Engine tries to die after 50 miles - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 3rd Gen (02 – 08) Forums > 3G Dodge RAM - General Talk
Grscooby
  Engine tries to die after 50 miles - Posted: 11-03-2012, 01:48 PM
Post #1
I have an 07 Ram with a 3.7 V6. Problem has been going on all summer and I am tired of it.
I can drive anywhere between 40 and 60 miles and my engine starts to die. It feels like a fuel problem at first because it stutters and then won't rev up when you try to accelerate. I replaced the pump assembly. No change. As the weather got hotter, it did it sooner than 40 miles.
Changed the MAP sensor, plugs, and cleaned the air intake sensor. Only sprayed the throat of the throttle body. Cleared everything by grounding the positive cable. First morning to drive after the previous work was about 48 degrees and the truck had no issues. Now the afternoons are back in the upper 80's and it does it again!
If you put it in neutral, turn the key off for a few seconds, it will start and run fine for a few miles before running like crap.
Pulled codes and I have 0073 and 0463. i broke the ambient air sensor when I changed my condensor fan but it shouldn't cause a problem. As far as the high voltage at the sender, I could have pinched a wire or have one loose at the top of the tank. Either way if shouldn't do anything more than make the gas gauge goofy.
Anyone have any ideas?
Audie61
 Posted: 11-03-2012, 09:00 PM
City: SE Idaho
State: ID
Post #2
I know the FI system uses the air temp sensor. You did replace ti when you broke it right?
05 RC SB 4.7 4x4
Grscooby
 Posted: 11-04-2012, 07:09 AM
Post #3
I haven't replaced it. It's the ambient air temp sensor. The one that gives you the outside temp and shows it on the dash.
07MegaCabRam
 Posted: 11-04-2012, 10:37 AM
07MegaCabRam's Avatar
:: Mike ::
City: Chandler
State: AZ
Status: Online
Post #4
I could be wrong.. but I believe the computer monitors that as a "X" factor. If it's missing it maybe throwing something off. Should be a cheap try. Maybe a cheap fix.
I need to replace mine cause someone said it can cause bad MPG.. Mine reads at 85 most of the time.
::2007 Dodge Ram Mega Cab 4x4 5.7L Hemi::
Vision V-Tec Raptor 17x9 Wheels, 35" Nitto Trail Grappler MTs, KC 5" Apollo Lights in Factory Fog Light Location. Flowmaster Original 40 Series Muffler,
Painted B Pillars, Kenwood Sound System. Defender-PRO Spray in Bedliner I sprayed myself, 15% Window Tint applied by myself,
Carli Progressive 3" coils and Bilstein 5100s on all 4 corners. Updated 08+ Steering and Carli Steering Stabilizer 7100. 1.5" blocks in the rear. Carli Adjustable Trackbar.
Jimmi Jammer Door locks installed in all 4 doors. Kenwood DNX5120 head unit with 2 Kenwood 10"s, Kenwood 5 channel amp and Kenwood Components in all 4 doors.
crasher76
 Posted: 11-04-2012, 03:25 PM
crasher76's Avatar
Im wired!!!
City: K-TOWN
State: WI
Post #5
Torque converter??
Black 2003 QC SB SLT 4x4 Offroad 5.7L HEMI, Original Owner 3.92 LSD, SRT CAM, 6.1 Rods/Springs, Home Ported/Polished Heads, Psc1, 04 Map sensor and Fuel pump assembly, Oil pressure guage, Amsoil, Champs, MSD 8.5MM Full length Wires, Transgo HD w/out resistor, Superchip, 180 T-Stat, K/N 77 Series, Ceramic Flowtech headers with Y-Pipe, Stage 8 locks, Ditched the cat, O2 sensor mod, Jack Rabbit bed cover, Sprayed bed liner, Big Mouth Grill-Black, Blackend Headlights/Tails, Silverstars, Ditched all chrome, Custom 10's sub enclosure, Upgraded 160 amp alt, Window tint, Relocated purge valve, Energy suspension bushings, Rear spring clamps, Passport 8500 Radar Detector, Ditched the baby seat- kid wasnt mine, Cigarette burn in the seat mod, Debadged, Custom Rewired/Properly Grounded.
Grscooby
 Posted: 11-04-2012, 05:06 PM
Post #6
I am going to pick up a sensor tomorrow just to rule that out or who knows maybe it is the fix!
I thought of torque converter but outside temperature making the problem better ir worse made me think otherwise.
07MegaCabRam
 Posted: 11-05-2012, 01:33 PM
:: Mike ::
City: Chandler
State: AZ
Status: Online
Post #7
Lets us know if that worked. Also if you can get a part number. I need to get me one as well.
Guess it's your Standard Motor Products AX75 Ambient Temperature Sensor..
