swap? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 2nd Gen (94 – 01) Forums > 2G Dodge RAM - Drivetrain Talk
Harveyb
  swap? - Posted: 10-14-2012, 08:51 PM
Harveyb's Avatar
City: NORTHVILLE
State: NY
Post #1
may need a rebuild on my trans,am considering a swap to manual trans,I found a 2000 2500 ram with the 5.9 gas(same as mine)has a five speed,are there any issues I should be worried about?computer issues,wiring issues,ect.
2001 Dodge Ram 1500 Offroad Sport,fully loaded,360,SCT by Hemifever,flowmaster catback exhaust,Hard bed cover,flush mount(painted to match truck)bed rug,leather interior,custom sub box,2 10" MTX subs powered by a jackhammer amp,memphis door and rear speakers powered by a memphis amp,sir micheals roll pan,fresh paint after tree incident.
fastman 52mm throttle body,Gibson shorty ceramic coated headers,airgap intake,K&N cold air intake,mopar performance valve covers,harland sharp 1.7 roller rockers and magna flow high flow cat and y-pipe.37/12.50/17 BFGOODRICH M/Ts on Cragar Black Rock Wheels,4.88 gearing,converted to 5-speed,5" BDS long arm lift with full rear leafs,plus a 2" coil spacer and 2"taller rear leaf blocks,DT profab trackbar,Borgeson steering box and steering shaft,BD Diesel steering box brace,dual steering stabilizer,Bilstein shocks and stabilizers all around,1-ton steering upgrade.
JackedDak03
 Posted: 10-15-2012, 09:33 AM
JackedDak03's Avatar
City: Oxford
State: ME
Post #2
No if you get that parts truck its a simple bolt in procedure. You can use the wiring harness and computer as well and it'll be like factory. Search my threads and you'll see a similar swap that I did, but I used an NV3500 and automatic computer/wiring. Still worked fine.
2002 Ford F350 CrewCab Short Bed 4x4 7.3 Diesel
BHAF, Predator Tuned, 4" Exhaust
Gone:
1999 Dodge Ram 2500 Quad Cab 4x4 Sport V10
1998.5 Dodge Ram 2500 Quad Cab 4x4 24V Cummins
2004 Dodge Ram 2500 Quad Cab 4x4 HEMI
2003 Dodge Dakota Quad Cab 4x4 4.7
2002 Dodge Ram 1500 Quad Cab 4x4 4.7
2001 Dodge Ram 1500 Quad Cab 4x4 5.9 V8
1999 Dodge Ram 2500 Quad Cab 4x4 5.9 V8
1997 Dodge Ram 1500 RegCab ShortBed Sport 5.9 V8
2012 Jeep Liberty -Company Car
2003 Jeep Liberty - Wife's Jeep
Past -92 Daytona R/T, 94 3000GT, 91 TransAm, 88 RX7 TII, 89 YJ, 92 Bronco, 88 YJ, 94 F150, 96 Rodeo, 88,89,90,91 5.0 Mustang's, 03 Mustang GT, 04 SRT4
Harveyb
 Posted: 10-15-2012, 01:34 PM
Harveyb's Avatar
City: NORTHVILLE
State: NY
Post #3
Thanks,I looked at your thread and it was very helpfull-this all started with a check engine light and a p1740 code(I think that was the code)I changed speed sensor,and trans solenoids and code still came back,trans seems to shift fine but now since solenoid change I dont seem to have lockup in od.just weighing my options.thanks again
JackedDak03
 Posted: 10-15-2012, 01:43 PM
City: Oxford
State: ME
Post #4
Either way you won't go wrong doing the swap. An NV4500 from a gas truck would be an awesome setup and very reliable. You'll gain a few MPG's as well.
Gone:
spun360
 Posted: 10-15-2012, 09:23 PM
spun360's Avatar
City: Pottstown
State: PA
Post #5
i hear that the crank position sensor is different.
parts for sale
$125: 210lb double and dampener valve springs .550 lift
$20 : new, standard oil pump
$15 : new, super strength moog #377 frt axle hub universal w/ grease fitting
prices include shipping (for residence of the US)
cheep
shoot PMs my way
JackedDak03
 Posted: 10-16-2012, 08:15 AM
City: Oxford
State: ME
Post #6
It technically is but you can easily use the automatic sensor. You need to put 1 or 2 small washers (the bolts are small) to space it back a little and it works fine - I mentioned that in my thread and saved $100 doing this rather than buying a new one.
Gone:
Harveyb
 Posted: 11-19-2012, 06:18 PM
Harveyb's Avatar
City: NORTHVILLE
State: NY
Post #7
I have been looking at different trucks to buy for the swap,would a 98 be a bolt in?Is there any sensors,wireing,ect in the trans or truck thats different than a 2001?
nh5
 Posted: 11-19-2012, 09:32 PM
nh5's Avatar
State: NY
Status: Online
Post #8
I know the coil connector is different on the harness and that there were changes in the trans in 99. Might more that I don't know.
