your opinion on the magnum 360? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 2nd Gen (94 – 01) Forums > 2G Dodge RAM - General Talk
maachine
  your opinion on the magnum 360? - Posted: 10-24-2012, 06:20 PM
maachine's Avatar
City: Hammond
State: LA
Post #1
my LA 318 engine is done in my 87 w-150. talked to a fellow member today about putting a magnum 360 in my truck, along with possibly upgrading the driveline to a lock up type 4 speed trans as well.
just wanted your thoughts on the magnum 360 engine. you guys like it? been reliable?
my other concern is the tranfer case in the newer drivelines. push button 4wd or is there a shifter like my 87 has?
1987 Dodge W-150 "The Beast"
2" Lift
33" AT's
318 build currently in the works
208/727A w/3.21 gears
spun360
 Posted: 10-24-2012, 08:16 PM
spun360's Avatar
City: Pottstown
State: PA
Post #2
the 360 is a good roller & push rod engine, just its tough to squeeze the full potential out of them for performance applications. these obdII trucks really need a tuner chip and low gears. they run long and strong, not unheard of to surpass 300k miles. and it seems the aftermarket mechanical performance end is still being supplied well enough.
as for the 46re/ 46rh or chrystler trans "what ever" automatic, you may want to consider a stick, or spend $2k on a great upgrade in automatic.
the 4x4s are a stick selector on the floor
parts for sale
$125: 210lb double and dampener valve springs .550 lift
$20 : new, standard oil pump
$15 : new, super strength moog #377 frt axle hub universal w/ grease fitting
prices include shipping (for residence of the US)
cheep
shoot PMs my way
maachine
 Posted: 10-24-2012, 09:24 PM
maachine's Avatar
City: Hammond
State: LA
Post #3
i have a 727a 3speed auto right now. i've been told the magnum 360 will bolt to it. i was thinking that if i find a good donor 4x4 with a magnum 360 i might as well take the drive line too and get a 4 speed trans instead of the 3 speed. just for fuel mileage.
as for the EFI. my plan so far is to put an edelbrock rpm air gap intake on it and carb it. no computers allowed. keep it simple.
2" Lift
33" AT's
Binksman
 Posted: 01-10-2013, 10:25 PM
Binksman
City: Danville
Post #4
I say do it. My the 5.9 engine from my old 96 Ram worked hard from 100k to 180k before the rest of the truck rusted out from under it. I put new gaskets in the engine and swapped it into my 96 Grand Cherokee where it continues to run strong. Engine now has about 185k on it and I expect it to last as long as the body of the Jeep does.
Just don't ever expect good fuel mileage from them
As for the transmission... it sounds good on paper, and may work because your older Ram is lighter than what the drivetrain came out of (lighter=less work) but I trust the mid-90's Dodge truck auto transmission about as far as I can throw them (3 feet). I've had 5 auto transmissions between the two vehicles. That is why the new truck is a manual and why the wife gave me the go ahead to MAKE the ZJ a manual when the time comes.
The King
 Posted: 01-10-2013, 10:53 PM
The King's Avatar
It's good to the the king
City: St Pete
State: FL
Post #5
Swap out the stock 5.9 cam for.....anything!!! The factory ones are smogged down heavily. Heck, the 5.2 has a better cam
2004 Ram Off-Road 5.7
maachine
 Posted: 01-10-2013, 11:40 PM
maachine's Avatar
City: Hammond
State: LA
Post #6
well i have a ton of 318 parts laying around. i think i'm just going to rebuild a roller pre 92 engine.
besides that i have found many articles on how to build a 400 HP 318 engine. but when i start looking for articles on 360 magnum builds.....cant find anything.
2" Lift
33" AT's
RedRam1500Sport
 Posted: 01-14-2013, 04:24 AM
State: IL
Post #7
You might find this article helpful-
http://www.hotrod.com/techarticles/e...e/viewall.html
maachine
 Posted: 01-14-2013, 04:39 AM
maachine's Avatar
City: Hammond
State: LA
Post #8
thanks for that. reading it now
2" Lift
33" AT's
maachine
 Posted: 01-14-2013, 04:58 AM
maachine's Avatar
City: Hammond
State: LA
Post #9
i have read that article before. the issue is they changed the heads to aluminum aftermarket. from some of the articles i have read about using LA 360 and LA 318 parts is that you can achieve 400 HP with limited after market parts. you can build a beast of a motor with very little cost. this build shows after market heads....which are $$$$$$$. granted this build puts out more HP and torque. but the build options for the LA318 are plentiful and achive close (about 45 HP less) to the same goal at half the price.
2" Lift
33" AT's
RedRam1500Sport
 Posted: 01-14-2013, 05:05 PM
State: IL
Post #10
For the price then I agree- since you have the parts anyway the 318 is better.
