1998 doge problems, after all new goodies - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 2nd Gen (94 – 01) Forums > 2G Dodge RAM - General Talk
scott2171960
  Unhappy 1998 doge problems, after all new goodies - Posted: 10-20-2012, 11:07 AM
State: OH
Post #1
hi ev1, im new here and have a problem with my 1998 dodge ram 1500, 5.9 gas, 2 wd.
I guess this is the year evy thing that can go wrong, is going wrong. I have had this truck 8 yrs now. I do all my own work, and in the past 6 months i've put almost 7 grand in this truck. A rebuilt 518 tranny, new JBA shorty headers, magnaflow s/s cat and cat back system, new radiator new a/c, new plug wires and dist. cap and rotor button.
Last month i get in it to go to work, and the check engine light is on. I got 201, 301, and 204 codes. I know that 301 is misfire, probably spark plugs, which the truck has 1 yr old E-3's, i pulled all plugs and found yellow glaze on cyl. #1, which tells me running a little hot. I cleaned all plugs and reinstalled. 201 & 204 are injector codes which i have replaced.
The truck runs, but lacks any power untill about 2k and above RPM, but it still runs rough.I have started this truck at least 10 times scince replacing injectors. No codes are popping up. It feels kinda like the cat is plugged up, but it surely shouldnt be, being 6 months old.
I have checked evy thing from compression to checking with noid lights to pressure in the fuel system, which came up to 50 PSI. My book says 35-45 PSI. Could this be pressure issue?
Any critisism or advise is welcome. This motor is a Jasper rebuild and has only 56k on it, the truck has 156k on it.
dodgensince74
 Posted: 10-20-2012, 05:09 PM
Post #2
first Welcome to the site. What were your compression readings? I wouldn't count the cat out just because its new. How does it idle and rev when not going down the road?
01 1500 5.9, Q/C, L/B, 4X4
Tanue cover
Super chips
Magnaflow S/i-D/o
K&N cai
Eagle alloy 102's
BFG LT285/75r16 A/T's
scott2171960
 Posted: 10-20-2012, 07:30 PM
State: OH
Post #3
First of all let me thank you for your time. comp. readings are as follows 1=165 2=165 3=155 4=165 5=135 6=135 7=140 8=165. My thought has always been no more than a 30 psi difference , everything is good. 4&6 has a 30psi dif. which could be signs of head gasket problem, but doubtfull. no signs of leaks, no antifreeze in oil, and new gaskets abt 4 yrs ago.
After the tranny rebuild i went through 3 torque converters, that were covered under the transmission shops warranty, which kept throwing codes for that.
But after that this truck ran like a scalded daug, however still a pig on gas, which i guessed i would need a programer to to help with this.
As far as reving goes, sitting still it runs pretty rough through to abt 2k rpm, after that it seems to smooth out. On the road it is a different story, when taking off, i have to really mash the gas pedal, and it is really rough, herky jerky.
cblake
 Posted: 10-21-2012, 06:07 AM
Chuck Blake
City: Beckley, West Virginia
State: WV
Post #4
The first thing I would do is can the e 3's. It all sounds good, but I tried them and had problems.JMHO
1999 RAM 1500, 4WD QC, Auto, 5.9
1.7 Harland Sharp RR's, Mopar Magnum polished aluminum valve covers
Hughes FI airgap, 52mm Fastman tb, Fastman similator
4.56 gears
pro flo open air
gutted cat with 1 in 2 out magnaflow
SCT tune by Hemifever
Taylor 8.2 thundervolt, duralast cap and rotor with brass inserts
180 thermostat with Hypertech high output coil
ASP underdrive crank pulley
Doug Thorley ceramic tri-y headers
steering box brace
Bushwacker extend-a-fender flares
Warrior 2 1/2" leveling kit
AAL to rear springs + 1" zero rate block to spring stack.
