone But Never Forgotten!
2004 Ram 2500 4X4 SLT Quad Cab Hemi Silver Metallic, Black Line-X Rocker Panel, Westin Nerf Bars Sprayed with Line-X, Bushwacker Extend A Fender Sprayed with Line-X, Rhino Lining in the Bed and Over the Rails, Truxedo Low Profile Tonneau Cover, Hell 500's Behind the Grill, Warn Front Receiver, KC Backup Lights, Custom Mounted Bumper Backup Lights, V-7 V Force Muffler, Auto Meter Transmission Temperature Gauge, SRT-10 Pillar Grab Handle, Kore Recon Suspension System, Kore Race Steering Damper, Kore Chase Control Arms, Kore Coil Spring Isolator, Kore End Links, 35x12.50 Mud Terrain SXT Tires, SRT-10 Hood, AEM Brute Force Intake, Wet Okole Seat Covers, Smoked Recon Cab Lights, Tuff Stuff 12,500 Pound Multi Point Winch
cumminsmannow
 Posted: 11-23-2012, 06:14 AM
cumminsmannow's Avatar
diesel guy
State: MN
Post #3
I ran 35's on both of my 3rd gen 2500's and had less problems without a lift. I tried a 2" leveling kit and it made the tires rub on the mud flaps because the tire was closer to the rear of the wheelwell. I took the levelers out and it didnt rub at all any more on the flaps.
I had stock wheels and they did rub a little on the lower control arms at full lock so i added a set of 3/8" wheel spacers and no more rub at all.
With an aftermarket wheel you will have to get as close to the factory offset as possible to not have issues.
2012 2500 megacab 4x4 hemi laramie.
Mineral grey/ Bright silver bottom.
JFM-jr
 Posted: 11-23-2012, 06:52 AM
JFM-jr's Avatar
State: NY
Post #4
If you needed a 3/8 spacer on the factory rim then why would I want a factory offset? Wouldnt I want an offset that avoids me needing that spacer?
OEM 4.56 gears
cumminsmannow
 Posted: 11-23-2012, 07:43 AM
diesel guy
State: MN
Post #5
Yes but it is hard to find in aftermarket wheels. Unless you get xd's or spend alot of money on them it seems like all the manufacturers want the wheels pushed way out and have a shallow backspacing. The incubus wheels i had on my 12 had a good combo of offset and width but i never had 35's on them to see how they fit. If i remember correctly the factory wheels are +43mm offset. And my incubus ones are a 9" wheel with a +21mm offset.
ramminsilver
 Posted: 11-24-2012, 07:52 AM
ramminsilver's Avatar
City: NB
State: CT
Post #6
I'm running 295/70/18's with no rubbing whats so ever which is close to a 34 x 12.50.
2004 DODGE RAM 2500 LARAMIE w/ THE HEMI - BLACK ON BLACK/GRAY LEATHER - 295/70/18 NITTO TRAIL GRAPPLERS - 18x9 FUEL BOOST 5.75" BS/+20 OFFSET - AEM BRUTE FORCE CAI -CUSTOM MAGNAFLOW CAT-BACK EXHAUST 14" SI/SO - MAGNAFLOW Y-PIPE - NGK 5306 SPARKPLUGS - DIEHARD PLATINUM BATTERY - RECON SMOKED CAB AND 3RD BRAKE LIGHTS - RECON FIRE AND ICE TAILGATE BAR - TOTAL LED CONVERSION FRONT TO REAR - BILSTEIN'S ALL AROUND - EXTANG FULLTILT TONNEAU COVER - ALPINE 9886 HEAD UNIT AND ALPINE MRP_M300 AMP - JL AUDIO 12w1v2 SUBWOOFER - AVITAL 4103 REMOTE START AND KEYLESS ENTRY - UNIQUE COATINGS FLASHTECH HIDS - 9007 6000K BI-XENON HEADS AND 9006 6000K FOGS - EZ-DOWN TAILGATE ASSIST - HUSKY FLOORMATS - SUPERCHIPS CORTEX 3950 w/ TRANNY TUNE - MOPAR REAR WHEEL WELL LINERS - BUSHWACKER EXTEND-A-FENDERS - TEKONSHA PRODIGY BRAKE CONTROLLER-AUTO METER FACTORY MATCHED TRANNY TEMP GAUGE
04Ram2500Hemi
 Posted: 11-24-2012, 09:16 AM
City: Missoula
State: MT
Post #7
The trick is to not go over 11.50 wide or you will rub on the control arms. My buddy had a 2006 with 33x11.50 on stock rims on his HD and it looked great. If you don't want to mess with a lift or spacers that's the route I would go.
cumminsmannow
diesel guy
State: MN
Post #8
What wheels/offset do you have. Because that's the key.
