bilstein 7100 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Power Wagon Forums (05 - Up)
riorocks
  bilstein 7100 - Posted: 11-13-2012, 01:22 PM
State: BC
Post #1
Hi im looking into getting some 7100's on my 2007 power wagon, im having some issues with finding the correct sizes collapsed and extended.
From what i have read from other posts on the 5160's which are supposed to work i have gathered these numbers.
5160 front: 25-187595
collapsed: 15.20"
extended: 25.96"
5160 rear: 25-187601
collapsed: 16.54"
extended: 28.09"
So looking into the 7100's i have come up with these to be the closest match.
7100 10" front with reservoir: AK7110R04
collapsed: 16.1"
extended: 25.77"
7100 10" front w/o reservoir: AK7110S04
collapsed: 16.1"
extended: 25.77"
Both models the same.
7100 12" rear with reservoir: AK7112SBB
collapsed: 16.1"
extended: 27.68"
7100 12" rear w/o reservoir: AK7112S04
collapsed: 19.53"
extended: 31.1"
quite a difference in the rears, with the reservoir shock being closer to the desired lengths.
So my issue is i would rather run the non reservoir shocks seeing as the fronts would work no differently, yet what would i need to do to make the rears work? And if im going to put the reservoir shocks in the rear, than im going to have to put them in the front as well seeing as there probably more usefull in the front anyways.
I have spent the last 2 days price searching and have found the non reservoirs for 94$ and the reservoirs for 128$ dont get me wrong both a killer price but 30 buck more a piece adds up and there both going to be much better than stock alreadys.
let me know what you guys think of this situation. more than likely i will not be going for anything less than the 7100's just for the fact of being able to buy a set of shocks and be able to rebuild them for the lifetime of my PW.
coder
 Posted: 11-13-2012, 05:18 PM
coder's Avatar
State: CA
Post #2
You will not be able to find any shocks that are the exact same size as the OEM shocks. You will need to go slightly shorter or slightly longer.
Why do you want non-reservoirs in the front?
Also you can get, from Carli Suspension, a set of 7100's all ready to go, their Performance 2.0 shocks for a PW.
2007 Quad Cab Power Wagon
God Squad Group
Current Mods:
Carli Stainless Steel Damper, Carli King 2.5 Pin-Tops, Carli Front Diff Guard, Carli Control Arms, Dynatrac Ball Joints, EBC Rotors, Line-X Bedliner, Locker Bypass Mod, Magnaflow Y-Pipe and Muffler, Mopar Rock Rails, Odyssey Battery G-65, Performance Friction Brakes, Redhead Steering Gear, Dodge Off Road Rear Diff Cover, Thermal Protection Switch Mod, Toyo M/T's 295/70-17, Weathertech Digital Fit Mats.
riorocks
 Posted: 11-13-2012, 07:51 PM
State: BC
Post #3
No I would only use non reservoir in the front if I can use them in the rear as there somewhat cheaper.
And I can get a set of non reservoir for under 400 and a little over 500 for reservoirs, so quite a difference from the carli's
coder
 Posted: 11-14-2012, 03:11 PM
coder's Avatar
State: CA
Post #4
Why do you want 7100's, what are you looking to accomplish?
God Squad Group
Current Mods:
riorocks
 Posted: 11-14-2012, 10:46 PM
State: BC
Post #5
well im looking to upgrade from the stock shocks on her right, as well as being able to rebuild them when that time comes. truck see's alot of rough gravel roads hill climbs, mild rock climbing, as well as daily driver.
coder
 Posted: 11-15-2012, 05:21 PM
coder's Avatar
State: CA
Post #6
I have progressed up through various levels of shocks in my PW and here is what I noticed as far as performance. What valving are you thinking of getting on the 7100s?
OEM Bilstein's PW specific valving:
- compliant and absorbent but not overly soft
- some noticeable side to side sway
- when pushed hard they go right to the bump-stops
- they fade when pushed hard for a long period
Bilstein 5100's:
- somewhat stiffer than the OEM's
- a more controlled feel than the OEM's not as much side to side sway
Bilstein 7100's with Carli Performance 2.0 PW valving:
- slightly stiffer than the 5100's
- the more you push them the better they feel
- when pushed hard they don't go right to the bump-stops but resist
- they don't noticeable fade when pushed hard for a long period
King 2.5" Pin-Tops with Carli Hemi valving:.
- like driving a high-end sports car around town
- its like being glued to the road, but you feel every imperfection
- no sway in the corners, the more you push them the better they like it
- I can do 45-50 mph down a dirt road and hit fairly sizable ruts and bumps comfortably
- on rough roads I find myself waiting for the "wam bam" on big bumps but nothing happens, just a soft thump
- no fading when pushed hard for a long period
God Squad Group
Current Mods:
riorocks
 Posted: 11-16-2012, 12:15 AM
State: BC
Post #7
im looking to get the 255/70 i was curious as to what the carli's are near but im sure thats kept private. my pw takes a good beating here and there so i dont think they would be too agressive. you think the reservoirs are crucial? I have not looked yet but im thinking i may be able to fab something up to compensate for the extra length of the non reservoir option. or just go with the reservoir and its pretty damn close of the bat.
coder
 Posted: 11-16-2012, 12:04 PM
coder's Avatar
State: CA
Post #8
Originally Posted by riorocks View Post
im looking to get the 255/70 i was curious as to what the carli's are near but im sure that's kept private. my pw takes a good beating here and there so i don't think they would be too aggressive. you think the reservoirs are crucial? I have not looked yet but im thinking i may be able to fab something up to compensate for the extra length of the non reservoir option. or just go with the reservoir and its pretty damn close of the bat.
