Heating Times - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 3rd Gen (02 – 08) Forums > 3G Dodge RAM - General Talk
RUMBLE BEE 1546
  Heating Times - Posted: 11-11-2012, 12:56 PM
RUMBLE BEE 1546's Avatar
BEE Ready!
State: CA
Post #1
It seems like my truck is taking an excessive ammount of time to heat up off of a cold start. I'm usually to my destination by the time the truck starts to blow out some respectable heat.
I understand how the heater works which is why I don't think anything is "wrong". It just seems like it should be heating up quicker. I have a remote starter that I let the truck run for 3-5 mins before I get in too. And my windshield is frosted and hogged ove in the mornings and it takes a bit to get enough heat up there to make it so I can see.
The only reason I think it is so slow is because I went with some grinds to a concert last night and it was about 40 degrees out. Her 01 GMC Yukon was bone cold when we got back (was sitting for 6 hours). I started it up and the two gage was all the way at "C" and within 30 secconds it was blowing air hotter than my truck does after 30 minutes.
I'm wondering if there is a way to books the heater somehow? I would like the heat to come faster if there is any way to do so.
2004 Rumble Bee #1546 4X4
Ryan
Performance: Super Chips 3865, K&N CAI, Edelbrock Shorty Headers, Dual Exhaust with 18" Magnaflow Muffler and Y-pipe, Power Wire, Sonnax Line Booster, Jet 180* t-stat, Taylor 8.2mm Shortie wires, Flex-A-Lite 183 E-fan, Grounded TB.
Appearance: 22" Black BOSS 334's wrapped in Nexen Tires, LED Tail Lights & Third, Shorty Antenna, Honeycomb Grill, Tint:5% Visor and Rear Window, Deadged, Retro'd 8000k Projected HID Headlights w/ SMD Halos, 3000k HID Fogs, Switchback LED Turns, Full LED Bulb Swap, Snugtop Tonneau w/ Stripe Extensions & 1546 in Stripe
Other: Kenwood KDC-X994, Pioneer 5ch amp wired to 2 10" Diamond Audio Subs in a custom ported box and 2 Kenwood Door Speakers, Clifford Remote Starter/Alarm System w/ Smart Start, Husky Floor Liners, Push Button Start, Jimmy Jammers.
Future Mods: Looks Like A Cam Possibly This year , Alarm Accesories (Motion Sensors, Microphone Sensors, Level Sensor, ect.)...
badblackram
 Posted: 11-11-2012, 01:12 PM
badblackram's Avatar
City: brookhaven
State: MS
Status: Online
Post #2
Maybe installing a lower degree thermostat?
2006 Ram 1500
4.7L- Gibson S/S ceramic shorties
Catless w/ 12279 magnaflow
Apm ram air hood w/ ram air intake
Painted grille, bumper, & handles
Painted headlights w/ Retrofitted morimoto projectors
Power slot rotors
Superchips vivid Paq w/ ATT
2/5 McGaughy's drop kit
Stk. 3.92 gears
Nitto 420s 285/50r20
RUMBLE BEE 1546
 Posted: 11-11-2012, 01:24 PM
BEE Ready!
State: CA
Post #3
Wouldn't that make it cooler since the engine would be running cooler?
Ryan
badblackram
 Posted: 11-11-2012, 01:42 PM
City: brookhaven
State: MS
Status: Online
Post #4
In a way but it won't affect heater temps. The engine will heat up like normal until the temps hit 180. Then the thermostat will open an send the coolant through out the system a little earlier than the stock thermostat.
A 180* thermostat opens sooner than the stock 195* stat But I have heard these engines run more efficiently at 195-200*.
Also it may be possible your current thermostat may be stuck open and not allowing the coolant in the engine to heat properly.
Has it always taken forever?
2006 Ram 1500
Power slot rotors
Stk. 3.92 gears
RUMBLE BEE 1546
 Posted: 11-11-2012, 02:40 PM
BEE Ready!
