debadging and plasti dipping! - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 4th Gen (09 – Up) Forums > 4G Dodge RAM - Interior/Exterior Talk
esahic
  debadging and plasti dipping! - Posted: 11-20-2012, 02:43 PM
esahic's Avatar
Post #1
Hey guys I want to debadge the side on my truck and then I wanted to plasti dip the front and tailgate ram logo. U guys got any advice on plasti dipping the badges on front and rear? Also wheres should i get plasti dip? Home depot?
ITSARAM
 Posted: 11-20-2012, 03:01 PM
ITSARAM's Avatar
City: Fairfax Va
State: VA
Post #2
Plasti-Dip is about 6 bucks a can at Home depot.
You can remove the front badge do the Plasti-Dip but for the rear, just tape it off.
09 Quad TRX4 HEMI
Detonator Yellow
Hot-rodicus supersonicus
esahic
 Posted: 11-20-2012, 03:21 PM
esahic's Avatar
Post #3
What do I use to remove the adhesive from debadging. I cant find 3m remover. Is goo gone safe to use
ITSARAM
 Posted: 11-20-2012, 03:25 PM
ITSARAM's Avatar
City: Fairfax Va
State: VA
Post #4
I used an eraser wheel.
09 Quad TRX4 HEMI
Detonator Yellow
SikHemi
 Posted: 11-20-2012, 03:50 PM
SikHemi's Avatar
Mopar Or No Car
City: 08360
State: NJ
Post #5
I taped front and rear. Make sure u go around with razor blade and cut it in the crease. 1st time I didn't and went to take off tape and took dip off with it. Just go around logo in crease where it meets paint. I used exacto knife. For the badged I used goo b gone and fishing string. Adhesive stuck on so I use lacquer thinner. Came right off. No the paint didn't come off too lol. When I was done I wash and waxed and used clay bar.
2012 Mineral Grey RCSB
33x12.50x20 Toyo Open Country Mt's
20 X 9 Fuel Hostage Rims
ReadyLift SST 2.5 & 1.5
K&N CAI
3" catback true duals w/ x-pipe
Tinted tails & 3rd
debadged
plastidiped grill & tailgate ram
stubby antenna
Line-X
Morimoto 5Five 6K heads & fogs
esahic
 Posted: 11-20-2012, 04:46 PM
esahic's Avatar
Post #6
I tried the plasti dip on a dealer emblem I was gonna take off anyway just to practice and it came out pretty good
Dillyw
 Posted: 11-20-2012, 06:26 PM
City: Quinte West
State: ON
Post #7
To debage you don't need anything but fishing line!!
Use fishing line to cut of than peel a corner and pull away slowly, mine come right of using that method. Good luck
2011 2500 5.7L
2003 3500 CTD
2003 1500 5.7 - sold!
brentwood
 Posted: 11-20-2012, 07:38 PM
brentwood's Avatar
State: NJ
Post #8
plastidipping the front and rear ram badges is very easy. i popped the front badge off the grill. taped off about an inch around the other badges. i did 4 or 5 coats, waiting about 15mins between coats. it's pretty forgiving. alot easier than regular spray paint. you dont even have to "cut" around the badges. just pull it and it stays on the badge. you have to be a little more careful on the 4x4 badge, but still pretty easy. a toothpick and tweezers will help around the numbers/letters.
'12 Ram 1500 QC Express 4x4 w/5.7 HEMI
Mods: Curt trailer hitch, Rhino liner, FLOWMASTER 50hd, JBA shorty headers titanium ceramic coated, 17x9 xd cranks, vht nightshade tail lights and 3rd brake light, magnaflow y-pipe, stubby antenna, plasti dip badges, edge street 2800 tc, diablosport trinity hemifever 93 octane tune, 180 t-stat, S&B CAI, black headlight housings, sylvania silverstar zxe bulbs, rancho quick lift loaded, rancho rs9000xl rear shocks, mickey thompson baja mtz 35x12.5x17
future mods: ?? pretty happy with my truck for now
Stryker6040
 Posted: 01-12-2013, 08:47 PM
City: Wyoming, MI
Post #9
for all that have done the debadging did the paint look normal under where the badges were stuck? it wasnt brighter or mismatched at all?
