Lift Kit Review/Pics Sticky - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 4th Gen (09 – Up) Forums > 4G Dodge RAM - 4X4 Talk
BEsRaider
  Lift Kit Review/Pics Sticky - Posted: 10-26-2012, 03:29 PM
BEsRaider's Avatar
City: Manassas, VA
View Member's FaceBook Profile
Post #1
Alright guys. I want to make a pseudo-database of lift kit combinations. I am going to maintain this list for the time being with Pics, reviews and install notes. If you have a lifted truck, please PM or email me at bryce.eastlick@gmail.com with A SINGLE pic of your truck and include what lift combo you have as well as tire/wheel size and any sort of SHORT review or install notes that you may have. PLEASE INCLUDE YOUR USERNAME IN THE TITLE LINE. That will allow people to contact you with further questions and I can lable your pics/reviews accordingly. I am going to continue to edit this original post with updates as I get them or find them (or have the time to seek them out).
Thanks guys! And hopefully this helps streamline some questions and searches.
1500 Regular Cabs
bigsarge:
2" level and 285/70 17's.
Unknown User:
4" Mopar Lift (so Im told)
1500 Quad Cabs
NMBowtie:
"2" TGC in front, nothing in the rear, and 255/80/17 BFG MT's (34" tall). The spacer was good quality, and I never had any shake/wobble or noticed any extra wear and tear. I installed the spacer when the truck had about 3k miles on it and I was pushing 40k when I traded it off"
Thor09:
" 6" RCX on my 2012 Outdoorsman. I already had Bilstein 5100s maxed out and I put in a 3/4" Top Gun Customz rear coil spacer. I also put in Air Lift 1000 air bags."
Fingerbang:
Rough Country 6" Suspension Lift -- Black KMC SPY 17x9 (-12mm offset 4.53 BS)--- Nokian Vatiiva M/T 35x12.5R17 -- Hubcentric rings
1974Rayne:
4" Superlift with Bilstein 5100's on all 4 corners set to stock height. 35x12.50r20 Toyo MT's on Fuel Offroad Octane 20/9 +1mmOS.
Musclemckeester:
6" Pro Comp lift, Bilsteins @ 2.8" and 1.25" body lift. 37" Mud Grapplers and 20x10 Hostages (-24mm offset)
BigHorn 4 Life:
6" BDS,Bilsteins 2.8",1.25" RCX body lift; 37x12.50 Nitto Trails,Moto metal 951 20x10 -18 offset
Johnnyfizzle:
6" with 3 inch body with 35s it is a true 9" lift
Triangleman29:
6" Rough Country; Fuel Hostages -12 offset; 35" Cooper STT's
Reckster360:
Bilsteins @ 2.8" and 1.25" body lift, Nitto Mud Grappler 33x12.5r17, rims are fuel krank 17x9 -12 offset
HEMIHag:
2011 Outdoorsman Quad Cab 4" RCX lift with 35X12.5X20 Toyo Open Country on 20x9 Fuel Pumps. Lift was straight forward install. Differential bolts were the biggest pain in the whole process. Just did my second one on my buddies truck. Went much smoother the second time.
Shots:
2012 QC 1500 Outdoorsman with only a 1.5" Auto Spring Level kit. It's the same type of level as Top Gunz Custom, and Hellbent Steel. I ordered 1.5" because the Outdoorsman sits .6" higher than other models due to different struts from the factory. My current height is 38" front and 39.5" rear.
