Thread Tools |
Post #1
hey yall, got a question, my 08 ram started fine and then sputtered and coughed and shook and died
i tried to restart it and it would sputter like it wanted to start but wouldnt catch, it would sputter for a few seconds when the auto crank was cranking then it would just crank with no sputter till i turned the key off or the end of the auto crank cycle,,,,,after 6 or 8 tries i gave up and called for a ride, a couple minutes latter i decided to try spraying some carb cleaner in the intake when it was cranking to see if it would fire at all,(to figure out if it was a gas or spark issue) so i tapped the key and started for under the hood and before i could get there the dam thing fired up and ran like a top!!! and has since ran and been shut off several times and is fine,,, any ideas as to what it could be? that was kinda scary because i just drove out of the middle of the cherokee nathional forrest from hunting, and there is no cell service or people for MILES around and i am disabled so i couldnt have walked out thanks PS i just drove the truck about 50 miles down the road and shut it off to go in the store for about 15 minutes and when i came out is when it acted up.... UPdate.... its worse today i went out and it fired right up, drove it about 10 miles drove it home shut it off and it restarted right away and was fine, left it sit about 10 minutes and it wont start, it fires up the first time and sputters to a stop, then thats it it just cranks and sputters let it set a few minutes and it seems to start and run fine till you shut it off again ![]() Last edited by TnGuy : 11-18-2012 at 10:21 AM. |
| Sponsored Links | |
Advertisement |
Posted: 11-18-2012, 10:20 AM
Post #2
First thing i would do is get the battery tested. When the batterys in these start to go, they cause a lot of weird issues. Did you have any lights stay on like check engine or the lightning bolt for the throttle body?
05 Patriot Blue Pearl Dodge Ram 1500 4x4 5.7 Hemi MODS | VaraRam Hemi Under Glass | Superchips 3865 with Trans Tune | SLP Powerflo Catback Exhaust | Shorty Wires | Electric Fan | 180 Stat | Ventvisors | Debadged | Billits in the Grill | Blacked out Led tailights | Blacked out Third Brake Light | Color Matched Headlights | 6000k HIDS in Heads and Fogs | Shorty Antenna | Torsion Bar Level 03 Silver Dodge Ram 1500 4x2 5.7 Hemi MODS | Home Brew Ram Air CAI | Superchips 3815 | TMR Mod | Magnaflow 14" SI/DO muffler | Electric Fan | 180 Stat | B&M ProStick Ratchet Shifter | Custom Gauges | Custom Shifter Surrond | Ventvisors | Debadged | Tinted Tails | Tinted Third Brake Light | Smoked Headlights | 5000k HIDS in heads | 3000k HIDS in fogs | Roll Pan | Shorty Antenna | Custom Painted Grill | Dipped Front Bumper | Poor mans 2/4 Drop | 17" Ram SS/T Wheels | And A Little Bit of ZEX BEST 1/8-Motor-9.23@77__Spray-8.89@78-Spinning BEST 1/4-Ill Know Next Year BLUE TRUCK MEMBER #246 | SILVER TRUCK MEMBER #261 |
Posted: 11-18-2012, 10:23 AM
Post #3
the battery seems to be fine as i cranked the hell out of it last night trying to get it started to get home, there is a light on on the dash when its cranking but im not sure what it looks like, il have to go look again, its only on when it cranking... i updated my post above.... thanks
Ok there is a lightning bolt on the dash when its cranking Last edited by TnGuy : 11-18-2012 at 10:38 AM. |
Posted: 11-18-2012, 10:55 AM
Post #4
The lightning bolt while cranking is normal as long as it goes off after it starts. You still want to get the battery load tested. When the battery in my 05 started to go bad, it still started and cranked like a brand new battery, but caused my throttle body to freak out a couple times to the point where at first i couldent give gas while running because it caused it to sputter. It also at one point caused it to not start with similer symptoms to what you have, and as like your truck, mine started fine if i let it sit for 15-20 minutes. After that, replaced the battery and havent had an isuue since. That was at the end of last year.
Posted: 11-18-2012, 05:52 PM
Post #5
got the batt tested and they say its fine, somebody suggested it was the fuel filter, but i cant see that because sometimes it starts and sometimes it dont,
Posted: 11-18-2012, 06:11 PM
Post #6
unless something has changed the only type of filter on these trucks is a screen on the fuel pump. With the way its acting it could be the fuel pump itself is starting to go.