State: CA
Post #5
That's a tough question to answer. It was previously my dads truck and I took it over when I got my licence back in 2010. I don't recall if its always been like this, but I belive it has been. I have a 180 stat but I don't want to go through the hassle of draining the fluid to get it changed out. I think I'm about due for fluids so I might have the shop do it then.
Ryan
Destructo09
 Posted: 11-11-2012, 05:07 PM
State: NC
Post #6
T stat could be stuck open, that does sound like a long time for it to get hot.
The hot coolant still goes through the heater core even with the T stat closed, so a 180* isn't going to make any difference.
I would try replacing the thermostat with a new one and see if that helps, won't cost much and shouldn't be too difficult.
2008 Ram 1500 Mega Cab 2WD
Magnaflow muffler with no resonator
2" drop shackles out back
RUMBLE BEE 1546
 Posted: 11-11-2012, 06:34 PM
BEE Ready!
State: CA
Post #7
Maybe I don't understand this, but if the t stat is closed and coolant still runs through the core, wouldn't it still go though when the t stat is open? I'm just wondering how having a stuck t stat will affect the heater is all.
How long does it take your cars/trucks to get heat going?
Ryan
badblackram
 Posted: 11-11-2012, 06:42 PM
City: brookhaven
State: MS
Status: Online
Post #8
It does but the heat disperses throughout the entire system (radiator) instead of being confined to the engine and heater core. If its opened there is a larger volume of coolant that has to be heated.
I just made a run to the store. At 68 degrees outside. It took the coolant 1.5 minutes to get to 150* and 5 minutes to get to 180*. If that gives you an idea.
2006 Ram 1500
Power slot rotors
Stk. 3.92 gears
RUMBLE BEE 1546
 Posted: 11-11-2012, 07:04 PM
BEE Ready!
State: CA
Post #9
ahh... makes perfect sense to me now
Ryan
RUMBLE BEE 1546
 Posted: 11-11-2012, 07:12 PM
BEE Ready!
State: CA
Post #10
I just checked my records and it looks like I'm 6k over on the fluids. I will be calling my shop on Tuesday to get her in for the fluids.
Ryan
N1K
 Posted: 11-11-2012, 09:33 PM
N1K's Avatar
City: Littleton
State: CO
Post #11
Mine takes 7-10 min at idle to warm that's been from the low thirtys in the mornings lately
oh8 Ram 1500
Black Truck Club #223
Ron_J
 Posted: 11-12-2012, 08:25 AM
Ron_J's Avatar
State: PA
Post #12
What he said....sounds like your t-stat isn't closing...or at least not the whole way.
2006 RCSB Hemi Ram 4x4, Superchips, Pacesetter LT's w/ Y, 180* t-stat, Raceland cutout, CAI, 4.56's, 2" drop shackles & 20" SRT replica's
07MegaCabRam
 Posted: 11-12-2012, 10:51 AM
07MegaCabRam's Avatar
:: Mike ::
City: Chandler
State: AZ
Status: Online
Post #13
Well, if you are not doing it yourself... have them flush your heater core as well.
::2007 Dodge Ram Mega Cab 4x4 5.7L Hemi::
Vision V-Tec Raptor 17x9 Wheels, 35" Nitto Trail Grappler MTs, KC 5" Apollo Lights in Factory Fog Light Location. Flowmaster Original 40 Series Muffler,
Painted B Pillars, Kenwood Sound System. Defender-PRO Spray in Bedliner I sprayed myself, 15% Window Tint applied by myself,
Carli Progressive 3" coils and Bilstein 5100s on all 4 corners. Updated 08+ Steering and Carli Steering Stabilizer 7100. 1.5" blocks in the rear. Carli Adjustable Trackbar.
Jimmi Jammer Door locks installed in all 4 doors. Kenwood DNX5120 head unit with 2 Kenwood 10"s, Kenwood 5 channel amp and Kenwood Components in all 4 doors.
DannyMK2
 Posted: 11-12-2012, 01:56 PM
DannyMK2's Avatar
City: Long Island
State: NY
Post #14
sounds like a bad t-stat or heater core starting to clog up. check the temp out of the vents when its fully hot with an infared thermometer to see if its even getting as hot as it should.