2012 Flame Red Ram Quad Cab 4wd, 5.7L Hemi, 3.92LS, 20" Wheels, Go Rhino Dominator II Nerf Bars, BT Catchcan, Moe's 87MM Throttle Body
brentwood
 Posted: 01-13-2013, 10:43 AM
brentwood's Avatar
State: NJ
Post #10
since you have a new truck, the color of the paint should be fine. just remove the adhesive, and wax that area back up
powersof12
 Posted: 04-06-2013, 12:19 PM
PowersOf12
State: IN
Post #11
I just debagged the giant "RAM 1500" from across my doors. It was easy. Put the side of the truck you wish to work on in the sun for a half hour, use nylon fishing line (it will break often) to slowly saw off the letters, then use the 3M Eraser wheel on a low speed drill to clean off sticky stuff.
The paint looked perfect underneath. A quick wax and it was done.
Whiteout08
 Posted: 04-06-2013, 02:58 PM
Whiteout08's Avatar
City: Rochester
State: NY
Post #12
Goo Gone is perfectly fine to use to get any residue off....just be sure you clean it again and wax that area afterward.
2012 Dodge Ram 1500 Express QC - Mineral Grey
Mods: Mufflex DOD14M, TGC Level Kit (2.5" front, 3/4" rear), 20x10 Ultra Baja Champs (custom "Black Chrome") w/ 305/55/20 NTG, DDM 5000k HID's in Fog Lights
Stryker6040
 Posted: 04-16-2013, 01:41 PM
City: Wyoming, MI
Post #13
For those of you that have debadged after removing the adhesive and washing and applying a wax to the area you removed the emblem from when the paint gets wet from rain etc can u still see an outline on the paint where the emblem used to be
Whiteout08
 Posted: 04-17-2013, 10:11 AM
Whiteout08's Avatar
City: Rochester
State: NY
Post #14
I've never had that issue.
HEMI-PWRD
 Posted: 04-17-2013, 12:26 PM
HEMI-PWRD's Avatar
09 HEMI
City: TX
Post #15
I used GOO GONE for the words.. works perfectly. Tons of use of your thumbs to remove it.
A friend used a pin stripe remover to take his off.
09 HEMI - CC SB 13.3 @100.6 Go to WWW.MOESPERFORMANCE.COM for all your truck needs!!!
RIPPs Supercharger!, 2800-3000 Circle-D Stall Single Billet, 4.10 Gears, JBA Shorty headers with custom Y-PIPE to Flowmaster SI/DO, Moe's 87mm TB, Diablo Intune, Moes pillard with boost and air/fuel gauges, 180 T-stat, Mopar V6 Efan, Denso 1 stage colder plugs 3/5" drop, R/T hood, 2013 Sport wheels on Kuhmos, Shaved grille-antenna-tailgate, HIDs, BT HEMI "T" shifter, and everything painted to match.
Next: L&M CUSTOMS Transmission, Custom/dyno tune, Moe's Catch can, re-do tint, spray in bed-liner......
