Rough in gear idle - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 40 Old 08-05-2012, 09:47 PM Thread Starter
the_Big_dill
Rough in gear idle
Hey all,
I recently changed my alternator, belt, idler & tensioner pulley, the car runs as quiet as new while in "park" or at a higher speed in "drive".
However when i put it into drive, reverse, low or 3, it starts sounding rough with consistent vibration patterns. What is causing that noise and how would i go about dealing with it?
Cheers,
Phil.
2002 Dodge Grand Caravan Sport 3.3L V6 @ 260,000 KM.
the_Big_dill is offline
post #2 of 40 Old 08-06-2012, 01:05 AM
dodge_duh
Just to verify, the car only started the vibration after you switched out the alternator and other stuff?
dodge_duh is offline
post #3 of 40 Old 08-06-2012, 02:07 AM Thread Starter
the_Big_dill
good call, and NO, that rough in gear idling was there before anything was changed in the van.
Also, are the instrument cluster lights hooked up in series? As i took one out, now the gas and the lower revs are not lit up...
post #4 of 40 Old 08-06-2012, 09:02 AM
bngreenchev
Could possibly be a bad motor mount, or a dirty throttle body when I took mine apart to replace my valve cover gaskets mine was completely covered with carbon cleaned it up and the van idled and accelerated smoother at low rpm's, you could take it to a shop and have an induction service performed on it, that would clean up the throttle body and intake plenum, also maybe a partially clogged fuel injector or line, just some ideas.
1999 Dodge Grand Caravan 3.8l, 152,000mi
bngreenchev is offline
post #5 of 40 Old 08-06-2012, 09:05 AM Thread Starter
the_Big_dill
I guess I will just clean the throttle body myself and see if that helps. Should I actually take off the plenum and clean in there, or is that negligible?
Is carb cleaner a decent replacement for throttle body cleaner? Because I have some of that, while throttle body cleaner I will need to buy.
post #6 of 40 Old 08-08-2012, 11:32 PM Thread Starter
the_Big_dill
As it turns out, Carb cleaner should be avoided
post #7 of 40 Old 08-09-2012, 02:15 PM
Ratchet75
Quoted: 12 Post(s)
Could it be too low idle rpm once you shift into gear? The IAC valve should be bumping the rpms up to compensate for the added load.
Ratchet75 is offline
post #8 of 40 Old 08-09-2012, 08:04 PM Thread Starter
the_Big_dill
It is normal RPMs. I believe it is the throttle body that needs a cleaning. If the roughness remains afterwards, then i will be back
Thanks for the help and tips
post #9 of 40 Old 08-09-2012, 10:59 PM
no_common_sense
Quoted: 11 Post(s)
I've noticed with dodge instrument clusters in full size and minivans is that you're best off to replace all your illumination bulbs at the same time. I can't explain why, but installing one or two new bulbs tend to burn out the old ones you left in once you reinstall the cluster. You won't need to change the bulbs for indicator lights.
No matter how much technology changes, there still isn't much that can't be solved with the sensible and practical application of a bigger hammer.
no_common_sense is offline
post #10 of 40 Old 08-10-2012, 12:38 AM Thread Starter
the_Big_dill
I placed an order today for 8 new PC 74 bulbs.
Looking to fix the idle, i took off the air duct and could see and feel a black hard substance on the edge of the throttle plate! At least a few millimeters from the edge.
After some research, i found out the 3.3L has no mass air flow sensor and no EGR valve. Why no EGR?
Also, i am going to seafoam the car this weekend, i took out the break booster vacuum hose, and the revs started building, to my hesitation, i plugged it back in... is the rev building normal?
post #11 of 40 Old 08-10-2012, 07:42 AM
no_common_sense
Quoted: 11 Post(s)
By taking the hose off, you gave the intake another source to pull in air. The computer is going to add fuel to accomodate the extra air going in to maintain a certain air/fuel ratio. So, yes the RPM will go up when you pull any vacuum hose that attaches to the intake manifold.
post #12 of 40 Old 08-10-2012, 11:36 AM Thread Starter
the_Big_dill
Yep, when i went to sleep, it kinda hit me that im opening another source of air to the manifold XD
So why is there no EGR valve on my engine? i am assuming not having one is a good thing, since its just to control emissions?
EDIT:
I looked closed into the idling and as it turns out it isn't steady on the revs.
Once the engine settles its at about 900RPM then after a few seconds it will drop down to 700RPM and idle roughly, sound and vibration, but only lasts for a second or two before the engine goes back to 900RPM and repeats this.
post #13 of 40 Old 08-10-2012, 08:54 PM
no_common_sense
Quoted: 11 Post(s)
I don't have an answer for your EGR question. I've heard that sometimes cam profiles are set up to retain some exhaust gases; thus, doing the same job the EGR used to do. I know that varaible valve timing engines are set up to retain exhaust gases and eliminate the EGR valve too.