Unless you drive for long distances on ruff dirt roads at moderate to high speeds I don't think the reservoirs are required. The 255/70 valving is a good option plan on it being a little firm around town.
God Squad Group
Current Mods:
riorocks
 Posted: 11-16-2012, 07:15 PM
State: BC
Post #9
Hey so you have clearly changed out your shocks a few times, have you noticed if there might be room to move the top mount up or further down the line from the lower mount? Cause to make the non reservoirs work I would need to gain around 3 inches, or else there would be a chance of them bottoming on full flex correct? Seeing as there 19 inches collapsed and they need to be around 16.
riorocks
 Posted: 11-16-2012, 07:17 PM
State: BC
Post #10
Hey and thanks for your help so far , the more input the better i find
coder
 Posted: 11-16-2012, 07:44 PM
coder's Avatar
State: CA
Post #11
The best way to mount the front's is to use an adapter like Carli does (see pic) 4wheelparts sell something similar to this as well see link below.
4WheelParts Link
http://www.4wheelparts.com/Lift-Kits...s=90&t_pt=8664
God Squad Group
Current Mods:
riorocks
 Posted: 11-17-2012, 10:18 AM
State: BC
Post #12
so those 7100 that you had what lengths were those?
to me it seems that the lengths are pretty important as well as the amount of stroke to the shock.
if i go with this shock:
collapsed: 19.53"
extended: 31.1"
when this is the size that is supposed to work:
collapsed: 16.54"
extended: 28.09"
it would be 3 inches longer collapsed and extended. meaning upon full flex the side to be compressed will actually be bottoming out 3 inches sooner, because it has the extra length, in theory you would gain 3 inches on the extended side but unusable because the compressed side would be bottomed out.
now thats just what im thinkin in my head and im not sure if that would be how it works but seeing as its solid axle +3 inches rise on one side would be -3 inches on the other.
correct me if im wrong
coder
 Posted: 11-20-2012, 07:09 PM
coder's Avatar
State: CA
Post #13
With the internal design of any rebuildable style shock you want to make sure you don't top or bottom them out it will damage the internal much easier than a regular disposable shock.
That why Carlis and most others utilize limit straps to stop an 1 1/2" before the shock fully extends.
God Squad Group
Current Mods:
riorocks
 Posted: 11-20-2012, 10:16 PM
State: BC
Post #14
Hmm interesting. I need to get some flexed numbers going on here I think to see how close I may be getting to topping or bottoming out. Cause I would guess stock would leave some room to spare
coder
 Posted: 11-24-2012, 04:25 PM
coder's Avatar
State: CA
Post #15
You can purchase a limit strap kit from Carli you will need to weld on the bottom tabs, let the axle hang all the way down then, measure for the top strap mounting hole 1 1/2" higher.
God Squad Group
Current Mods:
RustyPW08
  Talking  Posted: 11-28-2012, 01:37 AM
RustyPW08's Avatar
Moab Tested
City: Brownsville
State: PA
Post #16
Give 8lug a call. He'll set you up with the 7100's. That's what I'm running right now.
PWOC #53
2008 POWER WAGON RC
Sequentially Number #08-1505,
Inferno Red, Automatic
Mods to the PW; Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Extang Tonneau Cover, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, Had 35" Cooper STT's now 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper, PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, BIG Pul-Pal and it's own body bag!, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, MORE STUFF COMIN', TTI headers, Somebody's long arm, 7.2L MOTOR ,
Mods to me; Ti hip replacement. Zerk fitting in knee. Now it's gets greased more than some guys front drive shafts. I've been Used, Abused and Recycled!
Survivor of The Cold War, Heaven's Gate, The Grand Conjunction, The Pleiadeans Landings, Y2K, The Winch Mob Banning, The Mayan Apocalypse, and some other covert stuff. Future zombie killer!
Jacqui, loving wife and mother. 7/11/61 - 5/13/11 I miss you!
"Moab '10, '12",
"Rausch Creek-Spring, Fall '11, Spring '12"
RUSS
RustyPW08
  Talking  Posted: 11-28-2012, 01:41 AM
RustyPW08's Avatar
Moab Tested
City: Brownsville
State: PA
Post #17
Oh, I forgot pictures.
PWOC #53
2008 POWER WAGON RC
"Moab '10, '12",
RUSS
riorocks
 Posted: 11-28-2012, 04:19 PM
State: BC
Post #18
Yeah it was those pics that originally got me looking into the 7100's about how much did the set run ya? If I ever get some time after work I would be able to get these numbers I need just been getting worked like a dog lately.
RustyPW08
  Talking  Posted: 11-28-2012, 09:28 PM
RustyPW08's Avatar
Moab Tested
City: Brownsville
State: PA
Post #19
Think it was around $1,300 for all 4 from 8lug.
PWOC #53
2008 POWER WAGON RC
"Moab '10, '12",
RUSS
Orton
 Posted: 11-29-2012, 08:23 AM
Orton's Avatar
City: Bethlethem
State: GA
Post #20
Rusty, what are the rubber air bag looking devices sitting on your rear axle? Not trying to steal the post or sound dumb. I just don't know and curious.
bilstein 7100 riorocks 3G Dodge RAM - General Talk 4 01-09-2013 05:35 PM
Blistein 9100 or 7100???? HOSSherrera 3G Dodge RAM - 4X4 Talk 6 05-17-2012 01:52 PM
bilstein 5100 or bilstein HD trx450 3G Dodge RAM - 4X4 Talk 10 09-15-2011 02:36 PM
Bilstein 7100 Reserviors bigdodge4x4 For Sale - Truck Parts 3 10-21-2009 11:10 PM
Replacing VP-44 with P-7100 cmns2500 2G Dodge Ram Diesel Talk 22 02-12-2009 06:43 PM
