Thread Tools |
Electronic Throttle Control Location
- Posted: 11-20-2012, 09:13 PM
Post #1
Can someone direct me as to where the ETC is located? I am getting the red lightning bolt on the dash. This is happening when i am at a stop light and everything shuts down except for the dash cluster lights and headlights. RPM's and etc are gone. Have to turn the ignition to off and turn it over again for it to start.
2004 5.7 Hemi
2004 QC 1500 4x4 5.7 Hemi Magnum Sport Package Hellwig Helper Springs Prodigy Brake Controller |
| Sponsored Links | |
Advertisement |
Posted: 11-20-2012, 09:31 PM
Post #2
You sure your battery isn't shot?
Posted: 11-20-2012, 10:02 PM
Post #3
Etc is your throttle body....clean and check the connection on TB. Clean and check connection on gas peddle...make sure as said ur battery is good. Pull intake tube off throttle body and check condition of TB.
2008 Dodge Ram 1500 5.7L 4x4 - 3" Dumped Exhaust, Superchips 91 Performance Tune, Superchips Trans Tuning, No Cats, Y-pipe, Powerwire, 4" CAI, 1- 12" Alpine Type X, Pioneer Head Unit, Pioneer I-Pod hookup, Alpine mrd m1005, Infinty sound system upgrade, Infinity Reference 6by9s in door, Bell Radar Detector, 400 Watts Aux Lighting (Behind Grill), Recon Headlights, Recon Tailights, AVS Color Matched Vent Shades, 2" Drop Shackles, Full leather interior swap, Painted rads, 2/0awg big 3, Dual Agm Batteries |
Posted: 11-20-2012, 10:54 PM
Post #4
I was having the same issue, was due to a gummed up throttle body. Disconnect the Negitive off the battery and then take the air intake off then the throttle body, and clean it out with some throttle body cleaner and reinstall.
2007 Dodge Ram 1500 Laramie - 5.7L MODS:Superchips 3815, eBay CAI, 1.25' Spacers, 33x12.50 Toyo Open Country MT's, 2.5' Leveling Kit w/ 2' Blocks, Smoked Headlights. |
Posted: 11-21-2012, 08:16 AM
Post #5
Whats the theory behimd removing the neg on battery first? Reset the tb?
Posted: 11-21-2012, 08:33 AM
Post #6
Resets ecm, if you're having issues or poor performance because of it, it will help it relearn the proper performance and clear any codes caused by it.
Sent from my DROID RAZR MAXX using Tapatalk.
![]() 08 Dodge Mega Cab Laramie 4x4 loaded. A.r.e Z series topper, Line-X liner, Bushwacker pocket flares, tinted windows,Galaxy Miradge 44HP Cb,Larsen Nmo27b cb antenna, Weather Tech floor liners, AVS vent visors,Mopar nerf bars,Mopar wheel well liners and Retro Solutions Head and Fog lights,Retro Solutions l.e.d backup lights, Mopar cab lights, Magnaflow dual exhaust, Magnaflow Y pipe, K&N drop in filter, Kore H.P Lift kit, Carli Trackbar, 305/70/17 Nitto Terra Grapplers on Mb V-Drive rims, 4.56 gears,Borgeson steering shaft, Prodigy trailer brake controller, Optima yellow top batt,Superchips Flashpaq, Smoked led tails and 3rd brake light, Stainless brake lines, Kobalt toolbox, Recon Projector Backup lights, Rvs Backup camera, and the ever important Cartman figure on dash. Red truck club #281 |
Posted: 11-21-2012, 04:18 PM
Post #7
The first way:
1) Disconnect the Negative battery cable for two or three minutes then reconnect. 2) Start truck and let idle till it reaches operating temperature. 3) Turn truck off for 5-10 seconds. 4) Fire her up and drive her the way you want. The second way: 1) With the key out of the ignition 2) Disconnect the Negative battery Cable. 3) Put the key in the ignition and turn it as if you where trying to the START it. 4) Release the key and leave it in the “ON” position and let it sit for 10- 15 min 5) Remove key from the ignition. 6) Re-attach the negative battery cable. 7) DO NOT TOUCH THE THROTTLE when starting the truck for the first TWO times!!! 8) Start truck and let idle till it reaches operating temperature. 9) Turn truck off for 5-10 seconds. 10) RE-START the truck but DO NOT TOUCH THE THROTTLE! 