98 ram 1500-2001 ram 1500 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 2nd Gen (94 – 01) Forums > 2G Dodge RAM - General Talk
Harveyb
  98 ram 1500-2001 ram 1500 - Posted: 11-20-2012, 09:25 AM
Harveyb's Avatar
City: NORTHVILLE
State: NY
Post #1
I am going to be doing a 5-speed swap in my 01,have a chance to buy a 98 1500 4x4 5.2 for the swap,I know I will need to buy a 5.9 flywheel but are there any other differences between the 98 and 2001,will I have everything I need for the swap other then the flywheel and a computer flash.I also can get a 2000 2500 with a 5 speed but the truck looks pretty beat,the 98 is mint and a friend is willing to go halfs on this one just for the body.thanks
2001 Dodge Ram 1500 Offroad Sport,fully loaded,360,SCT by Hemifever,flowmaster catback exhaust,Hard bed cover,flush mount(painted to match truck)bed rug,leather interior,custom sub box,2 10" MTX subs powered by a jackhammer amp,memphis door and rear speakers powered by a memphis amp,sir micheals roll pan,fresh paint after tree incident.
fastman 52mm throttle body,Gibson shorty ceramic coated headers,airgap intake,K&N cold air intake,mopar performance valve covers,harland sharp 1.7 roller rockers and magna flow high flow cat and y-pipe.37/12.50/17 BFGOODRICH M/Ts on Cragar Black Rock Wheels,4.88 gearing,converted to 5-speed,5" BDS long arm lift with full rear leafs,plus a 2" coil spacer and 2"taller rear leaf blocks,DT profab trackbar,Borgeson steering box and steering shaft,BD Diesel steering box brace,dual steering stabilizer,Bilstein shocks and stabilizers all around,1-ton steering upgrade.
cblake
 Posted: 11-21-2012, 10:17 AM
Chuck Blake
City: Beckley, West Virginia
State: WV
Post #2
I am not any help on this one, but I would love to do the same swap on my 1999 with a 360. That is what I wanted when I bought mine new, but they only offered a 5 speed with a 318 and I wanted 360. I will be watching to see what you run into.
1999 RAM 1500, 4WD QC, Auto, 5.9
1.7 Harland Sharp RR's, Mopar Magnum polished aluminum valve covers
Hughes FI airgap, 52mm Fastman tb, Fastman similator
4.56 gears
pro flo open air
gutted cat with 1 in 2 out magnaflow
SCT tune by Hemifever
Taylor 8.2 thundervolt, duralast cap and rotor with brass inserts
180 thermostat with Hypertech high output coil
ASP underdrive crank pulley
Doug Thorley ceramic tri-y headers
steering box brace
Bushwacker extend-a-fender flares
Warrior 2 1/2" leveling kit
AAL to rear springs + 1" zero rate block to spring stack.
3" body lift
37x13.50 Mickey Thompson ATZ on 18" eagle wheels
Transmission cooler added along with transgo shift kit
deep transmission pan, + 4 quarts
black nerf bars and grill black bull bars
FS: 2001 Ram 1500 freezingbelow For Sale - Dodge Trucks 0 12-22-2009 07:22 PM
2001 Dodge Ram 1500 Josh87 For Sale - Dodge Trucks 2 08-25-2008 02:12 PM
2001 1500 axle ?'s Kory 2G Dodge RAM - Drivetrain Talk 1 12-19-2004 10:22 PM
2001 1500 pulls right cycorider 2G Dodge RAM - 4X4 Talk 6 12-09-2004 03:54 PM
