dumb noob question about rear end gears - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 3rd Gen (02 – 08) Forums > 3G Dodge RAM - Drivetrain Talk
catman113
  dumb noob question about rear end gears - Posted: 11-09-2012, 06:36 PM
catman113
City: belle chasse
State: LA
Post #1
i have a dumb noob question. I have a 2006 ram 1500 qcsb 2wd laramie and when i got the truck the dealer said it has 3.55 gears but with out jacking the truck up and rotating tires or pulling cover how can i tell ?
2006 dodge qcsb laramie flame red 2wd hemi w/mds
3.92 gears, factory 20's, lund bedcover, k&n drop in filter, 4" sewer pipe upgrade, moes 87mm throttle body, SC 3865 tuned to 87 tune, flowmaster 40 series si/do exhaust system,pioneer avic-x710bt head unit,kenwood excelon 6x9 and 5.25,alpine 5 channel custom center console box with 12"kicker cvr
2002 chevy 1500hd 6.0 auto 3.73s pine green
AEM brute force intake,hypertech programmer, 85mm throttle body,dual pipe,muffler magnaflow system,kenwood excelon KDC-X794 head unit,mb quart 6.5 components f & r,planet audio 600w mono,2-10"kicker cvt's in sealed box
moparmutt
 Posted: 11-09-2012, 06:47 PM
moparmutt's Avatar
City: near Winston-Salem
State: NC
Post #2
You can check the build list posted in the glove box.
Nick
2005 Ram QC SLT Thunder Road Hemi 4x4, tinted windows, Rancho 4" lift, DC2 17 rims and FC2 35's, Magnaflow dual exhaust, Superchips 3865, K&N intake, Pocket Flares, Truxedo low pro, Nerf bars, bed rails, Weather Tech floor liners, Cobra CB, tailgate spoiler, back up lights, spray in bed liner, A/F gauge, Interceptor gauge
2006 Charger Daytona R/T Hemi, loaded with all the bells and whistles
Project 72 VW beetle chop top
catman113
 Posted: 11-09-2012, 06:54 PM
catman113
City: belle chasse
State: LA
Post #3
did not know it was there ill check it in a bit thanx
05Ramhendrix
 Posted: 11-09-2012, 07:15 PM
05Ramhendrix's Avatar
Ramistered User
City: Estero
State: FL
Post #4
What size are your tires and what is your RPMs at 70 mph, a simple calculation and I'll tell you what you have.
Scott
2005 QC HEMI * 2wd * Viper PSB Bright Silver * AEM Brute Force Intake * Powerwire * Jetstream Scoop * Stant 14168 180* T-stat * Superchip Flashpaq 3865 w/ Trans Tuning * BBK Ceramic Shorty Headers * Magnaflow Y Pipe * Magnaflow Catback * Motive 4.56 Gears LSD * Rough Country 6" Lift *Moto Metal 951 20x10 *Nitto Terra Grapplers 305/55/20 * Alpine Audio
Ron380
 Posted: 11-09-2012, 07:22 PM
Ron380's Avatar
Just a Comedian.
City: Ohio
State: OH
Post #5
My '07 still has the sticker on the rear axle.
It's on the passenger side, facing the front.
2007 1500 SLT 4x4. 2-dr, short bed; 4.7l; 3.55 w/LSD.
-- More to come...
sapien
 Posted: 11-09-2012, 08:13 PM
City: Northern VA
Post #6
I thought they always paired the 20" wheels with 3.92 gears, but I could be wrong
mine specifies 3.92 on the decal in the glovebox.
catman113
 Posted: 11-09-2012, 10:06 PM
catman113
City: belle chasse
State: LA
Post #7
ok theres no sticker in glovebox,center console,or under hood but i did find the sticker on the rear end where ron said its a 3.92 rear end yaaaaaaa no gas mileage lol
dmcelhannon
 Posted: 11-10-2012, 01:31 AM
dmcelhannon's Avatar
Moderator – David Mack
City: McAllen
View Member's FaceBook Profile
Post #8
Before you say that, you need to remember you're driving a heavy truck with the aerodynamics of a cargo parachute. Give this a read ...
AIR_RAM
This subject has been beaten to death, I know I personally have beaten it to death alone... so I will make this as short as possible.
-RPM's alone do NOT dictate fuel economy.
-The load on the engine at ANY given RPM has more of an effect on fuel economy then the RPM's alone.
At steady highway speeds at 2000RPMs your fuel economy will very depending on the terrain. UP Hills will cause increased load so even though your RPM's stay at 2000, your engine burns more fuel. On DOWN hills its just the opposite and at the same 2000RPMs your engine burns less fuel... this backs up the fact that RPM's do NOT control your fuel economy and the load on the engine does.
With that said, if we can decrease the load on the engine then the fuel economy will increase... This is what gears do. They decrease the load on the transmission/engine at the cost of increase RPM's. But the only way to know for sure if the increase RPM's will help or not is to do the math. I will not argue that a 1500RPM increase will have a negative effect on MPG. BUT on the flip side, a 300-400RPM increase teamed up with a DRASTIC decrease of the load on the engine at any RPM will only increase efficiency.
To find out what to expect with your particular application just do the math... its simple, and math only has ONE correct answer. Its not an opinion so you cant argue it.
1) Find your overall gear ratio.
