01 dodge ram heater issues - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 2nd Gen (94 – 01) Forums > 2G Dodge RAM - General Talk
azsickboy
  01 dodge ram heater issues - Posted: 11-13-2012, 09:43 PM
City: flagstaff
State: AZ
Post #1
I could use some help. I had a problem with one of my freeze plugs leaking. I fixed it checked all the other freeze plugs, they were good. I am no longer leaking, I did put more antifreeze in the truck. The heater hoses are warm going to and from the heater core. I have a 190 thermostat. I checked the oil to see if I had an issue with a head gasket, nothing. The heater blower turns on but I have no heat its just blowing cold air. Need some ideas what controls the inside temperature switch?
badblackram
 Posted: 11-13-2012, 09:48 PM
badblackram's Avatar
City: brookhaven
State: MS
Post #2
Not real knowledgable on this but you might have an air pocket in the heater core. Or is it possible the heater circulator door is stuck? Just throwing some idea out there.
2006 Ram 1500
4.7L- Gibson S/S ceramic shorties
Catless w/ 12279 magnaflow
Apm ram air hood w/ ram air intake
Painted grille, bumper, & handles
Painted headlights w/ Retrofitted morimoto projectors
Power slot rotors
Superchips vivid Paq w/ ATT
2/5 McGaughy's drop kit
Stk. 3.92 gears
Nitto 420s 285/50r20
spun360
 Posted: 11-13-2012, 10:01 PM
spun360's Avatar
City: Pottstown
State: PA
Post #3
prolly the blend door stuck or the actuator arm is busted.
parts for sale
$125: 210lb double and dampener valve springs .550 lift
$20 : new, standard oil pump
$15 : new, super strength moog #377 frt axle hub universal w/ grease fitting
prices include shipping (for residence of the US)
cheep
shoot PMs my way
dodgensince74
 Posted: 11-14-2012, 06:52 AM
Post #4
check your blend door motor to see it is working correctly
01 1500 5.9, Q/C, L/B, 4X4
Tanue cover
Super chips
Magnaflow S/i-D/o
K&N cai
Eagle alloy 102's
BFG LT285/75r16 A/T's
Mike Sal
 Posted: 11-15-2012, 06:07 PM
Post #5
How difficult is it to access the blend door & it's vacuum motor? I'm also having an issue of luke warm air coming from the heater ducts in my '95 1500 w/ 5.2L
medtech1
 Posted: 11-16-2012, 02:00 PM
City: Salem
State: IN
Post #6
Not sure on the 95. But, the 01 has an electric motor that operates blend door. It has a plastic asdaptor that connects motor to blend door. It is a fairly common failure item. It can be changed from inside the cab. Just takes a short right angle Phillips screwdriver. And, a little time standing on your head. Its on the passenger side, bottom of heater box. I've had to change the adaptor. And, the motor itself. If you search the forums. You should be able to find pretty detailed instructions. And, pictures. That's how I learned how to change mine.
1999 Ram1500 5.2 A/T
Flowmaster Catback si/do
Gutted cat with O2 simulator
Relocated IAT sensor
Fiberglass rollpan with cutouts for custom tips
Accel supertune kit
Tinted windows
2inch lowering shackles in rear
Euro corner lights
Altezza taillights
Completely debadged and tailgate black plastic removed
Dakota airhat with large k&n cone filter
And counting!!!!
canadian_mudder
 Posted: 11-16-2012, 08:03 PM
canadian_mudder's Avatar
City: Alberta
State: AB
Post #7
As others have said most likely a blend door issue, either bad actuator or broken door. If not that could have a partially plugged heater core, it's not to common to only be partially plugged but it has happened.
2000 Dodge Ram 1500 Driftwood 4x4 SLT Ext. Cab
BDS 3" suspension lift
285/75R16 Toyo Open Country M/T
Pacesetter Long tube headers with dual exhaust
AFE Stage 2 Cold air intake
Superchips 3715 programmer
And one sweet rockerguarded gas cap
Trucks and Guns Club member #137
Heater Core Issues rrog 3G Dodge RAM - General Talk 7 09-07-2012 09:50 PM
Issues with Heater Vents and Heater Core, need some help. 5.7What 3G Dodge RAM - General Talk 1 11-19-2011 10:02 PM
Heater Issues Ponchobroke 3G Dodge RAM - Interior/Exterior Talk 0 01-05-2011 05:35 PM
Heater issues. mudboynj Dodge Caravan/Grand Caravan Talk 27 03-03-2010 09:00 PM
A/C and Heater Issues, and Seatbelt? garrett03dodge 3G Dodge RAM - General Talk 0 11-10-2006 11:40 AM
