Alignment HELP! - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 4th Gen (09 – Up) Forums > 4G Dodge RAM - 4X4 Talk
o'malley_808
  Alignment HELP! - Posted: 11-22-2012, 11:58 AM
Post #1
Anyone know what the specs should be for a 6" Rough country kit on a 2009 ram are?
Dealer just called and said the truck wouldnt line up to factory specs and asked if I had a spec with the kit??? ANYONE know??
Dealer is waiting for an answer...Can't get a hold of anyone at rough country...
o'malley_808
 Posted: 11-22-2012, 03:03 PM
Post #2
I got the truck back. Seems to drive half decent...I'll post the specs once I get 5 posts lol
SikHemi
 Posted: 11-22-2012, 03:16 PM
SikHemi's Avatar
Mopar Or No Car
City: 08360
State: NJ
Post #3
Good news. Post away I want to see lol
2012 Mineral Grey RCSB
33x12.50x20 Toyo Open Country Mt's
20 X 9 Fuel Hostage Rims
ReadyLift SST 2.5 & 1.5
K&N CAI
3" catback true duals w/ x-pipe
Tinted tails & 3rd
debadged
plastidiped grill & tailgate ram
stubby antenna
Line-X
Morimoto 5Five 6K heads & fogs
o'malley_808
 Posted: 11-22-2012, 03:51 PM
Post #4
four
o'malley_808
Post #5
five
o'malley_808
 Posted: 11-22-2012, 03:52 PM
Post #6
This is the spec sheet I just got back with my truck! Seems to drive okay? Let me know if this looks normal to you guys...
Rock$tar
 Posted: 11-22-2012, 06:53 PM
Rock$tar's Avatar
State: NF
Status: Online
Post #7
Your toe is out a good bit, they should be able to fix that, if not your going to chew through tires quickly. Caster is out also it seems, but that is one item that will just cause the truck to handle funny but will not wear out tires.
Bring it to another place to get an alignment. Specs for the RCX kit are just the factory specs for a 1500 ram.
*EDIT*
Sorry looking at that now i read the columns wrong. Seems your alignment is fine now. Everyhting is inside of the specified ranges, not sure about the specs, but its says 94+ i know the 06+ are all the same, didnt know previous gens used the same specs also.
Jadesmarine
 Posted: 11-23-2012, 02:38 PM
Jadesmarine's Avatar
fake it til' U make it
City: 29 Palms, Ca
State: OTHER
Status: Online
Post #8
I actually had this same issue with alignment. I took it to another place where the people that work there actually have lifted trucks to let them align it. They had more knowledge on how to tweak it so it will drive the best. They actually let me test drive it after pulling it off the machine. They ended up putting my truck on the machine 5 times as every time I drove it something adjusted slightly. After the 5th test drive the machine showed the truck was pretty dialed in and it drove the best.
________________________
-Dan
12' Flame Red Dodge Ram 5.7 Hemi Sport Fully Loaded W/ Sunroof
/ 4" Rough Country Lift (F- 41.62", R- 42.75")/ Toyo Open Country 35x12.5 R20 / Diablo Trinity / Mufflex 14" Magnaflow / Magnaflow Y-Pipe / GREEN air filter / BakFlip F1 / Stubby Antenna color matched / Backup Sensors Color Matched / Tint 20% front/ 5% rear(not shown is sig pic) / 3.55 gears /
o'malley_808
 Posted: 11-24-2012, 08:08 AM
Post #9
How does your drive compared to stock? I find I'm constantly having to correct the steering to keep the thing on the road. Doesn't feel very planted. It was windy last night and the truck was work to keep it on the road. I'm used to stock where you dont have to think much to keep it on the road. Steering input feels more sloppy than stock too. (meaning a good portion of travel in the wheel is needed just to keep going straight, whereas compared to stock that same movement would almost be used to turn or would be too much input in a straight line)
Jadesmarine
 Posted: 11-24-2012, 09:27 AM
City: 29 Palms, Ca
State: OTHER
Status: Online
Post #10
From my experience it wont ride like stock because its not stock anymore. The steering will feel a bit different if you put larger tires on because you are going to feel a little more "road". I actually had to replaced my link bushings with energy suspension ones because the sway was rediculous. if i let go of my steering wheel on a flat road it will slowly drift to the right but doesnt pull. you will have to get your alignment fixed before you can to use to how it drives now being lifted.
-Dan
HEMIHag
 Posted: 11-24-2012, 08:08 PM
HEMIHag's Avatar
City: Sterling
Post #11
Be very careful with this. I brought my truck all over to find a place to align it after my lift. Unfortunately the wheels I bought are crap because they don't have the proper lip for 99.9% of the alignment shops machine to connect to, so most shops wont touch it.
Anyway I've been doing some traveling as of late and my alignment was way off. The inside tread of my Toyo's are shot (on the front wheels) and I only have 7000 miles on them. After hours of looking in upstate NY finally found someone to do the alignment and I'll tell you what my truck finally runs good after the lift has been put on. I rotated the tires and my MPG's went up 3 MPG after the alingment and rotation.