2005 Ram Daytona GoMango RC #1445 Orange Truck Club Member #19 Performance Mopar CAI / 4.56 Superior Gears / Auburn limited slip / Edge Converter / Shift Kit / Viper Fan with FK50p Controller / Edelbrock mid headers / Custom True Dual Exhaust / Superchips Flashpaq / Summit Underdrive / 195 t-stat Looks and Sound Night Runner 22s / DJM 2" arms / McGaughys Flip with Notch & Air assist / Alpine, Orion, JL, Kicker audio / SilverStar lights / Optima Yellow / AEM Wideband O2 in SRT-10 Pillar / Retrax Bed Cover / Spray in Bed Liner / Mopar Billet fuel door / Daytona floor mats Future plans Depends what I can afford.
Posted: 11-18-2012, 06:26 PM
Post #7
Could it be a fuel pressure problem? Maybe a fuel pump Issue? I've seen fuel pump weaken after they heat up and cause loss of fuel pressure.
Daytona beat me to it ha.
![]() 2006 Ram 1500 4.7L- Gibson S/S ceramic shorties Catless w/ 12279 magnaflow Apm ram air hood w/ ram air intake Painted grille, bumper, & handles Painted headlights w/ Retrofitted morimoto projectors Power slot rotors Superchips vivid Paq w/ ATT 2/5 McGaughy's drop kit Stk. 3.92 gears Nitto 420s 285/50r20 |
Posted: 11-19-2012, 02:12 PM
Post #8
sorry for not getting back. i believe its the fuel pump
when its cold it starts when you drive it and leave it sit about 10 minutes then try it wont start BUT tap on the bottom of the fuel tank and it fires right up NOW the VERY bad part... 519.00 for the pump only no labor just the pump i cant believe with only 49000 miles the pump is bad thanks for the help.... |
Posted: 11-19-2012, 04:19 PM
Post #9
where the heck are you finding a pump? try rockauto, i changed mine last year and i think i spent 160-170 for it....
--- Fast Freddie ---05 Hemi QC 1500 2wd (230,000+ on odo) 2005 Dodge Ram 1500 SLT: 12.100 @ 113.960 MPH 12.93 @ 101 na 12.10 @ 113 sprayin If you don't stand behind our troops, feel free to stand in front of them. Proud Member of the White Truck Club (#30) Part number for the 1 ton tranny cooler is 52029089AB Performance mods: Yes... |
Posted: 11-19-2012, 04:21 PM
Post #10
do you keep the tank full? these pumps need the gas to keep it cool and some say if you constantly run it to empty that it will affect it...too bad your not out here, i'd help you change it...
Posted: 11-19-2012, 04:26 PM
Post #11
I run an airtex in mine...and what I pulled out was an airtex
Posted: 11-19-2012, 07:18 PM
Post #12
Posted: 11-19-2012, 07:19 PM
Post #13
i never ever run my tank under a 1/4 and 95% of the time its never below 1/2
Posted: 11-19-2012, 07:24 PM
Post #14
Posted: 11-19-2012, 09:47 PM
Post #15
you know...you gotta give us ALL the details when you have problems you're needin help with...
Posted: 11-20-2012, 02:44 AM
Post #16
Posted: 11-20-2012, 11:14 AM
Post #17
thanks, found out the extended warranty i bought will cover the fuel pump so it looks like im out about 50.00 thanks |
Posted: 11-21-2012, 05:08 PM
Post #18
all fixed 661.13 bill from the dodge dealer but i only paid a 50.00 deductible
they said it must have been a friday built fuel pump ![]() |
Posted: 11-21-2012, 10:39 PM
Post #19
getting anything done that fast by a dealer is rather impressive, even more so since it was on an extended warranty. I figured they would keep the truck for a week to try and figure out the problem and give it back to you at least once saying they couldn't find anything wrong.
Posted: 11-22-2012, 07:58 AM
Post #20
| Thread Tools | |
| spilt and sputter | 83Dodge318 | 1972-1987 Dodge Ram Trucks (D, W-series) | 2 | 05-21-2010 07:59 AM |
| sputter an stalling | the h8ed 1 | 3G Dodge Ram Performance Talk | 11 | 02-14-2009 04:48 PM |
| New to me Ram with a sputter | backabit | 3G Dodge Ram Performance Talk | 3 | 01-27-2009 03:26 PM |
| sputter | Digitalsoundz | 2G Dodge Dakota General Talk | 1 | 12-09-2008 09:22 PM |
| Cough-cough, sputter-sputter | Thomwashere | 2G Dodge Dakota General Talk | 2 | 06-14-2005 08:34 PM |
Privacy Statement | |
