The best 46re - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 2nd Gen (94 – 01) Forums > 2G Dodge RAM - Drivetrain Talk
dannewman
  The best 46re - Posted: 11-15-2012, 11:40 AM
State: ME
Status: Online
Post #1
Any opinions on the #1 46re for my 2001 2500 4x4? I like the mega-viper from PATC,but money's tight. Old trans exploded internally at 45,000. So much for Mopar rebuilts. I tow a lot of bigger boats and welding rigging plus gear. Don't want to build one if I can help it.
2001 Quadcab 2500 HD SLT Laramie green forest pearl over driftwood,with a couple well earned dents.
spun360
 Posted: 11-15-2012, 08:36 PM
spun360's Avatar
City: Pottstown
State: PA
Post #2
http://www.apsprecision.com/TQConverter.html
http://www.apsprecision.com/Accessories.html
parts for sale
$125: 210lb double and dampener valve springs .550 lift
$20 : new, standard oil pump
$15 : new, super strength moog #377 frt axle hub universal w/ grease fitting
prices include shipping (for residence of the US)
cheep
shoot PMs my way
spun360
 Posted: 11-18-2012, 03:58 PM
spun360's Avatar
City: Pottstown
State: PA
Post #3
i am also contemplating a few rebuild companies. really what i want is a slightly higher stall speed converter/ firmer shifts/ and the absolute need for the 46re to oil in park. it also might be worth my while to upgrade the direct drive drum with more clutches and better spring counts. not sure if pact has the drum upgrades though. aps does. and both companies make a good trans/ tq converter combo
http://www.transmissioncenter.net/dodge.htm
parts for sale
cheep
shoot PMs my way
dannewman
 Posted: 11-18-2012, 07:50 PM
State: ME
Status: Online
Post #4
PATC calls their's the direct clutch power pack. The Mega-viper seems to have it all for one low price. I would also do the Borgeson steering box at the same time,,,,I mean what the hell right? It's all still cheaper than financing a new truck.
spun360
 Posted: 11-18-2012, 09:45 PM
spun360's Avatar
City: Pottstown
State: PA
Post #5
yes patc has a good set of clutches/ added ratio application levers and what not but i dont believe they have the ability to disengage the system the way it should be. the direct drive drum also has to counter the added forces.
http://www.apsprecision.com/images/H...ings%20891.jpg
http://www.apsprecision.com/images/H...Drum%20897.jpg
read about the problems that occur when a 5:1 ratio is installed without upgrading the drum!
gassers should only use the 4.2:1 ratio levers. and could benefit from the drum upgrades.
someone please correct me if i'm wrong. there is a serious learning curve here!
parts for sale
cheep
shoot PMs my way
dannewman
 Posted: 11-26-2012, 05:59 PM
State: ME
Status: Online
Post #6
Anybody got any horror stories about Transdepot in Florida?
MP408
 Posted: 01-01-2013, 02:43 PM
City: Stephens City
State: VA
View This User's Garage
View This User's Dyno Entries
Post #7
JASPER TRANSMISSION 3 year 100,000 warranty dont spend any money with rebuilds did it twice they just keep replacing parts and doesnt last long my jasper was better than factory new everything is upgraded that was weak.
spun360
 Posted: 01-01-2013, 05:20 PM
spun360's Avatar
City: Pottstown
State: PA
Post #8
so far my impression of a jasper typical replacement are not good. the standard "engine" replacement has been know to be 20hp less and the compression is lower than the original stock magnum motor. as the trans go- they may do a better job. though i would tend to aquire a class I or class II trans
http://www.jasperengines.com/performance-products.php
parts for sale
cheep
shoot PMs my way
MP408
 Posted: 01-01-2013, 06:50 PM
City: Stephens City
State: VA
Post #9
Impressions and opinions differ from actual experience too many people give there opinions on things they don't have experience or real knowledge.