3" body lift
37x13.50 Mickey Thompson ATZ on 18" eagle wheels
Transmission cooler added along with transgo shift kit
deep transmission pan, + 4 quarts
black nerf bars and grill black bull bars
Moparite
 Posted: 10-21-2012, 09:09 AM
Post #5
E-3's, Total junk! Get rid of them and put in Autolite 3923. Also did you replace the cap & rotor recently? Make sure you get a "oem" style. It has the brass inserts instead of the aluminum witch have a tendency to corrode. A good set of 7 or 8 mm wires wouldn't hurt either.
nh5
 Posted: 10-21-2012, 02:33 PM
nh5's Avatar
State: NY
Post #6
Get rid of those junk E3's. Only good spark plugs for dodges are cheap copper core plugs!
02 Ram 1500 QC 4X4 Sport 5.9L Magnum, EQ Iron RAM Heads, 52mm Fastman TB, ebay Shorty Headers, Magnaflow 12576, SRT Hood, 180deg Stat, Superchips 3815, Taylor Thundervolt Wires, Cutout, Detroit Tru Trac & 3.92's, rvinyl'd tail lights, led's all over, leds in tow mirrors, Polk audio's in the dash, center removed. Doors have kenwoods. New freeze plugs and more repairs than mods.
Next, Exhaust, 17rr's 2200 stall TC
http://img245.imageshack.us/img245/1943/009sq.jpg
scott2171960
  1 yr old E-3's - Posted: 10-21-2012, 02:34 PM
State: OH
Post #7
Thanks, cblake and moparite, i was looking at maybe changing them, because i have read that they need to be platinum.
Yes i have new dist cap(W/ brass inserts) and plug wires. I also believe the coil is original to the truck, probably going to change that as well, even tho it ohmed out correctly.
Somebody else told me to take the throttle body off and clean thouroghly, along with the TCI.
Thanks again, if this doesnt work im going to take the cat off to see how it runs then. YEAAA Open headers
scott2171960
 Posted: 10-21-2012, 02:41 PM
State: OH
Post #8
Thanks nh5, So you wouldnt do platinums either? just an autolite plug or similar?
spun360
 Posted: 10-21-2012, 09:01 PM
spun360's Avatar
City: Pottstown
State: PA
Post #9
i tried bosch platinums "not good" and went back to copper autolite 3923
parts for sale
$125: 210lb double and dampener valve springs .550 lift
$20 : new, standard oil pump
$15 : new, super strength moog #377 frt axle hub universal w/ grease fitting
prices include shipping (for residence of the US)
cheep
shoot PMs my way
cblake
 Posted: 10-24-2012, 08:39 PM
Chuck Blake
State: WV
Post #10
Autolite 3923's here also. No problems.
4.56 gears
pro flo open air
steering box brace
3" body lift
scott2171960
  problem solved for my ram - Posted: 11-11-2012, 08:41 AM
State: OH
Post #11
Sorry i havnt been back on here for awhile . I just wanted to thank ev1 for their help on my truck, cblake,spun360,nh5,moparite, and dodgensince74.
You guy's were absolutly correct. I put new Autolite spark plugs in and wow what a difference. I wont be sucked in by that bs again.
If any of you guys have any suggestions on how to get better gas milage i am open for suggetions.
Thanks again. Happy truckin
dodgensince74
 Posted: 11-11-2012, 02:31 PM
Post #12
these trucks don't get great milage, i'm leaning to a big part of the problem is our right feet, when they run good we like to feel it. The best ways to get better milage is to take off easy, coast to a stop, keep check on tire pressure and keep it parked
Tanue cover
Super chips
Magnaflow S/i-D/o
K&N cai
Eagle alloy 102's
scott2171960
 Posted: 11-12-2012, 06:04 AM
State: OH
Post #13
LMAO,
I here ya man. When i bought this truck 8 yrs ago, i got 9-9.5 mpg now i get abt 10-11.Your absolutly correct in what yr saying. I actually have tried that, no luck tho
I was thinkin about buying a superchip super tuner. what is your thought abt this????
dodgensince74
 Posted: 11-12-2012, 06:59 AM
Post #14
I have the superchips on my truck and use the 87 setting just to reset the tire size and to read and clear any codes that might pop up, I get to much pinging on the other settings even with 91 gas, Some day I will do the penlum gasket fix to see if that helps. If you have taller/shorter tires then stock then that could effect your milage calculations since the miles your odometer shows will not be correct.