jake09:
2009 Dodge Ram QC, 4" Superlift/Mopar lift, Bilsteins 5100 front adjustables set at 2.1", 1.25" Rcx Body lift, Rear Bilsteins 5125 12" travel, 1.5" TGC Rear Coil Spacers, 20x10 MHT Fuel Hostages -12 Offset, 37/12.50/20 Nitto Trail Grapplers
2012 Ram Express 4x4
True Blue
BEsRaider
 Posted: 10-28-2012, 07:40 PM
BEsRaider's Avatar
City: Manassas, VA
Post #2
1500 4x4 Crew Cabs
Desert Dawg
"6-inch ProComp Stage 1 suspension system, BFG 35-inch All Terrains mounted on 20-inch Eagle Series 064 wheels"
timberjack84:
" 6" pro-comp lift, 37x13.50 Toyo OC M/Ts, 20x10 MM951's (-18mm offset)"
truckerman01:
"6" Zone lift , Toyo 325/65/18 Open Country AT's "
JadesMarine:
Trim: Sport Lift: 4" Rough Country Tires: 35x12.5x20 Rims: Stock w/ .25" spacers
Stecker108:
RCX 6" lift 20x9 XD Spy Rims 37x12.50R20 Trail Grapplers
fastNugly (Multiple Transformations):
6" RCX, 2.1 Bilstiens, 1" TGC Rear Coil Spacer on 37" Nitto Trails (20x9, 0 offset)
6" RCX, 2.1 Bilsteins, 1" TGC Rear Coil Spacer, 3" PA Body Lift on 37" Nitto Trails (20x9, 0 offset)
6" RCX, 1.4 Bilstiens, 1" TGC Rear Coil Spacer on 37" Nitto Trails (20x9, 0 offset)
Nova5757 (Multiple Transformations):
2.1 BILSTEINS
2.8 BILSTEINS
RCX 4" with Stock Shocks 20x9 Fuel Wheels +1 Offset 35x12.5 Toyo Open Country MT's
RCX 4" with Bilsteins Set to 0.7"- Leveled with Rear
Durun:
RCX 6" 2.8 Bilsteins .75 Rear spacer and 1.25 RCX Body lift. Running 35 1250 Mud Terrains
1500 2wd Crew Cabs
BULLRAM:
2009 2WD CST 7 inch , stock chrome clad with 305/55/20 Nitto Terra Grappler ,1.5 Hub concentric and Wheel concentric spacers in rear,ride is a little stiffer than stock but still real smooth
True Blue
BEsRaider
 Posted: 10-31-2012, 11:54 PM
BEsRaider's Avatar
City: Manassas, VA
Post #3
2500 Crew Cabs
Wandell:
5 inch Rough Country lift. It is a "short arm" kit and the ride quality/performance is basically the same as stock. Most agree that the "long arm" kits ride better, but if all you want is added height the short arm kits are a great value. I'm running 355/60-20 (37x14.00) Nitto Terra Grapplers on 20x9 inch KMC XD Spys (with 4.5 inches of backspacing).
True Blue
Thor09
 Posted: 11-01-2012, 09:55 AM
Thor09's Avatar
State: PA
Post #4
I think this is a great thread for everyone to use. I'll be throwing in 1.5" rear spacers to replace the 3/4" ones soon and I'll get you an updated picture. I could also give you a shot of my 09 with a 6" BDS and Bilsteins at 2.1" to add into the mix too
2012 Outdoorsman 1500
|6" RCX, Bilstein 5100s @ 2.8", Air Lift 1000 airbags, TGC 1.5" Rear Coil spacers|Fuel Throttle 20x10 w/ Kumho MT 37x13.50-20|
|GoRhino Dominator II steps|Westin Lightbar|KC Daylighter HID retro|Hella 500 Black Magics|G2 Bakflip|Line-x bed|Weathertech Mats|Mopar Door Sills|Stubby|AEM Brute Force CAI|Mygig Lockpick v.5|Diablosport Trinity|
|MG Painted Quads|Morimoto Projectors/Halos|Tinted Fogs/Tails|6K HIDs| Switchbacks|Recon White Lightning Lightbar and Recon Smoked 3rd Brakelight|
BEsRaider
 Posted: 11-01-2012, 10:58 AM
BEsRaider's Avatar
City: Manassas, VA
Post #5
You don't do low trucks, do you?? HAHA.
True Blue
Wandell
 Posted: 11-01-2012, 11:53 AM
Wandell's Avatar
State: GA
Post #6
A similar thread for the lowered or stock height "street trucks" would be a great idea!
2012 Ram 2500 ST Cummins Crewcab. 5 inch Rough Country lift, 37 inch Nitto Terra Grapplers on 20x9 KMC XD Spys, H&S XRT Programmer, MBRP exhaust
BEsRaider
 Posted: 11-01-2012, 08:34 PM
BEsRaider's Avatar
City: Manassas, VA
Post #7
Thats a thread for someone else to start!
True Blue
Yellomantis
 Posted: 11-01-2012, 11:59 PM
Yellomantis's Avatar
Cali Wagon Wheeler
City: So Cal
State: CA
Post #8
You can use the pics/info on my Power Wagon as well. I'm too tired to look it up, but if you run a search for "ICON edition" Power Wagon, something should pop up.
Before you criticize someone, walk a mile in their shoes.
That way, when you do criticize them, you're a mile away, and you have their shoes!