Rich 2500
 Posted: 11-05-2012, 04:58 PM
Rich 2500's Avatar
City: Chesapeake City
State: MD
Post #8
Next time it does it open the fuel cap and see if it sucks air.
Elec. Blue 07 2500 Thunderoad QC Hemi 4X4
BTC #181
Mopar Cai, Mopar SS Nerf Bars, Mopar Tow Mirrors, Mopar Wheel Well Liners, EGR In Channel Window Vents, Tinted Windows 30%, Hella 500's behind the grill, Gibson Dual Sport Catback Exhaust, Magna Flow "Y" Pipe, Jet Stream Scoop, Power Wire, LineX Bedliner, Flexalite 180 Efan (shrouldless), Jet 180 Thermostat, Edge Evolution (used as monitor) DiabloSport Predator, Solid Steel Industries-Steering Stabilizer, Carli Starter Suspension System, Carli Adj. Track Bar, Toyo 35/12.50/17 MT on Stock Wheels, Carli Anti Sway Bar, Xeon Fogs 6000K
Grscooby
 Posted: 11-05-2012, 05:29 PM
Post #9
I tried the cap thinking the charcoal canister was plugged up and it was not breathing. But the cap was venting right.
I bought the part (SU3122) at autozone today. Had been running bad again this afternoon is how I even remembered to go buy it. Ran perfect the rest of the way home. The true test will be tomorrow afternoon as temps in Dallas are going to be close to 80 and I gave a 100 mile trip late in the afternoon.
We shall see......
sawcut64
 Posted: 11-05-2012, 07:25 PM
sawcut64's Avatar
Inertia ROCKS!!!!
City: Arlington
Post #10
The codes are for IAT sensor and fuel level sensor, I'd start with those and the wiring, also check the battery, weak or bad batteries can cause all sorts of weird issues.
2005 RC SB 2WD Hemi Ram
Inertia Motorsports Moe's Performance
NA Stockblock Setup-7.79 1/8 NA, Best 60ft 1.68
NA Stroker Setup-?
Inertia 400 CI Stroker-Inertia Custom Cam-170 Degree T-stat-6.1 Exhaust Springs/6.1 Pushrods-Caltracs-Superchips Performance tune-Ebay Knock Off CAI-Edge 2800 Billet Converter-IAT Mod-True 3" Dual Exhaust Dumped-McGaughy Rear Flip-Motive 4.56 Gears, Factory LSD-Pacesetter Long Tube Headers-Stock Front Coils Trimmed 2" Drop-Street Scene Roll Pan
Dodge4x4810
 Posted: 11-05-2012, 09:06 PM
State: MA
Post #11
P0073-ambient Air Temperature Sensor Circuit High
P0463-fuel Level Sensor 1 Circuit High
2005 Daytona HEMI qc 4x4
True Duals w/ x-pipe, No cats, 2 10 Series dumped, Mopar Cold-Air Intake, 3.92 gears, Removed Body Kit, T-bar crank, Diablo Custom Tune, 35x12.5x20 Pro Comp Xterrains, 3" PA Body Lift, Gibson headers, MSD wires, egr delete
"disturbing the peace since 1987"
Grscooby
 Posted: 11-06-2012, 03:09 PM
Post #12
So I can now tell you that the ambient air sensor was not the problem. Again ran great in the morning whe it was 45 degrees out. At 75 degrees it ran about 50 miles before it acted up again.
dmcelhannon
 Posted: 11-06-2012, 09:18 PM
dmcelhannon's Avatar
Moderator – David Mack
City: McAllen
View Member's FaceBook Profile
Post #13
I'm with Rich 2500. If it's the fuel pump then the pump cannot move the fuel against the vacuum the engine is pulling. Just because the fuel is vented doesn't mean the fuel system is getting enough air. The vented fuel cap is there to help the fuel tank breath while the truck is sitting, mot while it's running down the road.
Sent via a Texas RoadRunner Varmint ...