11) Let the truck return to normal idle (500-600 RPM’s) 12) Turn truck off, and then start her up and take her for a LIGHT test drive… NO WOT testing yet. 13) After driving around the block letting your computer LEARN the new air flow turn her off one last time… 14) Fire her up and drive her the way you want. The third way: 1) Pull fuse #19 or #23 or #31 (vehicle year dependent) 2) Close door and buckle seatbelt (technically you don't have to buckle the seatbelt, but it helps to stop all unnecessary chimes) 3) Put key in ignition and turn to "on" and wait until all chimes stop (on...not start!) 4) Turn key to start and hold until you hear 2 chimes (I think it was about 15 seconds or so) 5) Turn key off 6) Re-install fuse 7) You're good to go ... and last. This is from a past DT thread: You can do what is often called a "hard dump". We (techs) often do this when we need to totally reset the ECU and either don't have the proper tool close by (too lazy to walk to toolbox and get it) or just are "in a hurry". First, disconnect positive+ battery cable at the battery and ground it to the chassis. Yes, the POSITIVE CABLE. Wait a few seconds, 30 won't kill ya. Now reconnect the positive cable. Careful, no sparks now. Get in the vehicle, turn ignition key to on (run) position, now depress fully and release the gas pedal 5 times to set the TPS to WOT. (Make sure the floor mats do not keep the pedal from going WFO) Turn the key to off, wait a min, and you should have cleared everything in the ECU except for the factory programming. ============================================= The hard dump does not effect the (factory) alarm, the only thing I noticed is my radio presets, as this method came from a working Chrysler tech, I doubt if there are any negative effects. ============================================= ![]()
Sent via a Texas RoadRunner Varmint ... God Squad July 1972-To Infinity and Beyond-#40 Little Rammie Ridin' Shotgun Club287 Club Member #81 ~ Broken C Clip Club Member ~ Two-Tone Truck Club Member #13 ~ 4.56 R&P Club Member #8 Mighty Cracked Dash Enthusiast Club #11~Mother Earth Raping Big Truck Club Member #25~Truck and Gun Club Member #97 2002 Ram 1500 SLT 4x4 QC - (Nov.01) 4.7L with 89K/3***hrs, 2002 Ram 45RFE Jeep GC TCM Upgrade to 5-45RFE, Knolton Thunder Cylinder Heads & HO Cams by Sawcut, 4.56 R&P/DTT, SRT-10 Pod w/Dynojet Wideband Commander, 2-speed manual transfer case, Clifford Security System w/Auto Start/Auto Windows, RB1 CD/DVD/NAV Infinity Sound System w/30GB iPod, Offroad Package, 33" BFG T/A KO E's, Mopar Rear Wheel Liners, EBC Greenstuff Roadsport Brake Pads, K&N w/Airaid Jr Modular Intake Tube, BBK 70mm Throttle Body, Sonnax Line Pressure Booster, AIR_RAM Jet Stream Scoop, PML Diff Cover, ASP Underdrive Crank Pulley, MSD 1.65 Alt Pulley, Lincoln E-Fan, DCC 2-Speed E-Fan Controller, 180 Jet T-Stat, Denso 160-amp Alternator, Flowmaster SI/DO Exhaust, Accele 3.5" LCD Backup System, Line of Fire LED Light Bar, Sylvania Ultra Silverstars, Hella 500 Black Magic-100W, Nokya Hyper Yellow Fog Lights, $1600 Oil Pick-up Tube thanks Dodge Texas 1845: We the People of the Republic of Texas, acknowledging, with gratitude, the grace and beneficence of God. “Firearms stand next in importance to the constitution itself. They are the American people’s liberty teeth and keystone under independence … from the hour the Pilgrims landed to the present day, events, occurrences and tendencies prove that to ensure peace security and happiness, the rifle and pistol are equally indispensable … the very atmosphere of firearms anywhere restrains evil interference — they deserve a place of honor with all that’s good.” - George Washington
Official DodgeTalk Facebook Page |
Posted: 11-21-2012, 06:47 PM
Post #8
thanks for the different methods. I hope to see the red bolt issue disappear. it is frustrating.
| Thread Tools | |
| Electronic Throttle Control | JHaste31 | Dodge Magnum - Performance Talk | 2 | 10-05-2009 10:05 PM |
| 3G RAM Electronic Throttle Control | ccoffey3131 | 3G Dodge Ram Performance Talk | 1 | 08-22-2009 09:24 PM |
| electronic throttle control? | followme | 3G Dodge RAM - General Talk | 5 | 01-16-2007 09:29 AM |
| Electronic Throttle Control | Lynny | Dodge Caliber - General Talk | 7 | 11-30-2006 07:55 PM |
| Electronic Throttle Control | big_daddy_joe | 3G Dodge RAM - Drivetrain Talk | 24 | 11-22-2005 01:15 PM |
Privacy Statement | |