JFM-jr
 Posted: 11-24-2012, 10:37 AM
JFM-jr's Avatar
State: NY
Post #9
Im liking the Nitto Terra Grappler in the 305/70/17 wich is almost 34 inches and an E load rating
OEM 4.56 gears
ramminsilver
 Posted: 11-25-2012, 09:28 AM
City: NB
State: CT
Post #10
+20 offset
Abused_Hemi
 Posted: 11-26-2012, 12:09 AM
Abused_Hemi's Avatar
City: saint elizabeth
State: MO
Post #11
I've ran 35"s and now running 37x12.50 on my 06 2500 with 2 leveling kit, only rub is at full lock on lower control arms but that didnt bother me. thats with stock wheels
coder
 Posted: 11-27-2012, 03:33 PM
coder's Avatar
State: CA
Post #12
You can run these sizes with no issues on a stock height suspension. Tire under 35" forget the leveling kits the issue is the tire width not the height.
285/70-17 (32.5x11.50x17)
285/75-17 (34x11.50x17)
295/70-17 (33.5x12.00x17)
305/70-17 (34x12.00x17)
2007 Quad Cab Power Wagon
God Squad Group
Current Mods:
Carli Stainless Steel Damper, Carli King 2.5 Pin-Tops, Carli Front Diff Guard, Carli Control Arms, Dynatrac Ball Joints, EBC Rotors, Line-X Bedliner, Locker Bypass Mod, Magnaflow Y-Pipe and Muffler, Mopar Rock Rails, Odyssey Battery G-65, Performance Friction Brakes, Redhead Steering Gear, Dodge Off Road Rear Diff Cover, Thermal Protection Switch Mod, Toyo M/T's 295/70-17, Weathertech Digital Fit Mats.
JFM-jr
 Posted: 11-27-2012, 03:37 PM
JFM-jr's Avatar
State: NY
Post #13
Thanks for all the input in this thread guys I appreciate it. Now I gotta decide on the gears im gonna start another thread about that. The install shop quoted me a big number.
OEM 4.56 gears
07MegaCabRam
 Posted: 11-28-2012, 04:49 PM
07MegaCabRam's Avatar
:: Mike ::
City: Chandler
State: AZ
Status: Online
Post #14
I ran them with no lift.
I hear these load range D BFGs suck for our trucks. too soft and help with death wobble.
::2007 Dodge Ram Mega Cab 4x4 5.7L Hemi::
Vision V-Tec Raptor 17x9 Wheels, 35" Nitto Trail Grappler MTs, KC 5" Apollo Lights in Factory Fog Light Location. Flowmaster Original 40 Series Muffler,
Painted B Pillars, Kenwood Sound System. Defender-PRO Spray in Bedliner I sprayed myself, 15% Window Tint applied by myself,
Carli Progressive 3" coils and Bilstein 5100s on all 4 corners. Updated 08+ Steering and Carli Steering Stabilizer 7100. 1.5" blocks in the rear. Carli Adjustable Trackbar.
Jimmi Jammer Door locks installed in all 4 doors. Kenwood DNX5120 head unit with 2 Kenwood 10"s, Kenwood 5 channel amp and Kenwood Components in all 4 doors.
JFM-jr
 Posted: 11-28-2012, 08:12 PM
JFM-jr's Avatar
State: NY
Post #15
I like those rims the Vtec Raptors caught my eye long ago. Do you know what offset they are +18 or +25 ?
OEM 4.56 gears
Hemi_2500
 Posted: 11-28-2012, 09:09 PM
Hemi_2500's Avatar
Bigg Rigg
City: Herrin
State: IL
Status: Online
Post #16
I have had no trouble of out my BFG's and they are load range D now I dont hual anything heavy in the back. I put almost 35,000 and not once had a problem with DW.
You not liking yours.
O and I'm running 315/70/R17 stock with just a slight rub on control arm at full lock.
Proud Member of the White Truck Club #77
Proud Member of the Military Truck Club #10
2003 Dodge Ram 2500 Hemi
2005 Dodge Magnum R/T Hemi
07MegaCabRam
 Posted: 11-30-2012, 02:22 PM
:: Mike ::
City: Chandler
State: AZ
Status: Online
Post #17
Sorry, I don't know. They were on the truck when I got it. I'll try to see what I can find for you.
I need to try to get some new center caps. The no caps have grown on me but.. might like them with them.
The tires are ok.. I had DW and it was my old steering. But the new coils I put in helped, that with the tires, tie rods, steering stab all played into it.
285 or 315s?? dodgepower88 2G Dodge RAM - 4X4 Talk 16 10-10-2012 01:27 PM
315s on stock 2500? Dillyw 4G Dodge RAM - Tire and Wheel Talk 20 12-17-2011 10:25 PM
2500 -305s,315s with chrome steel wheels? Captain Salty 3G Dodge RAM - Tire and Wheel Talk 12 02-14-2006 01:01 AM
315s 0n 2500 3.73 need a programmer? Captain Salty 3G Dodge RAM - 4X4 Talk 11 02-11-2006 12:42 PM
New 315s gr8art 3G Dodge RAM - 4X4 Talk 14 11-08-2003 08:03 PM