God Squad July 1972-To Infinity and Beyond-#40 Little Rammie Ridin' Shotgun Club
287 Club Member #81 ~ Broken C Clip Club Member ~ Two-Tone Truck Club Member #13 ~ 4.56 R&P Club Member #8
Mighty Cracked Dash Enthusiast Club #11~Mother Earth Raping Big Truck Club Member #25~Truck and Gun Club Member #97
2002 Ram 1500 SLT 4x4 QC - (Nov.01) 4.7L with 89K/3***hrs, 2002 Ram 45RFE Jeep GC TCM Upgrade to 5-45RFE, Knolton Thunder Cylinder Heads & HO Cams by Sawcut, 4.56 R&P/DTT, SRT-10 Pod w/Dynojet Wideband Commander, 2-speed manual transfer case, Clifford Security System w/Auto Start/Auto Windows, RB1 CD/DVD/NAV Infinity Sound System w/30GB iPod, Offroad Package, 33" BFG T/A KO E's, Mopar Rear Wheel Liners, EBC Greenstuff Roadsport Brake Pads, K&N w/Airaid Jr Modular Intake Tube, BBK 70mm Throttle Body, Sonnax Line Pressure Booster, AIR_RAM Jet Stream Scoop, PML Diff Cover, ASP Underdrive Crank Pulley, MSD 1.65 Alt Pulley, Lincoln E-Fan, DCC 2-Speed E-Fan Controller, 180 Jet T-Stat, Denso 160-amp Alternator, Flowmaster SI/DO Exhaust, Accele 3.5" LCD Backup System, Line of Fire LED Light Bar, Sylvania Ultra Silverstars, Hella 500 Black Magic-100W, Nokya Hyper Yellow Fog Lights, $1600 Oil Pick-up Tube thanks Dodge
Texas 1845: We the People of the Republic of Texas, acknowledging, with gratitude, the grace and beneficence of God.
“Firearms stand next in importance to the constitution itself. They are the American people’s liberty teeth and keystone under independence … from the hour the Pilgrims landed to the present day, events, occurrences and tendencies prove that to ensure peace security and happiness, the rifle and pistol are equally indispensable … the very atmosphere of firearms anywhere restrains evil interference — they deserve a place of honor with all that’s good.” - George Washington
Official DodgeTalk Facebook Page
http://www.facebook.com/DodgeTalk
Grscooby
 Posted: 11-07-2012, 02:56 PM
Post #14
Like clockwork it is doing it again this afternoon. No sucking air when the cap is removed. I am driving it now with the cap off. And it has not yet set a code like I expected.
Last pump I bought was an Airtex brand. If its going bad I guess I buy a lifetime pump at autozone so I am only out my labor.
dmcelhannon
 Posted: 11-07-2012, 09:45 PM
City: McAllen
Post #15
Have you checked for clogged or kinked EVAP lines (hoses)? The only other thing that makes any sense is clogged pickup filter screen on the pump.
sawcut64
 Posted: 11-07-2012, 10:30 PM
sawcut64's Avatar
Inertia ROCKS!!!!
City: Arlington
Post #16
How can a fuel pump, pump fuel flawlessly for 50ish miles then like clockwork sporadically malfunction?
NA Stroker Setup-?
lightning04
 Posted: 11-07-2012, 10:33 PM
State: NJ
Post #17
Had this problem with a ford lightning, it ended up being the egr. Bought a egr delete kit for the truck, never had the problem return...
Steve
dmcelhannon
 Posted: 11-07-2012, 11:54 PM
City: McAllen
Post #18
I thought of that but he said some times it dies at 40-miles, then it's 60-miles, then 50-miles, and he's the one that's rounded the number off to a clock-work-50-miles. When an EGR goes bad, it's bad, and it only gets worse. Now I do not have to deal with an EGR on my engine and if I did, I believe it would some how fall off my truck.
lightning04
 Posted: 11-08-2012, 07:48 AM
State: NJ
Post #19
With my truck when it was giving me problems with the egr, if was cruising you wouldn't really notice it, but when i would let off the gas it would buck and basically lose power and almost stall... Then if i was to gas it again, it would hesitate bad... And on warmer days it would do it so much more then on cooler days. Happened for about a month, took it to my performance shop and like i said, egr delete kit and it runs great
Steve
Grscooby
 Posted: 11-08-2012, 08:35 AM
Post #20
Earlier this year I got the code for the egr and replaced it. Pain in the ass to get to because you can't see it and have your hands in there too.
I haven't looked closely at the evap but will this weekend. The idea of something plugged up is starting to make more sense. My truck acts just as lightning describes above with the exception that at highway speed it will start to buck and that's when you lose power. Ten seconds with the key off and you can resume acceleration but only for a few miles. Step on the gas and its as if you have no fuel. Shutting the engine off would seem to allow a slight relief in the clog. It almost has to be a mechanical issue as no codes are being set. Unless of course the ECM is bad.but that doesn't make sense either.
New Engine @65K miles...how??? Skyjacked Hemi 5.7L, 6.1L Tech 3 10-21-2012 08:59 PM
Engine break in, How many miles?? gregsrt 3G Dodge RAM - General Talk 9 09-30-2008 08:43 PM
Check Engine at 84,500 miles 2000DurangoTech 1G Dodge Durango General Talk 4 06-12-2006 08:25 PM
How many miles on your 5.9 engine? tyler40martin 1G Dodge Durango General Talk 21 09-10-2005 05:32 AM