RedRam1500Sport
 Posted: 01-14-2013, 11:17 PM
State: IL
Post #11
Here is great episode of horsepower tv for a "budget build" 360 with the original heads but they only squeeze just over 300hp out of it.
http://www.powerblocktv.com/episodes/HP2009-17
maachine
 Posted: 01-15-2013, 08:55 AM
maachine's Avatar
City: Hammond
State: LA
Post #12
thanks. i'll give it a look later on
2" Lift
33" AT's
rattler2000
 Posted: 01-15-2013, 01:57 PM
rattler2000's Avatar
City: Medina, OH
State: OH
Post #13
What a waste of time. They use an LA 360 instead of the much more plentiful Magnum 360. The stock Magnum heads flow much better than the LA heads. With even a little bit of money they could have built a decent 406-408 stroker. I don't understand what the were trying to accomplish??? Everything is stock ???????????/
It's green and it is fast.
RedRam1500Sport
 Posted: 01-15-2013, 04:46 PM
State: IL
Post #14
I think their goal was to keep the costs down, but I agree with you. They should have used a magnum. I believe the newer Magnums addressed some issues that improved reliability too.
Also just curious, but does anyone know if the Magnums use the special "high nickel alloy" like the LA's?
rattler2000
 Posted: 01-16-2013, 12:43 PM
City: Medina, OH
State: OH
Post #15
According to Larry Shepard in his book How to Modify you Mopar Magnum V8 "All Magnum engine blocks are made of high-nickle alloy, the same material used for DaimlerChrysler's special race blocks and 426 Hemi." He goes say that most other manufaturers only used this material for their race blocks but Mopar used it in all their production including 318s, 340s, 360s and Magnums.
If anybody is thinking about building a Magnum motor, I highly recommend Larry Shepard's book as well as How to Build Big-Inch Mopar Small Blocks by Jim Szilagyi.
Woodstock
 Posted: 01-16-2013, 04:46 PM
Woodstock's Avatar
Woodstock
City: Piney Flats
State: TN
Post #16
The Magnum 360 with a carb is the way to go. Forget about the 4spd tranny - too much work and expense in my opinion. If you are going to spend that much money beefing up a 4speed auto, install an aftermarket overdrive and have a bullet proof 6speed 727.
2000 1500 Sport 5.9 4X4 QC 46re w/TFODjr
SCT by hemifever, 4.10 Gears, Stainless Steel Headers
HellBent Steel leveling kit, 33X12.50X16 Super Swamper TSL Radials
RedRam1500Sport
 Posted: 01-16-2013, 07:22 PM
State: IL
Post #17
I'm going to buy the book. I never heard of it before.
maachine
 Posted: 01-16-2013, 09:27 PM
maachine's Avatar
City: Hammond
State: LA
Post #18
huh cool info. especially about the 6 speed 727. i havent gotten around to reading any of it yet, been crazy busy at work.
thanks guys. i started this thread when i was just about to buy a 360 magnum from a local neighbor. he wanted too much money for the mileage on it so i declined.
my point now is that i could make a budget 318 with 350+hp, especially since i have most everything i need to build one. just a block, crank, and a few odds and ends and i should be set to build.
2" Lift
33" AT's
madmikeismad
 Posted: 01-17-2013, 05:40 AM
madmikeismad's Avatar
R.I.P Big Blue
City: Moore OK/WNY/Johnson City
State: OK
Post #19
Aftermarket overdrives aren't cheap either, especially if you're talking about something like a gear vendors. Be better in the long run to swap in a mild built 46rh.
I would also keep the 318 you have now, and build that, save a lot of money on the swap, and that will get you a good bit more horsepower.
Mike Hill
Sometimes I laugh so hard, the tears run down my leg.
Purple People Eater - 98 12v http://picasaweb.google.com/mch8223/Diesel#
The Race Truck- New drag truck with big plans!
https://www.youtube.com/user/THEmadmikeismad/videos
Games and Trucks Club Member #1
Blue Truck Club Member #177
Military Truck Club Member #81
DodgeTalk.com 360MAGNUM Enthusiast Member #64
4wd Truck Club Member #24
Trucks & Guns Club Member #87
01 Ram 1500 Sport 4x4 5.9 (RIP Big Blue )
Woodstock
 Posted: 01-17-2013, 10:25 AM
Woodstock's Avatar
Woodstock
City: Piney Flats
State: TN
Post #20
This is the unit I was talking about. It bolts in place of the transmission extension housing.
http://www.gearvendors.com/
Magnum VS. Magnum (lots of pics) JarZ Dodge Magnum SRT-8 Talk 1 11-24-2011 09:44 PM
Engine swap 1993 5.9 magnum with a 1995 5.9 magnum bstopek Dodge Ram Truck 1st Gen (88 - 93) Forum 4 12-28-2010 07:38 PM
Magnum 5.2 in Older truck/Forged Pistons for Magnum impuresoul2k3 1972-1987 Dodge Ram Trucks (D, W-series) 17 09-18-2008 08:07 PM
New Magnum 5spd or Used Magnum 4spd V6 scottyd Dodge Magnum - General Talk 1 06-05-2006 02:36 PM
HELP! Magnum Owners or Magnum Drivers! Herb Jenssen Dodge Magnum - General Talk 24 09-22-2004 11:04 AM