2012 Express QC 4x4
2004.5 QC DRW 3500 Cummins 4x4
1998.5 QC DRW 3500 Cummins 4x4 - SOLD
2002 Ram 1500 QCSB 4.7L 4x4 - SOLD
Dodgetalk.com 287 Enthusiast Member #108
RUMBLE BEE 1546
 Posted: 11-12-2012, 03:29 PM
BEE Ready!
State: CA
Post #15
I took her to work today and it never got hot. It was about a 15 minute ride and I had it blasting on high the whole time. It got warm and I felt the vents but it wasn't anywhere near as hot as it should be or eventually gets. I only noticed when I pulled into the parking lot that there was a temp difference.
I will have the shop flush it out and swap out the t stat. I have a shop do it so I don't have to deal with the mess and the old fluid. Makes my life that much easier.
Ryan
DannyMK2
 Posted: 11-12-2012, 03:36 PM
DannyMK2's Avatar
City: Long Island
State: NY
Post #16
whats the temperature of your coolant? it should be equal to the value of the t-stat +/- 10*. if your trucks reaching operating temp but your heat isnt getting hot, you have a heater core issue. if your truck isnt reaching operating temp, then its the t-stat. it would be a shame to waste coolant now only to find out you needed a heater core all along.
2012 Express QC 4x4
RUMBLE BEE 1546
 Posted: 11-12-2012, 03:48 PM
BEE Ready!
State: CA
Post #17
Well the gage was at that if I had a 180 in. It was as I said running for a total of 15 minutes. I don't usually drive too far because if I am I take my other car. When I do it will hit the 1/2 way mark where it should be.
Is there a way to tell if its the core? I didn't know that those could go bad.
Ryan
DannyMK2
 Posted: 11-12-2012, 04:08 PM
DannyMK2's Avatar
City: Long Island
State: NY
Post #18
i dont really trust the factory temp gauge too much so its hard to say. i would point an infared thermometer at the heater hoses and rad hoses to get an idea of the temp of the coolant. if you watch the hoses with the thermometer, you should also be able to see the coolant change temp when the t-stat opens. if you do this and the t-stat checks out, then its more then likely the heater core. if its not leaking for giving off steam, fogging the windshield, you can try to flush it out with some CLR. that usually works if its a little clogged. if not, your looking at replacing the heater core. heater cores can go bad like anything else. its basically a mini radiator.
2012 Express QC 4x4
RUMBLE BEE 1546
 Posted: 11-12-2012, 07:05 PM
BEE Ready!
State: CA
Post #19
When the air comes on it'll sometimes fog the windshield but as soon as it gets fresh air it clears up. It takes a while to clear the fog on the windshield on cold mornings which is a pain because I have to either drive looking through a small circle or wait several minutes.
I'm wondering if I should just replace the heater core too. By the time I buy a infrared thermometer ($30 for the cheapest one) and if I find it to be the core, that's another $60-80 depending on what brand I go with plus install.
Luckily the shop I go to I get good prices at.
Ryan
Ron_J
 Posted: 11-13-2012, 05:18 AM
Ron_J's Avatar
State: PA
Post #20
if the water temp (the gauge in the truck) is going up, and it still isn't blowing hot, then it's the heater core. Probably needs flushed.
Heating Up ckchastang 2G Dodge RAM - General Talk 2 12-11-2011 07:37 AM
SuperChips Data Times - Post Your Times HERE SiZzOuRcE 3G Dodge Ram Performance Talk 623 01-28-2009 10:20 PM
over heating c0zgrove 2G Dodge RAM - General Talk 3 04-21-2008 08:59 PM
Site slow many times and times out SUN RA KAT DodgeTalk Site Feedback and Ideas 3 06-05-2007 02:02 PM
{AutoMeter} (1/4mile times; 0-60 times; & HP measure in your truck..Should i buy it? LoneStarHemi06 3G Dodge Ram Performance Talk 10 07-08-2006 02:18 PM
