4 wheel drive acting up - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 3rd Gen (02 – 08) Forums > 3G Dodge RAM - Drivetrain Talk
rangersgoalie
  4 wheel drive acting up - Posted: 11-11-2012, 11:14 AM
Post #1
So I'm running into an issue on a 2500 CTD 4x4.
LAst night we had some snow/rain/hail, and the roads were getting slick -
i put the truck into 4 hi and when im on decel its giving a grinding/howling sound - sounds like a manual(truck is auto) when you use the motor to slow. 4 wheel seemed to be working - gave me the kicks and hops on sharp turns (did 3 to make sure it was engaged a parking lot) and when I was on the gas I couldn't hear any grinding.
any ideas?
2004.5 Ram 2500 CTD 5.9 Quad Cab
Red Truck Club Member #339.
9/11/01 Never Forget
rangersgoalie
 Posted: 11-11-2012, 07:34 PM
Post #2
noone? please?
orvtenn
 Posted: 11-11-2012, 08:24 PM
orvtenn's Avatar
+ Hemi Addict +
State: TN
Post #3
It might be chain slop..
2004 1500 SLT RC/SB 4x4 Hemi 5.7
2006 Grand Caravan 3.3L
N1K
 Posted: 11-11-2012, 09:24 PM
N1K's Avatar
City: Littleton
State: CO
Post #4
Does it sound like it's coming from the frt diff or the t-case?
oh8 Ram 1500
Black Truck Club #223
rangersgoalie
 Posted: 11-11-2012, 09:36 PM
Post #5
Its hard to say as When I don't move its gone so I can't hear it out of the truck, It sounds like its more in the middle of the truck on the front end - I thought it was the passenger side and my fiance in the passenger side thought itw as more on my side. I'm thinking it was more towards the T case becuase it seemed like it was futher back then the axels. but thats a guess.
N1K
 Posted: 11-12-2012, 02:31 PM
N1K's Avatar
City: Littleton
State: CO
Post #6
Try feeling the t-case shifter when its making the noise might be able to feel it.
oh8 Ram 1500
rangersgoalie
 Posted: 11-12-2012, 03:49 PM
Post #7
If only it was that easy - I have the electronic shifter I wish I had the lever on the floor...
N1K
 Posted: 11-12-2012, 03:59 PM
N1K's Avatar
City: Littleton
State: CO
Post #8
oh wow!I didnt know they did that on the 2500 I thought is was just us 1500's with that dumb shift knob.
I thought I saw an ad where now you will shift the truck with the same kinda deal on the new truck.
oh8 Ram 1500
rangersgoalie
 Posted: 11-12-2012, 04:19 PM
Post #9
Yea, The extra space on the floor was nice the 1 time I had to have someone sit there, but other wise, it sucks.
Rich 2500
 Posted: 11-12-2012, 04:48 PM
Rich 2500's Avatar
City: Chesapeake City
State: MD
Post #10
Does it do it in low range too?
Elec. Blue 07 2500 Thunderoad QC Hemi 4X4
BTC #181
Mopar Cai, Mopar SS Nerf Bars, Mopar Tow Mirrors, Mopar Wheel Well Liners, EGR In Channel Window Vents, Tinted Windows 30%, Hella 500's behind the grill, Gibson Dual Sport Catback Exhaust, Magna Flow "Y" Pipe, Jet Stream Scoop, Power Wire, LineX Bedliner, Flexalite 180 Efan (shrouldless), Jet 180 Thermostat, Edge Evolution (used as monitor) DiabloSport Predator, Solid Steel Industries-Steering Stabilizer, Carli Starter Suspension System, Carli Adj. Track Bar, Toyo 35/12.50/17 MT on Stock Wheels, Carli Anti Sway Bar, Xeon Fogs 6000K
rangersgoalie
 Posted: 11-12-2012, 05:14 PM
Post #11
It sure does. Not sure if this matters - last time I was in 4 wheel I was off roading, used 4 lo for a short steep part - to help keep the truck slowed down, but 4 hi worked just fine after that. It seems to shift in and out of both just fine,
Shikityshack
 Posted: 11-12-2012, 06:43 PM
Shikityshack's Avatar
The sky is falling!
City: Kansas City
State: MO
Post #12
I would check the fluid and make sure its full.. Then make sure there is nothing metallic in it.. Any metallic residue could be bushings gone bad. Is it making any clunking sounds or just whining on decel?
...............................Bright Silver RC SRT-10
rangersgoalie
 Posted: 11-12-2012, 08:23 PM
Post #13
Can I check the fluid levels with out doing a flush? Just as somethign to do fast to rule that out? if not what kind of fluids should I use for long tern protection? does being a 2500 vs a 1500 matter?
Shikityshack
 Posted: 11-13-2012, 07:29 AM
The sky is falling!
City: Kansas City
State: MO
Post #14
Yeah you can check the level, w/o a flush.. Unless its leaking I would think the level should be fine, but it doesn't hurt just to check.
I don't have a 4wd Ram to look at for referance anymore but there are 2 plugs on the t-case. one to drain it on the bottom and one to fill it.. These both look like round plugs that need a socket extension or allan wrench to unscrew them. I think its a 3/8 but I'm not positive on that..
On level ground,
Find the UPPER plug and unscrew it. The Fluid should be level with the bottom of the hole. You can put your finger in there and check it that way.. Using a Turkey baster (Thats what I use) you can even suck some fluid out to get more of it for analysis.
The fluid should be bright red since its Automatic transmission fluid.
When I changed the fluid in my last truck (a 1500) I used Mobil 1 synthetic ATF, the manufacturer calls for ATF+4.
I don't know though if the 1500s and 2500s are the same. So definately check for your 2500 application.
Audie61
 Posted: 11-13-2012, 07:56 PM
City: SE Idaho
State: ID
Post #15
Make sure you can get the fill plug out before you pull the drain plug. Mine was a bit of a biatch to get to & get out. Exhaust was in the way on my 1500, plug was stubborn also.
05 RC SB 4.7 4x4
wanting to put a Grant Aftermarket steering wheel on My 1998 Ram 1500 2 wheel drive s Trapper-steve 2G Dodge RAM - General Talk 0 08-10-2012 03:50 PM
4 wheel drive is good but screw drive is better PowerwagonMark Off-Road Talk 9 03-14-2010 08:20 PM
4 Wheel drive acting strange. jrod82 4G Dodge RAM - 4X4 Talk 7 02-17-2010 03:57 PM
Chrysler Recalls Rear-Wheel-Drive Cars For Front-Wheel Issue RAM MAN Rumor Mill & Gossip Talk 0 11-04-2009 05:24 PM
Rear wheel locking in 4 Wheel Drive when turning Viking07 3G Dodge RAM - Drivetrain Talk 55 12-18-2007 11:59 PM