02 Ram 1500 QC 4X4 Sport 5.9L Magnum, EQ Iron RAM Heads, 52mm Fastman TB, ebay Shorty Headers, Magnaflow 12576, SRT Hood, 180deg Stat, Superchips 3815, Taylor Thundervolt Wires, Cutout, Detroit Tru Trac & 3.92's, rvinyl'd tail lights, led's all over, leds in tow mirrors, Polk audio's in the dash, center removed. Doors have kenwoods. New freeze plugs and more repairs than mods.
Next, Exhaust, 17rr's 2200 stall TC
http://img245.imageshack.us/img245/1943/009sq.jpg
Harveyb
 Posted: 12-08-2012, 05:53 PM
Harveyb's Avatar
City: NORTHVILLE
State: NY
Post #9
I picked up a 2001 1500 extended cab today,had to drive 3 hours to get it but it was worth it,its not in bad shape,only problem is its a 5.2,so I will need to get a flywheel.So I am closer to the swap,anyone know if the 5.2 computer is the same as the 5.9 computer,would save me from getting a computer flash.I may repair my auto trans down the road and put it back in the donor truck and sell it to get some money back.
Moparite
 Posted: 12-09-2012, 08:33 AM
Post #10
As far as i know they are different even for the same year. Different computer for manual and auto with the same motor. Not sure if a flash would work.
spun360
 Posted: 12-09-2012, 09:06 PM
spun360's Avatar
City: Pottstown
State: PA
Post #11
a 5.2 pcm will run a 5.9L. i dont believe there ever was a 5.9l manual trans equipped truck. this swap comes and goes and has been done many times. B&G can tune the pcm better and i doubt hemifever is in the dark either. just that you could do alittle better with a tune! automatic to manual drive train do have different pcms. to the best of my knowledge.
parts for sale
cheep
shoot PMs my way
Harveyb
 Posted: 12-09-2012, 10:45 PM
Harveyb's Avatar
City: NORTHVILLE
State: NY
Post #12
ya,thats what I was wondering was if I could take the pcm out of the 5.2 standard truck and put it in my 5.9 when I install the standard,just dont want any check engine lights when I do the swap.I do have a sct tuner from hemifever.Going to be my winter project,need to get a flywheel,clutch kit,ect.is there just 1 flywheel for the 5.9 magnum engine?thanks for the replies.
Harveyb
 Posted: 12-31-2012, 02:20 PM
Harveyb's Avatar
City: NORTHVILLE
State: NY
Post #13
Have everything together for the swap-donor truck,new flywheel,centerforce dual friction clutch kit,centerforce throw out bearing,pilot bearing with sleeve,new slave/master cylinder,new trans mount,all new emergency brake cables.cant wait to get started.
Harveyb
 Posted: 01-21-2013, 07:14 PM
Harveyb's Avatar
City: NORTHVILLE
State: NY
Post #14
swap is complete,went very well,now I just have to get the pcm flashed to standard trans or swap in the donor truck pcm,I have 4 codes which are all to do with shift solenoid,trans temp,and governor pressure solenoid,P0753,P0713,0711,and P1763,I assume these are all because the auto is gone.another issue I had was I had to change out plugs for the backup lights,the auto was 3 wire,and the standard is 2 wire,I changed the plug end and used the same 2 wires the standard had and capped the other,well the truck would not turn over,so I grounded the wire and it started,anyone know what the extra wire is for?
spun360
 Posted: 01-22-2013, 10:07 PM
spun360's Avatar
City: Pottstown
State: PA
Post #15
WOW! that doesnt seem too difficult! maybe something i'm interested in? in the near future i have to decide- either 3K on a new BUILT auto or swap to a manual trans. hemifever seems to think the manuals put down better.
parts for sale
cheep
shoot PMs my way
crank swap or engine swap crazzywolfie 1972-1987 Dodge Ram Trucks (D, W-series) 32 09-11-2012 12:58 AM
87 D150. Steering column swap and fried wires. 87 D150. Steering column swap and frie r130 1972-1987 Dodge Ram Trucks (D, W-series) 5 02-09-2012 09:34 AM
brake caliper upgrade/swap? 1/2 ton to 3/4 ton swap... LightSwitch 2G Dodge RAM - 4X4 Talk 35 09-24-2007 09:34 PM
4.7 swap to a 5.9 rums87 2G Dodge Dakota General Talk 11 03-19-2007 07:39 PM
/6 to 360 swap for a swap rookie virtros Dodge Ram Truck 1st Gen (88 - 93) Forum 13 03-23-2005 06:38 PM