So bad news is my tires aren't perfect anymore. Good news is problem solved and MPG's much better. I'll post my specs tomorrow if anyone is interested.
2011 RAM 1500 OUTDOORSMAN
Extang Trifecta Tonno
Mufflex muffler w/ no reso dumped
K&N CAI
20" Fuel Offroad Pump's w/ 35x12.5 Toyo Open Country M/T
o'malley_808
 Posted: 11-24-2012, 09:57 PM
Post #12
Where in upstate NY did you find a decent shop to do the alignment??
HEMIHag
 Posted: 11-25-2012, 04:58 PM
HEMIHag's Avatar
City: Sterling
Post #13
Orchard Park
K&N CAI
Thor09
 Posted: 11-25-2012, 07:44 PM
Thor09's Avatar
State: PA
Post #14
From the spec sheet, everything is in so that's a good thing. As for the steering, if it was windy and you are now lifted, that's a lot more wind resistance you are steering against so it will probably handle a little differently than stock.
I'm glad to see HEMIHag brought up the lips of the wheels, alot of people don't think of that if they have aftermarket rims. Sometimes you may need to bolt up a stock set of rims to your truck, get it aligned, then put the aftermarket back on if the aftermarket rims can't support the alignment machine panels properly.
2012 Outdoorsman 1500
|6" RCX, Bilstein 5100s @ 2.8", Air Lift 1000 airbags, TGC 1.5" Rear Coil spacers|Fuel Throttle 20x10 w/ Kumho MT 37x13.50-20|
|GoRhino Dominator II steps|Westin Lightbar|KC Daylighter HID retro|Hella 500 Black Magics|G2 Bakflip|Line-x bed|Weathertech Mats|Mopar Door Sills|Stubby|AEM Brute Force CAI|Mygig Lockpick v.5|Diablosport Trinity|
|MG Painted Quads|Morimoto Projectors/Halos|Tinted Fogs/Tails|6K HIDs| Switchbacks|Recon White Lightning Lightbar and Recon Smoked 3rd Brakelight|
o'malley_808
 Posted: 11-26-2012, 07:21 AM
Post #15
Originally Posted by HEMIHag View Post
Orchard Park
Oh that's not far from me at all. Only about an hour and a half. Could you send me the shops info and how much it cost???
HEMIHag
 Posted: 11-26-2012, 03:36 PM
HEMIHag's Avatar
City: Sterling
Post #16
Here's the shops info. Unfortunately I paid a lot more ($320) than I would've liked, However I was in town visiting and needed to get it done before I drove 8 hours back home, and this was the only shop out of about 20 that I tried that said they could do it so I didn't have much of a choice. Also he took care of me right away and didn't make me wait for an appointment.
Chet Kruszka's
3536 Southwestern Boulevard Orchard Park, NY 14127
(716) 662-7450
K&N CAI
HEMIHag
 Posted: 11-26-2012, 03:40 PM
HEMIHag's Avatar
City: Sterling
Post #17
Also if you don't have the stock wheels (like me). The shop that did my alignment stuck some weights on the outside flat surface of the rime and hooked the machine up to that. Seemed to have worked so try and suggest that next time you go to and alignment shop and they tell you they can't hook up the machine to your wheels.
K&N CAI
jake09
 Posted: 11-27-2012, 07:42 AM
jake09's Avatar
State: VA
Post #18
320 for just an alignment?? good day that's rape
2009 Dodge Ram 5.7 QC Sport 4x4
4" mopar (superlift), Bilstein 5100's at 2.1", 1.25" body lift, 1.5" tgc rear spacers, Bilstein 5125's 12" travel rear shocks, 37/12.50/20 nitto trail grapplers, 20x10 black fuel hostages -12offset,AMP powersteps, color match Tow mirrors, Led tails, Led swap, 5" mbrp tips, Diablo Trinity 20% tint, weathertech floormats, color matched grille,self retro projector headlights,laminx fog lights,ddm 55w 6k lows, 35w 6k hids fogs, flowmaster 10 series,spray in bedliner,debadged
HEMIHag
 Posted: 11-27-2012, 12:03 PM
HEMIHag's Avatar
City: Sterling
Post #19
Yep, it is, but I didn't have much choice.
K&N CAI
where to get a cam alignment pin pavester 3G Dodge Ram Performance Talk 16 01-05-2011 11:26 PM
Wtb: Cam Alignment Pin pavester Wanted - Dodge Truck Parts 2 01-04-2011 05:18 PM
alignment rus Dodge B-Series Vans 1971 - 2003 3 11-02-2008 10:38 AM
Alignment Hemi31 Dodge Magnum - General Talk 11 10-13-2005 10:45 PM
will I need an alignment?? lucky8926 3G Dodge RAM - 4X4 Talk 3 05-20-2005 02:08 PM