spun360
 Posted: 01-01-2013, 09:41 PM
spun360's Avatar
City: Pottstown
State: PA
Post #10
yes. i dont believe you got a stock 46re with a stock torque converter. so what kinds of things are done to the trans?
parts for sale
cheep
shoot PMs my way
MP408
 Posted: 01-01-2013, 10:06 PM
City: Stephens City
State: VA
Post #11
I got the stock replacement 46re they tell the upgrades in the planetary gears and clutch packs the only thing Tm trying to find out now is the torque converter has 175k stamped on it but when I called yesterday about it they said it has stock stall speed of 1800 -2100 they dont offer performance 1 and 2 anymore and I have the stock replacement
spun360
 Posted: 01-01-2013, 10:25 PM
spun360's Avatar
City: Pottstown
State: PA
Post #12
160k is the measurement used on the stock converters now, i think. the 46re has a standard stall out in the 1600 1800 rpm range.
you are A step up and it might not be noticeable to a daily driver, but on the dyno it does sure show!
i have been looking at sprag gears and 4 planetarys instead of 3. also looking into the changes made in the durango RTs on the direct drive drums. added springs, added clutches. trans are a headache!
pm calling "tactransman" is a good idea!
whats the best? ha! i have no idea
parts for sale
cheep
shoot PMs my way
Moparite
 Posted: 01-02-2013, 04:53 PM
Post #13
Are you shutting the overdrive OFF when you tow? (it's in the owners manual) A lot of people forget to do this and then wonder why they have trans problems. After you decide what to put back in i would get a good trans cooler.
dannewman
 Posted: 01-17-2013, 05:40 PM
State: ME
Status: Online
Post #14
I tow mostly local as in less than a mile and under 35 mph. Rarely tow on the highway and the welding gear I'd guess is under 1000lbs. Next trans will be a custom built one from Transdepot I suspect. I'll be buying one of their coolers at the same time. Now I'm just waiting for the funds to materialize for this and a Borgeson steering box. Might even get a little body work whens it's all done.
Murfman
 Posted: 02-11-2013, 10:21 PM
Post #15
Find a Daaco trans part supplier, buy a quality rebuild kit, rebuilt converter, and a rebuild manual. Pulling the trans was the hardest part of my rebuild on my 99 Ram. Even with replacing the solenoids, sensors, and adding a shift kit. I was still less than 500.00 total in my 47RE in my Ram. The OD is a bit of a PITA compressing the spring pack, but nothing too hard. I have 20K miles with a lot of heavy towing since the rebuild and it still shifts nice and crisp.
2005 Neon SRT-4 47Lb Stage 3
1999 Ram 2500 QCSB V-10
Non Dodge:
2006 Jeep Grand Cherokee SRT-8 392
1998 Jeep Wrangler 4.0/AX15
1953 Plymouth Suburban 218/T-5
And a Gaggle of Honda ATCs...
tactransman
 Posted: 02-14-2013, 10:50 PM
tactransman's Avatar
Transmission Man!
City: Gerald, Mo.
Post #16
Interesting thread................
Terry aka tactransman
'99 Ram 1500 4X4 5.9 Automatic #110 in the White Truck Club
Aren't you tired of getting your parts for your Super Bee from a kid that thinks a Civic is a "hot rod"!
Mods:
MSD Blaster 3 Coil
Magna Flow Cat and "Y" pipe
46RE Built to the Hilt
Transgo TF OD JR Shift Kit (With Mods)
Billet Cover Converter
Upgraded to five direct clutch drum
Five Overdrive Brake Clutch pack
47RE STEEL front planetary
Sonnax Reverse servo parts
HD Kevlar Lined Rigid Int Band
Deep Pan w/cooling tubes
3.8 ratio Int lever
billet Int servo struts
little_yellow
 Posted: 03-05-2013, 11:53 PM
little_yellow's Avatar
audio is my game
City: wainwright
State: AB
Post #17
i have been told a few times now that they make a 48 internal swap. makes it a whole bunch stronger then you have the ease of doing 48 upgrades and making it even better.