I always wondered if the EGR valve, or the lack of, tied to whether or not the engine is flex fuel. The reason I wonder is because some engines do have EGR while others don't even in the same model years. I've had a thousand chances to ask smart people about that myself but i keep forgetting. I've got a head that's like pouring water through a collander. It'll retain something for a little while but it's always going to wind up empty again.
post #14 of 40 Old 08-11-2012, 12:19 AM
Ratchet75
Quoted: 12 Post(s)
Now that I'm up off the floor that's me to a tee. Hilarious way to put it.
post #15 of 40 Old 08-13-2012, 01:31 AM Thread Starter
the_Big_dill
Haha, i know what you mean, completely forget about something you had in mind when you need it :P
I believe the EGR has no longterm benefit in an engine and is used to control emissions, maybe the location where my van was built doesn't have strict policies with emissions. Furthermore, I find the EGRs on the 3.8s not the 3.3s.
Regarding the problem at hand...
- I cleaned the throttle plate and got rid of LOTS of black gunk, just kept pouring.
- I seafoamed the van, however i was a bit cocky and didn't let it sit in the engine for more than 5 minutes... I think i will have to do it again.
- Did a compression test and got the following readings (in PSI):
C1: 160
C2: 146
C3: 155
C4: 155
C5: 175
C6: 155
I would like to note that the compression tester i bought was $20 with 2 adapters, definitely low quality :P
- Changed plugs (Iridium IX) and Wires (AutoLite Professional)
Guess what... That Rough idle is still there!!!
Now i am thinking it is not the engine, because its only in D, R, 3 and L that this really rough idle occurs at 700RPM, Just a bit of throttle to get it above 1000 RPM it shuts up and is smooth.
Last thing that i may try cleaning is the oxygen sensor, after that, i am stumped...
I was wondering if the power steering pulley could be causing this, because when i turn the wheel, the rough idle becomes more aggressive?
post #16 of 40 Old 08-13-2012, 07:26 PM
mfahey
Quoted: 1 Post(s)
When you replaced the alternator, did you use one with the Lutens decoupler? If not, there's a good chance that the low speed roughness is being caused by an incorrect clutch.
2001 GC ES 207,000 miles
2015 Volvo V-60
2012 Camry Hybrid
1970 Camaro, original owner
mfahey is offline
post #17 of 40 Old 08-13-2012, 08:03 PM Thread Starter
the_Big_dill
I replaced my alternator with a used one as it turned out cheaper than the decoupler and it quietened the operation of the vehicle (outside of idle) as well as charged correctly.
post #18 of 40 Old 08-16-2012, 02:47 PM Thread Starter
the_Big_dill
Anyone?
Could the O2 sensor be causing this?
P1192 is the only code i have, and when the key is in the on position, the LIM (engine light) blinks, which i read is a major problem.
post #19 of 40 Old 08-17-2012, 11:46 PM
no_common_sense
Quoted: 11 Post(s)
P1192 Inlet Air Temp. Circuit Low
The PCM uses this sensor along with the MAP sensor to help calculate the amount of air going through the intake. If it's not sending the correct voltage signal back to the PCM, the PCM may be running the engine with too much or not enough fuel which could explain that stumble. If you know how to test with a voltmeter, shoot me a PM and I'll get you a wiring diagram.
When you say LIM, do you actually mean MIL?
The power steering is another load on the engine. It's not causing your problems, it's only amplifying the problem.
post #20 of 40 Old 08-20-2012, 11:26 PM Thread Starter
the_Big_dill
Yea, I meant MIL
That actually is the only culprit left with this rough idle, as all else has been dealt with, yet this has been an issue longer than I knew anything about the car.
Regarding the inlet air temp. sensor: I was told it has been replaced without any positive outcomes. I checked the connector to the sensor and it was clean, i even blew it with compressed air, but that did not help.
Did a true fuel economy test and am pleased to say that on a full tank of gas I can do over 700 kms, which is 9.4L/100km.
Also noticed a funky smell coming fromm the exhaust, is it dirty catalytic? I do know that the car burns oil, so that may also be it.
    Rough Idle? bsobel 4G Dodge RAM - General Talk 1 06-21-2011 11:17 PM
    stalls due to rough idle/in gear NoPavemntNoProb Dodge Ram Truck 1st Gen (88 - 93) Forum 4 07-23-2009 11:02 AM
    rough idle mr.318 Dodge Ram Truck 1st Gen (88 - 93) Forum 4 04-06-2007 11:18 PM
    3.7 rough idle aje 3G Dodge Dakota General Talk 0 12-06-2006 06:09 PM
    Target idle/rough idle ss62 3G Dodge RAM - General Talk 13 06-30-2003 10:29 PM
