1985 Dodge w150 engine swaps - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 31 Old 10-20-2012, 10:02 PM Thread Starter
FirstRide
Just curious about if it would be worth it to swap the 318 out thats in it for something bigger maybe like a 360 or maybe even a 440. Just wondering your takes on it if it would be worth it and which motor would be best. Any ones opinion would be nice.
FirstRide is offline
post #2 of 31 Old 10-21-2012, 12:36 AM
maachine
maachine's Avatar
Quoted: 45 Post(s)
i'm thinking the 360 swap would be easiest. what kind of transmission?
1987 Dodge W-150 "The Beast"
some sort of lift
33" AT's
LA 360 bored .030 over, EQ Magnum heads, Hooker Headers, true dual exhaust, Holley 4160 w/Truck Avenger parts, Edelbrock Performer dual plane intake, StreetFire ignition box & MSD coil
208 t-case/727A trans w/3.23 gears
maachine is offline
post #3 of 31 Old 10-21-2012, 10:05 AM Thread Starter
FirstRide
ok and its got the 727 3 speed tranny
post #4 of 31 Old 10-21-2012, 10:39 AM
Moparite
Moparite's Avatar
Quoted: 312 Post(s)
a 360 is your best choice. Small blocks take the trans(727A) you already have. Big blocks take the 727B. You didn't say what you will be using the truck for. So what would be best depends on that.
Moparite is offline
post #5 of 31 Old 10-21-2012, 11:07 AM Thread Starter
FirstRide
O id just be useing the truck to drive and maybe a little bit of mudding not much but i just want it to have a little bit more power
post #6 of 31 Old 10-23-2012, 07:11 PM
roadram360
roadram360's Avatar
yeah if you got a 440 you'd have to get a transmission. the big block would be a lot more fun though. if you can, get a 360 magnum from a 90 something truck, put a 4 barrel and headers on it and kick up some mud
you like your truck more than you like me. sometimes i do
1978 d-150, 95 360, eddy 750, 4 speed auto, 9.25 rear. her name is sabrina
GOD BLESS AMERICA
*DodgeTalk.com 318 Enthusiast Member #(129)*
roadram360 is offline
post #7 of 31 Old 10-23-2012, 08:15 PM
maachine
maachine's Avatar
Quoted: 45 Post(s)
Im currently building up a 318 that should push out 350-400 hp.....I hope. That should be enough for some fun. I considered doing the 440 thing myself but the cost wasn't worth it to me.
If you tune up that 318 and its running nice with a few upgrades, you'll get some power out of it.
some sort of lift
33" AT's
maachine is offline
post #8 of 31 Old 10-23-2012, 09:04 PM
roadram360
roadram360's Avatar
hey when we get our trucks back on the road we should go to the track in baton rouge
GOD BLESS AMERICA
post #9 of 31 Old 10-23-2012, 09:25 PM
maachine
maachine's Avatar
Quoted: 45 Post(s)
I'll give you a run for your money
some sort of lift
33" AT's
maachine is offline
post #10 of 31 Old 10-23-2012, 10:42 PM
roadram360
roadram360's Avatar
so you saying i'd have to give sabrina a super tune up?
GOD BLESS AMERICA
post #11 of 31 Old 10-23-2012, 11:05 PM
maachine
maachine's Avatar
Quoted: 45 Post(s)
Yeah.....
some sort of lift
33" AT's
maachine is offline
post #12 of 31 Old 10-24-2012, 06:40 PM Thread Starter
FirstRide
what kind of upgrades would i have to do to the 318 inorder to give it some more power
post #13 of 31 Old 10-24-2012, 06:56 PM
maachine
maachine's Avatar
Quoted: 45 Post(s)
headers, i would say a HEI ignition upgrade, a 4 barrel carb if you dont have one. possibly an intake too. anything that would help it breathe.
you could add larger valves to the heads, upgrade cam, port the heads. the biggest issue with the 318 is low compression, breathability, smog equipment, and crapping stock cam. for compression you could get thinner head gaskets. or if you want to really dig into it, flat top pistons and zero deck the block to increase compression.
by the way, my 318 is shot. so i wont be doing that build. i'm thinking about doing a magnum 360 upgrade to mine
some sort of lift
33" AT's
maachine is offline
post #14 of 31 Old 10-24-2012, 08:50 PM Thread Starter
FirstRide
O ok which way do you think that it would be cheaper
post #15 of 31 Old 10-24-2012, 09:36 PM
maachine
maachine's Avatar
Quoted: 45 Post(s)
I would start with headers, intake, & 4 bbl carb. Also ditch any smog stuff. Probably the cheaper and easier upgrades. Make sure timing is correct and vacuum is good.
The HEI ignition upgrade I liked, but a lot of mopar guys will say its not necessary. Best route would be msd 6a ignition
If you still want more then you can take the heads off, port, bigger valves, and reinstall with thin head gaskets. And install an after market cam.
After that, it'll be boring the cylinders, changing to bigger pistons and zero decking the block.
All that would run about a thousand bucks or so. Google "318 build" you'll find some cool articles of guys making 400 hp 318's.
some sort of lift
33" AT's
maachine is offline
post #16 of 31 Old 10-24-2012, 09:42 PM
maachine
maachine's Avatar
Quoted: 45 Post(s)
Im thinking the magnum 360 would be cheap and a good route. Get one from a junk yard for like 200 bucks or so.
I was into doing a 318 build just so I could tell people my little 318 has more hp than their 360
some sort of lift
33" AT's
maachine is offline
post #17 of 31 Old 10-24-2012, 10:00 PM Thread Starter
FirstRide
O ok ill prolly go to a junk yard sometime and see how much it will cost for a 360
post #18 of 31 Old 10-25-2012, 10:46 AM
lunchbox1671
Fabricator Extraordinaire
lunchbox1671's Avatar
I REALLY REALLY REALLY like my 440 so far....
1975 Dodge D100
-Clubcab "Adventurer Sport"
-1-ton Dually
-440
-Auto
lunchbox1671 is offline
post #19 of 31 Old 10-25-2012, 02:01 PM Thread Starter
FirstRide
Ya but for me a 440 would cost a lot more so I'm leaning towards a 360 because of cost
post #20 of 31 Old 10-25-2012, 02:18 PM
maachine
maachine's Avatar
Quoted: 45 Post(s)
Keep in mind if you get a junk yard engine that it'd be wise to rebuild it before swapping it
some sort of lift
33" AT's
maachine is offline
    1985 dodge w150 exhaust?????? FirstRide 1972-1987 Dodge Ram Trucks (D, W-series) 16 10-11-2012 04:14 PM
    1985 Dodge W150 FirstRide 1972-1987 Dodge Ram Trucks (D, W-series) 4 09-26-2012 08:32 PM
    1985 W150 VIN/engine question MasterOfReality 1972-1987 Dodge Ram Trucks (D, W-series) 1 07-05-2009 01:31 PM
    1985 dodge ram w150 carb question connor90 1972-1987 Dodge Ram Trucks (D, W-series) 4 05-23-2006 11:37 PM
    1985 Dodge D250 engine swap hgn1551 1972-1987 Dodge Ram Trucks (D, W-series) 1 02-08-2005 09:30 PM
