Ignition control module - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 11-17-2004, 11:18 PM Thread Starter
m_mccrehin
can anyone tell me where the ignition control module is on a 91 RC?
m_mccrehin is offline
post #2 of 10 Old 11-18-2004, 06:06 AM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
In the past Mopar ignition modules have either been located on the firewall or on one of the fenderwells....it's usually a small black or chrome box. However in a '91 the ECM (Engine Control Module or computer) may control the ignition and may be located up under the dash behind the glove box or behind the passenger side kick panel.
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
post #3 of 10 Old 11-18-2004, 06:09 AM
Dodgevanman
Do It In A Van
Looks like in '91 they still used the old style unit...here's a picture.
Nate Breece
5.2L Magnum
3.8L
Member of:
post #4 of 10 Old 11-19-2004, 04:24 PM Thread Starter
m_mccrehin
I called Dodge to find out where it was, but none of their mechanics knew either. It is not on the fire wall and not on the fenders, so I guess that if it's there it would be under the dash somewhere. That's a real mess under there. I got a hold of one from Napa and they gave me excatly what your pic shows. I would assume that something that size would be easier to find? thanks for the help
post #5 of 10 Old 11-19-2004, 05:05 PM
Dodgevanman
Do It In A Van
No, it should be under the hood somewhere. Check on the driver's side inner fender by the hood hinge area. If that's the module you were given those were mounted under the hood, most definitely. Unless someone in the past moved it inside.
Nate Breece
5.2L Magnum
3.8L
Member of:
post #6 of 10 Old 11-21-2004, 02:13 PM Thread Starter
m_mccrehin
I looked all over under the hood. I had someone else tell me that it was part of the onboard computer.
post #7 of 10 Old 11-21-2004, 05:29 PM
Dodgevanman
Do It In A Van
I initially said that it may be part of the computer, but the parts stores are saying different and show the external type I have in the picture above.
Here's an idea...follow the wires coming off of the distributor. Worth a shot.
Nate Breece
5.2L Magnum
3.8L
Member of:
post #8 of 10 Old 12-18-2004, 06:17 PM
Grotesque
that's funny, i went to a parts place to replace my I/M and they were saying that it was the older style too, but that's not the case, it's loacted in the computer, i believe that it's the first circuit board in there.. in anycase it's right behind your battery, in the drivers fender.. I hope this helps for you, I've got an 89 R/C.. it's begining to be a puzzle to me!!
Grotesque is offline
post #9 of 10 Old 03-20-2005, 10:37 AM
tdimark
from 1988 and up to 1993 vehicles with fuel injection, ignition is in the ECM located in left front fender right aside of the battery
DIESEL POWER RULES.
list of projects: 92 d250 86K.93 W250,360 Mag,24K. 92 W250 4X4 CUMMINS 76K. 92 W350 4X4 dually CUMMINS 100K. 4 RAMCHARGERS. 88 W350 4X4 dually dump. 73 CUDA 340-6pak. hope to get em all done before i die
tdimark is offline
post #10 of 10 Old 03-21-2005, 03:44 AM
Chump
Chump's Avatar
Yes, it's part of the SBEC(Computer) but the 2 most common failures for "no start" or intermittent start are the hall effect device in the distributor and the ASD relay. Were you havng a specific problem?
Chump is offline