BigHorn 4 Life
 Posted: 11-04-2012, 09:31 PM
BigHorn 4 Life's Avatar
City: Blue Springs
State: MO
Post #9
Pics and info sent to your email
2010 Dodge Ram 5.7 HEMI, 9"+ suspension Lift, BDS 6" Lift ,Bilstein 5100 adjustable struts set max settings 2.8",RC 1.25 body lift,Nitto Trail Grapplers 37x12.50x20,Moto metal 20x10 951 -18 offset with a 4.75 back spacing, Dominator 11 's,Charcoal Lamin-X Blackouts on the tail lights, Gunsmoke Lamin-X on Head lights,SuperChips Tuner,14" Magnaflow,Rhino liner,DDM 35watt 6000k fogs,Retrosolusions Digital 35watt 8000k heads.
nova5757
 Posted: 11-05-2012, 05:21 PM
nova5757's Avatar
City: Memphis
State: TN
Post #10
Hey BEsRaider, I have an issue with reading instructions. You can delete my post and take any info you desire. This is a great idea and I wish it was out there when I was doing all my research.
Keep Calm and Chive On!
-Kevin
2012 Sport CC 4x4
_________________________________
Rough Country 4" Lift / 1.25" RCX Body Lift / Bilstein 5100's Set to 0.7" / Bilstein 5125 Rear Shocks / Fuel Throttle Wheels 20x9 +1mm / Toyo MT 35/12.5/20's / Tri-Fold Tonneau Cover / 5% Side Tint, 2% Rear Tint / PlasmaGlow Firestorm LED Tailgate Bar / Painted Grille / 5K HID Heads and Fogs / LED Interior Lights / Tow Hooks / 3500 Ram Flares / Blendmount Radar Mount / 20" Rigid LED / Bully Dog GT for Hemi Plus / Line-X Bed and Step Bars
fastNugly
 Posted: 11-07-2012, 11:23 AM
fastNugly's Avatar
City: Toronto
State: ON
Post #11
Your post was informative and great for those considering options
BEsRaider, I sent you a PM with the different lift options my truck has gone through
BEsRaider
 Posted: 11-07-2012, 01:50 PM
BEsRaider's Avatar
City: Manassas, VA
Post #12
Hey, thanks for the support guys! I have a couple emails and PMs with pics to upload. I took this weekend to help some family out of town and I am getting caught up on my life still this week. Please be patient with me, and Ill have it taken care of in the next day or so.
True Blue
BEsRaider
 Posted: 11-07-2012, 02:08 PM
BEsRaider's Avatar
City: Manassas, VA
Post #13
Okay, I loaded BigHorn's. I am going to load Fast's and Nova's a little later. They each contributed 3 photos each, and I think will make a strong contribution to this thread, but it will take a little more time and frankly, I just lack the motivation at this moment. Check back later and this thread will probably grow by 50% or more with those two uploads!
True Blue
fastNugly
 Posted: 11-07-2012, 02:19 PM
fastNugly's Avatar
City: Toronto
State: ON
Post #14
Sweet!
Great work OP!
Any way I can help others is all I want to come out of this.
I spent way to many nights trying to figure out what to do and bothering other members....LOL
BigHorn 4 Life
 Posted: 11-07-2012, 02:33 PM
City: Blue Springs
State: MO
Post #15
Thanks BEsRaider. This thread is awesome bro!! Great job bud.
Thor09
 Posted: 11-18-2012, 09:12 PM
Thor09's Avatar
State: PA
Post #16
Yeah, this thread is awesome, I could have really used this in the past. I got bigger rear spacers in so I'll get some pics soon and get you the info to update mine
fastNugly
 Posted: 11-18-2012, 09:36 PM
fastNugly's Avatar
City: Toronto
State: ON
Post #17
Nova5857 and my pics have yet to be uploaded.
I too wish something was out there when I was looking.
BEsRaider
 Posted: 11-18-2012, 10:14 PM
BEsRaider's Avatar
City: Manassas, VA
Post #18
Ill do it tomorrow man. I work crazy hours, and this isnt my top priority.
True Blue
fastNugly
 Posted: 11-18-2012, 10:46 PM
fastNugly's Avatar
City: Toronto
State: ON
Post #19
Sweet man!
BEsRaider
 Posted: 11-19-2012, 02:59 PM
BEsRaider's Avatar
City: Manassas, VA
Post #20
ALRIGHT GUYS! I think this is completely up to date with all emails and PM's. Sorry for the delay, but life has been keeping my busy...and I haven't sat behind my computer long enough to do all of the uploads, especially for you dudes that sent me 3 or 4 phases!
Thanks again for the support, and let me know if there is anything I can do!
True Blue
Tire review Thread moparhindsight 2G Dodge RAM - 4X4 Talk 52 04-05-2012 10:36 AM
rough contry lift kit review bandar 4G Dodge RAM - General Talk 3 12-06-2011 02:04 AM
PICS of my new Sticky 22" tires!!! HEMI450HP 3G Dodge Ram Performance Talk 49 01-21-2007 05:16 PM
Doetsch body lift review fourtraxrider 2G Dodge RAM - 4X4 Talk 0 11-17-2005 02:17 PM