Tanue cover
Super chips
Magnaflow S/i-D/o
K&N cai
Eagle alloy 102's
scott2171960
 Posted: 11-13-2012, 05:22 PM
State: OH
Post #15
Thanks man, much appreciated information
spun360
  are u kidding or just a newbie - Posted: 11-13-2012, 10:04 PM
spun360's Avatar
City: Pottstown
State: PA
Post #16
Originally Posted by scott2171960 View Post
LMAO,
SCT tuner from hemifever. no substitute
parts for sale
cheep
shoot PMs my way
TrappedPerson
 Posted: 11-13-2012, 11:48 PM
TrappedPerson's Avatar
Registered RAM User
City: Edmonton
State: AB
Post #17
I get up to 16mpg around town, as high as 22-25mpg highway. I noticed a big difference when I cut out the cat and started watching the vacuum gauge religiously. BUT I do have an sct tuner from hemi fever and a k and n CAI as well. Honestly didn't notice a big difference in mpg from the tuner, mostly from changing driving habits
1996 2WD 1500 RCSB claret red-- Lowered 4/7, 3rd gen 20's, one piece "open mouth" billet grille and billet inserts in bumper, sport bumper conversion, shaved tailgate handle, fiberglass bed cover, dual exhaust through rollpan, no cat, HID headlights and fogs, Double Din, 2 12" JL W0's, suede headliner, K&N CAI, SCT tune from Hemifever
2001 Offroad Edition, silver-- Tow mirrors, all stock *sold*
2004 Durango Limited, black-- Stock *sold*
Ret.ArmySF
 Posted: 11-14-2012, 07:46 AM
Ret.ArmySF's Avatar
An Army of One
City: San Antonio
Post #18
Autolites are for Fords! Stay with the Champion coppers!
Ret.ArmySF
Lead, Follow, or get the Hell Out of the Way!
1998 Dodge Ram SLT 1500 5.2L/Debadged
COIN HOLDERS ASSOCIATION MEMBER #69
S.N.A.T.C.H. Spec. Ops. 2nd Lt!
Exterior: Blue Xenon Head and Fog Lights - Stainless Steel Toolbox - Mopar Molded Mud Flaps - Red Painted Brake Calipers - Tailgate Handle Lock - Alteza Tail Lights - Rear Spoiler - Aluminum Gas Door - Aluminum 3rd Brake Light Cover
Interior: White Face Guages - Hard Wired Radar Detector - Pioneer Head Unit - Front 6x9 4 Ways Rear 6.5 4 Ways - Bazooka Tube Sub Woofer - Center Console Coin Holder
Performance: TPS Modification - ACcel 8.8mm 300+ Plug Wires - NAPA Brass Contact Distributor Cap and Rotar - K&N cold air intake- Magnaflow High Flow CAT - Magnaflow Stainless Steel Muffler - Traction Bars
Planned Additions: Cam -1.6 Roller Rockers- Fastman Throttle Body 52mm - 410 gears and Posi
Water marks Powered by "PictureShark" http://www.picture-shark.com/
1998 1500 T Case problems mred423 2G Dodge RAM - Drivetrain Talk 4 02-17-2012 06:59 AM
1998 Auto tran problems 1991StealthR/T 2G Dodge RAM - Drivetrain Talk 4 12-09-2008 09:57 AM
Radio problems in a 1998 3500 Maxi jcpowell27 Dodge B-Series Vans 1971 - 2003 8 10-12-2007 03:10 PM
1998 Grand Caravan PROBLEMS cward76 Dodge Caravan/Grand Caravan Talk 1 04-08-2007 09:46 AM
1998 neon R/T starter problems wgillis Dodge Neon - General Talk 1 03-21-2005 04:54 PM