96 short box regular cab
323, xtreme energy 264 comp cam, hydraulic roller lifters, 1.6 roller rockers, ARP studs, comp magnum push rods, electric fans, 42lb cobra injectors, fuel pressure gauge, MSD 6-BTM, MSD blaster SS coil and MSD wires, machined heads, 2300 stall, a/c delete, SCT tuned, DIY TB, DIY intake, shorty headers, single 3" turbo back with a flowmaster pro series muffler.
2/4 drop
blow through with 4 fi bl 10's, kicker zx2500.1 amp, pioneer 7" flip out ,big 3, 3 monster batteries, 220 amp alt
3rd gen 05 steering wheel and auto window conversion
custom built turbo kit running a H1C.
come take a peek
http://www.cardomain.com/ride/2676273
tactransman
 Posted: 03-06-2013, 01:19 PM
Transmission Man!
City: Gerald, Mo.
Post #18
You can put any 48RE part in a 46 RE EXCEPT the rear band. The case prevents you from using the rear ( Rev) band.
Mods:
MSD Blaster 3 Coil
3.8 ratio Int lever
RamThis
 Posted: 03-06-2013, 05:13 PM
RamThis's Avatar
City: N. Richland Hills, Tx
Post #19
Is APS even still around now that Wayne is gone? I cant get much info at all out of him on Facebook, I admin his old chatsite that he basically has deserted and left me high and dry on with no way to fix it. If anyone can get through to him let him know I would much like to talk to him.
2000 Dodge Ram 1500 Single Cab, 5.9 Auto, 4.10's, Auburn LSD, Edelbrock headers, 2.5" true duals with crossover, MSD Superconductors, APS Plenum Kit, Level10 Trans kit, Trans-Go shift kit, 2-4 BellTech Drop, SS/T rims, Toyo Proxes ST 285-60-17's, Sir Michaels Roll Pan and tailgate handle relocator, Keystone bumper cover with light openings, PIAA fogs, painted grille shell, painted Street Scene Speed Grille Inserts, SCT XCAL-2, Alpine head unit, Infinity Components front, Infinity Coaxials back, Infinity 500W 4 channel amp, Infinity Basslink, new dash, steering wheel, and guage bezel. Building new engine for it now. Truck is slowly being blacked out....
1996 Dodge Ram 1500 Club Cab, 5.9 Auto, 4.10's, Detroit Locker, Race Truck Trends Nascar Bumper, Painted SS/T Stripes, Alpine HU, Alpine Sound Field Processor, Clarion Amp, MTX Thunderform. On the stand as of Spring 2013, 5.9L bored .030 over, Sealed Power coated pistons, balanced and polished crank, Comp 210 Cam, MP Timing Chain tensioner, Melling HV oil pump, 1.92 oversized valves and mild porting, MP Triple Nickel Chrome headers. Trans being assembled as of 3-1-13 with Level10 performance kit, Trans-Go, deleted check ball, and Long LPD 28,000 GVW tranny cooler.
spun360
 Posted: 03-09-2013, 10:47 AM
spun360's Avatar
City: Pottstown
State: PA
Post #20
i would like very much to talk to the fellas who beef up the 46re. but i hear it allot about wayne at aps and his customer service not being so great! what do you mean he's gone?
parts for sale
cheep
shoot PMs my way
46re? EightSeven 1G Dodge Durango - Drivetrain Talk 2 03-28-2011 03:14 PM
46re 2wd to 4wd apples4551 2G Dodge RAM - Drivetrain Talk 1 07-28-2010 08:27 AM
46re !05RAM05! 1G Dodge Durango - Drivetrain Talk 2 02-13-2007 01:43 PM
will a 904 pan fit a 46RE? chizzle1 2G Dodge RAM - Drivetrain Talk 2 02-01-2007 08:07 AM
46re ? azhuff1 2G Dodge RAM - Drivetrain Talk 2 05-28-2005 12:57 AM