jimbobway69
 Posted: 04-17-2013, 02:03 PM
jimbobway69's Avatar
~TYLER~
City: Blind River
State: ON
Post #16
I used heat gun and then 3m earaser wheel used a fine cuter/ then polish to get rid of the shadow from my eblems on the paint
08 Dodge Ram 1500 Quad Cab Short Box Inferno Red 5.7L H.E.M.I
Rims&Tires
-NITTO Mud Grapplers 35x12.50-20
-20x9 Ballistic Jester Rims
LIFTS
-3" Performance Accesseries Body lift
-Bilstein 5100's
-Rear Adjustable Lift Shackles
-Rancho RS9000XL Rear shocks
EXTERIOR
-N-Fab RSP Full Replacement Bumper With Zone Offroad Bumper Brackets-4 Hella 700 Series Lights With Eurolite Bulbs
-Bush Wacker Pocket Style Fender Flares-Pacer Clear Roof Lights With Pure 360* LED 194 Bulbs In White-Paramount full replacement grill-Dupli-Color Bed Linned Fender Flares, Rockers, Front And Back Bumpers And Grill-Tinted Tails and Third Brake Light-Tinted windows, Top And Bottom Tint On Windshield-
-8000K H.I.D'S In Headlights, Eurolite Bulbs In Reverse, Cargo, and license Plate lights-Street Glo Pro Strobe Kit Front Headlights And Rear Reverse Lights-ACCESS Low Pro Tonneau Cover System-Mopar Rear Inner Fender Linners
INTERIOR
-Auto Meter Triple Piller Mount Gauge Pod-Pro Sport Gauges Air/Fuel, Voltage, and Tranny Temp-Next And Browning Camo Seat Covers-Camo Floor Mats Front and Back-Led Rocker Switch's Hidden In Dash-Animal House Speaker
AUDIO
-Alpine Cda-001X Multimedia Deck With Intergrated Ipod And Sirius
-Alpine M850 And M400 Amps-2 12" Alpine Type R's
-Custom Made Center Console For 2 12's Under Plexi -Alpine Type R 6x9's In The Front Doors -Energy 5.25 Component Set In The Back Doors
-3 Clarion 4" 2 Ways In The Front Dash -American Legacy Capacitor
-BassWorx Digital Read Out Fuse/Splitter-4 Gauge Welding Cable With BassWorx Mini ANL Fuse Holder-Big 3 Done With 4 Gauge Power Cable
UNDERHOOD/PERFORMANCE
-Custom Made 4" Airraid Intake-AEM 6x9 Dry Flo Filter
-Diablo Trinity T-1000
-Pacesetter Long Tubes-Dual 3" Cutouts-No Cats
-Pacesetter Y Pipe-Dynomax Y-Back Dual Exhaust
-Magnaflow Straight Through SIDO Muffler-3.5" Matte Black Painted Tips
-2nd Battery Tray Out Of 3/4 Ton
-Primary Battery NAPA Dual Post 75 Series-Secondary Battery NAPA Deep Cycle 27 Series
Outfitr
 Posted: 04-19-2013, 07:44 AM
State: MT
Post #17
There will be no outline left. I used a little lacquer thinner to remove residue.
2011 Ram 1500 Hemi 4x4 Quad SLT Bright White, 2" leveling, Truxedo tonneau, Nitto Trail 295 70R 17 tires, Airlift 1000 bags, Nfab bar with KC driving lights.
The_Bishop
 Posted: 04-20-2013, 09:57 AM
The_Bishop's Avatar
PW # 5851
City: New Jersey
State: NJ
Post #18
Just did the same to my '13. Giant RAM 1500 now removed from the doors. Used dental floss to saw the letters off, then carefully peeled the adhesive off. The tiny bit of residue left came right off with a little lacquer thinner. Looks much, much cleaner.
2013 Ram 1500 Express QC
1998 Camaro Z-28
17" Vette Wheels - Magnaflow exhaust - Subframe Connectors - Control Arms - A lot of stuff, it's fast.
Click Here for an important forum message.
Plasti Dipping the rammer WannaBee119 3G Dodge RAM - Interior/Exterior Talk 107 08-08-2012 03:39 PM
Quick plasti-dipping mitchman 4G Dodge RAM - Interior/Exterior Talk 10 04-11-2011 08:48 PM
Plasti-Dipping BMRbrnSNRbrd 4G Dodge RAM - General Talk 15 02-15-2011 05:05 PM
Dipping RPMs at start-up enhanced250 3G Dodge RAM - General Talk 7 06-19-2005 11:50 PM