TRANSMISSION GEAR x REAR GEAR = OVERALL GEAR RATIO
2) Find your RPM's at any speed.
SPEED X OVERALL GEAR RATIO x 336 / TIRE HEIGHT = RPM'S
You need to keep in mind that the OLD SCHOOL thinking does NOT apply hear.
Back in the 60's/70's they did NOT have dual overdrive transmissions. They did NOT have 31"+ tall tires... as a matter in fact the tallest tire was like 26" tall... So a 4.56's with NO over drive and a 26" tall tire would have you whipping your crank around at 3535 RPM's...
While 4.56's in your Ram with short 31" tires .67 OD at 60MPH would have you at 1983 RPM'S.
So as you can see 4.56's in today's overdriven overdrive vehicles does NOT instantly mean poor fuel economy... In my opinion these overdrives ADD to the load of the engine because they are way to overdriven.
If you're planning on driving with the shorter tires, I would suggest the 4.10's if you're UNDER 30". I never had a problem when I ran 29.5" tall tires and 4.56's... but I don't feel it was ideal. In my opinion, 31-32" tall tires would be a good candidate for 4.56's... 30" you could go both way's but under 30" I would have to lean towards the 4.10's.
Ohh yeahh... we still have the best prices with free shipping!
SPEED SAFE, AIR RAM
Sent via a Texas RoadRunner Varmint ...
God Squad July 1972-To Infinity and Beyond-#40 Little Rammie Ridin' Shotgun Club
287 Club Member #81 ~ Broken C Clip Club Member ~ Two-Tone Truck Club Member #13 ~ 4.56 R&P Club Member #8
Mighty Cracked Dash Enthusiast Club #11~Mother Earth Raping Big Truck Club Member #25~Truck and Gun Club Member #97
2002 Ram 1500 SLT 4x4 QC - (Nov.01) 4.7L with 89K/3***hrs, 2002 Ram 45RFE Jeep GC TCM Upgrade to 5-45RFE, Knolton Thunder Cylinder Heads & HO Cams by Sawcut, 4.56 R&P/DTT, SRT-10 Pod w/Dynojet Wideband Commander, 2-speed manual transfer case, Clifford Security System w/Auto Start/Auto Windows, RB1 CD/DVD/NAV Infinity Sound System w/30GB iPod, Offroad Package, 33" BFG T/A KO E's, Mopar Rear Wheel Liners, EBC Greenstuff Roadsport Brake Pads, K&N w/Airaid Jr Modular Intake Tube, BBK 70mm Throttle Body, Sonnax Line Pressure Booster, AIR_RAM Jet Stream Scoop, PML Diff Cover, ASP Underdrive Crank Pulley, MSD 1.65 Alt Pulley, Lincoln E-Fan, DCC 2-Speed E-Fan Controller, 180 Jet T-Stat, Denso 160-amp Alternator, Flowmaster SI/DO Exhaust, Accele 3.5" LCD Backup System, Line of Fire LED Light Bar, Sylvania Ultra Silverstars, Hella 500 Black Magic-100W, Nokya Hyper Yellow Fog Lights, $1600 Oil Pick-up Tube thanks Dodge
Texas 1845: We the People of the Republic of Texas, acknowledging, with gratitude, the grace and beneficence of God.
“Firearms stand next in importance to the constitution itself. They are the American people’s liberty teeth and keystone under independence … from the hour the Pilgrims landed to the present day, events, occurrences and tendencies prove that to ensure peace security and happiness, the rifle and pistol are equally indispensable … the very atmosphere of firearms anywhere restrains evil interference — they deserve a place of honor with all that’s good.” - George Washington
Official DodgeTalk Facebook Page
http://www.facebook.com/DodgeTalk
05Ramhendrix
 Posted: 11-10-2012, 03:23 PM
Ramistered User
City: Estero
State: FL
Post #9
Be thankful for 3.92's instead of 3.55's
Scott
HemiLonestar
 Posted: 11-11-2012, 04:06 AM
HemiLonestar's Avatar
Red Trucker
City: Wilmington
State: NC
Post #10
X2...if you really ant to throw away your gas mileage, go with 4.56's
2003 Ram 1500 QC Hemi Lonestar Edition "Big Red"
SRT-10 suspension, brakes and interior parts, Circle D, Bilsteins, Superchips, AiRaid, Taylor shorties, McGaughy's shackles, Borla cat-back, Goodyear 305/50R20 GTII's, Extang Tonneau, Sonnax, Power wire, Daytona lip, tow mirrors, SRT hood.
Mods to come: 06+ coil conversion, Comp 260 install, 05 PCM conversion.
Sarcasm - it beats killing people.
Maybe stupid Question about Front/Rear Gears JohnMcD348 3G Dodge RAM - Drivetrain Talk 4 12-04-2010 01:25 PM
It's help a dumb ass out on DT day (rear end) 163612 4G Dodge RAM - Drivetrain Talk 18 11-16-2010 02:52 PM
dumb gears Spid3r 3G Dodge RAM - Drivetrain Talk 9 11-26-2008 01:09 PM
Dumb NOOB question... BlameCanada 1G Dodge Durango - Drivetrain Talk 7 06-08-2007 01:42 PM
Rear Gears Question Albert1500 3G Dodge RAM - Drivetrain Talk 31 04-19-2006 08:33 AM
